我先在草图中画了一个圆,现在想用API拉伸这个草图,我想用2 C( f* e) D+ o9 E1 d7 f! k Z2 M
+ M6 q) I* k) F2 e$ W5 x) I
UF_OBJ_cycle_objs_in_part( part, type, &feature )来遍历 ( ~! q' \9 E/ i. t2 W
- I% J2 R A$ M% P4 E一、 设定type =UF_sketch_type,能遍历到草图的特征标识 sketch_tag ;
, U2 k7 G9 V0 e6 c
4 n' a7 Q4 l. C; n' g, B二、 然后用 UF_SKET_ask_sketch_features(sketch_tag,&loop_list);
: j0 T& u" b! A/ V$ s" s0 I' e. P& g* V& x8 M2 Q. e
获得草图里的特征标识的链表 ;( ~7 M, N. e( y: M( e; z5 T; v( _0 f
/ x6 |" w, f" Q; m+ f( ]. b
三、 再用UF_MODL_create_extruded (loop_list,taper_angle,limit,ref_pt,direction,UF_NULLSIGN,&features);
/ F# t7 x. P2 R0 t) i) F
5 v' m q( x9 m5 B6 _4 k) ` 来拉伸;
u% T4 Q4 y3 C9 W2 c) y: A& k
4 o6 f0 c3 [! y0 f4 L但是总是不能拉伸成功,不知道是哪步做的有问题啊
& [2 [$ u4 o: i0 L/ A+ Z% c9 {5 W, y, d! T* E. ]
5 X5 A4 f3 k. u
请大家指点一下,急用,不胜感激!!!4 M/ a t, g7 R
% t4 M+ X" g7 Z+ C
^' I7 D- \5 W; I5 M6 ~/ x
% w' o- C5 }! A9 ~
) T* k$ L3 x/ G, @! F5 n. K( P8 n
代码如下:$ X+ Q7 B2 t& \& T
H3 u( _3 ]# e' I/ O8 n) I8 c0 p) {
9 z( k" e7 I G7 nchar *taper_angle="0.0";
3 L3 t" S, s% N7 p& D1 W) [char *limit[2],limitl[2][30];
6 Q2 N' O' ?: N# Mdouble direction[3]={0.0,0.0,1.0};! h' i4 Z. L p' q
double ref_pt[2];
( Y8 o# N: d8 @6 Vstrcpy(limitl[0],"-20");& D$ e9 ?! m* k. ?) A/ f% g
strcpy(limitl[1],"20");5 _$ _3 d/ _6 W2 ?5 z
limit[0]=limitl[0];1 l1 P& i/ a$ q" }! P* x( [
limit[1]=limitl[1];( f+ p- i! a8 f3 O$ T/ Y3 @. g7 A
2 I$ R& P2 H5 |; _4 _. C) P2 V; `
int count_1,type;
% ^2 R5 D3 p9 T$ `8 otag_t sketch_tag, part_tag; : T7 O/ _; u$ o1 O
uf_list_p_t loop_list;) ?. G7 d; X! y1 ?4 ] }
feature = NULL_TAG;
. L8 A! U8 ^, l9 D5 {6 ctype=UF_sketch_type;
8 h8 u+ l P/ mnume=1;& S$ X+ u3 E3 N$ t+ p! [
count_1=0;
0 q9 `9 `+ p: Z
0 o* ~6 u- H( @$ P6 H* X2 Q4 O1 T6 N3 U2 n* v
part_tag=UF_PART_ask_display_part();6 z9 S# v- J R D J: X' y
) o0 }# f2 N4 S9 O$ f2 v+ S/* Start the cycling process by passing in a NULL_TAG. */
& @8 L$ }9 G4 ?; F$ d8 a3 P& p) G# b
1 X2 ~' P6 Q4 g# F UF_OBJ_cycle_objs_in_part( part_tag,type, &sketch_tag );- ~! s0 S: J" b' b0 a; V f. B
% l; X2 c+ z7 q/ h* S9 ]$ y
while(sketch!=NULL_TAG)
; B$ I1 q0 Z5 z! ?+ ^- x {" X, X1 V( J& ^ w
count_1++;" P* W. ~! _. p
7 |& U: `/ n/ \7 f% x2 r/ o UF_MODL_create_list(&loop_list);6 a D+ |+ H7 i) d$ d3 H2 Y( r8 _
/ g9 X2 O: ~" J: z: P UF_SKET_ask_sketch_features(sketch_tag,&loop_list);8 J# N- V$ q3 J: E0 Z# J- W
* ]# Z+ l9 k9 L8 X; h u0 L$ |' @
UF_OBJ_cycle_objs_in_part( part_tag,type, &feature );0 u. b- ?; d$ D8 B" S
7 q3 X# [; K! y1 i) i4 l* t7 o
1 c- n1 r0 q: B3 z5 J0 Z6 _ UF_MODL_create_extruded(loop_list,taper_angle,limit,ref_pt,direction,UF_NULLSIGN,&features);: O/ x0 [ ]% f/ ?
UF_MODL_delete_list(&features);
% F3 I# V/ i( K8 m3 h$ x }, f2 y9 i6 W2 l5 o! J) _; F
. r7 \- o" h; T+ C
) G0 M0 H9 v& n" X$ \} |
