UF_ROUTE_ask_app_view_sys_ints- r! t; B1 u8 C. ]6 e( Q
UF_ROUTE_fix_stale_stock( u" W: j; W1 Y
UF_WELD_locate_welds
* m2 M ?# g( H$ `$ Y" iUF_UI_ugmgr_ask_create_part_name
9 A. F, K7 Z+ n5 m; \% P6 AUF_PART_name_for_display
1 |2 u7 ]* P* P9 q4 u0 t" wUF_UGMGR_decode_part_filename* C6 H- v- z! e, [2 B/ ?
UF_UGMGR_convert_name_to_cli
# p8 p5 E1 k3 ^& gUF_UGMGR_add_product_assembly
7 S, K4 [1 X. \; B9 h0 F0 j0 RUF_UGMGR_remove_prodcut_assembly
4 `: V) D5 h' q& p1 _1 E; yUF_SF_POST_create_combined_lcase7 N/ d9 u# p6 C: L* k4 W
UF_SF_POST_delete_combined_lcase* `9 z3 e; G7 [0 z: t
UF_SF_POST_display_results
* [1 @7 F) C% ^! f) S9 {9 c0 eUF_SF_POST_exit_overlay. u2 |) u4 s% j+ Q
UF_SF_POST_export_display_to_text
' f- _3 u, E3 q9 `$ SUF_SF_POST_export_vrml
7 F4 \, j/ q5 \$ yUF_SF_POST_get_component_unit_tag
( U! n; Y8 z( X3 @UF_SF_POST_get_unit_tag: E! m0 V0 l7 ~$ B+ p
UF_SF_POST_initialize_clip_params6 \" t* v3 u+ _$ }. v) s r
UF_SF_PSOT_initialize_def_disp_params6 @$ \+ `) `1 S% C1 ?0 `
UF_SF_POST_initialize_def_scale_params- z$ ]. a8 w: [/ j( w* |8 o! X
UF_SF_POST_initialize_deformed_result_params
9 T6 B9 [. P; X. E3 q; r7 c& qUF_SF_POST_initialize_fringe_params
. s" N( `- S+ U- ?& R6 AUF_SF_POST_initialize_ident_params5 U8 \( d0 s3 h: D( s
UF_SF_POST_initialize_result_parms1 j' ?. N% v/ P8 R: q; B
UF_SF_POST_initialize_undef_disp_params
8 t: `5 z/ q9 nUF_SF_POST_mark_setting- s# n5 i5 y2 ?- k, |# z4 T
UF_SF_POST_overlay
) @3 P1 F( h1 \" F8 `3 O1 Y8 `4 a- ^UF_SF_POST_remove_overlay
3 D, Y9 N8 ^0 K/ a N6 jUF_SF_POST_select_deformed_results
' g4 T ]/ h+ C% h. }0 u' IUF_SF_POST_select_results
( E0 u3 |$ b8 w- B5 I0 V- }UF_SF_POST_set_clippings- Q) \3 o8 T2 S0 `: {
UF_SF_POST_set_def_disp_params! @" |- ~! E4 i8 D# U8 }- U& R
UF_SF_POST_set_fringe_params7 N5 L- `; Y6 {' a3 ~0 i
UF_SF_POST_set_undef_disp_params
{$ q1 T% l- I& B$ O* AUF_SF_POST_write_ident_data2 z! r8 [* G$ U8 N
UF_SF_marker_display
+ K0 \' r& I7 qUF_SF_POST_get_result_params
; i5 j& S6 \+ r3 | w& @UF_SF_POST_get_result_iters9 u9 k" i) H" A$ _' |) s9 a
UF_SF_POST_get_id_result
( z" _9 |$ T: tUF_SF_POST_get_fringe_params9 N! c( {" I& ]; D/ L4 S* ?
