$ F" t" |- v8 Z& H. A/ ?1 ~一款着名的数控程序的编辑和仿真工具.可进行存储和检索NC程序、NC程序优化、后处理、以及快速NC程序仿真。& g* R1 F" N8 ^3 i1 T7 a! E9 f
CIMCOEdit 8.01.01 | 257.7 mb! G; M; W6 a e6 y# U p
CIMCO A/S has released 8.01.01 version of CIMCOEdit, is a major update that delivers powerful new features, faster performance and a streamlined user experience across the entire line of CIMCO Software products.. K) w% |5 p0 Q) B! J+ a3 u! O ?0 x. I
With over 80,000 licenses distributed in the past few years CIMCO Edit is the most popular CNC program editor on the market. Every aspect of CIMCO Edit is new, from the multi-pane tabbed layout to the dynamic toolbars and menus. CIMCO Edit also includes new and powerful tools such as an enhanced file compare utility, a reengineered graphical backplotter, and the new NC-Assistant programming tool.
/ e+ J' C& U3 J1 l* W- A9 a$ Y7 I- Essential Editing Tools+ M$ d+ y8 {1 w& Q, t
CIMCO Edit provides a comprehensive set of essential editing tools necessary for meeting the demands of modern CNC program editing.$ p9 ]5 ~3 \2 k
It has no program size limitations and includes CNC code specific options such as line numbering / renumbering, character handling and XYZ range finder. It also features math functions including basic math, rotate, mirror, tool compensation, and translate. CIMCO Edit offers all the functions expected from an editor including drag-and-drop text editing. Best of all CIMCO Edit is completely configurable and is easily adapted to any existing CNC program editing environment.6 n2 l/ L0 C' R. q- ]* w
- Faster Editing with NC-Assistant* d3 y. a6 x6 J1 M4 P' _3 |2 S
The NC-Assistant makes editing NC code faster and easier than ever. Point at any M or G code and the NC-Assistant will identify the code allowing you to modify values using an interactive interface linked to the CNC code. Input the desired values for any register and the NC-Assistant updates the CNC code automatically.
. l, T- |5 b- O7 M: F; q+ o; uThe NC-Assistant in CIMCO Edit allows you to quickly insert and edit complex cycles and operations. CIMCO Edit includes built-in cycles and macros for the most common operations such as program start, program stop and tool change. You can also record or create custom cycles and macros for the operations most common to your own specific setups and applications.
9 N5 a- g# ~' ?9 }1 y3 w2 k- Graphical Backplotter
7 c3 D0 M% w6 BThe 3D Mill / 2D Lathe backplotter handles your 3-axis Mill and 2-axis lathe CNC programs with step and continuous forward and reverse plotting. Edit the CNC program and the update is automatically reflected in the plot. Analyze the plot with dynamic zoom, pan, rotate and measuring functions. CIMCO Edit supports solid visualization of NC code with toolholder collision check and gouge detection. @0 M! @/ ~5 \8 `
- Intelligent File Compare. }" `) m* L) M5 [7 t3 D
CIMCO Edit features a fast and fully configurable side-by-side file compare, allowing the user to quickly identify CNC program changes (shown at 2:40 in video). The file compare identifies changed and deleted / inserted lines, but ignores trivial format changes like block renumbering and spacing. Differences are displayed one line at a time, all at once or printed side-by-side for offline review.& X# a2 G( ^( z2 Z! D7 P# G
About CIMCO Americas, LLC" ?+ E6 w1 G _9 |7 p
Founded in 1991, CIMCO A/S has sold more than 100,000 software licenses throUGh experience and customer service all over the world. Cimco known for their Reliable DNC software, Cimco also has the world’s best G Code editor available on the market. So even if you are happy with your current DNC and CAM solution the Cimco Editor will compliment anyone’s day to day needs.
: N$ _9 n. L/ X1 y5 AProduct: CIMCOEdit
7 W( ?6 k* S4 ]. [Version: 8.01.01
- p* s# y$ T) a* ySupported Architectures: 32bit / 64bit9 Z( M: }3 {7 E4 `7 Y
Website Home Page : http://www.cimco.com: W1 B& }6 b; v# ^% d) D# d, f
Language: multilanguage
2 ?+ @- j1 L' \9 T. j6 D& u. NSystem Requirements: PC
6 p; W) f d& c% F8 ~4 ^- RSupported Operating Systems: Windows Vista / 7even / 8.x / 10 / Server 2008 / 2008 R2, and Server 2012 /2012 R2 are supported.' f& v3 }$ x& T) A" R/ J9 a0 [% q; a
% K# r3 ?& J$ c; ^$ v4 p) S& jDownload uploaded0 F- s$ I5 t" R4 ]4 T/ u- \
http://uploaded.net/file/91shzwcl/mcCid80101.rar4 W. {1 |: D& I7 k2 k* v
Download nitroflare) V. F& \9 {. ]3 i$ `4 q% u
http://nitroflare.com/view/2AC82136D41C3F8/mcCid80101.rar; v/ c0 \1 b( T! s% p: f) i+ P" f
百度网盘下载(包括安装文件与破解文件)与合谐文件:
1 L' W8 B5 i/ H% q1 o9 B; N) |/ p |
