下面是我编写的创建焊接标注的程序,但是执行后,只出现点,并未出现焊接标注,大家帮忙看看代码有什么问题,多谢!. S) |3 l n8 v; G& s' u
5 D4 H6 K* @: h4 N6 ]6 W- Y Copyright (c) 1999 Unigraphics Solutions, Inc.
; z! e) V, M4 l/ ]" v Unpublished - All Rights Reserved
8 K. w, W6 t1 v' j$ Z*******************************************************************************/
3 a1 J9 G: D& H5 H2 ^, q) }/* This example creates a weld symbol. *// A& Y. j# _) i: k
#include <stdio.h>
" C+ _& N% C" r#include <string.h>
0 m4 o; d' i6 D) d, P#include "uf.h"5 _1 J. F, l M- {* F/ v
#include "uf_defs.h"' ]3 g3 E) J+ J4 a; N; F
#include "uf_drf.h"
6 H5 g, q8 ?# l4 h" B% H8 @ ~8 x9 F#include "uf_curve.h"" q% A+ G$ z0 A
void ufusr(char *param, int *retcod, int param_len)
/ k+ Q2 }, K4 ?{
5 K7 n A! Z: c9 p! f int status = 0;, x& J# X# d$ j5 t7 F& X) ^9 O9 x
static double origin[3] = {20.0, 0.0, 0.0};8 \! o3 Y7 V* x& _# f! O" W
static double base_pt[3] = {20.0, 100.0, 0.0};
7 W. ?# Z/ N% D4 S! n //char **text=NULL;# K' d: S- @4 M1 ~) K3 ]& t; w8 G
char *text[2]={NULL,NULL};
! S2 x# ~1 C2 r" P2 { //char text1[133];
5 A K6 M& ?% ~& J //strcpy(text1, "This is a LABEL.");
5 s* z! ]6 o! q; R/ G% d0 N tag_t base_pt_tag;
% ]" f) }# N) y8 _6 J8 ^" g' S tag_p_t weld_symbol_tag=NULL_TAG;1 ~' l) g# X7 N; W) T
UF_DRF_weld_symbols_p_t weld_symbol_data=NULL;- @7 V. Z& k# \' s4 E( k! d
UF_DRF_weld_sym_info_t sym_info_top;
/ ]" J+ z% H7 j7 X1 {! q9 ?6 K UF_DRF_weld_sym_info_t sym_info_bottom;
- M" Q- b3 M/ T6 G UF_DRF_object_t object;. }- q, o/ {* b. ^3 S
char stat_msg[133];! J2 M! R) |9 @- R
status = UF_initialize();
! d `8 ^* c- Q4 i7 M/ P. I if (!status)
* H% |, p! c. J2 B1 W! Y Y {0 f, ^" k4 J& ]$ G. V
/* initialize the object structures */: s* G0 J5 M6 n# l+ k; c/ \4 W$ J: Z
UF_DRF_init_object_structure(&object);1 A0 P R+ D3 W
/* create a base point */
$ O; M, D# _ j9 `5 e status = UF_CURVE_create_point(base_pt, &base_pt_tag);( P q- I4 `1 x% e" t0 i, b5 i
3 [: @+ w1 @0 K: v; X$ s: i if (!status)
: z; j) {0 Y4 m( F5 Q3 X2 g {+ S+ p d' n5 D: j/ r* d! m
/* Creates the weld symbol */
8 Z# B. M7 D3 ^+ [$ b" n //sym_info_top.angle=text1;
0 S; d8 f! n- \+ t: l object.object_tag = base_pt_tag;
! i9 Z% z$ U9 ^# v4 ]: F object.object_view_tag = NULL_TAG;9 G: T! }3 E# p% B5 [8 M! R1 E: B
object.object_assoc_type = UF_DRF_end_point;: d6 V9 T. S4 B- U4 q
object.object_assoc_modifier = UF_DRF_first_end_point;$ |$ [( e1 l0 e4 O+ G
strcpy_s(sym_info_top.angle,133,"30");) D& A! |7 \$ r5 `' A0 q
sym_info_top.contour_type = UF_DRF_WELD_CONVEX;; l$ J, ^* A' H% w7 F, z6 V
sym_info_top.finish_type = UF_DRF_WELD_CHIP_FINISH;* y3 T( v' n q' a l) `
strcpy_s(sym_info_top.num_root_depth,133,"8");! M. f) Y9 t4 F( Y/ v( Z7 n9 a% q
strcpy_s(sym_info_top.pitch,133,"30");
/ _0 G! G4 b/ `- U strcpy_s(sym_info_top.size,133,"20");! z3 o! u1 |. U" Z6 g* o
//sym_info_top.pitch = 30;, h3 \. t9 E- L. x8 V% |4 @7 i
//sym_info_top.size = 20;
8 h9 l+ J0 ^; l$ D5 K) Q5 Q sym_info_top.size_code = UF_DRF_WELD_CODE_A;
