源玛:
3 I" [, G2 X1 m- [( ~/ b- G2 @( ^7 D ^! i5 Z; c" @, C8 Z# I. c, y! H: f; K
+ J h' C5 h9 A! u////////////////////////////////////////////////////////////////////////////// ^3 h9 Q: W4 V& b: {* T0 S/ j3 K( |0 l7 M& [4 I6 {/ R" ~# j
//" `$ N3 d3 G1 f8 T- r5 A, J# ^
& P' U! r5 ^$ K! z- E1 X3 W// create_oper.cpp' @7 T) O0 x$ }
; |; i; Y2 }$ a8 v$ O0 E' ~" w* n//( e1 x( @# e- j0 Q
* ~3 D0 @9 o! V7 r// Description:
2 f( {& ^* m$ D3 L5 Y8 v1 }- q+ k v# d) X0 t# S// Contains Unigraphics entry points for the application.* _8 d4 j0 [5 J
7 o' {4 F, W: r2 C Q//2 L9 J N4 `2 O9 ~, w, e. W5 I. |* \& v$ z( i, Q
////////////////////////////////////////////////////////////////////////////// R3 ~" P2 ^6 [4 J' ?& W, l
h) I3 l' \7 F" o u/ [/ W* d- l% m7 {) f: Y: D j7 [7 i: s) g* r
// Include files
" ^/ B" X6 \+ n3 G4 [2 i" O4 c. [" c, O+ D5 }2 R$ i#include <uf.h>4 p' [% L. e& x+ x% H! h
( Q3 A0 @- h: p5 m#include <uf_exit.h>
0 I, U, m4 `. ~6 J0 g3 a% ^- b6 |, b#include <uf_ui.h>3 z" F1 [& c- n6 N% X
( k4 Z4 V8 F5 F& Q#include <uf_oper.h>
/ Q6 c6 E$ w/ {+ n6 ]( {8 V# _% ?$ q* j#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun ): y$ F' a3 x% a& R( {. A2 k$ G5 g* S: b
# include <strstream>7 ]/ k4 H- b8 v
: ^4 P, M7 i/ ]8 l4 R$ h# include <iostream>
$ v5 D8 h8 _2 {5 O% K4 [3 Y$ F) k7 @9 n6 e9 X' [9 R- v8 ^ using std:strstream;! T4 z1 a2 r' h+ `6 }4 P% e5 o: ^7 \$ f/ w) g7 r# x; ]
using std::endl;
, K- r. \$ ?; Q+ [5 N& a% Q- I$ U5 a! r/ F5 h, c. M using std::ends;& m& ~$ _! H% w# w% A; }# X. f* R( x3 x H l" ?
using std::cerr;
+ Q) L% p# B3 [! w: f: c4 u R7 J5 a#else) L: [$ R) }5 G+ U/ B9 p9 ~
# I6 ~ y0 N7 p2 w# include <strstream.h>- }4 F+ c- s x X5 k/ Q* X
& @! j; \! s1 _0 x3 L- o6 d1 p# include <iostream.h>
{" R6 L' T- r h \# }8 {2 C7 q2 a" U+ G#endif' M8 m l' p9 `- r% [
( @0 M8 W/ s" H1 H#include "create_oper.h"
) z( B- A0 y6 N7 A( }& n5 w( _3 a; v( M% g. X9 Z( }2 g( @6 |4 r( E% L) V6 Y3 B% R1 o' [& Y
! o% j; t- g9 D* P1 J" d2 B7 ^# G+ D- m4 M4 v// Activation Methods* o7 c+ V3 ?2 [. `. [! C
! P# ~/ n9 d& I//----------------------------------------------------------------------------
# Q9 ]: e0 P& }* Z7 y6 {; ^9 I' ~1 z& w& D% q2 x* [( _( \" k2 @( x6 |& K) a. ~" T9 F2 R+ o4 }
// Unigraphics Startup b" Q" y4 }$ y5 Q0 ?
