查看: 14568|回复: 18
[原创] UG车间文件更改原代码,便于制作自动程序单
发表于 2009-1-10 13:11 | 显示全部楼层 |阅读模式
QQ25499556,如有需要请联系
( F" q" a9 i$ k本人把ug车间文档原代码进行了更改,可以将加工信息直接反应出来了,便于自动出程序单编辑人员使用,原代码如下!
- n, `, S3 Q) g% O9 U9 f######################################################################
* G, ~" J/ Y9 i; |( `#      S H O P D O C _ P R O G R A M V I E W _ T E X T . T C L; [2 Y2 _( J1 Z8 V& d$ C( s8 ?
######################################################################- B2 r) j0 l: \  X9 Q" ]( M- s
# EVENT HANDLER SECTION
7 f( y) K3 L( ~  }0 l0 K0 n#   This section contains the control section for creating an operation list
+ F5 n8 M$ h9 a2 S, Q8 d, A#                 ' ^% k4 c" ^* \) L7 J% N
#   CAM will loop thru each event in the path and call the procedure
/ c& Q$ ~2 ^5 a0 G, a% |#   whose name is the name of the event.$ c3 \& C% h+ W( b" k* ]0 @2 e6 y# e
#, s2 ]5 y! p6 J' E+ [
#4 X5 Y% |/ \( X( S4 u" `! F
# ( w9 |0 d7 O4 ^, n
## r  k; M" \* N7 p  ?. j+ C& P1 B
#_______________________________________________________________________________
# f& t+ f) k9 F. o# Here you should define any global variables that will be used in any one/ A+ j4 v! e! U* J8 {7 x) s
# of the event handler.
- m6 b0 ?: }% ]) d5 c$ i( D#_______________________________________________________________________________- e. n$ x' F: C- q; X# [; _( B
set mom_source_directory [MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR]7 h  j4 A4 g' \" K0 u, t
source "$mom_source_directory/shopdoc_header.tcl"5 m" ~& H! q7 `% \
set line_flag 0
9 s0 H/ E# ?8 mset template_type ""
9 e# D% }& l2 V5 y# L  yset template_subtype ""
7 E/ ^4 S2 X( \2 U# This procedure creates a part documentation.
/ v9 p7 J2 o) ~& l9 I4 j#_______________________________________________________________________________8 }" \# K2 Y" d' _
$ G. u! C  l% Q8 j. `8 ~0 vproc MOM_Start_Part_Documentation {} {; N6 w) E1 w- c. S
* k% f% ]- C+ M4 u4 u   # Calls the shopdocs header# |8 m- D3 [8 ^0 x) w+ ]
    global mom_sys_output_file_suffix4 c% f' c& o$ N
    set mom_sys_output_file_suffix "txt"
- ]( T4 l! ~. ]2 i% u/ A- ?
: t0 X  l9 _8 J) G" [4 s
    Open_Files
) b9 s" K! K. _    ShopDoc_Header_text
% M7 ^% ^( B+ `+ e% ^. b) U
) D% v% }/ X8 g7 U9 `' W: k#==============================================================================* c- q2 e4 u) v% |1 \7 ]1 L9 Q
proc MOM_Part_Documentation {} {
2 i  ?! h* i, Z) l# o1 X#==============================================================================
" g# E: L! D& T7 Z! j4 R+ h
    MOM_do_template_file "[MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR]shopdoc_programview_text.tpl"
' E6 ^* m9 X4 m. ]  s! I}
& X6 s* }( k4 p#==============================================================================
; K# m+ G0 o9 ?proc MOM_End_Part_Documentation {} {
+ ?  P; x3 _) z#==============================================================================
/ q$ O- N8 M; v
}0 U% O) ]4 Z/ l. y5 Y7 d$ L
% F- q+ B! g& A# ^# @# Setup
1 [# x" ~5 o. [4 x% W#===============================================================================
, W1 Y4 c9 Y9 n( E" Y* B) N, I#==============================================================================  B" `' R6 |1 N% E  \
proc MOM_SETUP_HDR {} {7 b! J; P! [& L' i5 P0 x
$ ]  F' R# I9 L. b3 c
  # Calls the setup header
9 S* R4 T4 N+ N4 l    Setup_Header_text
. J' o0 h) R" l4 U}
) N6 k8 D1 s8 ?6 {+ m' \  k
2 Q- _3 s$ a# O8 _#==============================================================================/ G3 X( h% \2 i
