查看: 956|回复: 0
[疑难] 求图层可以手动输入文本层命名,附上源码
发表于 2016-4-21 14:24 | 显示全部楼层 |阅读模式
请大神们赐教,我一直找不出原因在那,试过vaf=valf(obj)
还有b3=valf(a3)都不行,谢谢
: q3 y: B7 O" a; K4 V  t6 d+ d/ V# `
entity/obj(1000)
string/st1(132)
' Y; V. i0 v$ f
l10:
    choose/'<<图层设定>>',$
           ' 中心线图层 ',$
           ' 母模仁图层 ',$
           ' 公模仁图层 ',$
           '手动设定图层',resp
    jump/l10:,end:,,,l20:,l30:,l40:,l50:,resp
l20:
    mask/3,5,6,9
    ident/'中心线图层',obj,cnt,n,resp
    jump/l10:,end:,,,resp
l201:
    &layer(obj(n))=50
    &color(obj(n))=186
    &font(obj(n))=4
    cat/'center',50
    n=n-1
    if/n==0,jump/l10:
    jump/l201:
l30:
    ident/'母模仁图层',obj,cnt,n,resp
l301:
    &layer(obj(n))=60
    &color(obj(n))=109
    cat/'cavity',60
    n=n-1
    if/n==0,jump/l10:
    jump/l301:
l40:
    ident/'公模仁图层',obj,cnt,n,resp
l401:
    &layer(obj(n))=70
    &color(obj(n))=36
    cat/'core',70
    n=n-1
    if/n==0,jump/l10:
    jump/l401:
+ |! B5 X; H% I+ x( R# F8 J$ l9 J# ]8 h
l50:
    ident/'选择工件物',obj,cnt,n,resp
) m9 ~% m- f& d
l501:
    param/'设定图层的位置和名称',$
          '设定图层=',nm1,resp
l502:
     text/'输入图层名称',st1,resp
- c. m. z5 p6 D3 j' |
l503:
    &layer(obj(n))=nm1
    cat/'st1',nm1
    n=n-1
    if/n==0,jump/l10:
    jump/l503:
8 Q$ a0 }. {# ]* g: x3 M  T
end:
  j) V! n( U# D3 ?% a5 ^
halt
1 u3 ]/ g- s/ j8 u$ U, T% H
8 ]9 D  a- d8 C% @9 X% s
GMT+8, 2025-3-11 15:40 , Processed in 0.161686 second(s), 19 queries .