UF_SF_POST_get_def_disp_params
$ H4 S6 \1 _/ O5 m9 rUF_SF_POST_get_undef_disp_params
( F/ J% i2 V( K) d0 B( R' |3 RUF_SF_POST_get_clipping
; B+ L) N: L- J @$ GUF_SF_POST_get_deformed_results* k& ^& i7 d9 {9 [' |
UF_SF_POST_get_import_result_filename2 P% C7 P+ F4 D; |- c: n
UF_ASSEM_ask_mc_data_of_compnt- A0 t4 s4 p6 ~9 W1 Z! O! y6 w
UF_ASSEM_solve_mc' ~' q% A. k* P2 P2 E3 K5 D% Q- m
UF_ASSEM_init_mc
' [" Z0 c9 p+ E9 z0 r7 `5 fUF_ASSEM_check_mc_structure
( l3 K( i# k1 ~7 J( ~UF_ASSEM_apply_mc_data
- @4 t# X- Y* j, S6 {7 o; d* o: kUF_ASSEM_delete_mc& |8 U8 ]) ?7 G
UF_ASSEM_ask_comps_mated_to_me
& p) j* F! O7 h; T" XUF_ASSEM_create_suppressed_mc
" R/ b' O2 a% V& D3 I, VUF_ASSEM_suppressed_mc
% z3 R. j8 s% F7 V& s4 j4 A6 }
& N0 R6 Q# A5 M7 l, `. {0 N+ G. N/ _. D, h+ A! w* K$ v
ENUMS:2 w; c) b: r$ p5 G$ m* |
UF_ASSEM_load_status_e
+ @3 \( r3 c! |! x4 H: ~1 u# T* r+ EUF_ASSEM_mc_status_e
3 L: _4 ~/ d/ p/ MUF_ASSEM_mc_structure_state_e ; L }# q. d% t
+ u7 H( p! n" l9 _Structures:
% ~8 N1 R. |" z4 q, Y% eUF_ASSEM_dof_s
0 j$ x |. c9 [9 m/ j* M/ I" iUF_ASSEM_constraint_s- ^4 O8 c$ [/ u8 j3 ?, j
UF_ASSEM_mating_condition_s
" V1 |1 B4 L" t3 Y$ d; p& t
. ~% u; H) C" W#defines:, m' ?1 l |/ j" }
UF_ASSEM_MAX_CONSTRAINTS
1 n$ k# G/ f3 lUF_ASSEM_planar_face+ O6 I! R1 s* R
UF_ASSEM_cylindrical_face
2 g6 }( l. D' C* L- d- N* m& m3 H& JUF_ASSEM_conical_face
" {' `9 Y( w3 R' d) S4 }8 iUF_ASSEM_toroidal_face; e1 m) [* P3 K" U S
UF_ASSEM_spherical_face
3 m2 V$ I3 T& k) yUF_ASSEM_axi_sym_face6 H# y9 s7 d+ c& W5 g+ G- L
UF_ASSEM_straight_edge, z4 h: H. Y% N7 v# f5 U0 ]5 p
UF_ASSEM_datum_plane
* r7 b7 n) s+ |- w6 }" bUF_ASSEM_datum_axis! _$ p8 {1 J) N) J% i, ^- x7 r# C
UF_ASSEM_csys
: p& k1 P+ P8 I: z6 YUF_ASSEM_component
' T4 T( Y I, }; c* iUF_ASSEM_point* s; e# z! ]0 ~: O4 c2 h
UF_ASSEM_line- Z# a' y t. m% h9 a2 ^2 b$ i
UF_ASSEM_circle_edge0 H7 A3 v- n. v' U: L. ?3 K2 F2 h
UF_ASSEM_circle
9 D$ a; n+ R( E g4 I# C0 WUF_ASSEM_spline
' b% t1 E( ^+ O8 f, hUF_ASSEM_port
, P" y0 g% [/ _0 k7 NUF_ASSEM_parametric_face$ h/ f* W) h$ n* k! n" g- x, m
UF_ASSEM_mate! S2 u; [7 T6 ~
UF_ASSEM_align7 Q: w9 B; S! T
UF_ASSEM_orient- K$ W( [( `6 G/ R. O/ P
UF_ASSEM_v16_mate
- W7 V, n& ~2 C+ z$ }( SUF_ASSEM_v16_align
, `2 T1 F8 p7 V' FUF_ASSEM_angle
& Q o" l) o+ pUF_ASSEM_distance
7 q {+ E4 T, i# s4 |5 F# N1 fUF_ASSEM_parallel- l8 w1 [7 P! h0 c7 l) {- g$ _
UF_ASSEM_perpendicular
) b9 F) b, I; ^ y) y2 z9 e( lUF_ASSEM_center+ B) \2 P* ~: {4 W- M* }
UF_ASSEM_tangent/ o2 h9 X+ v# _+ Q- y0 c! l
UF_ASSEM_planar_angle' b2 X; F( b- `' W
UF_ASSEM_3d_angle% O6 m6 I# f7 K1 Y! @- n8 |
UF_ASSEM_center_1_to_1. u& o/ s! [ V
UF_ASSEM_center_1_to_2
1 t5 e% E# C- U/ [9 f3 b" \UF_ASSEM_center_2_to_1
* g7 u. I3 a, l7 V+ B: }UF_ASSEM_center_2_to_2' L: D1 L4 A$ Y' ~
UF_ASSEM_has_no_help_point
& m/ D1 ~% K0 C$ z1 J' c8 @UF_ASSEM_has_help_point_on_from
1 K0 Q( F$ c, O8 d7 p2 XUF_ASSEM_has_help_point_on_to
9 f, }% S: v7 p: G& l, j' q/ XUF_ASSEM_has_help_point_on_both |