proc MOM_SETUP_BODY {} {8 }& M  P4 m: |, U: |2 A. c- U( W9 L
1 e0 x; m0 j" b  global mom_template_type5 T# c7 W4 \  M$ x- @7 x1 I
  global mom_template_subtype
6 d! M+ I- p0 s7 Y, `3 r
  MOM_output_literal "                        OPERATION  LIST BY PROGRAM"
, [9 d; W+ k- f/ m  MOM_output_literal "                        *********  **** ** *******". c5 }' n" g& L& @
6 W( J9 J. Q: N3 `; a% \
0 c4 O8 y  C1 y+ s7 H#==============================================================================
/ T, E' }/ a8 }, {8 zproc MOM_SETUP_FTR {} {
# J3 ?6 d% e. I#==============================================================================
: L( A$ }) N; F3 s7 ^, Q. x
1 S% V. i- e$ d' H: Z# I/ v9 o3 {! ~+ d" r9 }: z* O  F; F6 g
#===============================================================================9 R; |+ b2 J  Z, Q
# Operation
2 m8 ?: x  ~% `- ]+ y" e) i# t#===============================================================================
, v& n( l2 ^* [8 \* s+ O' S#===============================================================================7 U. b' w1 z; A3 c  [5 t0 K& U; R0 b$ J
proc MOM_OPER_BODY { } {
, c5 {8 `- Z6 M" N6 R: _, U#===============================================================================4 w; w' i7 m9 i& [& o
  global mom_template_type2 h- m2 w1 r5 U! E7 p, V# U4 W
  global mom_template_subtype' H/ R; |2 z& O& J5 U
  global template_type9 m( p* x6 g+ q6 h- ?
  global template_subtype
, Z$ x/ l. ]( |7 K# N. k  global mom_operation_name) F) W; y4 m9 F1 [" q
  global mom_operation_type
& A" X( v4 w, J  set template_type $mom_template_type: C8 F. z. ]0 n8 S  X6 Q' P; l0 ~3 [$ z
  set template_subtype $mom_template_subtype
' o* z" ?- b- _- d5 R
  if { $mom_operation_type == "Wire EDM" } \/ F" Y$ _/ I: m" K1 b! ^5 B) [
4 O# Z, P& [% ~! I# i; L! I/ ^- F  {      set oper_desc "$template_type/$template_subtype"1 n% Z, t# T1 z$ \/ d6 A9 r; ~9 |; y/ x
      set output [format "%-30s %-35s %5s \n" $mom_operation_name \0 Y' G& Y; S* C9 T4 T- z5 J7 b! j
                          $oper_desc "WIRE"]
* J8 o# |2 ^4 M' ]2 t      MOM_output_literal "$output"% g/ A3 p2 u# \2 U  x$ W
5 t- X) l6 l$ ]( }8 J4 }+ I. N' X}
, F- ~' X- a- K+ r6 F
: v& f  P! z1 r' L1 {8 Oproc MOM_TOOL_BODY {} {. F; B# G) Z* l$ X/ `6 O
- K* B5 n9 F& G+ R5 D  global mom_operation_name# K- _$ Z: _' k) N% u
: ]; T: M6 `) D4 M  global template_type
  v( l# ^( w4 v; w$ {: D5 S" e. w/ f  global template_subtype
6 @, ~1 p6 q& ?2 h+ h% n  global mom_tool_name' [# M4 x; m  s0 Z; y6 w
  global line_flag
0 U1 Z5 Z; T" i- P. g  global mom_stock_part7 G& Y6 L: n" ^0 E
  global mom_stepover_distance
; G' z' }  c" f9 v, }  global mom_tool_length6 S7 ^+ B: d) Q: f
  global mom_inside_outside_tolerances
1 l$ k/ A( x1 l" ^
  set oper_name "OPERATION NAME"
/ g* u5 z4 \1 f+ T4 u  set oper_type "OPERATION DESCRIPTION"0 m% ~& \# B2 G2 O( S. \/ d8 w
  set tool_name "TOOL NAME"3 s+ Z& g& Y0 q- G
  set stock_part "STOCK"
" X! ?+ t# h' o- m  set stepover_distance "stepover"7 f0 j: Z; G0 b5 T# R
  set tool_length "length"" }( Q( |8 b* a
  set inside_outside_tolerances(0) "toll in"; S$ _$ ?/ S1 t9 b
  set inside_outside_tolerances(1) "toll out"
( j7 ?/ ?  M" \) R   p0 P. V) q$ D& b$ E/ y
  if {!$line_flag} \
, v5 k  `0 x- F  {" K, U; X0 I' q: R5 e; {$ m2 {  T
    MOM_output_literal "-----------------------------------------------------------------------------------------------"