) }( {" E6 o0 n/ h0 X T: N, D// This entry point activates the application at Unigraphics startup
' ]. S. E0 l( U8 e7 n5 `0 J: v, k" U9 [7 w! @extern "C" DllExport void ufsta( char *param, int *returnCode, int rlen ). m* F" c, h/ G5 |( R$ P' ^, N. v9 ]
. }) d6 T- i7 X# c2 b$ _) I/ V{
- C+ I" t1 C. d7 h2 \, P/ I) x* F /* Initialize the API environment */ @0 j& `. X3 M: v
5 L4 o( ^# k, T0 Q: W( c int errorCode = UF_initialize();) h& w* Q6 P; ?6 r# d- z7 `5 F+ ]8 `3 [$ C
7 {" ?# j# ]2 E. R, t3 z4 W1 r/ R
$ u0 r9 l4 q% |* C if ( 0 == errorCode ). M0 v" `7 Q6 |# E
! d* M" \! L. k {. X0 h' d; I! ], Q
/ \5 f2 e% }7 D9 [# p* [8 [ /* TODO: Add your application code here */
: J9 f1 u! P1 n- o& P; n( J' n; W0 v7 j1 k
/ S, m7 c" I. r) Y# s5 l* s% m8 y# d* j0 m A+ I0 u char *type_name="mill_planar";7 q; b& |+ B! c$ y, o
/ N$ m+ g% \" s; u5 f m char *subtype_name="FACE_MILLING_AREA";% E. A+ p4 ] p0 G- ?) x4 \
4 [4 S1 a* p' g5 h4 J8 _: |* m+ H tag_t oper_tag;( J5 W) H/ i& V8 _: c+ R+ m; D$ n. V( X
' u8 C3 @. {+ U2 [- M. G/ ^ z4 u3 f6 y/ e/ w$ b1 K' b
UF_OPER_create(type_name,subtype_name,&oper_tag);
1 c2 |6 E; F7 J. \, W0 B8 t' ]! g, K8 h$ Z: p$ | T; y2 I" k s) ? u' x# _5 W% m- e2 y4 `
! \. D& I7 F+ G/ V+ k" ?7 F: o- x2 o/ o' g- d& \& F, M) b4 U$ V
1 |7 k8 Y1 D% K7 a1 S$ p+ x: ~1 Z) g# B a8 }# k( _+ F, e! ~3 g
1 Z9 @& B0 p; w" s8 ~# |9 K) h
" \ a' P4 e9 f& n6 x /* Terminate the API environment */
" t; l0 r+ {: C2 @3 h: G! c8 z) H/ ?% k& J& ^' M errorCode = UF_terminate();9 ? L$ K4 T. }: d) z8 j0 |) D8 U9 [ s, O6 }, b8 O0 o4 O0 J
) ]( @1 b- p0 A0 z" x6 F/ A5 I, h& O+ }7 W& r8 b( m4 o# y$ P6 X8 t
1 ~, k9 w' B, A: U9 R& K0 K/ ] /* Print out any error messages */
" T1 r( Z( m" s# o4 p5 T2 r, D- t# v, m5 F% Y7 ]% ]! S PrintErrorMessage( errorCode );! e1 w6 |, Y8 L! j% Q" b
6 P W5 _* k: u* R}0 a X' r1 S* K" {/ V9 t$ c4 ^2 }$ S3 K" [
$ \5 s3 k5 M2 r) ^+ h
# b3 ~3 W, G/ ]- i//----------------------------------------------------------------------------% G9 E% U/ o, a( M* m5 A
; y9 `) E' D/ `: W4 u' [) e// Utilities
8 o/ s% X' K, N; N; L% {8 F7 X3 T! {$ O3 G' L- _2 `1 g d//----------------------------------------------------------------------------" p! |/ V; ]! L( p0 `" k( C( {# c. q# T' y7 d" r2 t
5 I8 @# q$ t3 [& @0 x! d
M& G6 V' y" `// Unload Handler
: c/ C1 c% u- G# I/ M3 y" |: ~2 a$ {// This function specifies when to unload your application from Unigraphics.) T, A9 J) q% V& X2 R; @, }$ d8 [9 t2 N' X2 ?
