楼主 |
发表于 2008-12-30 12:10
显示全部楼层
我写的程序代码如下,自我感觉没啥错误啊~~~~~# Z1 K$ g( d' r" s* M3 u4 `. A) O
还请高手们指教!!!
' o! A( W5 ^4 d% I; d2 d
! ]7 K5 [$ {- _ V$ Y6 d8 p, {static void do_my_Program(double PARA[])% V! ?* }# e7 ?4 p: Z
{: e t6 l H- b( \* I/ R! i8 `9 e, _
int i;) h6 D" _4 t) E8 m2 o, K7 o
// 放置位置 [12/28/2008 %CREATED BY AUDREY LEE%]
/ |1 B% W4 J) N$ K }6 v3 k) u( ] double tao_orig[3];
$ v5 F1 Y, L. P% _7 R tao_orig[0] = PARA[3];% s! b |" O8 |
tao_orig[1] = PARA[4];
9 K/ Z+ h2 V! _, O: b tao_orig[2] = PARA[5];
: v' n7 ]# ~( r$ K" e; j
( N, \6 x* D9 H0 R6 e CString str[3];
4 @/ H7 u& m( }& p for (i=0 ; i<3 ; i++)
" \% `, j2 I. j6 ~4 w6 Y! X3 c {+ w$ m8 o" C: b9 \1 b2 d8 K1 J
str.Format("%f", PARA);0 H1 h8 d1 t% n b/ h/ N
}% W' V' W7 j' U- j: P: E) v# M
char *height = (char*)(LPCTSTR)str[0]; // 总长度 [12/28/2008 %CREATED BY AUDREY LEE%]+ o1 I8 @2 Z { ^
char *dim_big = (char*)(LPCTSTR)str[1]; // 外径 [12/28/2008 %CREATED BY AUDREY LEE%]
% R8 Z$ N' I) t) R( b9 u char *dim_small = (char*)(LPCTSTR)str[2]; // 内径 [12/28/2008 %CREATED BY AUDREY LEE%]
% ?0 O$ l% b2 \
$ k! V8 }4 d$ p5 ]: r double direction_cyl[3]; // 矢量方向 [12/28/2008 %CREATED BY AUDREY LEE%]
! C+ G9 Y7 ^# t6 H5 u( } direction_cyl[0] = 0.0;
$ R- ?8 h* |/ [& y& K. S direction_cyl[1] = 0.0;
7 B D5 y% R! ^/ t4 w8 Y direction_cyl[2] = 1.0;
M( Z8 v2 H# T, ~ O- r( h q8 j/ f/ y! Q8 H
tag_t cyl_tag_1, cyl_tag_2;
. s: V5 b# |0 ~. g- i4 U% T' U; e9 z* H. d1 J7 n' w3 W
UF_FEATURE_SIGN sign_1 = UF_NULLSIGN;
2 i# O% j {: Z5 E int rec;
( `1 ?0 F' E2 C0 B; x/ P& a. ` rec = UF_MODL_create_cyl1(sign_1, tao_orig, height, dim_big, direction_cyl, &cyl_tag_1); // 生成外径圆柱 [12/28/2008 %CREATED BY AUDREY LEE%]3 q5 C, s3 D8 u: D
// 做布尔运算 [12/28/2008 %CREATED BY AUDREY LEE%]/ K8 k0 W; h; P
UF_FEATURE_SIGN sign_2 = UF_NEGATIVE;
l) [. W9 N6 C& K, J1 J9 r rec = UF_MODL_create_cyl1(sign_2, tao_orig, height, dim_small, direction_cyl, &cyl_tag_2); // 生成内径圆柱 [12/28/2008 %CREATED BY AUDREY LEE%]' F8 h* N4 X, [. q! Q, Z2 L7 O
