static void do_ugopen_api(void)( V7 \8 q% z) X$ ^5 c
* I- h& C# i( V8 h8 N* }. u int obj_cnt;
% n: k& J: S/ h1 T h6 N char *offsets[2] = {"0.0", "0.0"};& X. q7 i1 Z) T# L) n* R0 y
UF_FEATURE_SIGN sign = UF_NULLSIGN;
! `, y: p0 e: U. }0 Q UF_FEATURE_SIGN sign1 = UF_UNSIGNED;
" N& ]" B+ n N! F tag_t line1, line2, line3, line4,line5,line6, guide, *objects;( P6 F. z7 c9 y3 e' ^/ [9 F5 t+ X8 Z
tag_t generators[6]; ; j$ f3 g+ w, V o% N: B: G* d5 M
tag_t cone_obj;6 V; d, I9 W' O% b1 {/ ?
char *height="10";. Z) b! S' W( [% J( t" B; e* M
char *diam[2]={"66.64","30"};- b7 H' }/ i/ m5 [* X# x
double orig[3] ={0.0,0.0,0.0};7 R/ r# Z/ O, [; I7 \
double direction[3] = {0.0,0.0,1.0};
+ z/ U: l* `8 _) M `0 k# X; K5 J double pt1[3] = {-8.660254, -15, 0.0};
5 z3 |8 K6 I' N7 `4 o1 e UF_CURVE_line_t mline1, mline2, mline3, mline4,mline5,mline6, mguide;: U$ _- u) v0 f) ^, A, X, {
/* line 1 */
: {6 ?2 e1 i; W) Z0 j& B/ J mline1.start_point[0] = -8.660254;
0 V, q% C F4 a mline1.start_point[1] = -15;
/ Z4 j# b1 e+ n0 l mline1.start_point[2] = 0.0;
3 P* P- |( g8 N6 Y mline1.end_point[0] = 8.660254;% H9 p) }# t8 Z; H9 V0 ?; {2 A. ?
mline1.end_point[1] = -15;
4 _! \: O3 C8 t w6 c mline1.end_point[2] = 0.0;
6 q- |" _$ F! J UF_CALL(UF_CURVE_create_line(&mline1, &line1)); F" y; m/ s6 Q4 o4 \
/* line 2 */
) {, n" p( e( A+ c mline2.start_point[0] = 8.660254;
9 R8 j3 e2 C& Q W9 e. k* Q mline2.start_point[1] = -15;
) W! R; a7 ]6 `0 \5 R5 i7 j4 G3 i mline2.start_point[2] = 0.0;* o1 p3 {% x% N; X. m4 O
mline2.end_point[0] = 17.320508;5 Y8 o! V7 X6 k. ]/ L+ A. B' l& s* ?
mline2.end_point[1] = 0.0;
# V+ K2 g6 a5 N2 z1 j# _: M8 ~ mline2.end_point[2] = 0.0;
# p# {6 o, X4 b UF_CALL(UF_CURVE_create_line(&mline2, &line2));8 q& C; p. N8 s* T; t( b
/* line 3 */: G% {3 y2 D, W9 s( i% r
mline3.start_point[0] = 17.320508;. g( x f/ S! R0 O4 _% }' |2 Q
mline3.start_point[1] = 0.0;
0 B, u$ C9 r3 W( A4 V* p, Y$ ~ mline3.start_point[2] = 0.0;" r: N8 D$ d4 d7 G/ ^. H
mline3.end_point[0] = 8.660254;
: u) n* r0 E! J! p8 V mline3.end_point[1] = 15;9 ~+ C; ]. q+ g% L, v( ^% l
mline3.end_point[2] = 0.0;
/ }+ d1 E1 _ l. S3 X8 b5 O0 h UF_CALL(UF_CURVE_create_line(&mline3, &line3));
. F7 E- T5 e6 x4 i) i" S/* line 4 */
9 @3 r4 b3 p/ s& r mline4.start_point[0] = 8.6600254;
