本人把ug车间文档原代码进行了更改,可以将加工信息直接反应出来了,便于自动出程序单编辑人员使用,原代码如下!
- ~, }- ], z! s5 f n9 ^5 j###################################################################### J v5 e/ n8 G! S# \+ Q
# S H O P D O C _ P R O G R A M V I E W _ T E X T . T C L
0 z5 u8 [! z- ~/ f- `/ F* c% O1 H######################################################################
7 B/ k9 P r6 b! N) [6 i, N# EVENT HANDLER SECTION
- O& b7 f' D5 H+ I# This section contains the control section for creating an operation list ; {7 q$ k& Y+ K& i, p
# $ w$ o* T! u2 _! s8 e
# CAM will loop thru each event in the path and call the procedure9 n9 s3 }" u( w. {5 R
# whose name is the name of the event.
% r! W# f+ K0 E3 I8 z$ ~ V. }#
! C9 o# i9 x3 h$ e3 Z" T#6 N! F0 q% i/ l$ _7 F" w: ? e
# 5 }, ~' m, {6 ^/ a' p/ Q9 r
#8 x. t* a. I4 \5 |( w& h- D; u
#_______________________________________________________________________________+ C1 } x. f7 @9 ?# Z
# Here you should define any global variables that will be used in any one
2 t) G E1 u; A j# of the event handler./ P q' V& a" ~, O P9 z
# z% O2 i7 y m* Jset mom_source_directory [MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR], }4 C/ p- I9 L7 R3 V& n2 @/ s
source "$mom_source_directory/shopdoc_header.tcl"
9 X1 _0 z" i; f# a% I. ?- Y ?set line_flag 09 M9 e( S/ f p6 `( b, X( p
set template_type """ Y/ \/ R& R- ^2 a. L, U# s" h
set template_subtype ""
; |0 U# A( I8 U- p( Y8 s# This procedure creates a part documentation.
' F* _0 [& M+ ~$ n" l$ `4 J#_______________________________________________________________________________/ J! X1 ^* V; r! e3 u+ i
2 \! J8 k6 C0 U. eproc MOM_Start_Part_Documentation {} {
/ o8 l& O, y% _0 p- Z) A& ]& v' K#==============================================================================
# q2 ~6 f- ~, U& \2 q( f8 {/ u/ a # Calls the shopdocs header8 l; ^1 i" a: h5 W9 l( X! l9 i g
global mom_sys_output_file_suffix
/ E* M$ U6 x, ^" @. F set mom_sys_output_file_suffix "txt"
! s; |. h% {" F/ V, E: |' q" Y
Open_Files0 D+ i8 d. W, V5 O5 w/ g' u
ShopDoc_Header_text% e9 A5 Y* N& }7 ^3 h3 t8 q+ ^4 G
+ U+ u0 q; }' z6 R5 L#==============================================================================
9 r5 A2 g4 L* y+ jproc MOM_Part_Documentation {} {& h4 Y: T4 K, A2 `
#==============================================================================. i3 K9 [* s$ O7 j7 f9 }
MOM_do_template_file "[MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR]shopdoc_programview_text.tpl"3 |* \$ n e/ X
3 f6 ^3 {5 } e9 w6 O8 s#============================================================================== e+ A1 U/ |" |5 h, j6 ]
proc MOM_End_Part_Documentation {} {! Q( u) ?2 @$ L' j* y
#==============================================================================2 W5 U3 \2 |9 b! B: h8 h
}4 T8 P% ~8 X& i! k) |
- n8 T) B9 K6 T% {# Setup& V& A; I) K7 `% F