0 C& y* N. y& G# J. K7 z: A    set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s" $oper_name $oper_type $tool_name $stock_part $stepover_distance $tool_length $inside_outside_tolerances(0) $inside_outside_tolerances(1) ]1 I" o0 T" p# c8 ]
    MOM_output_literal $output- t5 p  d  b0 w$ G! H; p
1 \1 T: M; o9 m+ l% n: B3 K4 a8 w    set line_flag 1: Q) n. o% R4 H6 u
. D6 B% M# A& k+ @  if { $template_type == ""  && $template_subtype == ""} \& B9 O( Z5 r8 m9 A. x
  {& D8 a) a- Y6 G
      set oper_desc "--/--"
+ X/ I# N+ D, g, H9 E1 ?1 d  } elseif { $template_type == "" } \
# b* C0 ~( v) t8 P, ^  {$ |! m& w) M. g
      set oper_desc "--/". H# R& D* J6 n# @: a
      append oper_desc $template_type) _9 B/ z0 I% m, W
  } elseif { $template_subtype == ""} \* Q* A# z# P8 ^
- a* _2 k! I6 T6 k      set oper_desc "$template_type/"' t  O: m  \; O- p
      append oper_desc "--"/ `$ F' ~3 {0 J, h* r. N% f
  } else \" Y# S$ T" I1 p/ x+ ]; b5 G
  {* d5 X) `1 z5 `: g1 V
      set oper_desc "$template_type/$template_subtype"& u1 W3 S4 D$ v$ q  Z0 @
" r0 ~4 J: A5 Y, C: A. ?/ O# R  set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s\n" $mom_operation_name \( k! ~9 \% f  G! {9 D
                          $oper_desc $mom_tool_name $mom_stock_part $mom_stepover_distance $mom_tool_length $mom_inside_outside_tolerances(0) $mom_inside_outside_tolerances(1)]
# x0 M& Q/ |$ ?+ x- h  MOM_output_literal "$output"
* M# I% T. a: ^1 V  set template_type ""% ]5 y, m& {& w" @, P* w( D' e
$ T% v, U2 R, l9 r}
4 P6 h$ ^) x% ]* f% A! uproc MOM_PROGRAMVIEW_HDR {} {
* `' _$ q1 o8 W9 W% o   global mom_member_nest_level
5 Y( ^8 I& p- `% b}
5 t% U( z. d) C
' K2 K6 `4 P* W
#==============================================================================( C# c* C( E* ^, v
proc MOM_PROGRAMVIEW_FTR {} {
! T2 B+ C- R/ b#==============================================================================
2 p( [- Q+ Z. t% I}
1 A0 |& s$ ^! u: M, M5 O6 h
% \1 K* M. o2 T7 {: I5 Wproc MOM_PROGRAM_BODY {} {
. A1 Q: m2 Y& l7 O0 t) J9 ]0 x#==============================================================================1 j' S4 z' a4 X& n' d' P# w: C# l
   global mom_member_nest_level! A4 y9 K7 U6 W! [5 L) x, U( p
   global mom_object_name
* E8 H- B( ?/ t8 p   global line_flag
! N1 l+ ^7 c* A2 T   global mom_stock_part/ F0 k8 U# e" e
3 d, f% n3 o  ?. J   global mom_tool_length
- F- H/ n2 @  V) O; i   global mom_inside_outside_tolerances
; m4 p) a/ _5 e  n: T! N
   set oper_name "OPERATION NAME"7 G0 }+ t9 Y! R) _
* A2 f7 V% G' ?4 Y; C, Q! P6 D   set tool_name "TOOL NAME"' {) J7 t4 X2 R8 y
4 l, K# y, w+ R( J/ W1 I* Z5 X1 U   set stepover_distance "
步距
"+ F2 t/ Z4 _; w7 \, O. P2 q- d2 [
   set tool_length "
刀长
7 D' d$ S# D4 b# F: X1 a  u   set inside_outside_tolerances(0) "
内公差
"4 }) n; ?% A9 O
外公差"
( s4 y7 H7 v9 w! O% Z' i
3 B4 X: G! w* C& G0 m   if {$line_flag} \
9 K$ N) A7 y# y* i2 V& L   {
- o# C, r. W6 J# d     MOM_output_literal "-----------------------------------------------------------------------------------------------"
- E! Q7 \8 }; X- N! x     MOM_output_literal "    "
( _$ |# a' i0 m5 b     set line_flag 0
, {" U' Y* F/ z   }
* t) b/ X8 H5 D9 }
   set output [format "PROGRAM NAME : %-25s" $mom_object_name]  |$ m9 S* j7 U$ j- A0 k1 u$ N; ^  S
5 I9 `; ~2 [, M  ?2 X
   # puts the header only for the operations
, m, N3 q0 h% L" K4 W2 i# ?* C- y     MOM_output_literal "-----------------------------------------------------------------------------------------------"$ ~3 L; v' n/ K8 W! ^, z3 N" B$ M
