查看: 24332|回复: 8
关于UG 4.0补丁的问题,也就是升级包
发表于 2009-9-30 11:23 | 显示全部楼层 |阅读模式
Date:               4 Feb 20099 ?) t- g) X. |/ D! `
8 J/ @. a4 [+ d' ?5 p
Subject:           Maintenance Pack 10 for NX 4.0.4
% c! q/ j' S& f1 @* U- f
$ i9 w6 G: k: S* w6 Y* L, K! TTo:                   All users of NX 4.0.49 y4 e$ q" f  Z/ X
% c" |. K$ j1 X) yFrom:              The Siemens NX Team
) A. b6 q1 w4 V1 c  R+ B' I) k7 n9 N3 ^$ m7 R* I! |  t# e
, }; Z  N/ A* B/ e( c
" Y9 F* C. X- J% u& J/ r5 @3 ~$ A8 u9 e5 Z
We are pleased to inform you that fixes are available for the problems listed below.  A maintenance pack (MP10), built for installation on top of Windows XP32, Windows XP64, Sun/Solaris, and HP-UX images of NX 4.0.4, can now be downloaded from the ugS FTP server.  This maintenance pack fixes an accumulation of problems listed in the tables below.
  y+ D8 M. d2 e* ?: p/ T6 Y+ x$ `6 c, { 7 v; V9 [* y7 [1 }: q* r/ [) }
: H$ Z2 M- Z6 y$ G! I$ CRelease+ h# _( [, c; c% z
PR Number" u2 e, x$ l. y& w4 S" N
Problem Description% r6 M. H% N) e4 O) i0 @
& x! ^6 D2 D8 U
MP1
. d9 u$ X- I- L2 ]1 t% U 1373242
% e8 q0 B8 l# R0 z The problem in Translator where it took a long time to import Catia V4 files is fixed.+ V& n* A: r8 u
7 I: Q) `4 E) \# V3 a* s4 h2 }2 hMP1% H" F7 Z0 U8 N) s! j. `. _7 F; L( o
1394922 1589456
( Y+ L0 H! @, x" e' f& M2 w The problem in Translator where dimension values changed after export to 2D is fixed.: Q+ \3 e7 c, r
$ H  |/ }! X6 E$ k6 s) I4 L
MP1$ {/ b4 a; E/ o( ~# S: i
14183285 l& p5 k. X* R) p' S( [' v! P
The problem in Drafting where a CGM file could not be created in some cases is fixed.
2 l( |1 Q6 d+ [/ J
: l( z" A) y3 u9 r$ lMP1* `6 P3 `# t2 d
1481242 1481271 55770527 v' i8 x2 W2 x( S- E! ]
The problem where the part family members could not be Saved As to an altrep under the same item revision is fixed.
% d# R, `: A; S) B3 E3 D" t/ _
1 M0 o; n& O# N# PMP1
; v% J/ M6 r! ^4 h 1499572
. V# l  c5 w$ `" I8 ^& Q* D The problem in Assemblies where deleting deformed part components caused errors in some cases is fixed.
/ z( M# a. f) }, [8 {. }9 v8 Z5 z( x : V0 R% V+ ?" G3 L# y
MP13 Y. ~! `6 ~* c7 K8 S7 {
1518293 1588742
; S2 r! u0 E, [( y- {5 v$ x2 L% j; n The problem where the part entry list found in the Window main menu did not reflect changes made to the part name style Specified Attribute unless the part was reopened is fixed.2 M2 U9 N$ E: X/ \6 d
; h% u# y9 d1 E2 w9 q) Q: z' \/ e/ n
MP16 B/ v( z" z+ W' E0 f1 R/ Q& e
1537177 1586101 1586727" L- W  c4 f0 }' f! R% n
The problem where a JT file could not be exported twice is fixed.
. [0 B4 e$ c9 t* ]
7 D% @# X! n2 n; w5 CMP1' r7 c# t- D9 v/ c+ u7 z' R
1561122 1595028 5745783
5 _% ^# D: `2 p* r7 k4 ~ The problem where the expressions in a UDF were not copied or renamed properly is fixed.
! e0 E; Q: B# \1 m2 B; y
" Q9 a9 j. Y: m  V  P, {) j2 aMP1( T  E( n# Z+ T- u# c
1567176 1594990 15938189 P, M( z. s+ S$ U. v
The problem where the Save As did not work with CAM setup template is fixed.9 i# d$ |7 ?4 e/ x5 x
6 P+ ~( `- A3 a, FMP1" @$ x9 g% Q; p& m- S
1569845# f, V' ^1 y& @8 \8 @
The problem in Drafting where associative notes were not placed correctly when importing a part is fixed., H1 Q. T( u5 T6 _3 ~
4 x! J. N& O' ]$ E* f
MP16 j; {7 R4 t: a! ~  V
1571948
8 q4 `4 @% M5 n* ` The problem in Translator where a re-migrated assembly throUGh CMM lost mating conditions is fixed.
0 w1 D' u7 u; ^* O9 B. H : u1 Q- Z2 w" G; d; `" J( Q
MP10 U. X% C/ b( s* F( }0 y
1573431 15944272 ]3 Z. J2 d/ }( x2 U# X
The problem where the UDF did not keep the expression value set to another expression is fixed.* y( A, T$ H) N; A
, a& f) b  |+ i1 K3 VMP1
0 a& a! j% G% w% k, z" a( a 1576448 1593034 5719139
( B2 S# D+ w9 x9 U1 y0 j6 v; B The problem in Assemblies where importing a part gave errors in some cases is fixed.
5 K% R/ @/ d$ N( O9 q $ c" b0 N3 V' Q5 t% b% q/ s/ w
MP1% ?! ]* b5 v1 n* A1 J& D
1578189& ^0 J! u. h! ~9 H4 }4 B* C
The problem in CAM where the tool path of the planar profile operation with output contact enabled was generating gouges in the part is fixed.8 Z* B0 O5 d( ]' q9 p6 h% v" B3 q
( Z5 C5 U9 o7 AMP1# |. z9 p. l, ?& s
1581799 1529106 2082454- P. H# I! J/ s' J, M& Y
The problem where Edit with Rollback failed in some cases is fixed.) {3 z$ I% E# _2 h* s0 O6 X
, q7 R; M: U5 C0 S  \3 @) C& WMP1
4 R( D. m1 z8 h% H3 ~& u 1584682
( [0 A. Y( t# m6 ~" a# b1 F The problem in Assemblies where component suppression caused a component to be incorrectly missing from a drafting view is fixed.4 m+ t2 J) M( i) U6 N
+ x) r2 J8 Y2 ?3 L0 lMP1$ ]$ Z1 \) D8 U8 h: P' a
1587937 5741667 1583833
7 |1 k0 P! E0 A* ]' z1 @ The problem where a command line macro did not playback in Teamcenter Integration for NX mode is fixed.
$ M- U5 G- s6 O* i" f8 i6 f( u
0 f* M" ~2 A5 P: A, V" [MP1. h. M- W5 o* G. o" T
15879629 Z! g/ t( {7 M6 H& m0 T9 V2 `" ^
The problem where the Open C function UF_MODL_create_linear_iset required a free form feature license is fixed.
- R6 \5 w& D; J5 t* C$ p  P8 d
( P) q$ W: E* r- Z: p5 EMP1
3 K2 N. M. g/ u7 Z 1588277
  \3 Q& s1 b) [# C$ K The problem in Drafting where dimensions lost associativity when views were updated is fixed.0 |; B3 h) ~- o6 [$ u  q- R2 e
1 Y8 N- f! J# ~! z. N' M+ u8 r  |6 P- K
MP1
% D# X) ?' R! [3 ?; [5 d- t 1588337 15907585 ^; J7 K" P" v! @7 _- i! q
The problem where the Replacement Assistant dialog did not open when performing section mapping on parts which had been edited in NX2 is fixed.
$ v1 s; g9 H) s2 g1 N/ b
. @' |, K# u3 t5 @, \8 uMP1
' y5 y7 j6 o  {1 J 15895562 F0 P$ S& d9 ]' H0 p0 Q# k
The problem in CAM where GOHOME events were not generated in some cases is fixed.& q! a3 {' q1 }; H
8 j. j$ g3 ~* {8 w
MP12 X7 K$ V9 V5 G: o  w& ^
1589580* d+ }* ~" U- R1 w; i& ?
The problem where NX Open Java method askUpdateFailOption gave errors is fixed.
* s+ J; g: t  G  a3 v' b
2 U1 Q: A0 w9 l3 A& i( AMP1% C9 V) u3 E' ?; J2 ^3 ?
1589595
$ u( U! t5 L+ Q# _8 U; t8 f3 @- q. Y. e The problem where a specific UDF could not be inserted into another file is fixed." ~4 r- b1 D4 D# s
+ e  U5 |! s/ W
MP19 p! L, Q! Y0 a8 m
1591465 15898211 y- G1 A' Y4 S( r; Y7 u
The problem in Drafting where Teamcenter tables were not updating when inserting new partslist with save-as-template is fixed.' v# T9 I  h* j2 a+ X
: x3 F* ?# V* z) @" UMP1
0 [% |1 `& F( V" ` 1591810
/ |9 ~( g. O( A& r The problem where certain assembly parts with pattern features could not be opened is fixed.4 x% U  Z$ L1 |% ^$ [
: G7 A% Q% e0 ^* T9 \' j
MP1
% d3 d1 ?* ~3 X; n- I& T 1592330
" i1 o6 I# Y$ O1 P- c; }# p The problem in PMI where dialog box values of a user defined attribute were incorrect is fixed.9 [5 j8 a% s9 d/ n6 x; z
* x, a2 N8 a% C( C. k: dMP1
- r! y$ K- A7 z# C8 u7 Q2 m) A 1592947 5748354
! e. A2 B& E" u  D; H) k; l+ S The problem where the pattern feature update was slow in some cases has been improved.
$ j2 f0 o8 o8 m9 k# n' v. v% i2 j
# x: l2 H8 T: jMP12 ^' `( C: ^2 N4 ^
1594821- `% e- E- o8 v( m7 H. S
The problem in Drafting where threads were offset in the rotated section view is fixed.7 V( z: n6 c) l. f: {5 g' I
; e+ b" S, p: l4 t0 pMP1
9 d8 X3 {% V1 x+ m 15970587 g  S$ h; J6 B  B0 H) U3 \, ]
The problem in CAM where toolpaths could not be exported or listed is fixed./ b! R6 [, a* \& L+ f
! ~7 b( p8 e$ R# S7 Z5 H) PMP1
0 t: Z8 j. {) W. |, a0 o. w' Z 1597221 5763650, J* k! Q2 S- g, j
The problem where highlighting a component gave errors in some cases is fixed.! ?' W. X+ l. `  u% m5 @) K
& O, p* l/ y5 }! e
MP1, e* P' o0 Y8 x  v6 `
2073336 2076592
# G+ }" W; e( X  d0 |+ U4 n The problem where Edit > Feature > Playback > Step did not work for Extrude features containing Internal Sketches is fixed.5 C" q  t& q' s  W. j
1 ?6 B# X: x9 eMP1
. Z0 e$ S$ [4 J# t1 b" f 2074062 2082474 2082720 5756315 1560407 1560860 5666883 1565091 1565552 5694571+ j( m, L2 b; `8 u" u- l- @* j1 @
The problem in CAE where the stress and vibration wizards could not be used from the modeling application is fixed.
& F6 v0 v- y' m' e/ @' k/ `
. t' ?; B" f) r" ?MP1
: K. H* S  Z! ? 2075887 2076560
/ }. v1 d& V  m; M) E1 A5 m# C The problem in Sketcher where the referenced object for sketch dimension changed location when sketcher was activated is fixed.
- ~; Z, I! L  _" v4 V - e0 l) H1 J9 `( @
MP1
1 k+ l6 y1 R  Q) [+ W$ r' R 2078082- M4 r( }) a7 V4 e0 Y# M* ?
The problem where creation of a new sketch during edit gave errors in some cases is fixed.
6 W: r" B9 M0 Y3 T0 \. b9 o+ P
- q/ ?7 w7 U0 d/ I- ]MP13 Q% C  B) o* B. @+ V5 L5 V
2078829 2081030 2080975 2081340 5730892
- ~3 t8 A/ H" @7 D; C7 h" \ The problem where undo of sketch dimension creation caused an error is fixed.
9 ?* e; Z$ D" X* N - a3 m& W& v- N: I& o
The problem where undo caused an error after canceling the edit extrude dialog is fixed.; i& E! p* K) |& c* ]) L) M
, e& ]% v: {4 ~/ A" @. m. g9 C
MP1/ a( N& k( L: ^/ S1 y( ~) K6 h2 T# n
2079140" v% R3 P  A" c; P
The problem where sometimes geometric entities were added to the section resulting in a self intersecting error when editing an Extrude is fixed.) \- A3 T$ L! g  v
3 _9 S/ n# U. OMP1* C1 G/ C; _0 ?0 e" h# L3 l
2079162
& h( q4 g& B2 ^4 @/ Z& d The problem where the Selection Intent option "Connected Curves" did not work correctly in some cases is fixed./ [$ D9 H/ E3 R! h
4 y8 F8 C- }( T5 ]MP1
8 {4 H- I& L* S! Y/ Q 20796340 `9 W  p) B( I; L( t) P6 G  ^& v: J& W
The problem where pressing certain key/mouse buttons while dragging an object resulted in that object continuing to be dragged even after MB1 was released is fixed.
