我做了一个由100个点组成的曲线,API程序如下:/ ?9 `% ?7 C3 s+ z! v# W6 Y% v
#include <uf.h>( r8 A% V6 R, W) U K
#include <uf_modl.h>
( M0 Q5 W P+ M( t9 @#include <uf_ui.h>
, O. F% E+ c7 l; y#include <stdio.h>
1 X* l5 G) o/ G* T) {' s {7 x0 Y#include "uf_ugopenint.h"/ U5 `5 i) ]- K$ m9 w
#include <uf_defs.h>0 ?9 m" x$ [8 A) L0 Z S/ q6 E
#include "StdAfx.h"
+ L# d' b2 R; o9 R( ^" F5 Q( a1 @#include <stdio.h>6 T9 h |9 j. W s, j
#include <cstdlib>
( d' j. [% M4 K$ M#include <fstream>8 P! @% K, S/ W$ `+ v, c6 w% T
#include <iostream>
' _. ~) @/ x9 T) [( D% w#include <uf_curve.h>% r0 H" Q( T& D& a
#include <uf.h>9 E: q; x8 M6 ^ |4 M6 b! a& x
#include <uf_csys.h>
) e6 J$ ]3 E% _% j; o$ m0 c& ~" @( i#include <uf_ui.h>
/ Y: M5 T6 @* [5 ]#include <uf_mb.h>; o2 D" o. A0 {' l+ t5 U. h
% n' R6 B3 {* p' ^0 j$ e, |#include <uf_obj.h>4 U# ]# w. u/ e" W* {' ]1 \
#define N 1007 B: b, c3 S4 v
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
, R! O, P+ p: s* C; T6 \static int report( char *file, int line, char *call, int irc)
W* a/ u4 [6 R4 w6 D{
6 @/ c7 u' @5 K1 o5 X( A$ y/ s9 p if (irc)
& a0 {$ S8 ]1 y4 j" T {5 [$ Q9 g$ f; p( X4 Y& Q7 [
char messg[133];
7 g# H4 b5 F) d# F printf("%s, line %d: %s\n", file, line, call);
$ H$ Q/ \ q' C8 p0 O& j6 e- } (UF_get_fail_message(irc, messg)) ?
' Y) P, r, \+ ~8 b printf(" returned a %d\n", irc) :
4 Z7 c: F+ f& ?5 Q7 G printf(" returned error %d: %s\n", irc, messg);4 H: a7 |% _4 M9 }4 B3 s" H: |
}6 o9 i2 a4 M# g p
return(irc);" e" k0 ?3 h6 F( ^# e
, d1 x/ c0 ?) l4 ~ q; f* [4 Utag_t SmoothSpline(tag_t spline_tag)
' h( i- `6 {, C" G4 o; u% C{
h' h& Q1 q2 J% o: { UF_CURVE_spline_t spline_data;
! X% u2 `- S, |9 H" O4 p int cont_order;0 A0 T# Q% Y2 j+ h- F0 H4 f* `
double dist_toler, ang_toler;* n4 r1 }) k+ @
double smooth_param = 1.2;% A+ l' X- T% Q( ~5 i3 y
int num_states;
0 _3 i, F# C; H+ j9 m8 Z UF_CURVE_state_p_t states;
) g q; P3 i8 \1 }, j/ m i tag_t output_tag;" Q, j" F" y9 Z; }( z$ L* }
UF_CALL(UF_CURVE_ask_spline_data(spline_tag,&spline_data));//get spline_data% Q' f/ M& w1 P# {8 Y
cont_order=2;
M2 Q$ F: z9 M6 o% V dist_toler=smooth_param;- k' v+ ^" p( l7 u# H) g9 j
ang_toler=360;
4 W- ~. n/ d' j
* Q! B" z) M* @ UF_CALL( UF_CURVE_smooth_spline_data
7 t0 K p6 T" |# r) S+ | (&spline_data,cont_order,dist_toler,ang_toler,&num_states,&states));//光顺曲线
