0. Uninstall ANY SIEMENS SPLM License Server if one is installed:8 }. R2 a: S8 f; }4 g w
& i* |- \* h! ?& S( a6 Y6 q6 C
- If the original SPLM License Server is installed, use "Programs and Features" ) d# Y2 u- S/ q( X- W7 K4 a7 M
to remove it. s5 ]. | Y9 [5 m9 Q& h
: b, _, G- n4 `8 G- ^1 @ - If SSQ SPLM License Server is installed, run as Administrator the "server_remove.bat"
& X0 Q1 v( A5 W3 O# t from the SPLM License Server folder
: h- I- R: U2 J2 f: C/ G. b _# b5 c+ C1 g$ ?2 J# P, \+ x2 ^
1. DO NOT install original SPLM License Server from NX-12.0.0 setup media!!!2 h" _3 _7 }4 O1 O" C/ u
/ V. F8 E' @0 i) t9 R$ O2. Install or update the SolidSQUAD Universal License Server+ |6 x4 f; n! q% h2 p3 G5 i
" l% b1 D* h0 u" ]: ?- o
If SolidSQUAD Universal License Server has never been installed
9 s( A0 | f2 t. ^5 z( ?/ _# A on the computer: u3 i) y9 I" ?4 L
6 M' V5 q8 W( } K8 g6 M - unzip the "SolidSQUAD_License_Servers" folder from 5 o: u9 R9 Z: i1 u5 G e
"SSQ_UniversalLicenseServer_Core_<release-date>.zip" to any DRIVE ROOT ! i6 L' D1 n) n
folder X:\ (like C:\, D:\, E:\ etc), so the path will be:% r9 S7 w; N6 R# S& J; e X# h
3 j5 Y' Z: ]2 T9 R3 N* E/ N
X:\SolidSQUAD_License_Servers
; F5 e' {6 b T+ {2 N
8 T: N, ~+ d5 t& \) m2 D - unzip the "Vendors" folder from
* ?% n& |% E/ z" \, Q: b# f5 a4 o4 K "SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip"
# {) ?. j! l) g7 h% Y: S2 ]: W* F to the "SolidSQUAD_License_Servers" folder6 e7 L4 O2 P. m0 f
1 S5 z; x1 D6 X0 }* ` - As administrator run "install_or_update.bat" from "SolidSQUAD_License_Servers"
7 X8 H( X& O5 s0 ]1 h& f+ R( N# N folder and wait until it completes
. ?8 H+ l# d) K R
: j3 j; }( P; Q$ n, D -- OR --
' f9 ~& L) J+ h6 U6 x
* {: z2 ~2 G9 ^; Z1 h If SolidSQUAD Universal License Server is already installed,
3 V5 F8 u1 O+ ~+ s2 m+ a; o but the release-date of "SSQ_UniversalLicenseServer_Core_<release-date>.zip"' |$ M* W) F) H
is newer than the installed one, update the server installation:
( l- O' ?% c* U9 W$ `2 N: g% X. h# K5 M
- As administrator run "uninstall.bat" from "SolidSQUAD_License_Servers" 6 V( ]# _. Q# s$ U9 P+ e7 Y, E) a
# l# B) i; s* O( R& |7 K% F$ Z ?- }& g2 k6 V8 h
( t2 O7 y' o3 F6 k0 L( y "SSQ_UniversalLicenseServer_Core_<release-date>.zip" to any DRIVE ROOT
0 H u0 }: h; `8 T, r0 F) Q& m folder X:\ (like C:\, D:\, E:\ etc), so the path will be:5 {3 z# s( ~/ R: H8 ~
: `$ q6 I: o- b" C k# B X:\SolidSQUAD_License_Servers
- j% Y& b4 I% t0 C0 w
% @1 U) x" y1 _+ ?- x/ Q k - unzip the "Vendors" folder from
* f$ V8 [4 v% G# Z- r2 E "SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip"# A/ |. R2 k7 m) j% {* B: R& C0 Q: o' c
, `% J0 ^& F5 X4 n2 u- t; p4 i( n' D, A: F8 \% N" N; b
/ ?( b) a$ c) J z folder and wait until it completes
% ~7 ?0 y. l# k2 C4 A$ O0 Z' o' F$ z' \( n
-- OR --
& A$ C3 G+ F0 i& H6 }: M4 i
% _* q: ?( n/ r; O( p: { If the release-date of "SSQ_UniversalLicenseServer_Core_<release-date>.zip" is not newer
0 V1 O: F3 F" S i than the installed one but the release-date of $ i. a# ^; O3 q0 }( L6 ^ X
"SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip" is newer than the installed one,) T5 o0 }2 I1 ~4 ~- S0 N
update SiemensPLM module only:
) x' j @9 C/ k6 N' P
, `& P8 \/ A3 B) i; x- w! X! A; L - unzip the "Vendors" folder from
6 X+ I8 v& Q5 E) d& u7 T1 J "SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip"
5 Q; G( W9 p3 j; F to the "SolidSQUAD_License_Servers" folder
% _' b' K1 F4 G* @5 Y2 e% v0 t& I9 u8 P7 H/ y( O& u
- As administrator run "install_or_update.bat" from "SolidSQUAD_License_Servers" 5 o0 v- I z- T4 v+ p4 U
* Y ~9 }/ p) u" s9 e9 I+ ~
% v: x5 [+ Z" E) n! ^( \5. Install NX-12.0.0 Win64. At setup when asked for license server port and name input 27800@localhost
1 E% H: E9 S, B+ X( i: O! D9 w& e' Z( W/ t0 G& C3 |
6. Replace original <NX 12.0 program folder> (by default C:\Program Files\Siemens\NX 12.0) with cracked one$ A( L" S A H+ ~& }6 p
# z1 u6 X- x% h0 c7. Reboot computer
! B/ o" ~; d% H+ g6 A" q* b3 E5 ]# I0 c, ~8 B2 l8 V
8. Enjoy!
/ I: M+ B- p; Z, A0 z7 a7 t/ }5 a2 L5 |$ Z5 y) S
c+ U1 e7 r& o+ pCracked by TeAM SolidSQUAD-SSQ
9 T( c$ I- ]' @% y5 K/ {6 i$ m0 k. O, D) X. s