6 J4 q. b. w% n1 l" p  e   t: f; `5 s( s' z
MP1
$ ?3 E% o7 i/ \+ V" I  q) c( i 2079915
; T) i( u0 W* d# M" s The problem in Drafting where the Symbolic Threads were not displayed in the Half Section View is fixed.( b2 G: R5 C! a6 j# Y) \8 U
5 H6 q5 S& \5 p( ]; J, OMP1% l. Q: V# N- V; x
2080037 2075593 2078566 2080375 2080686 2081053 5728183 5730732 5739401 5749632 57513240 s% K9 Q  X/ {
The problem where undoing of a File, Close Part operation in Teamcenter managed mode could cause various errors is fixed. This problem affected both explicit closing of parts from the ANT and also error recovery which did undo for problems within Close Part.1 p0 n7 j; F: y6 x+ i
7 n  c3 ~. v( O# UMP1
. k% [7 f+ a$ {" D) I 20800598 C% D/ M! U1 k2 }! v6 M
The problem where an error occurred when attempting to make a Mirror_Set feature the current feature in some cases is fixed.
" b# k: z$ s. i* T6 B+ c % c5 l+ F9 ]$ S
MP1) ]* A5 g( L% ?  V8 w
2080302 2080608 57519783 g) Y# {2 A2 z/ g: Z# g9 s
The problem where renaming a solid body node in the Part Navigator led to an error is fixed. : Y+ [! \: I3 V, q
# n- @! j2 A# uThe problem where invoking the Part Navigator Properties window when the Part Navigator was not opened would cause an error is fixed.' d9 f5 J& {* f' C1 @: ?" S
4 E) Q: Z: C3 s) H3 }MP1
# S/ F+ q) ^1 z 2080762 2083547
  S0 {  G9 i  y% h! K" M3 t The problem where deleting a solid body after doing a Copy/Paste across parts was causing an error is fixed./ |1 o; w. y0 U7 ~. V3 o4 Y1 \
" h1 O/ ?8 D) I. ]% |
MP1
- t% p4 D# o5 o( M! e7 O 2080802 1588284 5706217 1594682
. O0 q4 i& l3 z The problem in Translator where the IGES file was not correctly translated in some cases is fixed.
, W- m! k+ h& t/ r  f  M( O0 o+ U
6 W: o6 u; M: Y) aMP1
: J$ p" x1 F% t1 K1 W5 h 2080946, o! }$ h4 S5 U# c  H& n8 I( A
The problem in Drafting where the preview of certain dimensions was different from the created value is fixed.
7 J' `; O0 Y# e5 ]  k
7 L: y  G8 v7 j& Y3 PMP1& I' A+ P& _/ [9 P; p
2081092- l5 Z7 Q3 ~1 I* _
The problem where canceling arc creation caused a "session restart recommended" warning because of a missing undo mark is fixed.  Also certain cases where undo marks were not available after line/arc creation are fixed.; a: D( u) T8 x4 L$ o! W; c7 @
2 a# K* `3 ?( g
MP1) z9 l9 d$ M8 q; W' n
2081098% E3 F$ V* i4 _; Y0 K& k& F# f
The problem where deleting an extrude feature could cause an error is fixed./ I, R. E3 y' @4 I
. L1 a- ?5 O7 Y2 E: S' z6 oMP1
" ?" W: Y: g: l# i  V 2081159 2081272 2081148 5740280
$ U& J; H6 ^9 a; j4 k7 S- c4 C The problem where seemingly random errors occurred when the clearance browser was opened in the sketch environment is fixed.
! j* p( k) q+ g  x, g" \
+ \$ @" d# Z( ZMP1
/ ~( p3 j0 _" h4 Q8 b1 R: d' [) T 2081176
8 A  _& i$ q- D4 u The problem where Project Curve inside sketch could cause an error is fixed.
& o7 y& z: ?' B5 \1 m* Q 5 `2 e/ m6 o- g, p9 U) _7 b
MP1
8 [! R9 h: C5 H. r$ y 20812360 N/ W8 b# |9 z! g! U, u8 f
The problem where Blank/Unblank options were not properly displayed in the Part Navigator with MB3 on a datum plane while working in assembly context is fixed.4 ?$ A, \, u6 Y% t
7 [0 W5 E# A8 ?
MP17 R0 N) [* ~! q- ^
20812410 U8 g' b; L7 A5 f$ }- v
The problem where transforming a drafting member view sketch with external constraints would cause an error is fixed.3 g! s8 h$ K1 }* \: N& j' T6 M
; A+ R0 W, h( _' EMP1
7 ~2 S; d" [7 m& T% ?# c( X. Y6 Y 2081249
' C# s. ]0 h) t$ ~( p% R2 j* ~ The problem where attempting NX/Manager export part to a folder which the user did not have write access would cause an error and disable part loading is fixed.- z5 ], t6 x: X- N1 }$ s
+ }- L1 A) N& L3 SMP1
7 f2 x; N% H% O7 o  ]7 w 20812607 J: t( ^( q% `0 f3 j6 o2 R. R- R
The problem where it was not possible to replace a defining sketch for an Extrude feature associated with an instance array is fixed.4 Q8 _0 S; b2 M; d$ ?  L8 Y
( F( S7 h. c4 x; }' xMP1
: ~9 C9 w0 ?, p- A 20812866 s' B- H! y1 h' [
The problem where Convert To Sheet Metal and Edge Rip caused memory leaks is fixed. ( b- v( @7 P) q5 H) _% O
/ \/ `) c0 S9 _) `4 T
MP1
& @" D2 ]7 w0 ?+ ?3 N: h 20812880 @9 n7 o" E& z" f! F
The problem where deleted view names would appear in the dialog to create automatic centerlines and choosing a deleted view name would cause an error is fixed.
) [+ d/ b8 z/ `, c3 d( }9 S2 f, U# G 5 Q( E( c# V6 v8 ~
MP1, O5 W: t8 D5 p, E5 t
2081349
, E& E# a. n- {4 T. @ The problem where a solid sphere would be pasted if a parent body was not selected while pasting Extracted or Linked Body features is fixed.* t5 M7 @" q( p% n, _
) Z: v7 j9 d6 V  t4 Y* ~. |MP1& O3 c5 `; P  X  Q' n5 w+ t8 o2 a
2081353
3 `' \) I7 g0 R) a, `5 n The problem where after deleting a feature set, creating any Modeling feature in a particular part would cause an error is fixed.: E  r: D9 `6 i
) l. e7 H$ X/ F! V. M6 d) H
MP1
, M, u7 b: N- t% j# Z6 F- @& m/ w9 l 20814276 j. r% x: Z, L- n3 c7 R1 b
The problem where some part files gave errors when opened is fixed.; Y7 X0 X$ B7 `! h) w5 R
7 W3 K. h+ k; u- {' I! R& aMP19 q% L' W: ]5 @6 n' B
20814369 l$ O9 J. q4 {; r! J& M+ Z" a9 r7 q" [( x
The problem where feature Copy/Paste would fail in certain conditions is fixed.5 C9 |/ R, U& c3 e& Z' j3 R
5 n. M+ I8 t/ J! c# y) i* YMP11 l( ~, n2 d6 x; l) y
2081438
/ q; A0 G3 y1 v; \ The problem where flange preview and creation would fail when the infer constraints option was turned off is fixed.
0 p+ w' g6 t+ y2 Y9 _# } : x1 V6 o4 v- W% t" ]/ v3 B+ D2 C
MP1. l0 p7 x$ B: q  k) l
2081522 2079818 2080033
9 }8 X2 d' w9 ^0 ]8 f  \) s The problem where editing a linked body would cause an error is fixed./ m" U( V* `" r) B. S- ^
# f. n& H& t0 GMP1, J3 s5 ?; t: h; i
2081585 5732508
. U0 O$ S+ F8 }2 O' E0 m The problem in Teamcenter Integration for NX where Save As of parts failed when Enable Multiple Revisions was set in the  Customer Defaults is fixed.
+ a" b0 g5 q. v* S1 B8 D0 p6 i& i/ Y ' T7 u, j# K2 k. A! |
MP1
, `! ]# k# f+ b* m, R 2081634
. o; T+ }: K+ A8 ^ The problem where the Ordinate Set name for an ordinate origin dimension created at a Utility Symbol Intersection point displays away from the intersection point is fixed.( {5 l- n6 W$ n+ _
3 i3 Y# Z2 Y7 }MP1/ T( k3 n/ s% l; N# ?" I
2081643$ {7 y6 d2 r' K, s, [4 t
The problem where deleting an SB Flange failed with an internal error is fixed.
( t, ^  {8 M- p! n5 Q + _+ a9 f7 a: T1 Q& w  G7 X
MP16 E' X0 b  x* }
2081803
/ W  e) j. I: z3 i The problem where solid bodies produced by PMI sections would be considered when doing interference checking is fixed.
( ^% M* h+ Z7 v" ~. D+ J; C" b
2 A( d1 q8 e/ ]- g7 B2 nMP1
2 E2 L$ \4 Z7 U" A+ Z( ~ 2081916/ Z7 j$ n1 A, S
The problem in Teamcenter Integration for NX where a save operation some times incorrectly marked the structure as in sync between NX and Teamcenter is fixed.
) I6 |/ u* j0 k
) Q2 \, r) E  D& dMP1
" d) M. Q  u. S. x6 `. V/ P9 ~% j 2082039. ^- o% i. w6 p0 Q9 t: U# A; t; s1 s
The problem where projecting extracted curves from a master-model drawing into a drafting member view sketch would cause an error is fixed.
6 ]) ?% A4 q9 D
  O8 M/ a) H- T2 k+ nMP1. ^( Z7 n0 l) {8 V% j9 V; @% M; a
2082129
& t/ C% k  Z% h* _ The problem where deleting a sketch curve caused an error is fixed./ r0 c. Y3 t" R% u* z
/ z' E: e! Q, P: C9 z8 }4 C1 }  a
MP1
* v0 ?! t* X+ k1 N- ^* R2 t/ q, E 2082269/ {: m" T; x2 r  h* ]8 F% J
The problem where an assembly with subassemblies containing assembly sequence objects would fail to load is fixed.' @  J! m! i9 ^8 m: B
1 Q$ @% F  _5 b% M0 }: n& O; _2 g& A
MP1
% J0 t' [. P& J 2082271
7 c7 E0 y) o& i' @8 ^9 Q The problem where after successive Feature Playback operations the model would eventually fail to update is fixed.
1 T7 O/ U3 l2 k: D" t ! }. {1 Y% t9 ?& e/ A% Z/ h4 W
MP1: ?4 o% L: @3 H, `. f6 Y
2082333 2082724 5666881
3 J8 M1 }, V3 O, H' H, I8 u" S8 ~ The problem in Teamcenter Integration for NX where exporting an assembly with no read access to components gave errors is fixed.
, E- D* q3 z- v) m! E% F& ^# e
& g0 H1 d  `) B1 Z" L' n' LMP1
4 ~4 R0 ]2 T9 _/ j$ h! X 2082620
+ f& d& }# d1 d, v5 e* ^/ U The problem where the parts could not be saved if checkmate was set to run during a save operation is fixed.
1 Y  f; T( C( ~6 m( o
8 f5 l2 c# t% V: g9 PMP1
" }# w3 p7 W0 y5 o; S" ]; X: ~4 L 2082704
! N/ W/ Y$ S& H; x1 p. U: b  ^ The problem in Sketcher where incorrect inferred constraint caused a zero mm diameter circle to be created is fixed.
1 E$ z. x# P' l  ~ # v; J- X' s4 ?; }* J- S  |# t0 r
MP1
1 p; K- F2 I; c& a8 P, I) Z" d$ j 2082744
+ a/ [: c# ~+ o/ v The problem where some parts failed to Save is fixed.2 G# ?$ ?, U2 _: \, M5 _/ E; a% b: @
1 \) U6 H4 e; `( g& n( V# KMP1
2 z. ^: e9 ~* m' f 20827878 [: |0 v3 }" p* P5 B
The problem where sketch curves disappeared while editing internal sketch of an Extrude is fixed.# P& y. f& J0 m; O+ }2 D
# Z6 \0 H( _) W
MP1& A7 G' B4 F7 }' w, {, j, n) d
2082803
  B7 I. s$ A; @9 y' M3 V" d' l$ b; @0 g The problem in CAM where the Zlevel Profile 'Depth First' option behavior was switched off for slightly interfering paths is fixed.. J! s2 W7 ]$ ]3 D& b, i: t+ G
1 f, F4 ~5 k8 i$ R* K" D
MP1. S; m& A! x3 u, V
2082998
. t5 C* O( p; f, ~+ F The problem where no default name was provided in the Reference Set name field of the Create New Component dialog is fixed.
  A1 U" u: w* E8 z) Z( ~: h
& I- ^7 y/ [( j1 a+ aNote: this field is now populated with the name provided in the Assemblies > Extras > Create New Component > Reference Set Name customer default.
  ?% h* z8 j; d1 M) N) ~& w
9 E0 a6 O5 R  i, U* jMP11 e7 n* h3 w- R
2083179 5691332
( E5 `% e+ A3 d, L& n" Z/ }$ C The problem where NX Collaborate did not shut down after disconnecting from NX is fixed.
