三者的关系我在以前的文章中讲过了。但是他们都不是孤立的,互相可以使用。
. K5 p Q- J: T: ^下面举了个不同部分用不同的代码,
_3 h* m ]! |2 g" ?/ H函数形式的是Open C,也就是API了6 {: k& C$ t6 X7 _" T$ z' H, P
类形式不带NXOpen的是Open C++,否则是NXOpen C++了。. Y+ [% G- Q6 C) @. @
Tag是所有之间的桥梁。
/ g0 j1 H- \- w; {//NXOpen header files. x7 r( k' }7 ~+ C+ v
#include <NXOpen/Session.hxx>
2 R9 u, T& k. }( F, A# x; x#include <NXOpen/Part.hxx>
% w( g: r) b1 s4 O5 Z#include <NXOpen/PartCollection.hxx>
4 f! L+ a6 r0 X* S/ a" V//#include <NXOpen/Point.hxx>2 g* O2 ~. }0 Y! m0 X' ^: c
#include <NXOpen/Line.hxx>
2 j0 j( x. t1 U8 F# y5 }#include <NXOpen/CurveCollection.hxx>% n3 b. Y* e. _! Q- T
#include <NXOpen/Arc.hxx># X T2 \- j5 M/ r9 l, |5 A
#include <NXOpen/NXObjectManager.hxx>3 D) v/ o/ V. u* i6 w- ?& W4 V1 y$ m2 _
//#include <NXOpen/NXString.hxx>: ?/ R* q9 U7 |+ S* ?0 W; T
//UFunc Headers% Y5 s3 _* v, C' a. B
#include <uf_curve.h>
8 ~! T2 l5 y: n H#include <uf.h>
9 K6 P6 n9 K1 R" Y) s: r7 m+ `#include <uf_csys.h>
6 F8 m t1 @6 \/ c1 ^2 }#include <uf_part.h>& J) P/ {" y9 d! x9 q) a. Y
// ugOpen headers2 p& l* ~/ F6 E: F; k$ @- o
#include <UG_session.hxx>
/ V1 c9 L P' G! e5 x2 c6 c3 ]#include <ug_part.hxx>
0 c. U5 T4 u8 C% a#include <ug_line.hxx>
* g7 d4 J$ a b0 |( | B#include <ug_arc.hxx>4 B0 x% m d, T' O( I+ u
#include <ug_coord_sys.hxx>
5 F% q! y2 M' H8 k7 _% |- i#include <coord_sys.hxx>
s2 |% Z1 l3 H: y: y% A9 Oint main(int argc, char* argv[])& Z3 q( |+ V% r2 I2 U6 \
...{/ {. M, S% B# m X" }. Z
int errorCode;
2 f0 ^: O( C* u* q, Q: s /**//* Here, we can initialize session using :
! \- B* Z$ I+ X- V& C! x 1. Open C API environment
, w5 Z+ \! d1 n' v. \ 2. Open C++ API environment: S$ [8 U9 U1 L8 I2 C& K
3. NX Open C++ APIs.
( s( ]0 e/ s% V( w. ] User has to initialize, UG Session using Open C++ as well as NX Open C++, session
3 w3 U1 \6 D( X/ [5 P m( H4 D8 p. J also.
