楼主 |
发表于 2017-5-7 10:46
显示全部楼层
7 ]$ U! F8 p! P( h$ C# B5 E8 x) h, \int GLASSEX_structure ( int dialog_id,void * client_data,UF_STYLER_item_value_type_p_t callback_data)
' r3 P+ i9 \. O9 ?, q: @) O! @, D; q- G{
% X7 u7 L( R% v/ F if ( UF_initialize() != 0) & b6 [- a: ~! J' m
& ]' b/ A3 T1 B6 l return ( UF_UI_CB_CONTINUE_DIALOG );
_! _! t4 d& r! T, P ?9 {- y }7 Z* b" i$ l; R) |4 f2 v+ y
//修改按钮名称) Q6 Q: R% ~6 [/ x0 K$ u
HWND MFCHwnd =GetForegroundWindow(); //获得主窗口句柄
2 K. C) a6 L4 Q, S/ H HWND hand_button=FindWindowEx(MFCHwnd,NULL,"Button","应用"); //得到按钮的句柄) _0 l4 K( E* O# o
SetWindowText(hand_button,"更新");, L+ L" b* U6 W' W& E9 \! P& f
data.list_all_body=NULL_TAG;8 K! t! }+ R" e$ o5 d+ ^! Z6 h( I" F
UF_terminate ();
6 ~) |! F8 `+ _' l" Y/ y return (UF_UI_CB_CONTINUE_DIALOG); 2 U9 \6 {) S/ i7 l4 r7 x
}: H7 r0 Z4 {3 h3 U' T, K! q" ^ d
int GLASSEX_ruin ( int dialog_id,void * client_data,UF_STYLER_item_value_type_p_t callback_data); d ~ B1 R* S# o# C3 W
2 T$ E1 }0 I0 W if ( UF_initialize() != 0)
* ]) A$ o+ Y, T- k {
3 Y2 [* |# o# p N7 T* A return ( UF_UI_CB_CONTINUE_DIALOG );( l6 g d5 \; t! M! M' s/ P
! v: I1 o. n" E
2 x t. @+ U& K# F: | UF_terminate ();
* u/ b9 e: v" F2 T4 q5 ? return (UF_UI_CB_CONTINUE_DIALOG);
3 }6 y1 M" q/ D; }}
$ \/ N' t6 i" O! J/ |9 ~//确定
/ n. X/ L( S M' K/ a5 {$ G4 Iint GLASSEX_determine ( int dialog_id,void * client_data,UF_STYLER_item_value_type_p_t callback_data)7 d$ I6 q& Q0 h: N& P
{8 z3 k4 u. C& A+ q( Q# q$ M/ E
: \) F: A( l5 t. e5 M# k) s. G {3 X! u0 C7 z! t# l L
return ( UF_UI_CB_CONTINUE_DIALOG );5 t" {0 Y( t& C& m7 U
; m% ?& {6 R" ^) o6 T" s
, D# ^. Z( P$ P UF_UNDO_set_mark(UF_UNDO_visible,NULL,&data.mark_id);9 {& A! i% G: c8 _2 ^
data.PD=MGKJ_ask_double_value(dialog_id,GLASSEX_REAL_1);. [! l1 J. b, r' M' d
data.PH=MGKJ_ask_double_value(dialog_id,GLASSEX_REAL_2);
6 A% p$ N- R" `8 ] data.value_color=MGKJ_ask_int_value(dialog_id,GLASSEX_CTOL_3);3 U6 t7 |: `# v. }, K
data.value_leg=MGKJ_ask_double_value(dialog_id,GLASSEX_REAL_6);8 T3 p+ |; V& K
double multiple=data.PH/(28.74/2.0);6 {+ u9 E: @; B. Z$ y
tag_t tag=NULL_TAG;
. w6 e9 v; C* `5 T- g. ?+ I double point[3]={0.0,0.0,0.0}; ]" _/ ]" T: R# `# O9 C/ l
//判断是否打开模型
5 x$ y3 Y2 {- m# A6 T6 G+ N. T5 F tag_t pat_tag=NULL_TAG;
: a0 B3 S: x+ i4 I0 ?; ?$ J& h pat_tag=UF_PART_ask_display_part();# D. U5 ~# H7 g4 f2 N/ R
if(pat_tag==NULL_TAG)9 X/ c! r7 f- o4 R# U2 H
2 P# c |! y# R% i! \ return 0;
% ]2 j/ [5 h" A* N# @0 g# H }7 m, |2 H7 N: G( |$ X
( V- n- P# {# y3 s0 }9 a- T1 w7 F UF_MODL_create_list(&data.list_all_body);
# \- H: g7 J/ d //导入模型% ^, o0 q1 [: L0 I
char file_name1[]="F:\\graduate design\\MODEL\\my_engineering\\glasses\\modl\\GLASSES_LENS.prt";
$ y! P) {5 _- S! A' B! b UF_import_part_modes_t modes; * L0 C8 I6 a @8 Z/ t
double dest_csys[6]; Y/ i/ U+ A) {
double dest_point[3];
; s% I; n' D' l$ |/ D double scale=5; * g5 ^5 l& z6 Q
tag_t group=NULL_TAG;% k* r) \% s% V
modes.layer_mode=0;
! i" q- O! H9 X2 l7 m7 p; ]& J modes.group_mode=1;7 O" p2 y$ c0 O" j3 k
modes.view_mode=0;' j+ Z3 P, X6 l+ I0 |
modes.cam_mode=FALSE;
8 t. F# q9 L. v: k% I0 r" V. O dest_csys[0]=1; - c* C& s( Y/ x3 l
dest_csys[1]=0;1 u" J8 e8 P4 r8 |2 X
dest_csys[2]=0;
# {- g. @3 L+ Q; m' j! M/ W# _ dest_csys[3]=0;
, i" z# {) p2 [& | dest_csys[4]=1;. {8 s: d3 L% Q6 X, p9 v
dest_csys[5]=0;
3 V+ R% \* Y! T3 { dest_point[0]=0.0;
" b9 K3 k/ k9 j3 n6 E J% N2 f dest_point[1]=0.0;
3 z7 `( r0 y2 v7 J6 q! N/ \9 a$ J dest_point[2]=0.0;
1 A* [. ^% e8 h+ e UF_PART_import(file_name1,&modes,dest_csys,dest_point,scale,&group); s$ y! R+ n! |9 \+ G! T
3 \9 i3 Y( X" @8 M, A& C+ h
(附件里是两个全部的代码)& C: n% c, ~/ t+ @
谢谢大神~~1 ?# x% A4 n1 D* i- }4 _& X