- d; {+ B( q  E+ y3 Q! E0 j * U7 q" R! ]7 w3 L$ d! y. x* J
MP1
, D4 f- \$ Q* ~0 y 2083195- y$ i, \! f5 m
The problem where a section did not honor the limits during edit is fixed.1 s* `7 e9 [: B6 n. c8 x' [. |
' q, c. ?$ Z1 G8 {. O
MP14 W$ D8 n+ ]; I' a1 {: B1 H
2083371
9 v) w+ P( z+ u/ r0 h! I* d The problem where choosing the option "Studio" as "Rendering Style" would cause an error is fixed.) n5 J" _% N/ S
. ?  N7 _# u4 T
MP1
/ @4 j5 _8 f2 k- i/ |5 b 2083466% l4 J$ P+ o3 R; n* \) c" X- E
The problem where an error occurred when switching to Drafting and simultaneously pressing the F1 key to pan is fixed.
4 J3 p+ v9 H- ?2 h
9 k5 N  p( C9 J6 R- ?MP1
9 ^) h3 P# M6 J$ n/ q 5042179) O4 e" c. t; h: V0 u/ n% S/ P6 R8 y
The problem in Translator where drawing sheets with space character in the names were not converted to 2D Exchange is fixed.9 O, `) j4 M' D' K/ t. S
# n4 ?: u. M( l! O. {- e
MP1
8 Z$ d1 O9 ~; g% }) \ 5346749 5370674 5442336 5591821 5741351 5763266
9 Q) w+ ?$ K7 ?9 F$ _ The problem where Solid Edge assemblies created in inch and loaded into NX were created as metric part files is fixed.9 {2 j$ K& d7 a" e: y* K6 `' }
% q& _& s7 a, k( nMP1! L7 G: L4 V, g' F" K
5531624
$ C9 C4 d1 c1 W5 o. m$ |- O The problem in Assemblies where Open Base Component and Select Base Component were selecting the wrong component when the user was selecting a subassembly-level faceted representation is fixed.7 q6 X1 i; Y( ?5 F
/ [/ S! O/ h9 s) J$ r$ z
MP1
- k: I7 L4 Y6 [$ C 5573884 5755228
& f3 W& C$ A2 H$ W# F3 J. F/ ^ The problem where the drawing was not marked out of date when a component was deleted is fixed.
0 S+ z, T4 ?. ~( N7 ` 8 j1 O) k6 {4 }: G; Z- L
MP1
. k1 p# t; s, l& H3 [! I 5610933 5749847
! b) M" \2 N4 L  M The problem where the warning informing that an inter-part reference passes through or into Multi-CAD parts kept appearing multiple times when adding a view on a drawing in Teamcenter Integration for NX mode is fixed.
, r, L) w2 S5 V+ v) X % h4 ^9 Y8 i5 p
MP1
6 e6 r( s& B+ l8 o 5700830
" F/ h& E) |4 m The problem in CAM where post processing of an operation did not correctly define "mom_tool_offset" as an array variable is fixed.
" y9 T. a0 G) m
' [' U# A' R/ B* D: ]MP1# ]7 S; `3 j. G
5710641
, x# v; [4 h- I: U' X3 c The problem where an error occurred performing a part cleanup on Drafting Objects after adding a Thickness dimension is fixed.
6 L: j+ Q. L7 P& D) G0 e! m! v* k
$ K' f; X5 N$ E# \# c3 s* ]MP1
% {& ]# b# f2 ?3 ~/ T/ a& p 5715559 1579062 5715571
( m5 b2 ?3 v" w- b5 X The problem where a Offset Surface feature could not be successfully edited in some cases is fixed.
- s# j. Q! Z: g' S" q  a6 s  y% g
& K5 ]: ?0 c( \2 r1 UMP14 z$ _4 _, d# T7 d& T+ r" B4 q7 t
5724319 5741456 5709862 5690410
  B& B, a: z* f. N5 X The problem in Assemblies where the ANT did not show component names for direct children of a loaded parent part is fixed.# ~' t& b' R" l9 h2 e% S
$ E: E) s* L7 ^$ A, S/ s
MP1# Z) k9 l: e* {9 `% z
5724330 5726643' \( _4 _7 X  }8 X! N/ ^
The problem in CAE where an error occurred when reviewing Animation Result in Motion Simulation on wntx64 platform is fixed.
  o5 G' H6 c- m  \8 o
7 b! `# s4 x  ~; n7 a7 h3 WMP1( W  V4 ~( y3 d5 Q$ ~0 ^9 R
5726834 1532896 5208149 5596127 57467630 |( T9 ~8 @; A- K+ t
The problem in CAM where Visualize 3D Dynamic showed incorrect results for circular motions in turning operations is fixed.
1 x2 t! k- C' B% U) U 2 z4 p. ?' o% K
MP1
/ |* ^  i5 `" Q/ }% E 5729806 5752397 5754471+ n2 q# w2 y2 d5 n0 h1 j; _: h6 H
The problem in Drafting where some part files could not be saved is fixed.! W: c, Q" X( v3 f: t$ I
; d* O( L% r& @MP10 K; V7 x0 l; [# [' z
5731873# `7 v# I( D! u: t* c- E
The problem in CAM where entering the feedrate dialog in Point-to-point operations caused the previously entered tool depth data to be changed is fixed.
/ }; {1 O+ d' M& s$ r( `
" w! [# l! p  U( W6 }. gMP1
# b# r+ }9 R7 @* m. I/ b5 Z 5732166 5710719
4 {/ P9 h5 _. c5 s The problem in Drafting where sketch curves were removed from the sketch when used in a breakline/detail view boundary is fixed.
' m$ z+ `$ C/ D5 Q& B3 j- M" c
9 j6 r, f6 W" q. b( u5 q  O; e2 aMP1/ U- t- J. W) F. W9 C
5732251
- X0 ^! W' \) @/ ?6 \( J The problem in Drafting where Ordinate Dimensions and Centerline Utility Symbols were not updating to their associated edges when drawing views were updated in some cases is fixed.
* t! y4 \5 ?: ~0 p8 T9 H
: O1 ~0 E& [$ a7 Y/ ^MP1
, X; T$ ^$ x3 ]; I' ]  t 57322751 w2 O. N$ I0 B+ ^9 a
The problem where a Mirror Feature which failed to update was not visible in the Part Navigator is fixed.
) s2 v, w# Q. K5 K. _
& @  g* }- i4 a. V' b- u8 E+ DMP1
2 G. e2 e) ~2 S! z( _6 L 5733222" A% |2 ^- e* d) p2 O! f+ {
The problem where a feature copied from the displayed part could not be pasted into another part is fixed.; W( v/ l8 V" ~1 `# R1 V
# u% m- |, p, e) K* j2 |MP1
* [% e; M/ [& w) |  b2 I# ]9 \ 5734160 5769433! O6 E8 H/ _5 e- x
The problem where creating dialog bar items gave an error is fixed.
5 Z7 c& D# F6 \% ?% | 5 v) \0 p/ M2 w) J9 }
MP1; i2 h4 R2 M' ~4 L6 I# c
5734171( p% C: G( @' l  z7 k8 I& u: {0 L
The problem in Assemblies where sometimes an error occurred when closing a pattern is fixed.
  d$ m( }2 z, U6 n( n& i
2 ?* ~: z& b' MMP1
& L: e( S, Z- Z 5734179 5748975
1 N) n5 Z2 }2 P5 `, J1 g; h The problem where there sometimes was an error selecting in Part Navigator is fixed.
1 _$ ^8 j; |9 l1 N 5 U$ D% }7 d5 K
MP1
4 R- f) a- i) ?( E8 G8 F% @# w 5735779& a( A; C! A$ w$ y
The problem where Offset Surface did not have the option to remove missing parents during editing is fixed.' J0 _: ]) q4 [9 k) O
# c# {1 Z/ [& M! A4 ~MP1
+ Z- [* H3 g1 `6 G( N  J( Q 5736907 5739436
% m3 A$ d* Y" i The problem where dragging a spline in a member view sketch would cause an error is fixed.
" r4 r/ }+ i5 S) q* b, b 2 y( O+ T4 j7 S0 b" M
MP1  X/ f' S$ F0 ?% F
5737589
4 Y; O9 c/ @0 j$ |, C' F" a8 a The problem where the use of selection intent, as in curve projection, and moving the cursor over a particular edge would cause the system to hang is fixed.5 x- `% `+ ?* a1 ~+ f
8 i% w, J3 f9 n5 a" X
MP1
: l* d6 ]9 b1 c  F3 e 57375994 d: j# h2 W% ^* v7 P5 L
The problem where offset surface preview failure would cause an error is fixed.
; a# x- F1 Q, D% c6 `9 a- ]
' S% P9 A2 B  i1 F# YMP1
2 ~" p9 k. L2 {* ? 5739134% U+ Z; o; j( t+ d& D: R
The problem where saving an assembly failed after editing a top level sketch and updating inter-part references is fixed.
$ ~. m- F, \/ g/ ? ' p# H+ K9 P8 c
MP1
. T) k. E+ |. Y& c* l 5740288 2082545 2083427  ^8 X1 _9 @, s2 X- D
The problem in Sheet Metal where update of some parts failed is fixed.
- P' R2 C  J# o
4 |6 E0 B& C5 f* W' `3 \5 u3 tMP1
7 E$ r3 m: a4 x5 p# X" f' I9 D" E 5740358" x9 ^7 s$ q% F. Q0 T. a
The problem where sketch curves were not placed on the sketch plane when in assembly context is fixed.6 f8 e9 F# V& o+ g9 O  n
& T0 W- [# R% i& f6 a& Q
MP1
7 G5 X* M* Y. o0 \ 57412232 L' U& y! |# l
The problem in Drafting where using the Open C API functions UF_PLOT_print and UF_PLOT_save_cgm in external mode caused several angular dimensions to flip is fixed.
$ i+ S& T. N* Z9 v: Z" u- c* u
; f2 B  q9 i8 \) U0 p) O. _MP1
8 m- R8 d4 a' r* W' {* c 57425150 w: w5 Z8 T( T- d! {2 R1 e
The problem where cursor response was slow while the Part Navigator was opened during PMI dimension creation is fixed.
( E8 j1 W7 q6 O% l
# X6 W  l, U" E  M* m2 u+ RMP1
3 `' X/ @& i# {. ~( D3 c2 k7 M 5746225
, d: I  X7 n( W) k The problem in Routing where the formboard modify path tool would regenerate the entire display after each branch orientation is fixed.
4 P4 b6 Q  |3 A8 W& U - Z7 J- w6 a" H- `/ Q7 }1 A
MP1
, L4 ]! ~+ J2 I+ X 5748582
: C  H. s; _& w' g5 M8 K The problem where formboard generation was not properly identifying proxy connectors during generation is fixed.; {7 B9 X/ Q5 f& {* F
) w5 O+ V2 U+ w
MP1  s2 x  |3 U5 v5 _! j& m& E
5749337. j' b1 k- q; T% \0 j# D
The problem in Plotting where the dimensions changed when creating a CGM of an inactive sheet is fixed.$ A4 I! G. P/ n. v, ^' X
7 x6 w1 ?. }% O3 h8 t  A* N3 ]MP1
4 O! L0 ^. ]& z! V9 J- G 57495528 e3 y+ T: `9 b; X9 P3 ?6 c
The problem where Overcrown by Function in Global Shaping would cause an error is fixed.# V9 [1 T, D7 f3 @
3 f% i! ^+ A. V+ nMP11 l# |3 t9 n. I8 X4 G9 c
5749651
% E8 Y4 q1 W1 Q2 ]* w The problem where an extra body would show up in the part navigator after a copy/paste operation is fixed.
% o, v. R7 O# m' z6 o + l& g  e9 v+ A/ o# A4 o# k5 \
MP1& I3 V$ q& n& H! v2 }9 l. I4 n
5751340  z) D" B/ k: q0 [1 G
The problem where there sometimes was an error when selecting a indirectly copied projected distance measure feature is fixed.
. A* g& i& i: D - z/ U* P9 u) k
MP15 l: a( N6 C& b) L" }! ?3 J+ L. ]
57513568 x1 A$ }4 D) V( V
The problem where creating a normal Sheet Metal cutout in the context of an assembly could cause an internal error is fixed.
8 ^- F0 t# i: ~% i! O! A & k9 S7 o, T# M. ~+ L4 p$ s0 {  i
MP1
. j4 P3 t# Z' M" X# y5 M/ e 5751360" J1 e, ]) t5 w) i# |, L0 Z
The problem where canceling out of Vsweep command could cause an internal error is fixed.
* G2 j( j7 p% Z3 n7 I
4 T1 N. h( |) T7 |: F9 ]MP12 o; s2 \# S9 K
5751408; d/ D3 P/ A7 |- |2 t" T7 P
The problem where after changing the Draft type on an edge, re-selecting that same edge would cause an error is fixed.
3 y5 M/ a: ^1 o) W% P7 p
: U5 o& Z, X7 A8 D2 FMP1
5 n9 |% L3 f3 _ 5751433
" [! E% X1 ?* ]8 C0 } The problem where ungrouping and dragging a surface finish symbol could cause the session to terminate is fixed.
% B  S8 m, T8 T ( t( i9 T& Z9 h
MP1, V% a/ @& }7 f! o3 R
5751781( ~# K! x0 w9 M$ r; r: j* K: z
The problem where using the check box in the ANT on a multi-selection to make components visible did not draw all geometry is fixed.
