楼主 |
发表于 2009-2-27 16:41
显示全部楼层
$ ], @$ _( k; f5 n! v
/ A# g3 N- r3 o, \5 M4 a5 v; l f%$ W* Y: l; X0 h1 g. l7 ?, M/ k
O0100+ B2 ?+ Z3 n! n, Y! T# E1 W
G40 G49 G80 G0
0 Z) R* M2 N; {, s" gG17 G21
, ?6 q# A/ A- O8 {; qG05.1 Q0 (这是高速高精功能关闭,否则不能换刀)
0 s1 {) D. }' jG91 G28 Z0.
2 i* t: A* c5 X3 [; T, k! ^8 pG49
' U6 S" S$ r( S4 e, g2 D4 H, S2 \T03 M06 (换刀) 这之前都是第一把刀定义,与后面换刀不一样!
( O$ R x; u5 P$ n- y) CT06 (下把刀准备)7 G# @+ \* d: k! n n# J- w
G05.1 Q1 (高速高精打开)
- k0 p' P% M' \. N- c' M% eG90 G54 G0 X0. Y0.
1 J* l5 H% F: Q. z/ d7 X7 UG0 G90 X1.463 Y.771 M03 S5000
7 m0 Q4 z3 V2 }G43 Z14.85 H03 (刀补)
7 b: o& ?3 n' T$ L8 D7 k/ [Z.05
7 v. `. m8 B* o3 ]) i- O& |/ s/ eZ-.7: K0 G0 y J- l& @
G1 Z-.9 F2000.
# y3 p* r& V' b* HG17 G3 X1.136 Y.892 I-.327 J-.379 (圆弧输出支持,不用老是用线性输出,影响精度)- A- S" t4 Y" Y$ U" f+ ^
X.636 Y.392 I0.0 J-.57 u+ H4 Q' J! X* I
X.637 Y.378 I.5 J0.0
8 s, X7 F4 S& r f QX1.507 Y-.467 I.87 J.025$ ~! d4 B& s# V: [, y3 c
X2.377 Y.403 I0.0 J.87+ F3 T' p6 r. j6 p9 t F# s" L
X1.507 Y1.274 I-.87 J0.0
* i% t5 G* R5 D8 `7 rX.636 Y.403 I0.0 J-.871
* e1 v& F4 g; I" A* |- u# GX.637 Y.378 I.871 J0.0
, X+ t; O/ \8 vX1.136 Y-.108 I.499 J.014
: S6 r7 j* q- W X: ZX1.151 Y-.107 I0.0 J.5
v3 A+ b0 ]: a) [' W% c; yG0 Z-.74 j5 n5 L( u2 ]4 {- o
G1 X1.543 Y.733 F2500.# {. r ]/ u3 w( f. z) G1 n9 m/ R
G0 Z-1.45+ d" p: L! f- L0 ]0 x d
G1 Z-1.65 F2000.
3 v1 U% [( {" e6 TG3 X1.175 Y.894 I-.368 J-.339+ z( U+ _; I4 O' Q4 L2 [) F C
X.675 Y.394 I0.0 J-.58 [8 X8 \/ v1 m, a- i1 y% `
X.676 Y.379 I.5 J0.09 [! T) `/ T1 H1 S' q: m" M2 n
X1.507 Y-.428 I.831 J.0240 `; H5 r( _9 O- B
X2.338 Y.403 I0.0 J.831
7 D' P9 T; d# y5 e( t' `6 sX1.507 Y1.235 I-.831 J0.0
3 W# {4 Q. p QX.675 Y.403 I0.0 J-.832
( }/ }1 {: P( f" w- Q# T* iX.676 Y.379 I.832 J0.0
4 I) { x( |( l9 g1 J6 H0 _2 _X1.175 Y-.106 I.499 J.015/ _7 U) j8 _0 ]0 ]4 A% x+ N
G1 X1.19
( Y# D8 |8 a, C- u [0 G; P5 OG0 Z14.856 [4 g; _6 b" _" a3 x
M09 (关油关主轴准备换刀)$ L" [. a3 G$ R$ p" S. s7 K1 ?
