楼主: 893011376
[分享] UG哈斯三菱法兰克三轴四轴通用后处理刀具列表各种友情提示让你编程无忧无虑
发表于 2019-6-5 20:30 | 显示全部楼层
大师们,在那下载的啊8 P& Z# L% U1 U  x
发表于 2019-6-6 08:52 | 显示全部楼层
下载学习一下。不错的材料。+ g4 b  ^2 z9 H
发表于 2019-6-6 09:14 | 显示全部楼层
更好好好好好
发表于 2019-6-6 09:24 | 显示全部楼层
发表于 2019-6-6 09:28 | 显示全部楼层
好好学习天天向上
$ Y+ q$ A: b$ d. N' Z& ^, [
发表于 2019-6-9 01:56 | 显示全部楼层
求下载 求下载 不甚感激7 M) j( _. s9 q; K
4 N9 P6 Y) U7 j
发表于 2019-6-12 10:53 | 显示全部楼层
谢谢楼主分享% x5 Z  O( X" [
' x5 |- h( }" h# d
发表于 2019-6-13 09:04 | 显示全部楼层
4 ]; [2 f5 N" p2 u    proc PB_CMD_Zmax_Zmin_start_of_program { } {
/ x) @* ~; r: h: A. Q    #=============================================================
2 B; I% r* K: J0 Y     #4 H+ H6 u' s$ _2 |
     # This custom command may be used to check for the maximum& @3 f) ~% A# k( i5 Y) K0 U7 R, ?) m" u9 }
     # travel for each axis.  A warning will be output for each( Y% {9 ~" |; f
     # GOTO that exceeds the limits.  It does not check for
( I- b6 z4 K6 z* |2 A. _     # parallel axis such as Z and W.  It does not account for0 o% x$ ~. \' z
     # any modifications done by the user to mom_pos before the# V1 A$ T) E1 J
     # coordinates are output.
5 B7 y1 `5 p, b' ]0 i9 a3 T     #8 a" H! V; _, \+ r
     #% ], Z  j0 u' u, s  S1 H
     # Import and call this command in PB_CMD_before_motion.
/ m1 g& f8 h: {     #( x) `' G8 x9 V5 A) W- ~
     #& O! |& c) A4 ]2 R; J  K
        global mom_sys_max_travel$ l& x1 m$ _/ s0 A3 D
        global mom_sys_min_travel0 f) a; d" W# x( {1 g8 E! b
        global mom_kin_x_axis_limit
' @5 ]% L5 ~, Y7 N2 r% ?        global mom_kin_y_axis_limit
. d8 ~* P) V: ]        global mom_kin_z_axis_limit! e2 Q. {- M, [$ X& y( q. l
        global mom_pos# y& ~' \8 D# S( v' A
        global mom_cycle_rapid_to_pos
$ O  X$ c+ F; N        global mom_cycle_feed_to_pos5 j8 p! L) O4 E' J7 ]
        global mom_cycle_retract_to_pos
. S0 a# q% J5 @6 Z/ B. a$ L        global mom_motion_type0 m2 i! ?$ n. t1 [" O+ K7 b
        global mom_warning_info
1 e2 a* ^' T& A* e- e2 a
9 V5 L0 b( \/ M4 q- h2 Q" ~        if {![info exists mom_sys_max_travel]} {
. X+ b" R6 f- K: U- _( m1 ]/ o* \
           for {set i 0} {$i < 3} {incr i} {- d5 e& Z. e7 M/ t& C" W4 w: {1 d* z
+ P; o) `9 N+ q. F, I* ^. B% j( |) Z  }) V              set mom_sys_max_travel($i) $mom_pos($i)$ k  |( J4 V7 z1 {9 U8 q8 [/ i
              set mom_sys_min_travel($i) $mom_pos($i)
' [7 D0 |! M$ G3 }           }
  q3 i. M7 B3 V% X' L' q. R( |8 I3 U2 L( U% {4 x) ^# c8 [" [( w# s+ x& \
        } elseif { ![string compare "CYCLE" $mom_motion_type] } {
$ W/ Z# A, F5 U
: D& p9 a( F9 l. p, H( B           for {set i 0} {$i < 3} {incr i} {( ~; m$ t$ S6 {9 Z; \6 u
1 O. M  U7 I" [$ W# g
              if {$mom_cycle_rapid_to_pos($i) < $mom_sys_min_travel($i)} {
1 m. K3 U* U' p. i5 A! ^; Y! K4 Q                 set mom_sys_min_travel($i) $mom_cycle_rapid_to_pos($i)
) j. r5 p+ O- L! c              }% j$ L8 y1 c7 R) ]' _
              if {$mom_cycle_rapid_to_pos($i) > $mom_sys_max_travel($i)} {' P" m. u7 A, G) I3 ?2 M4 L& I