; v7 T' q4 {! B( P, T6 ~
* n! r( W8 }5 d! J3 W; F; Y' K* IMP18 L5 h7 E* a$ c; J$ B3 o
5752228% W+ q5 }+ x  H  ]
The problem where pasting a secondary tab feature would cause an internal error is fixed.
. z: g* C% {( {5 _ - u' L3 b- [" p& t2 z" \
MP1
, n# p! ^( l8 K4 ~9 N. | 5752250, Y' O- m: X  Q5 u3 |4 w
The problem where view dynamics operations (panning, rotating, zooming) would appear to stop working after an error is fixed.
- d; ]; G1 ~2 j0 G+ `' Y
3 T7 T! Y3 P- j' a8 f' \MP1
& I& B2 ?  k) Y- l4 T2 p, p3 F' l 5752814
% N) y; q6 ]+ i! s3 i& E! H The problem in Routing where intermediate components were not displayed in the Connection List Navigator is fixed.0 a2 _; d$ x  Y6 X4 o, _/ [# M7 h+ ]+ d
$ {  J: g+ w, S
MP1* S8 s, U. d- z: T" L! W
5753060 20828973 k( a' o6 V- F$ M) U* ?
The problem in Teamcenter managed mode where an assembly could not be cloned to a new Item Type is fixed.  ~' p) {, C7 i
6 m1 g% P4 m3 z. {% f3 NMP1
9 T! w) C% m8 P 5753751" x: x# G) M  M3 C& L
The problem in Teamcenter Integration for NX where read-only piece parts were not being marked correctly with the preference "Add NX Datasets = Never" is fixed.0 e$ O2 Q6 q7 _4 R3 a8 B, M5 w
$ ^9 {3 \( [, B7 M! E
MP1, q9 }5 N6 ~! x- j9 l! N& ]9 i) Q
5756225 57597246 E, d/ u  F3 n% K) R
The problem in CAM Turning where Move to Clearance Plane acted differently in NX 4.0.4 when compared to previous releases is fixed.
8 _8 ^5 w; Z' m  V9 K: gSee Note 1.1 below.
1 L* G# n% ?4 x6 K 8 B2 A2 Q6 T4 i6 z1 P' K
MP1
# Q! D4 L. e5 a 57567031 D" E* X& ?- w" g
The problem where Curve Projection sometimes gave an incorrect result is fixed.
: J  \- O5 c  U: S
2 R" S' M: v3 |- Z0 qMP17 M3 X' G. Q  a3 z" b5 V& w
57577248 c. o/ {" ^- b1 S8 e
The problem where making a component the work part caused it's model-dependent PMI to disappear is fixed." X. N3 l4 \5 C# U/ C; G6 L1 }% T2 Z
9 I7 O5 e/ U" P+ P: Y% e: B/ C
MP1
) |: Z5 E+ H7 B% G 5758299
* i6 q9 ?2 J, i. p5 Q The problem in Drafting where crosshatch created unused geometry on layer 256 is fixed.
0 ?( K1 T2 r7 @7 `2 |, Y 4 m: M% f! i6 O6 r6 n
MP1% x' D. |8 t& N: r
5760827 5764444
4 z5 `8 A4 J, N- ]3 n The problem where some some parts with an exploded view but no components failed to open is fixed.& G* p; K8 b- B) B; {9 d: c: N
8 n* U% ?- T1 x$ l% e0 v/ u) [9 j; }- d& g" r/ }5 \+ k5 [
1 o/ x# `# L+ k0 W, y4 k$ B: ^) M( S+ `1 W9 j6 j% }5 D. G+ i& |7 h7 S
3 }& O  B' X2 B0 I0 _$ ?" _4 [( O) v
Release4 ]' g' }& F. t
PR Number
& y, `2 k8 K& y! h Problem Description: g% w7 Z& |' k( X4 l; V( Z" x
+ \3 v) D* [& H0 n7 f  `0 N" v
MP26 ~/ e8 K: `. v& I: b+ N
1569287 1576654 1584952 1588897 1589580 1593173 9 ^+ i' O; M& C! U  C8 G0 p
The problem where the NX Open user function UFAssem.InitMc was wrapped incorrectly for Java is fixed.
4 j0 [. b( }4 t' E. T
# }$ y) c* [# x+ `; R+ @The problem where the Java wrapper UFClone.AddAssembly gave errors is fixed.
: q5 Q" x+ F. K
& e. ~7 p+ F  V: bThe problem where there was no Java wrapper for the NX Open API function UF_FAM_ask_family_data is fixed., ?0 A: A2 b) s' ~; |$ H
: i2 q1 M! ?' q  w2 y
The problem where the NX Open function askUpdateFailOption gave errors is fixed.
2 U! R# Y$ G/ G* Q. L" C8 f3 o% Q3 v4 C! V! `
The problem where the NX Open function Assem.RepositionInstance in Java stopped NX is fixed.+ ^9 Y/ i2 @4 U; m+ n+ s) T) C
3 m* t' s7 \( T' x; |MP2
4 T! I; F; A% Y 1575527
! K7 r: }& }# d: G3 A8 ] The problem in CAM where the access vector of a blind hole was wrong is fixed.( e4 d5 Y) C9 F+ w8 @
' ]2 G5 @' R. H$ G4 UMP21 a4 C0 ?; S( C6 q( c, ?% f. a% Q
1577765 1584471 1577765 1583944 5573941 1580172 2071927 5731249 16017591 H6 z: t1 j) Z) m
The problem where using dots at the beginning of a directory name caused errors is fixed.0 T" k/ @4 ]+ V( _( x: G
9 s/ A' Y$ o2 j5 e) |) wMP2
4 J; K, K7 a& Y 1578205 2081794, S2 G" T  R7 E# c9 P9 M
The problem where certain assemblies with deformed components could not be opened is fixed.0 f* K; w  u9 [% b; Q- ?7 D, m
7 t1 i  ]7 X) ZMP2
+ D" M2 x: E: a$ W4 x7 L 1578935
+ X, _+ E  W9 U0 V# R The problem where changing the ownership during cloning did not change the BV and BVR ownership in NX Manager mode is fixed.
8 Y5 O& V  U0 o. j. r( ^9 y4 Z
- ]3 A- S, B9 p  TMP2+ I& `1 h$ c7 V* L  Q" ]# l
15851711 ^' S8 r) o, l" t. I& o8 Y  S7 }
The problem where a UDF could not be instantiated through Knowledge Fusion is fixed.5 L% p6 o( w4 I1 I; |$ V4 t
0 v  c3 b# w3 P; j8 \
MP2+ r7 A3 |/ E; I$ B9 b2 T! [1 ?
1590182
  c7 d6 m" E5 s/ J- W5 l The problem in Drafting where text in some of the parts list cells incorrectly changed after an update is fixed.
: I7 @) R; D: u6 ]% N8 M
) o& l0 T1 v; D& t' F0 C* F& iMP21 L0 J1 e( p, \; |9 z: r
1591218 1606489
* k3 L4 a8 r, V" X+ G/ {% {, i7 H- t The problem where some Assemblies containing CAM operations always showed out of date operations when opened in NX is fixed.
; P4 p% A8 a: h# K: |  h) e; D7 P& A ; k' ^6 z4 Z) E" x
MP2, Y4 }/ R6 B# [! a! C5 Q* \5 H
1592469 1597784 5702414
& r. j) B) h1 O; H" Z( j The problem where the external DXF/DWG translator failed after translating certain number of files is fixed.
/ u+ T4 a- E+ {# V' D
! `* L* q3 R+ a6 d. KThe problem where 2D Exchange did not export Cyrillic characters correctly is fixed.+ M- c: @4 l9 @5 g4 ~" K, t; J
9 i. i7 Z8 w* [: _0 D8 I! A. y
The problem where some geometry was not being exported when exporting as DXF/DWG is fixed.
6 Q4 ~: G7 j# A* r8 L $ S- r6 K" M& o  I3 o% R9 U
MP2" r2 S. m- @, C
1593234* K0 [4 k" X/ A1 ~
The problem in CAM where the boundary for a tool path changed after the part was imported is fixed.2 ]9 f# N3 B5 y' o# A! x) Q) J
: F% h" }( s! g. l; }
MP2
' ]2 }+ F. ]5 F' {$ _ 15932625 h5 f$ g- g6 E0 j& K9 r8 ?3 U
The problem where editing complex hollow features on some parts degraded performance is fixed./ _" G& S) a; j) j% o
8 \; x' x5 X2 y" lMP2
& c+ J: }$ `6 }8 ~3 |; W 1595358
# [# t. `! V% g The problem where some crosshatches were deleted when a drawing from a previous NX version was opened is fixed.
2 g5 L8 d$ e6 T( g& w 6 H* B- U4 F) X# `2 I9 M+ c
MP2
- D% w5 z# z, x- @. Q 1595701
6 C: R! u6 T8 G8 |) O; `; U The problem in CAM where incorrect cut regions were created after drill operation is fixed.
, ^& Z  N: E" i/ E( D
3 G5 k! A- f( z" X0 V' e! m5 ~MP2- T! q1 A7 F3 B  ^* J: g5 k
1595844
; [5 _- l- g6 t* d The problem where editing an Extrude the End limit handle did not show in the correct location is fixed.  \: P9 G; }6 V0 e6 A
  A) q3 r$ M  oMP2
( m1 g& R2 ~2 m9 L0 g, v* \ 1596623 1597757 1599586 1596623 1594219 1603948 1596270 1597863 1599538 1601371 5767718( M- _  n; x: ]
The problem where plot file sizes were large when plotted or exported as CGM is improved.
; @9 |% P, S8 G9 h3 Z
: {+ D1 h. B& y3 lMP23 }1 B+ a2 ]" Z) U2 T1 S6 x
1596980
9 F- V7 z' w: h2 t7 h The problem where bringing up the Define Product Outline multiple times was causing problems to the translucency data is fixed.
7 ]' q2 O" t5 l* _3 b3 u ( ^3 a4 }' s# C. k0 ~  R+ U
MP2
7 A" |& I. T" f' I- U7 @* C; [$ ~4 [: I 1597312 1607039
+ ^& X* j0 Z, q- E The problem in Drafting where loading defaults in Preferences > View > Section, toggled on Assembly Crosshatching when it was toggled off in the Customer Defaults is fixed.
' f/ n7 n9 `2 d: }& n + `! Z0 `) K; E- |2 m" Q5 I
MP2
0 v! y7 J/ N% a+ R& {# p; h 15981435 V# A: Z& B% ^; K* D9 K* H2 G$ `/ [& N7 d
The problem where auto-route at the pin level failed if an intermediate connector with terminals was added is fixed.. |9 w8 D" f# o) o6 R$ k
5 y2 T  \9 l! b2 l& O7 v0 v( {8 mMP2( Q7 W) r$ d4 ^. @# g
1598498  @6 Y  I. \4 w2 B8 k, X
The problem in Drafting where up-to-date automatic views were forced to update is fixed.
; u9 {! b6 I: r, o9 p 7 n! w- p8 O: v$ o+ x( M+ N
MP2
8 o8 p; }- b/ v# N 15986671 A' T9 B" g- b* d
The problem where the NX session was not usable sometimes after substituting components and deleting out-of-date KF features is fixed.
- {" m) k" u, X# k , s0 D7 r" P% L* ^/ |, U- j
MP2
: P% p1 }5 x, u& @  k1 w( K 1598805/ r; n0 Y; B5 S* f" m8 A* x1 t
The problem in Routing where creating terminals sometimes gave errors is fixed.1 z, |( y, Z0 z6 e, R4 [9 T' F
6 J( K. R& v& n) V; ~MP2- H8 L% y0 b; ~4 e9 f
1599424 5753014
. I3 p; J0 [6 u, L1 _: s The problem where the Manufacturing Application could not be accessed sometimes because of the unloaded components is fixed.! P/ L# Z0 h2 ?% a, n0 m0 J1 H
3 s: J3 O, Z: ^MP23 O2 M7 f% x4 O! [4 y5 j+ ]
1599651 5627375
# J' B. o8 s+ ]; o3 Z7 d The problem where the OK button was not always displayed on the View popup for Feature Edit Parameters is fixed.
! y1 }; \( a! ^% {4 R( x  a7 |' N( C5 R! f/ l4 _
The problem where the F9 accelerator for OK was not working with Orient View is fixed.' r2 t. A3 J0 l9 m+ n6 |- G7 q4 W
/ _7 N" G% ]& i2 B1 p8 g; s
MP2
' p0 e! U- F$ V+ a* e7 m 1600991 1603174 1601466
& L# S" [! D* c0 [( e0 t& ]* P The problem in Drafting where views with manual boundaries did not update correctly when the model or an expression was changed is fixed.. q1 N/ _" ~- O: g! o  J; H
; n1 {0 e' h1 d: ?MP2, v. `7 l; L) f6 X% E
1601196, a" a4 E1 I( Z% i4 H4 Z
The problem where sometimes an error occurred from NX Open function CustomSymbolTextData.GetText is fixed.
' r9 o9 x8 l& S) I9 p4 V$ \$ O
9 B9 O$ \8 I) `. M6 N9 O6 k$ MMP22 j! A+ @1 G6 `) Y" V* y
1601445$ c! @1 {" K6 L, `9 z
The problem in Ship Design where the Longitudinal Y Frame dialog was not correctly populated during edit is fixed.