5 ^$ i9 r: L6 u! `9 G+ L0 W+ D* a#==============================================================================
2 `' X! y4 s1 b, h- p' Bproc MOM_SETUP_HDR {} {% s+ E* M5 h: w# d& T$ a
9 \9 M0 @) p$ B" P: _ \ # Calls the setup header
. T$ e: R" q$ n& C! r Setup_Header_text
; A3 l7 z" I" S2 E# A' _+ n}. q0 w6 Z' H6 F8 o# O4 M
1 Z& f5 Y' J/ z9 V3 F#==============================================================================4 c9 M2 j0 t% [& ^0 C- u; R7 h3 S
proc MOM_SETUP_BODY {} {
, P7 Z3 C9 ^" {5 `#==============================================================================" i: {/ a% p& U* a) ], [
global mom_template_type
; k5 A. ?/ A! e& Y9 w global mom_template_subtype
- D6 u, m) ?/ k- Q; f8 i MOM_output_literal " OPERATION LIST BY PROGRAM", v( ?7 k2 \' B+ W5 Z
MOM_output_literal " ********* **** ** *******"
4 O" d! U& \: {" x}- j7 |; u% Z3 W% j$ |* A
4 _* T# ~/ i! t9 W0 s. [#==============================================================================2 I$ o0 @% G3 d
proc MOM_SETUP_FTR {} {6 k& ^, X+ D" n5 i7 L- v0 u* h [
6 ^; I4 g7 N' m3 v4 X}; v5 H, t7 p+ T
7 U) A9 B" |5 q/ J7 r+ o#===============================================================================
0 B( q. i3 ^) s" B6 {# Operation
0 u& c+ Z8 _' O% ]2 e+ ]#===============================================================================
' ] X+ [; k* D1 B l$ [# k#===============================================================================" j _. j" [/ N; a
proc MOM_OPER_BODY { } { 7 n# d+ J. w' V' B. Y- C- }
#===============================================================================6 y8 M$ e7 W7 e! z
global mom_template_type% i4 W3 H4 ]* x7 [: p4 S7 n( o# }
global mom_template_subtype9 Y% T1 I, n- e4 U! h9 i2 T* j4 ?5 o
global template_type. \8 g2 Z2 n2 h# _7 H6 K
global template_subtype( f7 Q! K7 `+ q
global mom_operation_name
+ ^9 y( w: N" V5 C0 K7 M: e6 c5 M1 I global mom_operation_type* s: N# I1 s- P6 a+ ^) e
set template_type $mom_template_type! O; H. Q( z3 ~
set template_subtype $mom_template_subtype9 {, ^* N( [3 j; E
if { $mom_operation_type == "Wire EDM" } \
" A. D8 \3 |& v, E' W( V: X; I {' x. u& v+ ]1 J/ t9 {& B3 E
set oper_desc "$template_type/$template_subtype"
% Z G+ h8 ~, w. e set output [format "%-30s %-35s %5s \n" $mom_operation_name \
; ^ v+ {4 x" y $oper_desc "WIRE"]
) q$ ]" n2 t$ e& |8 A; L MOM_output_literal "$output"8 I% J$ C# @8 k
2 e$ K {: r* ~1 j9 C! e}
7 e3 c) j6 s) f9 j( H% \#==============================================================================
( H$ i+ T8 [+ ~8 t+ oproc MOM_TOOL_BODY {} {. c( u, d, ^* b" K
' c. X9 N: Y& n/ u: | global mom_operation_name0 E3 K$ l3 _4 u) O* [
5 Z: S7 [5 Q1 a# O# o6 U" o# q global template_type
, ^/ [. r6 d: g7 s global template_subtype5 d4 a+ {! A' |2 ^0 h6 h; y0 N7 V
global mom_tool_name
- Y. K; C* J( M5 k global line_flag
6 l6 Y* z+ K$ c( t global mom_stock_part
! `* d7 G3 W/ l global mom_stepover_distance