: @1 K2 ~. I( |! B% b6 @ mline4.start_point[1] = 15;
( D; E! g& x- P6 g0 ~$ l$ V F2 D mline4.start_point[2] = 0.0;
/ j& `3 @ I9 P8 W mline4.end_point[0] = -8.660254;
0 d$ c5 q( N( | V, ]/ G7 i mline4.end_point[1] = 15;7 l8 t6 d8 `- L& \3 A* l' t; E J
mline4.end_point[2] = 0.0;
; B: W! U3 c& f6 H" K# Z# L9 x9 s UF_CALL(UF_CURVE_create_line(&mline4, &line4));
/ i, x( n3 x2 p; S( q% |7 d/*line5*/
5 t- Q' _! Z6 ?& O* m4 J: v( n7 `9 m mline5.start_point[0] = -8.660254;9 `) m- R/ Z7 C' a
mline5.start_point[1] = 15;9 A, K+ o. N3 r% f# D
mline5.start_point[2] = 0;% R( h. X& O5 i1 `' } l
mline5.end_point[0] = -17.320508;5 c# \/ Q: [6 Z* A* ]
mline5.end_point[1] = 0;
; b0 N5 g4 }6 @; Z W mline5.end_point[2] = 0;! d/ `1 x/ \0 G; I# @' ^ u/ w
UF_CALL(UF_CURVE_create_line(&mline5,&line5));( n; f& b0 L# {; W v
/*line6*/
( ~ s/ z8 }9 q3 p+ j0 f mline6.start_point[0] = -17.320508;* v+ |5 M4 j: Z) \) A5 A4 i
mline6.start_point[1] = 0;
- O8 g& n& J8 G t4 {9 n2 ~ mline6.start_point[2] = 0;
: q# h+ B1 M& T8 n6 V/ }1 g mline6.end_point[0] = -8.660254;( p& K) A- r' Q& Y* w6 z3 G1 R1 O
mline6.end_point[1] = -15;/ ?4 b$ v0 |7 g8 K M8 W- o
mline6.end_point[2] = 0;
7 D: l+ O. n( w4 E+ b1 ]$ b UF_CALL(UF_CURVE_create_line(&mline6,&line6));2 ]. T" p3 f M, W* \) e
generators[0] = line1;: J- G6 Q7 Z1 y5 B0 @# m& J
generators[1] = line2;6 m, W* c9 ]% O) U( {, n3 N
generators[2] = line3;
+ E8 x* T, f% k: O generators[3] = line4;! c: Q6 _! c" @2 Q( o5 v
generators[4] = line5;
- R( O" W, V% k/ l6 Y; @ generators[5] = line6;
8 {% [5 ~$ T. n k. X9 Y" j- C; E9 P
/* Guide Line */% Y( _& h( F% c1 p) l
mguide.start_point[0] = -8.660254;
- F6 } x3 s4 ]; K N mguide.start_point[1] = -15;
/ E3 H( f5 ?3 w4 I* q8 v9 J0 [- V mguide.start_point[2] = 0.0;" y) O8 ?6 V; [! h$ z2 B
mguide.end_point[0] = -8.660254;
' L% [5 b6 d8 ^- x# r9 h mguide.end_point[1] = -15;
6 E x; t) e! a2 q( q' y% R* R4 K mguide.end_point[2] = 10;9 t4 E3 l2 y U# z
UF_CALL(UF_CURVE_create_line(&mguide, &guide));. k2 _3 S* D& M% a4 q/ J4 g& j) ^. U
% W( Q! C9 [7 v( t- v5 ~
UF_CALL(UF_MODL_create_extrusion_path(generators, 6, &guide, 1,NULL,
) A, O: d+ z3 {6 ^% w offsets, pt1, false, true,
4 x4 b" S; V6 _; K- F. | sign, &objects, &obj_cnt ));
( W- L8 g# B$ i! y$ {8 }1 u}
# o- |9 @) g3 j' g: e" m为什么生成的是片体而不是实体?! m+ G0 O1 F* O) L3 N
请高手指点 |