! m$ N# K4 ?. h. S+ g 5 j! b$ s2 `1 H& t. F' z! a
MP2! `' j  T! p/ b  l5 ?) }) }
1602901
9 _2 T  T9 f5 e& ^% m9 G8 N4 P3 N- p4 c The problem where sometimes there was an error when deleting a feature or making a feature current is fixed.6 D: M8 s5 t4 ]& Y
3 b' y' V! K1 F0 R; l$ G6 |2 B
MP2& ?/ t5 A$ C, Y1 {2 _
1603836" h5 X. g* p( y! R
The problem where Knowledge Fusion was not correctly adopting the expressions of Circular and Linear arrays is fixed.. C9 G' y8 C3 F1 A
( t. d; z' S5 ^; a* h* i9 H- @2 M
MP28 a; b: [% Q- U$ w% R6 ]* [
16045084 ~0 d& q9 h8 ^! Q
The problem in Drafting where an error occurred when inheriting view style from a view with an arrangement is fixed., @: V9 R) p! J/ B8 u4 h0 w3 T1 M
( e$ |. f7 K# c5 ^! R1 o8 z
MP20 I- ^+ d/ c, m
1605501
1 h. S7 G+ K- {' d The problem where a drawing view with filtered PMI datum reference symbol could not be created in an assembly is fixed.
5 V! p. N9 W( N% ^; a" R
. E2 ~% b2 m6 \# v% A; g( hMP24 j" a7 t9 S- P" d( R
1605725
7 Z% V9 E! x# k1 p" \6 U The problem in CAM where Toolpath > Verify > 2D Dynamic with 3D IPW ran out of memory is fixed.5 B  r; ]/ p& ^3 ^
: \8 c: y/ `( G
MP2" j* b9 J- U- w. `. y- L0 f
2080609 2082198 2082209
6 G8 n( u  D- x4 r The problem in CAE where there were sometimes undesirable results in the mesh update is fixed.  Y& M4 `* A+ H. P( N/ D
" x2 L7 m- A; Z; X, W2 q* T4 M
The problem in CAE where geometry update sometimes failed after editing the idealized part is fixed." D6 e6 W5 U8 p  T# D/ r. ?
! C6 J0 W6 x- C1 }! s
The problem in CAE where the 3D swept mesh was creating a wrong mesh by not following the seed 2D mesh is fixed.' O/ {: Q4 r/ ]$ S+ @: u  L% A9 A
. E1 E; j# [$ P% ]4 j% r1 `6 ]8 ^
MP2
+ t" Z- V* \  B9 g- E& r% X 2082879
. R6 T/ b, M1 P8 E5 L3 I The problem where sometimes a sheet metal bend feature updated successfully even when its parent sketch did not is fixed.
* R) n& O/ T3 X- c) F
! N; E: q4 [- C3 o8 {! b5 nMP2
4 S5 _, q4 D* e& L( F- C: N 2083100 2076610 20770351 Y$ X& h9 J1 L
The problem where performance degraded in some cases when working with large number of 3D curves with Part Navigator open is improved.
2 K6 A7 g# y; G
- q7 m8 n4 s8 K) XMP2) z) r3 X* h- c/ |" r9 d$ R
2083218
7 b5 n$ r& @/ |; c, Y" `2 k; q The problem where a component updated successfully when it was the displayed part but failed in the context of an assembly is fixed.
$ S$ y$ k2 _! ? ' @% d6 o4 T% \" p7 V. a# _
MP2$ {' i: Y+ Q; U7 u
2083333' K. I. \4 `' r4 X, m3 T
The problem where a Solid Edge part file with suppressed geometry could not be opened is fixed.
; c- ~. T' n2 \! @, T# z $ ^# M, [4 z$ {6 \2 \+ ]9 |1 D
MP29 S/ W! i' C" a
2083471
/ N; n$ R. \, M+ A The problem where after displaying a low memory warning the session could suddenly terminate is fixed.! x1 o' u  l: R5 ]% n6 T* r
( N1 A* u/ B5 M5 M; C
MP2
) N" R# t7 P" u) h$ s3 [  ~5 b 2083553 2082552 2084028; b& B7 Z. H0 D, V2 {$ v% l6 d
The problem where Save As operation failed with an error is fixed.! R3 r, ^3 k8 y) v7 Z2 B
8 x1 H! C( p0 k1 D. |
MP2
  A- [/ @3 G' n% A3 i8 D+ X 2083583 2069043 2069041
2 A0 _& }7 n, d" c The problem in CAM where groove finish operations failed to switch to the correct tracking point is fixed.
# Q9 G( |' W) P- f0 Z+ o! }$ v
: H) G( P3 R1 a( I0 sMP2
, x/ i. v4 j# i: d1 f5 X) @$ \ 2083597
" Y# \. A9 [1 v0 T The problem where close part was failing with out of memory errors is fixed.1 b: i7 \$ B' |) v6 d( t, M, F
& p! |# W. P: T0 I0 ^& n& E
MP2
0 l( l  i/ W; F' J6 |0 E; X 2083607 2084185  a( d" w& a* i$ w' H% C# [
The problem where measuring distance in the sketcher could cause an update error is fixed.7 ]1 c, M  \  K, i
# b) Q- N6 `, V2 \: v. T7 R% l9 C' kMP2
2 ]2 \' K; x! ]% Y 2083719& W, K. P. ?6 z+ E
The problem in MoldWizard where Chamfer was sometimes causing incorrect results in Hole Report in the drawing is fixed.: U7 b, ~# \  e# C2 W  N; o& e
7 a( n) t0 e$ Q6 D$ ?- J
MP2
3 c- I( Z- u( s9 e 2083746 2083763 5789831
  e* {; C! }2 |# N The problem in Assemblies where the newly created component did not sometimes use the reference set specified in the new customer default is fixed.
2 q: t7 z$ b! R0 V* h
( }. @1 P' G, s, \$ cMP2
$ h- E7 o0 S1 P0 Z9 V, |9 V0 k1 y0 z7 Y 2083797
4 P* ^* v  F' {8 k$ \% l The problem where a bookmark could not be loaded is fixed.4 c& P8 c: i8 ?
6 a7 q6 R! r$ R/ u/ `2 w4 h2 sMP2# [# @; d7 {6 @. T
20838316 ?  a/ b8 `3 g7 u7 U( T6 p7 @; `# e9 ?
The problem where Close and other operations on parts with annotation caused errors is fixed.5 l2 j9 C; }* d' T
8 k" f( c) A3 ~4 T7 ^
MP2
. s- M  t# }" t: K! x! W4 F- w 2083925# l8 C' _, r* H8 n$ J% s  Z
The problem where updating a view that contained a sketch point on a drafting silhouette curve would cause an error is fixed.
- o! w9 H# U- M0 B! r8 ?5 D2 [ % c) e) A. ~# v* a3 m+ U( i
MP2
3 ^- ]* j1 V. }+ q" \  j 2083957 2083837 2083923
! f0 i2 E; f' H The problem where make current feature in the PR parts would cause errors is fixed.  Part cleanup with the Cleanup Feature Data option must be run on existing parts that exhibit this problem.& p- U, g' c/ ~7 X
1 a4 C8 E6 L; T+ l
MP26 B8 ]9 U0 {4 ^. H# N+ c
2083960
) z# M# y$ v& n, H) a" [0 a, M  f The problem where Snap View while in the Edit, Divide Face dialog caused an internal error is fixed.7 p, V: s% q$ R/ t/ B* \" ]! o8 ~
% Z' J; p0 @7 D
MP22 D6 {% ~9 ?6 E2 _! I
2083965- M/ K# e8 w5 p/ K
The problem where exiting from the sketcher quick extend operation would cause an error is fixed.
6 b& A( n' q& `& w3 }0 a
' p, r8 ]% G$ D6 k5 o0 i$ OMP2
' @7 q+ E9 ]+ }5 R: d2 ?3 V  E 2084061 20837779 {  Y' g7 q2 f1 K
The problem where editing the solid body name of a linked body in Part Navigator unused items would cause an internal error is fixed.
$ v, w$ C& m; `: J# z0 @0 v
; s3 a' R0 @- P& RMP22 a: w! i9 k1 m: q# f7 C
2084064) P- V7 n  @7 S. R) m1 _" Q
The problem where copy of projection curve in Expand Member View caused an error is fixed.( t) ~  g- E. W* f" n: ^( v
/ D  B) V9 G6 m# }% v- S# b2 AMP2% _) v3 ?3 e  x; T3 O$ P3 N0 N
20840835 i6 E( @: ^) {% J  u
The problem where boundary curves were not selectable for crosshatching is fixed.$ U3 d( {0 S- h# |4 f
5 y( m% R2 k! m  z$ ?# D) a
MP2
) k# f" e4 \+ d3 E- p' T2 Y) { 2084102 2084142" k6 Q' I1 y7 _& Z1 e7 ]
The problem where the part failed to save after edit is fixed.' ?+ u% V2 J+ U8 M7 h; k: M
* k" C0 P3 P) a2 k: {/ D
MP2# o0 n# u0 N5 x8 G9 C5 J
20841547 w* j6 Z+ A  E, `, t* b) y% [! F& {
The problem where Blank/Unblank component while in the sketcher or while in a global functions (like Extrude or Chamfer) would cause an error is fixed.
! }% v* G( U; Z6 B9 V! b# b
, g2 E% Y0 S9 W% c8 b$ \MP2
! r% V, T% ]/ z+ [ 2084195
  V! S7 m0 I" `4 {1 c The problem where Save As an edited top level assembly caused internal errors and some parts failed to save is fixed.( u* [/ V, j" _
, E( w8 k# u( B4 z
MP2- c. h' L1 _2 }5 ~4 h* t
2084218" |. T) ?0 K2 x/ O
The problem where importing some parts would cause an error is fixed.
! f/ S* f4 ~7 n+ {  V ) t( r. r1 h; `! O3 M
MP2
; X+ m, G0 C9 p* Q 2084231
  C6 Q: r) O0 g& _ The problem where Undo allowed the reopening of custom symbol master files and caused Save All to fail is fixed.
2 o) |8 p  u; V
* G& d% O3 \$ R# s; g" i* nMP23 y4 s" _% e* a  ?' i
2084503# B! P& N* j. k& f" L: D# a
The problem in Drafting where an extracted edge was missing when the view was updated is fixed.3 Y! m: V/ m: Z3 B: N  N. |7 s
1 _) q; K& |: C9 r. n3 t* Y
MP2# d$ `  S) @  ^
2084571- ~' D9 l- O; {! I2 p# I& b1 I
The problem where editing an extrude body would cause an error is fixed.  t/ O, v9 }9 R/ J6 u0 D; d
' T4 w- Z7 D2 I: cMP2! H3 d6 L( D& b! \" C+ y
2084664
& b$ i( D3 m% h/ M4 L. o# B3 r. g The problem where warning messages were shown while exporting and when doing feature play back for exported data is fixed.: f7 o! W' k  @+ C' u2 D
  |8 S0 w9 a, S. O* U* J$ K# ?MP2& I& K6 s- M0 B; Y! f8 E
2084727 2084591 5723047" `2 u+ V8 U, j4 w
The problem where rapidly switching applications by using the shortcut keys could cause internal errors and session lock-up is fixed.! N% p- Z; K9 c; q1 V; H: w
6 \! ^6 a+ D- N/ O
MP21 b# u3 l  D3 V: Y! J7 X
2084890
% m( P  W* z* @ The problem where Save As failed because Function Keys for view dynamics were active is fixed.
6 I0 J8 a7 k& y
6 n5 J( q* i" c$ q4 x+ ?MP2
8 m, Y% B+ M: w3 p5 A 2085312
% b  F$ ?, ?2 S, C4 V6 r The problem where even though Locking Policy was set to Manual a dataset was left checked out if the Import Files for Part dialog was terminated is fixed.5 d- A% k) t/ J9 r. s
) f7 F0 F4 @9 e8 BMP2
% g, f+ q$ ^% \ 5589513 5516934 5607523
4 ^2 p/ ~7 q% Y  r0 \3 r( G% C# I The problem where hidden sketch curves displayed in the context of an assembly is fixed.
* {! p3 a- B& _+ S# D; w! d; e : v/ C: k5 K' G
MP20 C8 s# u  k! S) Z- g
5600812 1576934 5741567 5741790. W$ {7 n7 m  z* O
The problem in Teamcenter Integration for NX where some item attributes were not updating when part was saved as a new revision in Teamcenter is fixed.$ w3 V& B. n7 d
2 ^" O5 P, m  s: [) _6 |& PMP2" @/ f+ F$ B" l+ w
5700845
& j' p: ^9 h4 V5 h2 F The problem in Routing where editing a bend corner with user function UF_ROUTE_create_bend_by_radius gave errors is fixed.
: g' B4 ]) }# M3 z* F- f
$ P% T- a+ P' a& Y; JMP2
' A8 C: t7 T0 j  e1 d2 K 5716014' j  K1 Q, U7 e# D: s$ d/ ^! t' [
The problem in CAM where use of a custom version of the library_dialogs.prt was not allowed is fixed.
) G& E: A* F" \, q4 c, e  _# R  u9 t3 F% U' _/ h
See Note 2.1 below.; x1 k- i4 R/ }$ ^
2 f2 j+ Y; M! T8 L/ Q, B- Q6 v
MP2( E$ }* g; L& c" ?5 D: [# f& A
5727603
8 {+ L3 N& V3 e8 E4 j% ^ The problem in CAM where WCS did not orient to the MCS when editing a geometry group is fixed.