4 g2 [% x% k8 h" |. o" W0 q UF_CALL(UF_CURVE_create_spline(&spline_data,&output_tag,&num_states,&states));
* |0 Q- G1 o9 q5 M7 g //光顺以后重新生成曲线2 Q. T$ q; e8 S+ w/ |" M- G
UF_OBJ_set_color(spline_tag, 1);5 s1 y$ g% g. W9 L" `# ]6 R
UF_free(spline_data.knots);
8 q6 z9 Q! D7 F6 _) e$ H UF_free(spline_data.poles);# ~4 h; j" i/ Z5 r$ [% v. n; P
UF_free(states);7 L2 Z/ e6 w4 p& l5 ?- w
return output_tag;9 t% X" D! p2 [" ]! R+ K
}1 g. E1 y. V& ~! X
static void do_UGopen_api(void)- N0 N5 z" v. Y U! y k" D% X) z
: ^/ `; E* q& c* s6 b6 H FILE *fp;
: ]+ E& X$ s* ?' s5 q5 I8 H: }( ` int i, j;
) r' Z7 p- q8 }$ E$ K* n) E. ` char filename[100];
3 z' f8 n8 T9 j$ y4 c% p9 o$ o double point[3];, |6 u- o$ f4 }. W1 C8 [7 h
tag_t t_pnt;: A7 L7 y) m x. c7 V2 B
tag_t spline;
0 p9 O2 ~' g9 C* I- ?) n5 {7 j+ _ double pnt[3*N];( B$ R2 r1 w3 x5 ?' i. j. P, n3 Q) d
int num_points = N;
$ I- p0 g9 q- F9 U( U3 G$ _, N int opt=1;) V! v! _0 i0 W- y+ w
sprintf(filename, "D:\\text.txt");
: s, m0 I& V5 J- d# F fp = fopen(filename, "r");2 @- @7 P. _2 a8 O8 r* c7 u- ?
i = 0;1 V8 @- j* e8 Z5 {
if (fp!=NULL)) \- ?8 h: [- C) R1 L1 p
{$ j6 Z! \: d0 X) P% i
while (!feof(fp))
" f- g! l' u+ ]; O a% R @ {
$ V9 u2 v2 J) Z# s' _) }3 a fscanf(fp, "%lf %lf %lf", &point[0], &point[1], &point[2]);+ O7 l" ` {. M) f# r% ^
UF_CURVE_create_point(point, &t_pnt);: Z/ r1 Y M- B0 z
pnt[3*i] = point[0];
. k' f6 B, \- n' y pnt[3*i+1] = point[1];
x- ?$ H0 {/ _6 Q* v% D8 y9 M pnt[3*i+2] = point[2];
" A- K6 c0 N- v+ _ i++;) {( g) l8 H* f& R3 R
3 @$ C* R8 R4 }/ V$ J FTN(uf5080)(&opt, &num_points, pnt[i], &spline);2 S; ?7 R6 `: C- s* v) `
spline = SmoothSpline(spline);3 K$ X1 n! F9 _( F: G
& g& |% U2 G" a6 j6 A0 ^: o else
% u/ `! e* y8 e, Q4 s3 h4 Z9 J uc1601("Cannot open the file!", 1);
% o! Q7 K! M5 z) } fclose(fp);5 Q! K9 g/ ^) C( T0 |5 o6 ?
}) b$ g8 O6 G+ B
void ufusr(char *param, int *retcode, int paramLen)& b6 U( I- y% w" i$ ?* O
" P: j; U6 D6 g$ Y- d6 } if (!UF_CALL(UF_initialize()))
, R0 `; E( S8 B; z" g, G {
5 k& ~; u0 f# N; `6 w; }5 L5 }0 q do_ugopen_api();- w* F6 }2 K1 ^
UF_CALL(UF_terminate());' O$ b- \3 p; X+ P% M. P" F
}# Q, ?; V+ h0 {- ]! P6 F
- l, F- C' n4 Q3 J* @( [- d. k1 kint ufusr_ask_unload(void)
* S* I: j. k) o: x{
! h% ^" @& G3 X/ z$ @ return (UF_UNLOAD_IMMEDIATELY);
& W* r" _: W" c6 F}4 c$ x% a3 V/ L% c4 S
但是在UG里运行时,曲线出不来,编译却没有问题!!大家帮我看看是哪出的问题? |