$ d4 V, _; M6 C! G/ g sym_info_top.weld_type = UF_DRF_WELD_BUTT_WITH_RE_SYMBOL;
- K2 I" Q, ] e/ \: b8 `% {, k strcpy_s(sym_info_bottom.angle,133,NULL);) y" @8 T$ W n2 `$ Q
sym_info_bottom.contour_type = UF_DRF_WELD_NONE;
4 S9 r) L5 |' m5 k+ c sym_info_bottom.finish_type = UF_DRF_WELD_NO_FINISH;
. o- v. ~ l F+ Z$ W3 D strcpy_s(sym_info_bottom.num_root_depth,133,NULL);4 p! X3 R) b5 ?* } V
strcpy_s(sym_info_bottom.pitch,133,NULL);/ z7 O- g& ~/ g- N
strcpy_s(sym_info_bottom.size,133,NULL);# p1 j& Z3 u9 p+ ?9 X1 R7 q8 ^: r
sym_info_bottom.size_code = UF_DRF_WELD_NO_CODE;7 J/ y# }- }- x q9 f
sym_info_bottom.weld_type = UF_DRF_WELD_NO_SYMBOL;
2 S9 R9 w, J8 k/ ~: J //text[0]=new char[133];: I) w; }# g7 N, G
//text[1]=new char[133];8 S+ E8 M7 a1 T: l5 ]0 H R5 |- o
strcpy_s(text[0],133,"asdf");& _- m) O5 @! D
strcpy_s(text[1],133,"1234");8 T( L( D4 q0 h/ J3 }
weld_symbol_data->center_flag = 1;
8 k6 ^1 l. e4 Q# @1 G! U+ h weld_symbol_data->extension = UF_DRF_WELD_SYM_EXT_DOG_LEG;0 @! v' E- P6 G" J
weld_symbol_data->field_flag = 1;
p. Y5 L( Z! s+ r* Y4 X" I% H& @ weld_symbol_data->ident_line_type = UF_DRF_WELD_SYM_IDENT_LINE_TOP;0 k* ^) J- [2 C4 c# U! S7 h, C
weld_symbol_data->num_lines = 2;/ u' X, w. |% _/ \* {
weld_symbol_data->peripheral_flag = 1;* X4 \- h9 {* A/ @" p' D% s- B3 m
weld_symbol_data->reference_text = text;
5 o% q2 D" f4 A2 k weld_symbol_data->scale_factor = 100;
/ V9 ~+ E& v! A, T* }/ ? weld_symbol_data->staggered_flag = 1;% C1 g5 `8 }% p( h$ P
weld_symbol_data->sym_info_bottom = sym_info_bottom;
+ e" x3 _0 E: Y" f6 \8 @) a weld_symbol_data->sym_info_top = sym_info_top;2 U, V0 A/ {2 G- H
strcpy_s(weld_symbol_data->symbol_standard,31,"ISO");
+ r) |" o" j& ~ /*" t7 M) r& g: y* T
int UF_DRF_create_weld_symbol6 V( q B5 K! R) K x0 s& ~9 h$ p0 b
5 S' y7 ~2 ] D6 A* j% j double origin_3d [ 3 ] ,
! l3 `1 N/ P! y q; a- Y1 ]+ D, I UF_DRF_leader_attach_type_t leader_attach_type, 6 |2 z8 F. `4 {& e# ^
UF_DRF_object_p_t object,
0 u& ~; o8 B1 t9 C double model_pos_3d [ 3 ] , & l( M% Z v# N7 F
UF_DRF_weld_symbols_p_t weld_symbol_data, # N. M' I( u0 B# g$ G" V. ~
) T" Z4 j/ L9 u) @ )
# @( P9 A+ B+ v- G- \' Y* t */6 [2 v- v: C4 `$ A
status = UF_DRF_create_weld_symbol(2 c" z" q/ [* v! @7 }
origin,
) f$ w& b1 K+ G0 E+ O9 N; d3 {2 V UF_DRF_leader_attach_screen,
( c+ G$ D$ W: m &object, 5 T0 w5 D1 Y: S7 x' L* @
base_pt ,
- B5 d k8 l+ W$ x( [ weld_symbol_data,
+ h! X& D8 r& S- p* F5 ?$ q5 c weld_symbol_tag);
5 Z) ]; y. m/ e5 Z! p/ _ }0 A$ `" x% j% N& [% K4 v
printf("UF_DRF_create_weld_symbol ");" V2 z$ _8 k+ G1 `% M1 G% k
if (status)' O( X& f$ W( V( y/ x/ ~
9 n: j4 Y0 s; u) c: S UF_get_fail_message(status, stat_msg);
# p6 r, V" @. S* z printf("has ERROR %d: %s.\n", status, stat_msg);. ~# q1 T. q. M2 E7 b7 E" T( r
0 g C& l: a& D% {1 Q# v else
. h0 ]/ o% p" n' r9 n' } printf("is successful.\n");
# M: Y: L1 y& y# G. X( b, o UF_terminate();
5 D- H4 Y3 e+ F5 {( V( `# r# y+ @1 Y9 g