, B; Z" z( D4 I' I. O& a9 M
3 t3 u7 U9 L* i+ Q' m8 c1 IMP27 a8 [. b8 ~" [5 z0 u
5734181 57738239 @: z. b1 k# v! g  x: ]8 M
The problem where an error occurred when trimming curves non-associatively in the context of an assembly is fixed.3 v# ^* R+ {6 y+ d
2 L) {! y4 R* j* x5 U# _2 j0 XMP2' h5 ]- e) c' a* N6 b' @
5763610% {; G1 ~  ]/ z" m
The problem in Teamcenter Integration for NX where a changed quantity value in Parts List did not always update correctly is fixed.9 W0 B+ m8 E) C' K$ d( J: f
3 T; c# \9 h; ~) N1 f
See Note 2.2 below.
0 h, G6 b  I* z/ b- R 9 p' M3 N0 }6 L" n6 \+ X
MP2
+ s+ t1 K6 B  D. S( E4 G% o 5764714 1601293
# _4 ~! T! x1 ^  ^# F$ J: V The problem in CAM where a turning operation sometimes produced a collision is fixed.
' G% c# ^; [+ }* Y  l8 D! H( m  K9 x( X, }! y& u
The problem in CAM where unexpected results were generated by the tool paths in some cases is fixed.
& w) Z& ?( ^2 I3 e# C- P4 K2 _ 0 V! t& X  p+ b" f
MP2
; Y  T0 O6 T. I. w# H 5765774
" ~% ]  W3 [0 C" _$ @ The problem where there were errors sometimes on Save after KF update is fixed.' H! v: g  e6 g% I% d- C+ a
2 e6 h  ^. H5 p
MP2
/ m# \- n# X7 U+ t1 j 5774758
7 b4 P" a2 r- t9 u, ^ The problem in CAM where the modify button in the tracking dialog did not update the tracking point name is fixed.
/ I* d8 L$ m6 {! ] : C: g! v* @7 x5 A3 K1 r8 J
MP26 j# N. x8 y( P7 H6 V4 S- Z8 l
5751340- z9 _' P7 N; b2 q% J) ^7 K
The problem where there sometimes was an error when selecting an indirectly copied projected distance measure feature is fixed.
0 U* M- n' ~$ ?/ q4 ~  S+ q! ^6 G# |
: Y8 E; u$ \: t& Z1 N" [# mMP23 `# L0 w2 p9 Q) U
5784497$ w; N- W" E+ P
The problem where the projection of a point along a vector on a planar face sometimes gave incorrect results is fixed.: h4 _$ v3 V+ t& y, n% v
. u! X. q9 u9 d5 `* n- \
MP22 P$ i# Z0 |  e; n% M
5795068 5793870
% |3 }6 U/ X+ }5 Q: @% v5 M The problem in Checkmate where the custom dfa checkers sometimes gave errors is fixed.; q2 ]7 n* W' r$ d( h# y) m
6 {1 T  [1 H7 `, ^+ @2 l. s  ]% \
2 E2 z' s0 m5 S - w1 l* L0 d8 U) k" I
2 J( u8 t' L/ C" t
9 C& C  D1 G- J" Z1 S! |' l9 ]' T, C& r" q
! x% z4 d$ ^. l3 uRelease
: ~- G% |/ w' c! Z  `9 D PR Number% }3 K( U% u0 e$ j
Problem Description- r9 w3 V" H, B( ?* A& }9 S( ~( w
% F9 e4 I" d# H* ?. {* W. W5 `
MP3
: [: m+ V* e6 X$ g 15392558 g3 @/ j4 V' S/ b
The problem where NX Open user function UFAssem.InitMc was wrapped incorrectly is fixed. This also fixes the methods dependent on Mating Conditions.
+ V0 }3 P6 \- L* g& }$ X
* w/ f; W, n1 u+ M0 ^" ?MP3
' t" d( X5 z* u( o. w 1576652 16077234 p6 Q8 e: H/ n3 Q$ h! p
The problem where importing parts with the CAM objects duplicated tools is fixed.5 q2 r9 Q$ \1 Y6 k; Q+ X" y: `
5 u- ^5 ~! ~) D$ X9 |$ O
MP30 j4 D1 S. _9 B  R4 c
1583470 1593651/ J5 X  M# O) _% Q9 e6 _
The problem where UF_UGMGR_new_part_no sometimes did not work when using Tools -> NX Manager -> Import Assembly is fixed.
: Y7 y% x% _' C 5 s6 J. \& |7 [4 L1 u
MP30 B/ h/ n& p0 r1 B: k1 D" l
1598528
! D" g. O6 g  N2 {: i2 o7 ^$ H The problem in Assemblies where adding a component whose file name had embedded spaces would result in an incorrect component name is fixed.1 _6 A0 Q$ J6 B4 w" L& x- y, |! o
% t9 b" L& U; x$ H  T  ?MP3+ s; c8 a& A9 s: B+ I0 `# @2 e
1602468; P) D+ k& M* Q) y" p& k+ q! L* ~
The problem in CAM where Contour Profile sometimes skipped part of the toolpath is fixed.
/ t: v+ o1 E5 x0 d1 C+ k ( O) ?" c" g; i  `& N  p
MP34 L1 W" }+ f4 y! w* K
1603635) F  A) Z3 S% }9 Q% Q' g
The problem where UF_CURVE_section_from_perpcrv_planes sometimes gave incorrect results is fixed.8 L1 j4 l# b* Z' B" V# K+ X3 D
. J9 I/ K; ]4 g2 dMP31 x+ U$ [- V4 I4 ^# H# x3 u
1606392
' v1 ]0 O; r- f! } The problem in CAM where Zlevel operations using tool-holder checking and a trim boundary produced toolpath collisions is fixed.4 B7 G* W, s1 H% x; Z. G# u
2 R3 F: ?  V' o6 c1 A
MP3  W6 I: W9 U- l
1607027
" q7 h8 U( j; V( S The problem in Assemblies where some parts could not be saved is fixed.
  I" A1 e' P4 T# V( x2 [% w: A6 q 4 A! n( ]- u% q) j7 M
MP3
. b3 x( C- G) A 1607059
7 m+ G9 p) u: G$ L1 t The problem where editing the expressions of a UDF with an NX Open API would fail is fixed.4 \* M: d6 r1 Q, O! G
+ t" A' W( R* W5 j, I# gMP3
2 w& T- `% ~0 ?" W 1607448
) j$ M1 ?  V- k: }) {5 b; g1 Z The problem in Assemblies where some parts could not be opened is fixed.
% t* e! M& b8 k% ]  \  M + ^" A! q  q9 |& e, x; r
MP3) t" `# s- Q* k& `  \  ]& q
1607728 5822844
7 m/ c4 z% I7 ~; G The problem in Translator where ugto2d translated the wrong drawing sheet is fixed.) a) e- \& T& E7 D2 Y; `
3 B2 y9 U0 r1 i; H9 j
MP3' v+ }7 p/ s% F- {% W. K
1609677 58106388 ^' x& p; v- P6 j
The problem in CAM where editing turning tools created by GRIP sometimes gave errors is fixed.
4 S( m. C! n& W' F" P' r5 y
6 W& |0 P/ g2 k$ i" {6 z0 ~6 qMP3* \2 N& N4 p" G& w. V, ?- N1 i
1611708 2087510 5818247 1615500
! s" Q& U  P! `, k; _6 i) \ The problem where some NX Open Java functions gave errors is fixed.* ~% m4 C3 [# A) W
6 F8 ]7 j; m) \2 d
MP3
7 Z- \0 V2 |' ?; q% [! y 1612270; b9 g4 u3 z: c6 |6 \
The problem in CAM where clockwise helical entries did not simulate correctly in ISV is fixed.
( k( Z' n5 p) k1 g2 h # v8 I, P3 g  Y5 \. ^& v5 a' f3 w
MP3+ d/ G! D. H7 X" C6 }  [0 C
2074200 1606250 5741544 5785158 1605556 5814372
2 O* J+ S+ q) ^. g The problem where Part Cleanup on Drafting Objects caused part files with Tabular Notes to open and exit the spreadsheet for every cell that had been edited is fixed./ n  F& o- X0 D* a( I1 q. N( q
2 D; p8 p& o% p- x& PMP38 O, h; N9 D7 W1 ^
2083383 5817236
! w( q9 X2 m3 F4 f The problem where some assemblies failed to open when Enable Multiple Revisions was set in Customer Defaults -> Teamcenter Integration for NX -> General is fixed.5 T: T. v* y7 D' S' j# v
3 w1 R/ ]; D/ F
MP3
: I4 m8 h9 W2 I: u% e 20861459 M+ f+ c$ g$ r% n
The problem where changing the current feature sometimes resulted in an endless loop of dialogs is fixed.
# g' k+ M: X) s: W: Z8 t/ U
+ F$ F+ V1 W! z6 H6 _5 JMP3
2 }$ h0 @9 [, F+ s' e( [ 20863956 |  z2 g5 [- H5 z) V
The problem where in assembly context the measurement tool sometimes showed incorrect values for extrude is fixed.
5 \2 B9 l  x9 k  w ( Q& K" L$ E: y: m! ]) \* H  c
MP3' l# z( P+ Y3 E% G# R" G  z# J5 R
2086458 2086331
4 c$ d# E. ?5 u% h; p The problem where the measurement result between faces was not displayed on their own objects is fixed.
1 Z6 s" H. y3 W! v  S( wThe problem where the measurement between a face and a point was changed after repositioning the component is fixed.
% o& T6 T# v2 A6 T5 S4 C; H6 x. D
2 j  s' \: A3 m% k8 p- O& Z( ?6 T7 IMP3
4 r! j- Y4 ?) |9 J" F* _7 G 2087340 55897217 A% J6 K, e0 q! s
The problem where Part Cleanup -> Delete Unused Objects would cause the empty Drawing Views to update as imported views and display the model objects is fixed.9 ^2 u4 x( O, {9 D/ [
0 U% u0 s* ^0 `# ~- dMP3+ a. f. x- w& {6 S5 ^% M
2087580 2087582 2087607 5817309 2088217
9 V% n/ \$ d: P+ w  k  l+ x The enhancement to manage the opening and closing of the custom symbol master files such that they are not subject to being reopened if the user undoes the creation of a custom symbol is fixed.) ^! \, K' }9 o5 \% g0 `% J3 b9 Z
3 ^1 G# m+ P2 z# x) ~The problem where undoing the edit of a custom symbol would cause internal errors is fixed.% q$ V4 v! Q; \
1 f+ E# O1 j' V. M* ^
MP3; {% S, X" d+ E0 e; H
20881349 y8 |: G' ?  z: ]
The problem in Drafting where sketch curves could not be selected for use as a breakout section boundary is fixed.6 k3 }- ^5 d0 j8 h% T; D3 `7 `# `) q
. D! q* n. N+ x! H
MP3
* e: k: P( ]$ w* f  G 5711183 5744437 5744504 57451541 o( g) J8 ~, e. [2 q" _
The problem in Die Engineering where Product Replace gave errors is fixed.( Q* [9 @4 m, C/ e  r$ Q/ g- W* i. ^
The problem in Die Engineering where adding a second symmetrical die tip in the DOL Assistant did not position it properly is fixed.
7 u3 {- [& c( E1 m( T8 dThe problem in Die Engineering where no die output was created in the DOL Assistant is fixed.
% R; u" H0 E$ sThe problem in Die Engineering where a pierce task created a hole in both sides of a channel part is fixed.* W) B  ^- f9 u
# T& H7 k( r) c; k+ c8 c- p4 y, B5 Q; CMP3
" G$ O/ P2 |' X* j! Q8 u 5738718
9 a% I% r" {% @: R+ W  b The problem where Checkmate routine mqc_isBlankedEntity gave errors causing all custom checkers using this function to fail is fixed.. w: R8 O5 A) E( [' [0 |4 @8 l
# ?/ K! D* L- a( d7 E) u4 X, u
MP3
8 n' r  z1 M; _$ y 5743478: i4 Y& N. G$ z' H- i0 ~/ b
The problem in CAM where the ZOFF value was modifying the Z coordinate of the top of the hole of a Cycle Motion is fixed.
5 o/ t: i! C9 _6 p- C( [6 a0 i, E
5 X; u0 E, y. sMP38 R& s1 Z0 t5 f( Z6 ?4 C
5744528 1593654
# }  A4 e$ g2 \9 B  h/ P The problem where the Esc key on Unix systems keyboards did not function when the Caps lock was enabled is fixed.% T3 y7 m7 Y0 B
. \' A' {; _6 F$ J, nMP3
5 K" E3 x8 [& [. n( e, X( U0 ? 5761056 5775827 1604152 1605557
+ _) o* [6 T" h: U: N3 t7 r The problem where trying to set a return date in licensing_tool.exe gave an error on Windows XP 64-bit is fixed.- ^. z, L9 z+ Y. \- m3 H
. P: d; N+ T( n4 i# \, nThe problem where licensing_tool.exe did not show the Borrow Selection tab if something was already borrowed is fixed.
; S) Y1 r8 F8 ]. `   Z* }5 ?- o! F: R* I$ l
MP3) B) s: }, q( M
5767111 5792225
8 |! Y$ c) P/ J The problem in Routing where component ports connected to stock components were allowed for locking is fixed.: Y& z! ?% E5 S
! u, y4 c$ Z- y5 Y) m
MP3
; [$ j: P4 z: e+ D+ z& H" ]; J 5768340
! S2 @1 f; R0 F The problem where an Advanced Assemblies license was being used while restoring load options is fixed.