* c. S9 M7 Y1 N0 j global mom_tool_length/ Y- g, ?. Z! X7 \' s/ Q( u4 F
global mom_inside_outside_tolerances
o+ f: Z7 l1 A) [' z; ] set oper_name "OPERATION NAME"( G* J. z7 B. a, `+ y; i, O
set oper_type "OPERATION DESCRIPTION"
& H. v, }# d7 C3 Y! I* B set tool_name "TOOL NAME"
) h! K: u5 K9 _% Z9 O1 q set stock_part "STOCK"
9 j ], K% K3 h8 ~5 R set stepover_distance "stepover"
8 O) _+ l# j" F3 o: t2 Y set tool_length "length"
; u6 S) A$ j% p# N set inside_outside_tolerances(0) "toll in"
9 R# A+ S) ~ ^1 n$ R r1 H3 x set inside_outside_tolerances(1) "toll out"" P1 b: d! U. C+ g
/ m8 I/ M. l* X if {!$line_flag} \8 R1 B( G, x& Y3 T" p# c
{! r6 M3 f9 `' Q) {
MOM_output_literal "-----------------------------------------------------------------------------------------------"4 l }1 n4 f' v, b) c& F
set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s" $oper_name $oper_type $tool_name $stock_part $stepover_distance $tool_length $inside_outside_tolerances(0) $inside_outside_tolerances(1) ]
+ ]/ g* v# v4 V" Y MOM_output_literal $output
- g7 r% x0 P# ~4 B" G: ~ MOM_output_literal "-----------------------------------------------------------------------------------------------"
! a3 ^0 P# W, W* d, U& j set line_flag 1* s8 E2 \2 H" `1 d
}/ b8 W; |! L* { [" t
if { $template_type == "" && $template_subtype == ""} \6 J u0 e9 G6 U& V# t) Q
' a6 d% N }& }' D+ j1 f) R/ v set oper_desc "--/--"# q2 s! g# W) I0 A+ m7 p/ H% f
} elseif { $template_type == "" } \
T/ E7 ^9 u8 @ d6 F {
+ i' a9 r; y/ J3 s0 K; E set oper_desc "--/"$ F7 t! w% e' \; P, s/ ^3 m
append oper_desc $template_type
% d( k$ T; [4 s/ T! }9 i# L } elseif { $template_subtype == ""} \- }' \3 U7 W7 [; _' n
{1 z. t3 X r: D0 r! \' H. ~
set oper_desc "$template_type/"' n, i8 ?7 t# G0 Z# W9 d J# I
append oper_desc "--": f% z: u' B7 k4 Q4 ^( R; S5 l
} else \
& X1 i2 S. @% Q& f5 e {- w0 P. n3 G2 M
1 J; B7 |6 f/ P }, U' ^! d' j2 x* l7 V2 s
set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s\n" $mom_operation_name \
% A0 q% G4 R7 w; j$ k3 O! m $oper_desc $mom_tool_name $mom_stock_part $mom_stepover_distance $mom_tool_length $mom_inside_outside_tolerances(0) $mom_inside_outside_tolerances(1)]
1 B7 S3 E+ p# z% j MOM_output_literal "$output"% T' Q! j; F/ @/ ]
) |/ n% i. { H1 @( x* F; c; B set template_subtype ""
' b) }, \% v) S- V& D" q5 w; }}$ v$ z7 @ @9 g5 g* t9 v
proc MOM_PROGRAMVIEW_HDR {} {
1 W! M$ @% \; B7 E global mom_member_nest_level
3 _' a* n' ]- G: B: j9 u}
R. e( o! C+ h7 h6 A4 ^- k! |" w+ ^: O9 x" t
0 ^6 ]! j3 h v3 k- Oproc MOM_PROGRAMVIEW_FTR {} {0 u1 o2 w/ K! ^
#==============================================================================* ?) t/ k7 p* F- i2 t% F
& @9 s: ]' w0 ~5 i- d# G#==============================================================================3 ]7 v5 J2 L' v" V: c+ X; O
proc MOM_PROGRAM_BODY {} {2 j K$ n" p7 J* |