     set output [format "%-30s %-35s %-25s %-25s %-25s %-25s %-25s %-25s" $oper_name $oper_type $tool_name $stock_part $stepover_distance $tool_length $inside_outside_tolerances(0) $inside_outside_tolerances(1)]
/ C/ n. G" l' a8 U     MOM_output_literal $output1 `* Y* @4 W  g& o9 P
( `& R  x& i; r     set line_flag 1
" m) _/ e7 Y$ P+ F
6 ~+ C) U7 ^) x! e" w# b* M; q}
: H$ B9 @7 N- d8 _, f% b1 E* b#==============================================================================
8 M( Z( H" a1 e( \# q% I9 f4 rproc MOM_MEMBERS_FTR {} {  r5 z2 V0 F1 G- x8 g4 s- ^  ?
#==============================================================================3 G& e6 z9 Z& G7 k
   global line_flag
$ v1 i# I4 z* j, `) Z   if {$line_flag} \, v, F' i% T. l( V$ P9 b8 I0 _
   {8 b2 p4 k+ h1 }
* i0 W5 m7 o2 C# b3 x     MOM_output_literal "    "% ]! r$ E! X" h4 K( c; ?5 Q
     set line_flag 0
4 J9 f" Y7 w* G   }0 \/ a, h2 l5 e
. I8 X$ C  R+ {8 S
3 |9 I% K0 a2 s4 V  _6 X6 g#==============================================================================, q% j0 c( f9 g" H1 h8 f
proc MOM_MEMBERS_HRD {} {; W/ F! @* [: Q0 C2 f  P
9 u' g7 Z* d; V" c+ C0 r+ r}
 楼主| 发表于 2009-1-10 13:17 | 显示全部楼层
UGS0 Y& z  o% o) s! Y4 }+ H4 B
                                    **** k$ k2 d6 p9 |/ m9 G
                          SHOP FLOOR  DOCUMENTATION
7 B5 C# P! l4 H! N' s5 N0 H0 n                          **** *****  *************
9 {( N- b" L/ U* q7 Z# f--------------------------------------------------------------------------------: T1 x  G3 k+ ~) ^; b/ {; k
CREATED BY : Administrator              DATE : Thu Jan 08 10:17:36 20092 x" I# W( P! [, y
PART  NAME : D:\H1003-H1009\1009.prt  ' ^8 a* q; d& b  C- i9 \2 Q3 t
--------------------------------------------------------------------------------- t* u9 d2 E; h" N
                        OPERATION  LIST BY PROGRAM  l! }. P/ {: _4 p. I& Y; D
                        *********  **** ** *******- @) _0 K2 z" m! l6 V4 i
PROGRAM NAME : NC_PROGRAM
4 Q" h% l; }- [5 u0 k-----------------------------------------------------------------------------------------------
. i1 @! K: ]( b) |/ ?OPERATION NAME                 OPERATION DESCRIPTION               TOOL NAME                 STOCK                     步距                      刀长                      内公差                     外公差                     6 E- r9 i, {8 V$ w% s7 i) N% t4 j
& i' \! W7 B5 d9 Y9 iXD1C                           YCJG/PM1C                           D63R8L150                 0.29999999999999999       35.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000      : C: ^" j6 T7 a3 {* G: Y
* {% u( }) Y) p7 tXD1B                           YCJG/PM1BJ                          D63R8L150                 0.29999999999999999       35.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000
9 y* L& ~/ J, V6 E8 }7 [. q. n  D, [% B
XD1J                           YCJG/PM1J                           D125                      0.00000000000000000       115.00000000000000000     100.00000000000000000     0.03000000000000000       0.03000000000000000
+ H# b+ m3 l# I: m' ?3 a
6 S9 [# I4 k' s! l1 i2 U4 QXD2C                           YCJG/DQDGC                          D35R5L200                 0.29999999999999999       12.69999999999999900      200.00000000000000000     0.03000000000000000       0.03000000000000000      6 [  t* W7 V. n( _/ g6 K
) p1 Y; G4 {$ W1 D" M7 B! Q0 _
