查看: 665|回复: 1
[疑难] 为什么我这样代码只出现垂直标注,没有水平标注
发表于 2017-1-1 16:27 | 显示全部楼层 |阅读模式
/*创建坐标标注*/4 {1 N4 ^7 P% B* K
for(int i=0;i<count;i++)
/ D/ ?9 `1 t: ]& Y, x{  [. S( o  T. p, o7 ^; M: v- z% }
     UF_DRF_text_t   drf_text;/ g1 ?8 \. l2 f1 ], ]1 }2 p  n
     char append_text[1][133];
8 _$ S6 g- B8 V. I# o, n3 Z      strcpy (append_text[0], "");
# Y* v" t: R- C) O& l7 N3 d5 C6 v     drf_text.user_dim_text  = user_text;5 L8 |3 @2 K: Z! q( u2 g
     drf_text.lines_app_text = 1;
% D% l, \; S0 E, G5 Y  \     drf_text.appended_text  = append_text;
8 H' j/ }- M0 ]. ?) m          double origin[3]={0,0,0};
' a3 g* N3 i4 E8 ?- A% u      object1.object_tag = front_objects[ i ];
0 q3 ?7 z& H* y+ i1 O' s9 a$ ]      object1.object_view_tag = front_view_tag;
3 p" o6 P4 U/ `      object1.object_assoc_type = UF_DRF_end_point;
6 Y: V+ @/ ?6 {4 g$ v      object1.object_assoc_modifier =UF_DRF_first_end_point;, \: d; d% n& \+ g) D0 x7 D
      UF_DRF_create_orddimension(margin_tag,1,&object1,0,1,&drf_text,1,origin,&dimension_tag);
$ s  f3 j: Y9 r     UF_DRF_create_orddimension(margin_tag,2,&object1,0,1,&drf_text,1,origin,&dimension_tag);- J0 _4 B8 R1 ]) d$ `" I
         6 R4 z3 R5 g9 P1 }8 m$ u! t
5 x7 G( ^! ?/ F; O3 X3 z" w. e5 @}) r) [- j  A" a  i# W. d: r, @
& u9 o+ ], H' r7 N     UF_DRF_create_orddimension(margin_tag,2,&object1,0,1,&drf_text,1,origin,&dimension_tag);
! l( x2 |2 e9 T& M为什么我这样代码只出现垂直标注,没有水平标注7 }: \' Z) A) B8 G, `; l: S' L. R
发表于 2017-1-24 09:45 | 显示全部楼层
好的,好的,好的,
GMT+8, 2025-6-27 18:33 , Processed in 0.178723 second(s), 20 queries .