! B2 h1 U5 g& ]0 ]" O& w global mom_member_nest_level
. i1 f- q& {# O1 P global mom_object_name
% O/ k9 M% m6 l- e8 E' O0 T global line_flag
0 x4 O, v+ @6 U. M/ {# q global mom_stock_part
- U* U I$ j- m global mom_stepover_distance
4 t& n* R( c# V7 e7 E1 e global mom_tool_length; m6 Y5 v1 r' C) P1 a$ X1 n
global mom_inside_outside_tolerances) a- R) x2 p Y
set oper_name "OPERATION NAME"5 a6 G8 H R8 h9 P8 S/ c
0 u) w- j- q8 Z( ]$ X set tool_name "TOOL NAME"
0 U8 ?7 e$ F5 P4 x+ S! \ set stock_part "STOCK"
' x0 ~6 j& m" U9 u% z7 B set stepover_distance "步距"
5 P8 U1 y. F& ]# ? set tool_length "刀长"/ d6 a1 H5 \% Z' d0 m
set inside_outside_tolerances(0) "内公差". u7 E' d4 p5 Z) M- V9 P
set inside_outside_tolerances(1) "外公差"+ {4 |8 L1 O; L( S; q$ @* ]1 t
* M3 _8 _5 [; v, h/ F I1 S if {$line_flag} \* y' w/ D" y$ T2 |$ O
{8 R9 T* V' T" D9 r: l3 _2 @9 ~5 @
MOM_output_literal "-----------------------------------------------------------------------------------------------"1 @5 S+ a. @8 O( C
MOM_output_literal " "
+ {- J1 s- Q) f* A# { h* D, @ set line_flag 0 W$ w4 U/ k ^9 M5 M
}! O( V& {- f) l9 O2 \
set output [format "PROGRAM NAME : %-25s" $mom_object_name]
, U& Q% ]" x- R0 {7 R) D$ @ MOM_output_literal "$output"
; X8 [% ^( J) ]+ v: c6 D0 M # puts the header only for the operations$ v! z& p0 _; [* @' t$ w2 F* Q
MOM_output_literal "-----------------------------------------------------------------------------------------------"3 E' c8 K3 d3 }/ _ R
set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s" $oper_name $oper_type $tool_name $stock_part $stepover_distance $tool_length $inside_outside_tolerances(0) $inside_outside_tolerances(1)]# r; J, B4 k% C* a
4 p" j0 W- n( m: c0 r+ A MOM_output_literal "-----------------------------------------------------------------------------------------------"
) C! B" J9 w( k set line_flag 10 K) I( B, x$ o1 }
: Q& K+ i" V! y7 A6 J) l) M
8 V5 m% N: g% }1 e: ~; s9 k4 J$ p#==============================================================================8 w2 h) |8 b2 P1 [: t( V o
proc MOM_MEMBERS_FTR {} {
2 ^6 F; \4 _5 m9 Y+ p#==============================================================================, k/ C' o8 \( W' c7 x$ D
global line_flag3 o" g+ N7 q8 Q( z
if {$line_flag} \
4 v2 E5 ]0 Q# w {
X& F' ~# N4 e1 \ MOM_output_literal "-----------------------------------------------------------------------------------------------"9 @, Y- l5 ^- m+ O' N# _4 E- J
8 _' c; o- W2 x. }0 F8 X set line_flag 0
0 ~. I" n. @& w* c, s }5 H8 c$ e# @4 d
}/ a0 j: @3 @% w7 [
# f7 g2 `+ \2 E8 g$ n7 l#==============================================================================
. R: |" W( q0 O) b$ V7 Qproc MOM_MEMBERS_HRD {} {
% ~" U4 b3 N( x3 n" d#==============================================================================8 A. W7 F) T! e% r: a/ }+ P
r# {6 M4 r0 @/ W2 g
, K1 Z& {- U7 u, W+ }- e有兴趣的可以联系我QQ25499556 |