; D7 T$ f% U5 s& { */+ h" k4 I. Q- t6 u: \
/**//* Using Open C API, we can initialize UGSession as follows */
6 u. h9 n( p$ P* j! I. P2 T. V /**//*5 x3 B' X2 F. h+ i" z0 o
errorCode = UF_initialize();
% }% n3 }6 i. o4 c3 v if ( 0 != errorCode ) 6 v& ~ g6 U6 x$ Z- c y5 x& i
{ / |2 \7 V7 h, c
return errorCode; ) B# A8 y2 G h' \+ k
; e. P1 s2 X6 Z: z1 k/ @ */
: A" J, Y. I% s# Q1 y) H9 c6 z% M) p
4 [1 N! K. I1 B+ U NXOpen: art *part1;7 ^- Q8 G) P; i! V1 W5 `, p2 T( S
/**//* Using Open C++ API, we can initialize UGSession as follows */. O$ H( g" V- S% H+ ]
UgSession::initialize();
1 Z8 K3 P1 ]( O4 I 1 u7 m6 X8 x# f0 I& |; y
/**//* Using NX Open C++ API, we can initialize UGSession as follows */
, k0 D$ Q0 O1 X( O NXOpen::Session *theSession = NXOpen::Session::GetSession();6 p3 w6 ]/ x. A, |+ k9 [
/**//* Create a new part. + L- U. ^8 @4 r1 y z: G
To create new part one can use :
# q, s" @% B+ A 1. Open C API environment
( m2 d7 F+ m- M1 }4 m! u! k% ` 2. Open C++ API environment
; W/ S, e* x1 q9 G: d) n5 b$ | 3. NX Open C++ APIs.
: J: f& b6 \5 y$ \5 x1 T! o */0 l/ o# z# _" _2 x! G. @: ^
char* partName = "InteropWithOpenCOpenCPPAndNXOpenCPP.prt";' X( X& G: @0 @* b+ }+ l
/**//* Using Open C API, we can create new part as follows */
/ [* X" f* X5 z5 P5 P6 S /**//*
! a) |' N% J) v3 w tag_t UF_partTag;/ M$ J% B E1 n$ L9 g: ?6 s
UF_PART_new(partName,2,&UF_partTag);
' Z1 e0 M8 p; `/ ^1 j6 O */
/ T3 |% i7 s( z0 }% X /**//* Using Open C++ API, we can create new part as follows */) U! g1 z4 L: \! h* F3 k! D
UgPart *UGPart = UgPart::create(partName, Inches );
; g8 k% a1 i* A' S+ j6 C/ ?' @ /**//* Using NX Open C++ API, we can create new part as follows */4 Z$ j: b1 q0 U, H! [
5 o3 n6 h& [$ y% d4 i NXOpen::NXString partName = "InteropWithOpenCOpenCPPAndNXOpenCPP.prt";; X6 `$ h" u f! S/ N; d
part1 = theSession->GetParts()->NewDisplay(partName, NXOpen: art::UnitsInches);
% u6 i6 `6 X5 V& C' d. _, h& Y */
7 f! B9 E+ d1 F5 v& @ c
3 b) a8 X+ k4 [- V' G' Q: V //--------------------------------------------------------------------------
" ~ {2 i3 l7 u Z // Interop between NX Open C++ APIs and Open C
# |4 N, c# U e+ S7 }1 Q /**//* Create a line using NX Open C++ APIs*/ P, N/ }. p) R6 F& N* i# D
NXOpen: oint3d point3d1(-2.17019791346668, 1.13935390457001, 0);
' u( s; S7 F1 B G/ v6 T u NXOpen: oint3d point3d2(-0.714356813182783, 1.13935390457001, 0);
v, }/ T; O5 q8 u( H7 P/ l NXOpen: ine *line1;
& S) X- r: ?/ M; T6 O$ q- b line1 = theSession->GetParts()->GetWork()->GetCurves()->CreateLine(point3d1, point3d2);
, z' Q l4 M0 E1 F+ ?0 J M% @ /**//* Retrieve line coordinates using Open C API */; K8 d5 S1 I8 u8 T _3 {/ F
tag_t line_tag=line1->GetTag();+ I: x+ A) y1 e* _ k Q
UF_CURVE_line_t line_coords;
