如题 第一次做 不知道怎么做 8 s: @' {5 m: B
具体想做一个生成圆柱销的菜单 输入直径、长度和导角半径能够生成一个圆柱销
8 a/ l; y; o2 \! b5 r double d,c,l; : s; g' O9 v# b& w0 H( G
//定义参数
( t( g# @5 D: ]
* {: P K9 X9 ?' }% o/ `- p UF_STYLER_item_value_type_t data;
3 _2 m2 f; ]( ?& }+ \2 }2 P0 d0 g data.item_attr=UF_STYLER_VALUE;1 H; u" }7 p+ B% q5 J, i
9 n" x$ b7 i& a4 s, `( X$ M6 b3 M
data.item_id=TEST_D;" C9 T) ], S$ B! m* o. ~% b+ p
UF_STYLER_ask_value(dialog_id,&data);
' |' G9 E% l6 K' b, g+ y; n C d=data.value.real;
/ ~; l. j. k) T0 d I & h0 B! g. V4 ^" F
data.item_id=TEST_L;
, V8 U# q( f, K, O% ] UF_STYLER_ask_value(dialog_id,&data);
4 X: [: C$ y' f8 D l=data.value.real;0 u) u! d; q) p
data.item_id=TEST_C;- z* d* @+ [( T5 T5 \
- B. Q# X- m2 u1 G3 e" V' @ c=data.value.real;& Y6 e* V! h/ W, g+ J& L1 K
//获取对话框数值8 u s! W3 s. M( K% ?* T
int body;char height[256];char diam[256];tag_t cyl_tag;+ N$ ~1 J* q9 o/ q9 g3 v/ x8 ]
double origin[3]={0,0,0};, s" ]# k- r3 s4 v" M [+ m9 x' w; L
double direction[3]={0,0,1};
3 v. q5 I+ f( f. z* o% }5 E height[0]='\0';
D) G5 n8 X3 Q) L' z) C) _* Z diam[0]='\0';* y; Q! N8 y4 {0 q3 } V, A
sprintf(height,"%f",l);4 p& F `% I. D3 Y5 C+ ^5 L% `. Z! o
sprintf(diam,"%f",d);
) G+ H6 v j0 K" p! G1 G5 n body=UF_MODL_create_cyl1(UF_NULLSIGN,origin,height,diam,direction,&cyl_tag);
' `7 ^, {& G8 t //创建圆柱体. V( z6 ~( q, H0 L( s" j
tag_t cyl_body_tag;
. ~7 ^8 f. J/ T6 z) } UF_MODL_ask_feat_body(cyl_tag,cyl_body_tag);/ Z C% E6 Q3 U
uf_list_p_t edge_list;tag_t edge_tag;
2 y2 S, C4 _; p1 c9 R5 z& k UF_MODL_ask_body_edges(cyl_body_tag, edge_list); d1 Z8 `4 o# I7 @& j6 G, l, m
UF_MODL_put_list_item(edge_list,edge_tag)! @+ i8 i8 `/ |) D z3 A
//获取倒角特征
, d+ r/ L, T$ B) m UF_MODL_create_edge_blend(data,edge_tag);/ w* j9 m- {$ E3 S6 v% g4 ~, r
: A/ V. u6 s4 n: i8 Y$ [
UF_terminate (); |