1 ]2 ^; j8 ]2 Q+ T
1 v7 r8 l+ L9 w" O7 _" i; \MP3
* d4 t+ d  }% @! B 5780288- P2 r) m. D( Q1 g* \
The problem where Analysis -> Distance measurement could not be made to a point where a line intersected a face outside the face bounds fixed.
' ^' K; ~9 S- f7 @- p$ z " R  t6 \% A* K% {: B4 }4 {# u
MP33 N5 o' `* K) X
5796021 1611806
" y+ c) ~  J7 p6 S/ _0 v+ j1 s8 d' t* s The problem where certain data from a Solid Edge .psm part file could not be loaded is fixed.
4 r* H- j; P6 T; |+ i
2 ^0 i# k9 w3 F# w: @( jMP3
! A6 y2 w, J+ e! {* Y 5807251
: i) o. Z/ [& I- n5 [8 I1 f. | The problem in CAM where changing the tool holder parameters did not change the library tool definition or its graphical representation is fixed.
' w) m5 d: g$ `1 N5 B% A ' d% C% W: `' E. a6 N' g
MP31 R" C6 V5 A8 [% A
5808019 5821707 5812468 5818008
" q  m- m! \( t; p  s- k# z5 e The problem in Routing where no solid bodies were generated after executing Auto Route is fixed.
" k* t. n1 y+ `2 r' P4 N9 x 9 }/ v' M' r. g* d$ g. e
MP3$ Q" T, F& r) F/ M
5808902 1611355
! a' f. o5 B6 G6 B# A2 z7 \/ W; G The problem where selecting MENCMachining operation in CAM Setup parts created in Teamcenter sometimes caused an error is fixed.
+ C$ E% D* ~9 ]5 M1 Q9 G& j % U+ e# a* k( r! k$ P9 G, B2 q
MP3
# `* ~) k# O( P( t$ Q 5818315 58039778 ]* e' t' q& d7 d
The problem in Routing where there sometimes was an error when deleting paths is fixed.7 {1 M2 v1 c0 m" _  b6 C9 O7 D: @
6 u5 p! r+ X* c3 b0 t& r% Z& `4 V
$ l' D2 P8 O! ]8 c3 {' I% c6 I: w) k4 O4 H$ z: x. p
5 X- f* L) e8 F* A4 p! u
6 `% j' c5 _) x0 d) z! J- [
Release' j/ g: h' v5 F
PR Number
% ^" c! x& N+ z Problem Description
/ }; _; E  q6 s: ~8 S, t7 A3 o
/ l  U) [$ D' k! C7 d  M+ {. iMP4$ ?8 x+ ^+ c9 r# h; @2 g9 y
1537510 1506815 1507679 1598369
! R) |9 X. p: w. |) `$ Q The problem where the CAM data manager failed to import PTP files into Teamcenter is fixed.
/ K% c2 ^+ Y) F& C% B' G$ [ $ G; f; C* M+ K
MP4" k0 a! D# C5 _6 S5 e
1585679 5829096
4 @5 |# Y, l0 h$ E9 E0 e The problem where initializing CAM from a template which contained a spun outline feature caused an error is fixed.
- a- y: y5 K6 u" n7 X
6 Q2 N1 a( h% f, _/ v7 r. x5 v# UMP4- \8 F3 f$ \$ ?, p) |* G9 d& v1 q) `$ O
1586517
" Y* @* \- ~9 b& ` The problem where NX Open function UFClone.performClone caused errors is fixed.
4 s: w; R* h( }0 B: l2 O * T$ F6 Z" X6 e. o* k! b
MP46 P3 O, F# H  ]4 V
1588346& w: u4 B: P- U7 f: k
The problem in CAM where the material conditions for feed rates were not retained in the Wire EDM operations is fixed.- m) r: n& W$ V4 d% e
# M" p' x7 \* s' [9 g" H8 yMP4
1 p2 B( e; R# a3 y) W 1590390 1590393 5772554 5774139 1592337+ t  n% A  K8 z# D; r  m* c" h- M
The problem in CAM where the WCS orientation was not restored after editing a Turning operation is fixed.
  A: f- [8 M. B$ p! ]. N' ~, p" p2 W, X) J. s6 n' R- X
The problem in CAM where changes in the Synchronization Manager were stored although the dialog was exited using "Cancel" is fixed.4 n  c/ e, f' l6 R  C( u3 |
) A5 F3 Q7 E8 k) f# o+ KMP4, n; }; ~+ `- o& n! \
1592839 15948286 m# Z, t/ S9 p
The problem where no sketch parameters were shown in the details window of the part navigator is fixed.
) T* M5 V* V/ J% q, x8 w4 b: d ; I2 J' m2 L6 s  i5 w( c
MP48 ?+ N# m* O$ o: ]$ j3 s$ E
15963080 }- I- r" j9 V9 }6 q3 ]4 C
The problem in CAM where the Graphics Builder functionality did not work on Windows 64-bit is fixed.
$ L( Z. V) G7 c
8 v2 K  C7 t% X7 }! R. u5 MMP4
) A  N$ J. O" E5 _0 q! y$ h 1601235 1615921 1620205 1619713; m- A) W) F5 k2 Y  S2 j
The problem in CAM where there were errors while creating geometry or a geometry group in Hole Making feature is fixed.
2 n; D1 ?3 a3 P  i5 F4 V4 ^
! A) D7 F* C- e9 z1 x  tMP4
$ h9 M+ R- H3 _* H7 b- O- p 1602179
! G' ^: e1 a: x, t# m. B The problem in Assemblies where some parts failed to clone is fixed.6 z7 i3 v) }8 e1 F4 o
3 _$ P8 V* K0 t; C4 \6 f9 a  QMP4
# y  L( \3 v' d% M" T, D2 V 1603632  A3 u$ t4 q+ m; k: h) y2 v
The problem in Drafting where the notes moved after editing expressions is fixed.
2 o% q: ]- V* G8 Y7 U. r1 X # R  |, B7 o" F: Z$ y! a* O
MP4
% A9 l0 C1 x9 Z$ Z1 g, C6 ^0 B" ? 16039285 b6 e1 \+ U+ k; |
The problem in NX Sheet Metal where the Normal cutout failed to update after editing a related expression is fixed.
& u) n* c% @5 `- V( l! `" G 7 G- t2 t! C; h; O  h+ M
MP4/ s; ^" _" i& k' l3 X
1604785
% v5 Y) h! O6 W$ H' a( x The problem where in some cases copying CAM operations in Teamcenter Integration for NX mode failed is fixed.+ C- x$ }% z% I  I- Z% e* L; Q  e
: Q2 L% k  F. {MP48 O  ?& K5 L4 x% H) y5 g
1605301 1559682 4815100, k( y. g0 G. B3 t% m" f9 W
The problem where there was an error for interpart expression names with a '~' character is fixed.
+ x6 g, G* z$ i; A   g# R' O1 C$ }& Z
MP4
2 v9 }& r+ x4 D4 [0 r: V7 f: u# ` 1608413 58181667 g+ u, @% }1 l4 i# }
The problem where legacy datum planes in some cases could not be edited in the new Plane UI is fixed.$ u% _0 }: m$ l; }! H8 U" x
/ ?1 h; ~2 x6 A( V* I9 a& F2 AMP4
9 p7 n3 Q+ G0 U* a; O 1608881 1609686 1610836
2 n9 n) Q7 I6 S7 d+ m7 {5 T. _ The problem where 2D Exchange translator caused errors for some parts is fixed.+ F3 x% A4 B6 c5 \0 ?
# G  L! k, A( f5 v2 T
MP4
" y! B/ k3 j5 [* N$ G 1615384
6 X$ P9 @% y; z; \4 V: u/ `, E The problem where editing a Studio spline caused errors is fixed.
+ b4 h' {7 [# J2 s- f6 Z$ i3 \7 m- U
' L4 }; v. [7 e3 Q5 GMP4
1 b" X, Z9 R1 ]% Y5 @; Y 16160181 B1 G  N( E$ T6 @* B! E
The problem where trimming a curve with point in an assembly deleted the trim point is fixed.
+ G) ]% \  |& W# j3 ?& p  k 5 B% ]. _5 X9 V  U/ [
MP45 ^2 v6 w1 H6 x1 S. Y$ P9 K
1617934. C& D1 n2 i& J1 C8 i( U& D$ n
The problem where the suppressed components were visible in the Assembly Navigator is fixed.& x6 U; _+ U0 F" Y' B/ c  j
: s: G. \, ?/ H  UMP42 E2 Q" y0 b( T& F
1619472
! J' K4 n! B+ g The problem in NX Sheet Metal where editing a Normal cutout caused wrong results is fixed.- E# W5 O/ C$ r
$ p; G4 X9 V9 y9 c
MP4
6 u* H1 D! s) H# L# I: K& ?9 d 1623409) [) u$ B1 ^+ y: @* V6 {) v+ p" C9 ~& [
The problem in CAM where the CUTCOM operation was not generated correctly is fixed./ C; b; ]3 q: ^
. \# Y; C( B! r0 LMP4* ?/ Q: w" E- ~  d
1624004
6 E& Z" S5 V6 C" X' T# k& d; X The problem in Die Engineering where some parts could not be opened is fixed.
6 e3 ^7 r( b6 y" X; W+ P6 k4 F
+ ^  a: r& ^, g6 nMP4: c: x; ~! `6 i, d* W$ {
1624447
4 I7 S* _2 m& T, K! | The problem in CAM where some Turning operations was gouging the part is fixed., B$ P3 f" q& L8 F8 n% J/ G% z: N, X
8 H" s6 w: U* G3 x$ b1 }
MP4
5 O, _& O1 M4 F. F9 O" ^' W+ j 1626652
; \' ~0 E& B" G8 Y) @/ w8 J The problem where creating a Datum Plane with a null angular value would cause the software to stop responding is fixed.+ [7 q$ }# W9 C, m$ C
( G: ~1 o' q7 q; d8 T3 hMP4
! t6 h* b- |+ c6 Q- V8 x8 G0 }% w; @ 20713325 k/ E! H/ }: J5 p5 T
The problem in Drafting where the NX Open function UF_DRF_set_custom_symbol_scale did not change the displayed symbol is fixed.
! G9 o" V/ K8 ~& j0 ~6 } ! Z2 h3 B% \- ?" v) v) `
MP4
9 H1 v1 w6 E. d5 D0 I  K, W 2083851
2 V! ^" L* W/ c: z4 j6 S The problem in Translator where toroidal surfaces were untrimmed when imported is fixed.
5 q1 _! E$ n0 q# B" @ # h- ]  b& ]3 G7 A9 A
MP4
) `4 N# v# n; G" B! n 2084900
& ~2 N3 H+ q1 v" w8 b, t# \ The problem in NX Manager where there sometimes were problems importing an operation with clone log is fixed.9 b+ ?9 Z' S% }- V: H% O# F8 ^
7 Z& F  G9 N, z0 Y! z
MP4
0 K- L2 z# N3 Z 20857812 {1 w: N6 h' r  {7 v( I
The problem in Drafting where in some cases the revolved section line was not created correctly is fixed.
" {( ~" }. L( V& v" e  o5 E " G) G+ N0 |4 ^8 G+ {2 \. ?1 S
MP4
' k) o/ Q: K9 E 2087061 2090739
$ ?) ^' N; f+ n1 y The problem where in some cases entering the expression name of a Sketch dimension caused errors is fixed.
* E3 g( O2 N. M' `7 a" }
# S( M" C' W& K5 sMP4* n* S7 r# @! D. ^
2089227
# A. ~% Q! L' G The problem in Drafting where some detail views failed to update is fixed.6 C, ]2 r, i8 F) X2 ^+ o; s
& M# u# [, {* i8 pMP4' d3 h$ C9 ]5 O' F* B- S! N/ Y
2089461
4 d! ^/ S  U1 Y2 i The problem in Drafting where importing NX2D files placed splines on an offsetted plane is fixed./ {* l0 N# H+ Q% Z: X5 r6 V0 X
! ]# ?' [. n; @5 ?& M- P; S
MP4
; N5 [) U* p' M+ D( Q 2089795
$ y, s- X/ Q& h" M* @' b The problem some assemblies with multiple revisions failed to open in Teamcenter Integration for NX mode is fixed." M; I; [2 R1 f) u" \9 G
# ]: [4 `0 ?- E$ d0 V
MP4
( Y* J5 V8 Q, c3 n% o( A( B 56524205 N% u$ F5 f+ j1 V( y! x5 M: O$ S
The problem where some parts could not be opened is fixed.: K$ \& p5 D- m% x: Z2 K" k9 J5 h3 R
3 Z* s4 z9 L) f+ s/ L0 o, }& k: [7 i2 P! dMP4+ m: w8 D! e9 Z: c7 {
5732861 5732852
) D1 x% x  G) b The problem where the KF enabled UDFs could not be repositioned is fixed.
1 \. X9 F8 s  k  L4 s: f8 P 6 A% e9 E7 E) F
MP41 s) u4 ]! [; t, i1 J
5737755 1617294
! e! P! J6 C- \2 m The problem where the NX Open function UFCgm.AskSessionCustomColors closed the session is fixed.* d6 J8 E! k+ |0 I, b
+ c# F* K$ r' s2 S+ r# z# JMP4; ^, ]2 j6 R- Q3 Q
5771154
1 ^4 l6 D. C2 k- b% b; w2 ]6 k7 K The problem in CAM where in some cases a small linear move was added at the end of a circle record is fixed.3 `; [1 o3 g/ d4 }% S2 D" x7 K% ?
