楼主 |
发表于 2009-3-10 18:04
显示全部楼层
都添加了
]( y# {* j5 |9 ]1 p' j解决了,可是又又新的问题了
9 u+ o" ^# x+ K; P' G6 |void CEXTERN_DEMOView::OnLButtonDblClk(UINT nFlags, CPoint point)
" K, X+ ~+ V$ A2 Q" `{: u+ V0 p0 x4 V4 y9 e
// TODO: 在此添加消息处理程序代码和/或调用默认值
4 J3 Z4 B0 y% U& L I UF_initialize();: W. O7 h& K% `$ S) S1 z
AfxMessageBox("UG");
3 b: k" \: U; z9 a- w# F3 v F UF_terminate();3 n C, @! N, |: w/ k+ Y! i8 ^! M
CView::OnLButtonDblClk(nFlags, point);
4 N# w* T# g+ b" ?& a}3 ~4 o0 W' |3 l$ L
8 T" C' g4 H" [7 m3 o
' R% e: m- o9 N) B
! G4 a9 w, ]: ?& {' ~1 p: |7 [5 ]. Q o0 a0 `
1>正在编译...* B0 N! g$ K! j. i( c: j4 [
1>EXTERN_DEMOView.cpp( k5 M/ L' K8 e% r+ i7 x
1>d:\my documents\visual studio 2005\projects\extern_demo\extern_demo\extern_demoview.cpp(111) : error C3861: “UF_initialize”: 找不到标识符
) F% Z* ^" T! J5 I. O1>d:\my documents\visual studio 2005\projects\extern_demo\extern_demo\extern_demoview.cpp(112) : error C2665: “AfxMessageBox”: 2 个重载中没有一个可以转换所有参数类型
, f+ E' P) K6 ^! b) ?1> d:\program files\microsoft visual studio 8\vc\atlmfc\include\afxwin.h(5025): 可能是“int AfxMessageBox(LPCTSTR,UINT,UINT)”
$ }7 x# X: M \/ E$ K$ X1> d:\program files\microsoft visual studio 8\vc\atlmfc\include\afxwin.h(5027): 或“int AfxMessageBox(UINT,UINT,UINT)”! c; W j: _+ n n( A4 a) R
1> 试图匹配参数列表“(const char [3])”时: C o4 a6 }2 Z+ U! @3 |
1>d:\my documents\visual studio 2005\projects\extern_demo\extern_demo\extern_demoview.cpp(113) : error C3861: “UF_terminate”: 找不到标识符
8 @0 m+ m5 @: [- T1>生成日志保存在“file://d:\My Documents\Visual Studio 2005\Projects\EXTERN_DEMO\EXTERN_DEMO\Debug\BuildLog.htm” |