XD2J                           YCJG/LK                             D30L125                   0.00000000000000000       15.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000      ' T7 A# X* m2 t" P' u! s: i
* m7 c8 k" U3 U
XD3C                           YCJG/DQDGC                          D35R5L200                 0.29999999999999999       12.69999999999999900      200.00000000000000000     0.03000000000000000       0.03000000000000000      0 N% a, U4 _" ]
, p& W2 K9 _, L& }
XD3J                           YCJG/LK                             D30L125                   0.00000000000000000       15.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000
! ]0 d% ^4 E! c# ^" R* f6 W1 {/ M& f% a: p5 u; V5 j6 K4 w
XD4C                           YCJG/PM2C                           D63R8L400                 5.00000000000000000       35.00000000000000000      400.00000000000000000     0.03000000000000000       0.03000000000000000
% t4 f0 s, \3 s: B, _% D7 u" ^- K! m$ e; p: l1 O+ R: x: |$ g, C6 i& s7 B- v
XD4J                           YCJG/PM2J                           D63R8L400                 0.00000000000000000       35.00000000000000000      400.00000000000000000     0.03000000000000000       0.03000000000000000
: P9 a% l6 d" G% P6 _2 t; ^2 L0 d
XZ1C                           YCJG/PM2C                           D63R8L150                 0.29999999999999999       35.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000
! ~0 J' b0 H; I: `& Q0 @" ^5 o/ {3 S/ K' D; d/ a# ]; R6 [
XZ1J                           YCJG/PM2J                           D63R8L150                 0.00000000000000000       35.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000
3 Z# x: B/ U: c- a) e
" u1 m6 S& ]) v1 j7 I1 PXZ2C                           YCJG/PM2C                           D63R8L150                 0.29999999999999999       35.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000      % [9 n+ y1 Z/ i2 h# Z9 W
6 j+ c% d! P& Y# s+ ?( bX2Z2J                          YCJG/PM2J                           D63R8L150                 0.00000000000000000       35.00000000000000000      150.00000000000000000     0.03000000000000000       0.03000000000000000      + L. ]& s1 x. [, w5 ]
9 {% a6 b% Y) }
XZ3C                           YCJG/DQDGC                          D63R8L150                 0.29999999999999999       12.69999999999999900      150.00000000000000000     0.03000000000000000       0.03000000000000000
3 G- g, s2 F; [( r+ `; d0 ?$ s* N% d3 P$ t! i& |
XZ4C                           YCJG/DQDGC                          D63R8L150                 0.29999999999999999       12.69999999999999900      150.00000000000000000     0.03000000000000000       0.03000000000000000      2 k+ e9 e: l3 o  I  H( J* n0 _
4 i) G+ ^3 o+ J; xXZ4J                           YCJG/LK                             D50L200                   0.00000000000000000       15.00000000000000000      300.00000000000000000     0.03000000000000000       0.03000000000000000
发表于 2009-1-20 20:35 | 显示全部楼层
辛苦了,非常感谢你的提示,回头我也研究一下,不懂地方的还望你能赐教
发表于 2009-1-21 16:05 | 显示全部楼层
请楼上的下次发贴,把它说明白,说清楚。。。。到底具体怎么用,那样对大家才有用。否则别整些没有用的。。。
发表于 2009-1-31 11:41 | 显示全部楼层
你这是不是出.HTM
发表于 2009-3-15 16:13 | 显示全部楼层
看不董
发表于 2009-4-12 18:10 | 显示全部楼层
这些怎么使用  是不是直接复制到  那个.TLC文件里就行?3 N' p$ [6 L/ l% w5 Y
7 G% Z( g. S' ^# Y9 q
那个怎么改?
发表于 2009-4-12 18:11 | 显示全部楼层
应该有2个一个是TCL 那个我忘了
发表于 2009-4-12 18:38 | 显示全部楼层
来看看
发表于 2009-7-26 01:28 | 显示全部楼层
谢了
- ], k  Q) q& }% s8 T好像好用
GMT+8, 2025-2-19 06:17 , Processed in 0.063181 second(s), 22 queries .
