查看: 921|回复: 0
[原创] 用UF_UI_select_with_single_dialog选择后如何拉伸
发表于 2016-5-31 11:13 | 显示全部楼层 |阅读模式
  想做一个外挂,选择一条边后拉伸。但是选中是做出来了,但是往下该如何处理不知道了,请教高手。
/ l/ m4 G& ?% O9 E选择代码附上!
+ p% A9 g. I; b: r  F" _/ [+ O" b        //1.选择圆的边$ f* a9 Q- ~( |# ?
    char cue[] = "选择边(圆)";
* X7 R, [2 N; Q0 z# I4 Q* [# l) B    char title[] = "热流道防水槽和排水槽!";
/ k# ~9 f; W- @- }    int response;. k1 Y. Z/ x1 l" u# R  N
    tag_t object, view;
9 q5 \$ F) I7 V  a. r9 ^" @    double cursor[3];; Q3 L0 r+ Z' I0 B$ ?) s
    " [1 `' m3 Z- T1 k. z& F
    if(!UF_CALL(UF_UI_select_with_single_dialog(cue,title,UF_UI_SEL_SCOPE_NO_CHANGE, init_proc, NULL,&response, &object, cursor, &view)))
" n: `# h# l! P/ W    {, s1 D- c  Z( ]- E
        if (response == UF_UI_OBJECT_SELECTED ||response == UF_UI_OBJECT_SELECTED_BY_NAME)7 A+ u* Y! s# e( F" m; T
( n, z9 }( _7 J! _- T! {            printf("object tag = %d\n", object);
, Q. }/ p% x3 @# {5 n            if (response == UF_UI_OBJECT_SELECTED)8 {3 Z- y# t9 N
- l/ K  |4 M9 D( \7 t1 ?                printf("view = %d\n", view);* X% C2 `- S- U( b2 d: z* k0 V
                printf("cursor position = %f %f %f\n",5 W8 W% C% w" U: E
                        cursor[0], cursor[1], cursor[2]);
! w* h8 B5 @3 G            }
, c: v, _% s: o, q9 l        }
. ~+ V2 G8 P5 O# B. I% p        /* unhighlight selected object */
/ S8 D% d; o3 U# S( @% C        UF_DISP_set_highlight(object,0);# \/ G! V) N4 h2 J# v, X0 d
GMT+8, 2025-2-2 12:06 , Processed in 0.047910 second(s), 19 queries .
