0 _( n# Q8 ~8 [$ I//# i; i( C& c; E. K
// uf_first02.cpp
" Z. h( @* `; ?- W. f9 {//
2 i j7 G2 E+ y: w) E) t( c// Description:# G9 @+ g5 u! T
// Contains Unigraphics entry points for the application.3 y& g5 W: W' y+ N! Z: X
; L, c7 T8 i+ t1 c- V//////////////////////////////////////////////////////////////////////////////( i7 `, M5 p2 A& [/ E
// Include files" H" g7 ?$ w, Y* v/ l
#include <uf.h>
- L; @4 G0 B) R! J. E#include <uf_exit.h>
- G- n( F4 d6 |4 Z M#include <uf_ui.h>; l% { r+ s% J% a3 Y8 b
#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
0 x" s! w1 M {# include <strstream>6 \" }7 u& G' e
# include <iostream>
: t6 o2 e/ F- u using std: strstream;
0 \/ U0 }; X; W$ }" U0 ^ using std::endl;
5 Z& P' x9 h9 \: |* N5 F, g using std::ends;$ h+ A( F9 u: I9 R
using std::cerr;
0 o- }' `3 q2 D1 d# m( B#else$ H& r3 Y! r. h {) |5 r
# include <strstream.h>
* C2 i6 L! U0 b# include <iostream.h>: l( N5 Q8 d$ b& N
#endif
/ C% [: o5 `9 p( {#include "uf_first02.h"% p% f8 w- X& u% D) Z6 y/ i. ~
1 F+ [4 l! d! ^9 N: U7 | c// Activation Methods4 v: J# L8 ^# Z1 {+ Y% z3 ?# c- ]
$ ~, b: X s, t) ]3 n$ Z, l4 U// Unigraphics Startup. [& k$ N' b6 m
// This entry point activates the application at Unigraphics startup0 l0 L1 J: q) \5 Y' d
extern "C" DllExport void ufsta( char *param, int *returnCode, int rlen )
6 d5 l. M1 c% t$ \+ a/ B/ o{
* P0 i( {# ~( y- S+ o: R: {. i( j /* Initialize the API environment */6 L; Y# @( q/ P/ h# c
int errorCode = UF_initialize();
& Y3 s0 C* H+ }6 ]# P G; X if ( 0 == errorCode )
; s0 C7 s8 b4 L$ N; f {+ I2 t# ?: @. M. I3 [+ y
/* TODO: Add your application code here */
' w; j- D0 l' a3 _ T/ \ uc1601("hello ruan!",1);/ N0 F+ g1 R9 ]6 A# Z
/* Terminate the API environment */
5 ^' r, l' U- q, E& u- _) B errorCode = UF_terminate();0 h6 Y8 Q3 |% B7 d8 i' @
3 a! w @: n2 N0 w- G /* Print out any error messages */
1 E8 Z! s3 @% U# |( { PrintErrorMessage( errorCode );
5 N/ Z$ R" D& H0 B% m9 A# L* d3 S' t6 D}
" v4 _$ L7 R1 Z9 Q; ^//----------------------------------------------------------------------------
6 @0 q! J2 {4 I1 D) ?// Utilities' \3 E9 N' h( M7 z" y
//----------------------------------------------------------------------------5 Y/ {3 B# e, U
// Unload Handler
: R. ]% b( g% F g# x// This function specifies when to unload your application from Unigraphics.
% O. s0 y$ d/ `8 b& `3 s// If your application registers a callback (from a MenuScript item or a. F: R# O' l' \# ]0 S
// User Defined Object for example), this function MUST return3 w- I4 T0 P! J0 A. t/ P
// "UF_UNLOAD_ug_TERMINATE".- d2 k5 |8 K4 c& G" D7 X
extern "C" int ufusr_ask_unload( void )
' Y" [7 L* x8 U9 X f{
1 c) S4 t& \ t% S: u( ^3 `9 ] return( UF_UNLOAD_UG_TERMINATE );. Z' g/ i1 ~; H
}2 r2 m! R) _( ~2 L
/* PrintErrorMessage
# v _) G# d( {+ J) j O) G**
" F+ k2 |$ \% ^% {8 J** Prints error messages to standard error and the Unigraphics status9 Y; J3 m; K3 T; Q' V. Z- J/ ~
** line. */ `( }" e6 t+ C2 `0 f
static void PrintErrorMessage( int errorCode )" t5 w' E- P6 z8 a" Z# h- O
{1 W; m) ^# |* |' }
if ( 0 != errorCode )
/ b9 }+ ~/ v% M+ E1 q8 [ {
9 D& x( B3 C2 ^& V! o0 i. a4 h /* Retrieve the associated error message */
6 [5 c3 l5 T; N7 m char message[133];
& v1 N( v7 a8 G0 \2 { UF_get_fail_message( errorCode, message );. g0 K; N4 `6 m
/* Print out the message */
* z: r" A8 ^! b' x9 a UF_UI_set_status( message );
B/ [3 S3 ^" a, |( R* r2 T // Construct a buffer to hold the text.2 b$ h# C% L3 u; X% u
ostrstream error_message;
7 w( {6 {" S0 k+ p // Initialize the buffer with the required text.
6 n% ^4 V; J% g6 K3 } error_message << endl
& ^4 {+ r9 |2 M2 O << "Error:" << endl
' {- A5 q8 l% ^) G$ ` << message
! }0 w1 X% V$ k g5 D << endl << endl << ends;+ j w, ]; E- ~3 X4 f! o R2 h
// Write the message to standard error
& X2 j8 t$ f/ Q/ Z cerr << error_message.str();( R; B9 q" Y2 @4 A3 q" @6 B% C
}1 K) h9 _% [% @5 t3 J
( u/ a2 a( F) _
+ y+ t( x6 h5 {" h1 {编译时出错:--Configuration: uf_first02 - Win32 Debug--------------------7 T2 T& O& f% D% L
Compiling...! @- ~1 I. a' N6 k+ e
uf_first02.cpp
1 g( B# ^' v6 H, X3 m; ce:\open uf\uf_first02\uf_first02.cpp(11) : fatal error C1083: Cannot open include file: 'uf.h': No such file or directory
4 s' b7 _( i9 N/ p, E6 z8 t! U/ sError executing cl.exe.
- I& C" g4 |+ L! V, [4 Buf_first02.obj - 1 error(s), 0 warning(s)
. y7 a% a6 W/ s6 u: y: b: ]3 C我个人觉得很可能是安装c++时少了什么??因为装完时,还提示要装什么来着但是我的盘里没有那个东西!请教高手一般都装什么版本的? |