6 c) ]5 C+ z+ d$ E3 h8 D/ G UF_CURVE_ask_line_data(line_tag, &line_coords);9 C# h- Y4 x* u' E$ }
& j8 L7 ?0 }3 R) |) k) s4 b // Interop between Open C++ and NX Open C++ APIs# s. C+ G/ t- p& ^2 c* ~0 s# g
Point3 UGPt1(line_coords.start_point[0]+5,line_coords.start_point[1]+5, line_coords.start_point[2]+5);5 \: ]+ d" Q" D
Point3 UGPt2(line_coords.end_point[0]+5,line_coords.end_point[1], line_coords.end_point[2]);" |3 ^' o X! g; @
UgLine* UGLine;8 d; U7 ?! F- z/ n. g+ u( @4 m% P
UGLine = UgLine::create(UGPt1, UGPt2);
8 j+ M( o8 q! H6 I$ [ UgCoordSys *UGCoordsys;
; L( i7 o' A) _* n) c. C UGCoordsys = UgSession::getWCS();1 h& S6 b- ~, O6 J$ b* y, u" {3 O$ o
CoordSys Sys = UGCoordsys->getCoordSys();
! h! \# H9 F, K0 a. k8 D // Creating Arc
* y: D* l( T( N8 [ UgArc* OpenCPPArc = UgArc::create(5.0, 0.25, 3.14, Sys);
% Y) {' n5 X5 S tag_t arc_tag = OpenCPPArc->getTag();
% T. k5 ^& d5 ]: |& }1 }0 E NXOpen::Arc *nxArc = (NXOpen::Arc*)NXOpen::NXObjectManager::Get(arc_tag);3 F2 l5 f# R5 E8 j% ]6 S% \8 _
double nxArc_radius = nxArc->GetRadius();7 Q! A3 M' `& c e, Y' p6 z
double nxArc_start_angle = nxArc->GetStartAngle();
& i% J# ~& o3 B; K: a! \" w double nxArc_end_angle = nxArc->GetEndAngle();& r6 I3 g% @: r" e
6 m% k% Y- N4 U2 H
2 X: }# c8 q, \# n4 f: J2 v /**//* Save this work part. 2 F: M9 f3 c' n+ Z& L* l
To save this work part one can use :5 z$ v$ ]+ [8 Q* s2 I
/ g: v0 B! V$ D% d" ] ]6 ]. [ 2. Open C++ API environment) A. Y# G2 G8 V
3. NX Open C++ APIs.9 y. W8 b" |* H3 Z# {
*/( H" p7 j- _0 S& }
/**//* Using Open C API, we can save this part as follows */% u2 U. q0 t6 y, x8 }& R
/**//* / j! b. w9 o K! l. P- O
UF_PART_save();( C& k) o0 O8 Q/ @# g( n- Y1 a
) M3 r C* w/ L2 X& ^ /**//* Using Open C++ API, we can save this part as follows */- a& a L9 N! X u
/**//*# C) z* P5 e$ T/ l
UGPart->save();" J, h) b! @+ R% _+ h5 y
7 b3 \0 }$ p7 T5 M
" ]* j6 u) H! U) f# ^ /**//* Using NX Open C++ API, we can save this part as follows */
0 [, P- f0 }9 N. ?, b0 R /**//* To get the part from the Part tag */
9 }5 N$ ]* k+ A" G5 z part1 = (NXOpen: art*)NXOpen::NXObjectManager::Get(UGPart->getTag());0 k: _7 e; l( o. R1 m! u
/**//* To save work part using NXOpen automation APIs */
- F" J: D" q* Z: Z NXOpen: artSaveStatus *partSaveStatus;% ^( l& k" g3 n3 n+ r
part1->Save(NXOpen: art::SaveComponentsTrue, NXOpen: art::CloseAfterSaveTrue, &partSaveStatus);
# v9 G* K, [, S0 Q, }! `: f1 c! P /**//* To close all parts using NXOpen automation APIs */0 c( ~9 l$ v' R' Y/ G4 R" d! ? L
theSession->GetParts()->CloseAll(NXOpen: art::CloseModifiedCloseModified, NULL);
- i$ b1 U9 K/ E2 e5 q, X/ W; m
3 k# {. b! T- j' k: D2 m /**//* Terminate the session using Open C API */2 }8 n. W" x+ m; W
errorCode = UF_terminate(); S" m8 R% d& i
return 0;# x% y& Q9 d2 J/ l$ `' F* `: X' L6 M