// If your application registers a callback (from a MenuScript item or a
1 M' z9 I$ a8 _2 q. d+ y6 w7 t% t/ E+ t; i5 i1 S7 \// User Defined Object for example), this function MUST return
5 ?) d& G" g6 N* _1 d, {# [& B// "UF_UNLOAD_UG_TERMINATE".1 R5 A5 e6 h: X+ q; ]4 _1 J; t0 C6 m; v3 S, H( ~4 {* ^$ {! y
extern "C" int ufusr_ask_unload( void )
9 Q1 |1 V) d( u, _8 ?4 f/ A Q- `* s y" c' v9 U7 T{* E. o; z% h" ~% I
; u% [5 p: L+ t% d" l return( UF_UNLOAD_UG_TERMINATE );) c% D& U+ O+ {' l% D) y/ q
) `5 l+ [7 [' C: I3 e}# X, s/ _. j! T& t$ ~$ F
! y! @! O, a# e, b( l1 J- _- R& V0 v; d! P) M
4 n& _9 L/ f8 p" E% A/* PrintErrorMessage1 F* x. U6 A2 v; G! @8 r& {6 C& c, D; e+ |9 b
6 V& O' p& u4 L8 H4 U% E4 ]1 d7 `' _* K+ _! P- K** Prints error messages to standard error and the Unigraphics status
; e9 L6 b& r. ]/ u7 c% g9 I$ q$ M# T9 D/ L# E+ {** line. */2 r% ^8 w$ n4 I# K8 K7 \; i3 X5 ~; o
static void PrintErrorMessage( int errorCode )# r/ o% X9 H0 W+ ]( [6 r+ ~4 k
5 }/ H% l- A9 E9 y* Y/ v' }{, H) r: B: h' c, T a) ?
5 o9 E2 R/ M" c, j- ] if ( 0 != errorCode )
. O* n+ n" m6 z+ n* L# H9 J% I( B: k" f7 c. a& t. U {% M* _. B5 M9 \! B) h6 |1 ~- W0 [
0 G6 n; }6 ~) j4 f /* Retrieve the associated error message */
) b- ]5 v5 g8 G; U" V9 X1 `1 K! @& i# l, X: V4 g1 q char message[133];, K. k# L$ H+ T
% i" B' y6 s* Z, C2 ~3 d" f2 T UF_get_fail_message( errorCode, message );
3 P9 v. z ?, D2 c+ O( s0 Q' f3 o2 ?6 F+ m. E0 G: L; `7 v; U' ]& F$ q8 x. f: l. T
/* Print out the message */* Y8 l9 w9 h# B) G
c% O% h/ t" l! n/ w ` UF_UI_set_status( message );
$ m( J4 s% D; R7 v# D: Y: D2 p2 U9 r
/ w$ G( m! V! i. E" y' D8 z2 q8 E+ G // Construct a buffer to hold the text.5 G/ S/ u2 M6 ~; n: Q3 c( _4 f2 G- e- a6 \
ostrstream error_message;0 h9 ^) E% [: K: e/ i& a- }2 ]1 T# h3 S8 I
9 ` e+ _3 U1 [. C
* i1 [. D8 q/ N% Y4 c' C' Z m( b6 l // Initialize the buffer with the required text. x, R/ r/ a, R% L7 b5 \: U o& ]8 t0 x
error_message << endl Q; D8 D( A# y( Y
. B+ J) q5 B+ ^/ S << "Error:" << endl' O7 H: W- @9 Q7 V/ `
" s/ R1 c( `/ w$ P$ C. { << message* J8 W8 I; P$ }
; q4 b4 c; V* y: R" P/ O << endl << endl << ends;
K& t- A# b& D0 p8 T* d( v2 w G1 n6 v k! d/ Y: K- N+ a! n% X
1 p: k& h$ ?: G. I0 W) c, c. V& q- R' z. L% E // Write the message to standard error! Q6 L3 l7 f: p0 D! @0 Y3 N( ?: Z* {& h- L7 R7 z, b
cerr << error_message.str();4 l D7 E }& K9 X3 y1 ~* P
& O7 D* g5 @( [. M; H }
8 w8 `. z2 K* {2 f3 D# X0 u7 x# G7 ^4 y} |
