楼主: Favour_nie
[原创] UG有限元分析时添加新材料的方法
发表于 2014-5-26 13:53 | 显示全部楼层
好帖要顶,楼主的头像还是不错滴
发表于 2014-5-29 21:13 | 显示全部楼层
好好好好,谢谢
, L: F. k5 `) g2 e5 r, p  E" F" C; e
发表于 2014-7-2 19:46 | 显示全部楼层
很好,很强大- D/ R+ d2 R6 H/ q6 G: O* ], C- |8 S
发表于 2014-7-4 21:19 | 显示全部楼层
楼主说错了哦!应该是physicalmateriallibrary.xml文件哦。$ w8 c# a- ?) I) Q0 l, S
<Material># e" ?+ _4 Z0 i" i$ ~; r" Y( j# b
       <BulkDetails>2 o8 f8 y0 V# a( N
           <Name>ABS</Name>
- g6 D4 l9 D( Z/ H* S# v           <Class> <Name>PLASTIC</Name></Class>" t2 P  [* s7 K9 W, k
           <Source source=""/>
5 O% J' P% V( m0 m% o4 g           <PropertyData property="Material Type"># \9 H; Q+ w4 \" s8 n+ U/ _
               <Data format="string">IsotropicMaterial</Data>- e' [8 X8 @1 k; \7 a( B1 Q4 W3 {
           </PropertyData>
" j$ E+ |) v$ V0 y+ F4 H           <PropertyData property="Version">* m; w, S# S# t* _1 Y) x( s
               <Data format="string">V2.0</Data>
! N. U; z/ W. {9 L/ N           </PropertyData>
$ _% a/ b- X6 U) {! m$ e2 b: K9 X           <PropertyData property="Category">
' i; S( `+ C" @) X2 p$ U  E               <Data format="string">PLASTIC</Data>
9 B, T& o4 p9 [1 T           </PropertyData>7 @) o! f. z, a2 ~8 ^4 f; c
           <PropertyData property="Mass Density (RHO)_6">
2 T. K7 h" C1 s) }, l6 J5 I) [2 I               <Data format="exponential">1.050000e-006</Data>/ D1 F+ F" n* z: ~$ Y' ?" l
           </PropertyData>% ]! K  {* j4 @0 }( U7 p
           <PropertyData property="Youngs Modulus (E)_31">: ~) R& D6 M3 X
               <Data format="exponential">2.000000e+006</Data>
' p! E3 r1 ~# }           </PropertyData>. c5 r' ]7 V! V8 N$ Z+ Z
           <PropertyData property="PoissonsRatio">
0 h3 p9 H4 `4 a8 ^               <Data format="exponential">4.000000e-001</Data>  P1 x% L. ^: m) o/ T, _& n
           </PropertyData>
) W' a4 Q+ n- k5 m, n           <PropertyData property="MatlNonlinearityType">
5 Z, X6 D2 _" H% O6 w               <Data format="integer">1</Data>! u5 c- p/ l. M2 {2 f
           </PropertyData>8 c+ u. y! P$ w  e7 D
           <PropertyData property="YieldFunctionCriterion">
: }( W' }& C9 _, b5 g% r% m7 q: ?               <Data format="integer">1</Data>* X7 V4 B6 b4 i: ?# {9 ~; Z
           </PropertyData>$ L% u* \4 i. s: C# P( w# C
           <PropertyData property="HardeningRule">% `2 x) F8 B3 F* e7 X- \
               <Data format="integer">1</Data>* ~2 C7 h5 Z+ X1 b: Q4 b
           </PropertyData>
0 ~9 n3 j  m: f) r* _5 x% E           <PropertyData property="CSYSOption">: m( V- H! U. V4 Y5 x% x
               <Data format="integer">0</Data>% p% w0 U4 E9 R! n6 b8 f
           </PropertyData>
3 O4 m  ]& M% F2 G9 A& w           <PropertyData property="Yield Strength_32">
$ H8 p; [# q4 ]% F6 N) \               <Data format="exponential">4.000000e+004</Data>
3 s% ^# N, k1 y8 p; E           </PropertyData>  Q3 g% M9 X5 `! N
           <PropertyData property="Thermal Expansion (A)_34">6 a* D' L. Y7 u* i% L3 ^
               <Data format="exponential">7.000000e-005</Data>
5 v3 @0 z3 ?. D  A5 ]7 B           </PropertyData>
9 j  l7 p: [3 b1 v  G/ Q. b4 O           <PropertyData property="Thermal Conductivity (K)_35">
* J1 r& Z4 u# u. N/ C* x$ D: @               <Data format="exponential">1.700000e+002</Data>
4 G7 x! Y) o: |7 o           </PropertyData>
/ H( Z! j1 ~: S, [; ]5 j# f8 d           <PropertyData property="Specific Heat (CP)_23">8 T9 A8 A! X% d" G* f' P
               <Data format="exponential">1.800000e+009</Data>
, V6 y; S0 U* m, G           </PropertyData>3 @4 |( ]' j! ?6 f
       </BulkDetails>
' U1 Z+ {8 d- J$ p2 L7 n! C' D    </Material>
发表于 2014-7-18 15:49 | 显示全部楼层
过来学习一下!
发表于 2014-8-14 11:33 | 显示全部楼层
新手学习,谢谢指导!
发表于 2014-8-22 14:08 | 显示全部楼层
2 _3 S* g1 J  e7 d
knakna看看了。。
发表于 2014-8-27 14:01 | 显示全部楼层
kan kan ,xie xie
2 w! X" b2 g. w* k4 V& U
GMT+8, 2025-10-12 08:28 , Processed in 0.053764 second(s), 19 queries .