                 set mom_sys_max_travel($i) $mom_cycle_rapid_to_pos($i)+ {. i; Q: a" V# H8 G0 m4 A# b
              }4 G; }6 m" S. P6 {) i
              if {$mom_cycle_feed_to_pos($i) < $mom_sys_min_travel($i)} {
; V3 G$ ]- w% G                 set mom_sys_min_travel($i) $mom_cycle_feed_to_pos($i); |  c- i( P4 f% h
( i' _( S* ~" H) t2 ?              if {$mom_cycle_feed_to_pos($i) > $mom_sys_max_travel($i)} {
7 H9 Q3 x) w1 u/ E                 set mom_sys_max_travel($i) $mom_cycle_feed_to_pos($i)
  Q7 D9 R. [8 T# @              }
" T4 Q! l/ ^: o6 ?              if {$mom_cycle_retract_to_pos($i) < $mom_sys_min_travel($i)} {
: v# v% c0 ^$ F1 F% Z+ [$ s                 set mom_sys_min_travel($i) $mom_cycle_retract_to_pos($i), j8 `! P5 ?2 U: l! J
, v3 H' N1 q8 [$ A. {6 g; T. r* E              if {$mom_cycle_retract_to_pos($i) > $mom_sys_max_travel($i)} {/ N/ Z1 J% |7 Z; ^  D9 X+ w- H( w
                 set mom_sys_max_travel($i) $mom_cycle_retract_to_pos($i)
  x' ^* O/ f$ M& E: K& u# Y  f              }
& |2 M+ n' Y" o' O; D           }) C$ L& E+ f$ J! k
' @* @# N4 m1 k4 w2 N( M: R
        } else {, y# O; k7 J- p& b
* K* n9 I+ l# {: {
           for {set i 0} {$i < 3} {incr i} {5 G* F. _! t4 W9 D' P+ F0 K& F
              if {$mom_pos($i) < $mom_sys_min_travel($i)} {
5 |# u5 ^9 s# T. j( ~9 R                 set mom_sys_min_travel($i) $mom_pos($i)7 A8 M  J- Q- @2 Q7 ]
              }# ]3 [; z9 R, @/ ?% g
              if {$mom_pos($i) > $mom_sys_max_travel($i)} {
- r' b  M, ]1 [4 C' r                 set mom_sys_max_travel($i) $mom_pos($i)
+ t" s. ~& t8 c7 M2 b( e              }
9 ^& {$ ?" E' X5 Z( ^3 u. L           }
$ ?0 |% C( j) Y2 z9 `+ k- S        }
5 v. L, I# K$ \3 D: W# U6 \' d; g, C% e5 p' I
        if {[expr $mom_sys_max_travel(0) - $mom_sys_min_travel(0)] > $mom_kin_x_axis_limit} {
. d' e. c3 B% }, w/ m3 Q           set mom_warning_info "Maximum X axis travel exceeded, did not alter output"# ^; h, i! s7 @4 }. h) j: g( j
           MOM_catch_warning
, ]* \) o# }: H6 E        }
, s" e1 o7 h: T; D% o
* c. {2 ?+ C( U        if {[expr $mom_sys_max_travel(1) - $mom_sys_min_travel(1)] > $mom_kin_y_axis_limit} {
# ]( Q/ l+ H# V  f           set mom_warning_info "Maximum Y axis travel exceeded, did not alter output"
" Q* Q" _' O% N5 T           MOM_catch_warning
5 S. e: ]8 j0 V' A4 M6 ~! [        }
% B* @; U& l' }; |. F' R# Z4 L& V% t( Z. }; }3 \0 C
        if {[expr $mom_sys_max_travel(2) - $mom_sys_min_travel(2)] > $mom_kin_z_axis_limit} {4 I$ @3 @  O! D# R3 p! k, S
           set mom_warning_info "Maximum Z axis travel exceeded, did not alter output"0 Z, ^, |3 E! W' w1 U. a+ ?
           MOM_catch_warning" n: s% e0 Y( s9 @6 b2 m# i. z
  e9 P6 Q$ _2 q7 V) }  q" p) Q    }
+ j: S& F& O5 }9 R7 c% t0 F6 u/ i6 h
( c9 {* c- a0 L$ N8 L1 R9 ]
. w! d- q+ G" i" E$ }/ m
发表于 2019-6-13 13:44 | 显示全部楼层
1222222222222/ T, d8 n3 S( S
GMT+8, 2025-9-17 18:19 , Processed in 0.072956 second(s), 18 queries .