M058 ~, u! a3 ]& T9 n& a# [
G05.1 Q0 (高速高精关闭准备换刀)
8 \" m E) b+ R$ i- f. Z2 uG91 G28 Z0.0
& m+ @4 f: }) B3 I' G2 X' fG496 H) ?4 K i5 G% P8 o
T06 M06 (换第二把刀)
0 \1 f5 s: S7 aT03 (下把刀又准备好了)
4 m7 G5 L N+ r+ |G05.1 Q1 (高速高精打开)$ Q0 ^* D, d% o2 k, w
G90 G54 G00 X0. Y0.8 `% l1 w' E2 v# R) _
G0 G90 X.972 Y.855 M03 S5000
, k0 {9 q. ~5 dG43 Z14.85 H06 (刀补)
( t4 E! V/ p# H. V VZ.052 m* D4 k: S9 y/ \& X2 S( z, s# q, J
Z-.7
& r, {; h2 _0 V, c5 g* LG1 Z-.9 F2000.
' b# ?, J x! y2 b U C% RG3 X.807 Y.883 I-.165 J-.4721 L% ?4 m6 E3 M5 d2 Y. m# g8 w. k7 k
X.307 Y.383 I0.0 J-.5
# ?' ?2 U9 z. q4 |X.308 Y.368 I.5 J0.0
. b, w! C) B; E( s) nX1.507 Y-.797 I1.199 J.036
2 L9 n2 x" G# c8 L( B% ?) _X2.708 Y.404 I0.0 J1.201 {# c0 z4 }6 q
X1.507 Y1.604 I-1.201 J0.0
1 c1 C3 ~( g$ [. yX.307 Y.404 I0.0 J-1.2
, {3 e! J2 o' \0 B6 ~X.308 Y.368 I1.2 J0.0. I- h, J, b6 n6 S" l
X.807 Y-.117 I.499 J.015$ t4 _8 Q9 v& l1 C
G1 X.822* H% ]7 ?' v- K k
G0 Z-.7
9 [! r3 {. P$ g% s# BG1 X1.02 Y.852 F2500.
( U/ r4 P) O' y' ]6 f8 _G0 Z-1.45
* T; |" Y* ]5 _G1 Z-1.65 F2000.+ C( e: J/ g/ n; s2 ~ X9 }% F
G3 X.845 Y.884 I-.175 J-.4683 Z2 O- g& @+ e5 n8 B
X.345 Y.384 I0.0 J-.5
% ?! z+ ^% d* P& Z4 T) kG1 Y.369. r6 H/ Q& W; F. B& e% W
G3 X1.507 Y-.759 I1.162 J.034) F+ L7 Z5 h/ O* @3 D3 p. J5 l$ w
X2.668 Y.403 I0.0 J1.162- U O) @. V2 {& ]/ e9 d
X1.507 Y1.565 I-1.161 J0.0
& b! S) _- ^; ]6 tX.345 Y.403 I0.0 J-1.1624 X6 ^( `1 U5 S7 k
G1 Y.369( ?5 `( o' c! ^5 C% B1 c) @% r
G3 X.845 Y-.116 I.5 J.015
1 e# R3 Q7 z: t4 ~. C- J' xG1 X.86
8 K1 J( y* A# V. m. w9 ~1 H1 CG0 Z14.85
# `1 [+ C; c& P3 y: K) C4 N& V% vM05 M097 F. x, k. a5 n2 v/ H# ~: I
G05.1 Q08 ?! D4 |% S( s% ^
G91 G00 G28 Z0.
) I H- j. L# cG49" _; ` i. }, |, K O& V
M30
% }, k8 s- V, K. `( ?%
! j+ T# b; g4 ?- j& O7 t5 i# g6 G0 O- |
# k: |% T0 ?. Z7 z6 ~
而且此后处理增加了螺旋下刀,而且转化程式比一般的快10倍!自己可以体验一下,找个大程式试一下!
# X0 ]& X% b4 h* n0 Y$ K6 l3 [: z. Q+ \; B; i
如果觉得好请大家支持顶出来,好东西大家用! |