9 i4 h7 v; [( ]8 |; E
MP4
- n- q; L' k, E1 v  N/ t 57874647 e. R& k4 Z+ \
The problem in CAM where a Drive Curve Lathe operation caused errors is fixed., u' _" a2 [7 c/ w4 M1 d
8 c$ _: ~- V8 y) oMP4
. @7 H7 S+ l+ Q% X& t+ y' k 5796021 1611806
+ X! j8 R: b7 g3 J6 z The problem where certain data from a Solid Edge .psm part file could not be loaded is fixed.3 u2 j3 N, Q. E3 t' l& P' p+ {
. G7 Y8 k' @9 {) M0 C6 N% F5 p
MP4
: s  V3 x; g9 n" r1 Z$ i 5799635 57961755 V/ O; Q4 q  l! C3 L. a
The problem in Progressive Die Wizard where the thread size of pocketed feature could not be changed is fixed.) S3 K2 j0 X2 s3 Q. }- T
3 N) W" h5 F, Z* T6 H1 N
The problem in Progressive Die Wizard where the pocketed threads were not recognized in feature parameters in Drafting is fixed.- A, N) v: {% i. G3 O) F$ H, |
" V3 E0 U# ~/ n
MP4
# A, Z5 K" A" d6 E* D' b 5804114 5594321
  i1 n7 O) l+ a9 ? The problem in Knowledge Fusion where DemandOrder degraded performance is improved.
1 S% }. ~0 R" R; P 4 B; u! [$ j, d; o7 `7 `/ t( d+ o
MP4' h! s  J; c4 q/ ?; h, ?, H# K2 v
5817976 5817558+ H8 p/ T/ }0 k* c8 F, {8 a
The problem in Mold Wizard where the customized ejector pin could not be trimmed is fixed.
$ n1 T7 e8 {: o* Z ; q4 `- L6 {. X6 P
MP4* r$ d8 D/ m8 m# L+ n/ V
58258207 k3 K$ `! m! i. U1 {, }, A
The problem in Drafting where NX Open function UF_PLIST_ask_tag caused errors in Teamcenter Integration for NX mode is fixed.$ [1 B1 K4 ?1 n# r! J+ F
" `9 m  F( g5 f% R$ f2 nMP4
, q6 o$ l2 v# z9 t, v+ { 5829637 5831201
9 o/ k% t& T" w' h6 \# c The problem in Translator where some IGES files failed to open on SUN/Solaris is fixed.3 q0 i4 z6 Y9 C$ u# A
/ ^& n0 l8 ^- o" e
MP4
' k% ^. E4 o) K' W: u3 o  S, u9 D/ j 5830362. y8 S) o# [0 L7 B
The problem in Routing where using the Modify Path tool in Formboard application degraded performance is improved.( I0 A& P7 g3 U$ }. _$ n
8 w2 Z; _3 Y) R% F$ GMP4  E! [2 A( |6 U
58356884 V* q3 n% T: M8 W8 w
The problem in CAM where NX Open function UF_UI_PARAM_edit_object caused an error is fixed./ y+ m/ I# X1 z" E  L6 A
% P# e8 T4 @1 A& d, r2 cMP4
3 _- _, F2 f1 t+ ~( O" I: S, ? 5835909' W  H3 D( n6 I# l
The problem in Routing where cable outside diameters were not used in the bundle calculation after importing the electrical data is fixed.3 {3 s6 s, b/ a( u1 O1 O0 o
8 l7 Y% C- w% j4 Q% P
MP4( c' J5 V9 o9 z+ ?# Z7 j, O: _5 h
5841540 1624573
1 X% g9 h/ e" N/ x; U% d- l The problem in Routing where assigning stock to segments degraded performance in Teamcenter Integration for NX mode is improved./ ]" `6 A6 R! A8 y' ]4 V9 _9 i
3 r" L( `& b$ |) v
' ]0 q% U' I& N2 }( q! }7 Z & ^  {2 J  |$ z# n% C+ w# y
- Q8 u3 Q, O  TRelease  T0 C) m, z! j; w2 t4 u
PR Number
5 E! f! H/ o' v% ?2 l Problem Description$ i( d3 O& R/ Z
; `9 U/ k- j) u! X4 u
MP5+ [" @& w! K- H) x
1597581# F/ L# {% ^" Z* J
The problem where there was an error when changing the displayed part after canceling the PMI -> User Defined dialog is fixed.& C6 ]5 M0 q- a+ j8 g
% V8 g4 d% e% t  f; v
MP5
; O& Z/ f2 M8 _' e2 q: v5 O$ l 1598405
! d( `3 o+ b, [5 a3 }% l" R# Y1609569
' i, M. E8 Y7 N6 S0 r1 f The problem in CAM where synchronization events were marked incorrectly in some cases is fixed.
( x+ n, E" U, H) x 5 z5 ^4 B; H! m
MP5
, F; D! _5 R  f9 f 1601647
/ K( B+ Z- @8 ^20844415 U; T4 K1 S6 b/ |
1623759
. p/ G4 q* O/ E! [1640894( F) M% w  B+ ]% x% W/ g9 J
The problem in CAM where some Fixed Axis Surface Contour tool paths were not correct is fixed.( r. g" h0 V3 V2 H! R$ d( g
The problem in CAM where some Cavity Mill tool paths were not correct is fixed.
: i% l1 G. Z2 P8 AThe problem in CAM where generating some Zlevel operations caused an error is fixed.* n+ j8 h7 Q& T. E) K0 K5 s/ Q. F
The problem in CAM where the Surface Contour tool path was not correct in the corner regions is fixed.
, P9 k( r2 N5 M6 j% |6 [2 N ! j0 {1 Z0 p; s' W2 R* \/ h* @  a2 N
MP5
$ S: Y: O( S2 @$ \% R; l- p% b 1612265
/ e# G4 r1 C6 \/ H1541707, [( `& D& V1 @4 [2 i* s
The problem in the CAM PostProcessor where mom_csys_matrix was not working correctly is fixed.4 Z$ H+ u7 x! c/ x( m2 N1 |4 B8 ?
9 P) Y5 m, F+ f) m; _: x6 n1 P
MP5
4 f& ]& t/ O' W; k 16190369 z5 \- j7 A# S: M
The problem in Drafting GD&T where an error occurred during feature playback is fixed.
2 O3 J+ Y" R9 g7 x4 |8 r* n4 o! i1 o . Z, Z: c: n5 d/ {: v- B
MP57 ]6 L3 i* m' T2 \8 w
1620202
: a" u3 t; K: x The problem where UGII V4 part files which contained layouts with no names could not be opened is fixed.1 _! t+ Y5 M$ ?0 u0 \
( K) }0 |6 M. g+ C" m  lMP5# S6 H- l+ @" h% `1 U
16203995 Q1 l9 t. k2 n( W: r. H0 {" g
The problem in Teamcenter Integration for NX where sub assemblies were loaded even though the no components load option was selected is fixed.+ b6 A; O/ ?" f7 G( b$ y; v% P
8 k" L+ |7 W0 Z3 x! A8 v
See Note 5.1 below.
% Y2 c1 m. V8 [, y. T* ~0 f8 J : B' u9 C0 S3 |0 W: }
MP5/ z0 [6 m* t5 j+ o; z+ U
1624982
- n6 @/ ^/ }$ s. D2 ^/ f The problem where after the UDF instantiation dialog an additional mapping dialog came up is fixed.. g4 v2 g1 a* _
See Note 5.2 below." E/ L# }9 a0 {1 k/ C3 f4 `% A
9 |7 `1 `+ h% s7 vMP54 @4 n' D8 |: l* Z2 T
1626816! G( t. r3 i$ k" o$ q$ X( |
The problem in CAM where there was an error when generating a Face Milling operation with custom blank boundary stock is fixed.
' f2 v' N0 j" e1 d' @) ]
' O! h3 n4 q) V7 F0 _. PMP55 U1 x8 U* }; T/ B0 ]
1627505: q9 J$ j+ x, R  Y; R
1630088
; ~0 e3 V4 Y% S" s4 @ The problem in CAE where a warning message that a part had been modified was displayed when opening some assemblies is fixed., a: d/ N0 N) s9 N7 H8 [
" _& {" n4 V3 y9 ?8 s* u% S/ _
MP5
2 W! H9 F7 ~- t$ F/ d 16283667 N2 v$ E" b- a
20918486 z2 b' |8 ]% T! j
16366570 @0 `8 m4 G, \9 q# E1 Y
5842946( F% i3 V. c) L' f* T
16316056 z8 S/ u$ x* |1 e) u- r
2093635
3 v2 J* i) t8 o: M2094713" V  V% \  a- e4 E- `
5874124
5 s$ }5 }5 i* x9 K8 K* E) o: ^1633430
4 c& Q% {) ?. u The problem where loading some parts would cause an error is fixed.4 V2 y; @, b( H( h) i
6 O1 h) Z3 N0 c$ [7 C4 I4 ]) u
MP5
" q! N$ L! j. }1 b& W; U 1629064
& f  a& F+ W& c1 Z- M1640493
2 E$ q7 N9 O5 q9 |1 T1 H% F The problem in CAM where the GOTO commands were being transformed after regenerating a transformed Machine Control operation is fixed.
4 b, |. x: ]. A, f7 z2 s& }: Z
/ D1 H$ ^/ {# Y7 H% ~MP5
" M" i- B' f6 Q& B) v- y$ F 16301048 z" H7 a2 Y0 z
The problem in CAM where the tool was gouging the part when using the Corner Control option Add Fillets - All Passes is fixed.
" s$ [5 l5 Z# f0 b6 T2 v' q ! N4 _4 l- ^5 }3 i% R: i
MP5+ d/ w& `$ x! f( y& H9 A6 c
1630327
# K, l. M7 a' a$ H0 C- q16360412 Q8 d% T+ R; j" ~, e
The problem in Drafting where part files containing ordinate dimensions with no margins could not be opened is fixed.
: i9 X3 A! K/ M* g
5 b9 U! d! g+ q8 v" VMP5
; _0 f3 E% B+ E) R 16332732 ^' e/ O, Q" T# @" y/ [5 w; K
The problem in CAM where the Cavity Milling cut level type was not changed to manual if edited is fixed.
, K1 M( H2 P6 [  E 9 J9 S/ x( }" g3 ~
MP56 I1 D. i: ^9 {0 u+ \( m
1635728* c) b9 x  B9 F* ~  Q# l; A+ @
The problem in Routing where end connectors in a newly created formboard would fail to move when branches were oriented is fixed.8 Z& f: l4 f' w8 ], W) t4 G
) ]/ J2 B1 f/ D3 h( X9 L& uMP5
7 }$ U5 Z& ]2 c2 H; M 1635826, `$ q- t6 s5 p/ o6 @0 c  ?
1631837) y) r" Z) {+ }2 D) j$ c
5855031
+ n1 d3 u' V+ M# T1613713
/ o# y+ E& S( ]9 y9 _: Z) T5811343
+ X1 Z6 G" ~' ?% J* g) @5804129. Z# V& {4 P% b5 k1 ^6 y+ L" L' a  q/ l
The problem where the NX Open .NET wrapper methods NXOpen.UF > UFModl > DefaultRpoMenu and UdfRpoMenu did not correctly return an "int" is fixed.
+ y2 `0 B% w3 U9 U4 oThe problem where Camgeom.AppendItems raised System.NullReferenceException with multiple faces is fixed.
, X" d9 f8 D; N; [The problem where the NX Open Java UFKf wrapper method askInstance caused an error is fixed.
. C; s9 ^& L6 Y* ?/ }# s- |The problem where the NX Open .NET wrapper AskLockStatus didn't return any value is fixed.
$ u  e9 a0 L0 E. g% H- ZThe problem where the NX Open.NET method NXOpen.UF > UFModl > EvaluateCurve (wrapper for UF_MODL_evaluate_curve) incorrectly had a final argument which did not make a double array is fixed.7 K9 I' N0 V9 Q8 Y
The problem where the NXOpen StringList structure had a field named "string", which is a keyword in C#, is fixed.
1 s5 \7 @# J, i+ ]0 V: j8 @3 m 9 C- G) \: z; d9 u! Q& L
MP5# N8 y0 v$ K/ }, ~1 Y6 H( b
1636217& f* q% A" A8 F& H' x! m+ S
The problem where the NX 64-bit session end if the Relative Positioning Operation dialog for a Knowledge Fusion User Defined Feature was cancelled is fixed.
/ c, \6 D6 s" D4 ~$ k6 y
- U8 a% S, ]+ X; o) l, zMP5
+ ~) l1 J9 ~/ h, O 1637572% D& p0 E1 F' o* L! a6 a
The problem in NX/Open where there sometimes was an error after calling UF_MODL_dissect_exp_string is fixed.5 q/ Y' g8 P# D% f" U" H
/ O2 g* h1 m! s; b7 C7 b- FMP5) i4 B' `- L7 N" W+ \
1638039, i* |2 [! ?7 i7 S* U7 x# m* G
20809072 ]( H, P1 j4 ]$ F  p( C  I( T
The problem in the CAM PostProcessor where two different mom_pos were output in the initial/first move event is fixed.: f- j& ?+ \% Q7 T8 `* o$ \- q1 T
The problem in the CAM PostProcessor where MOM_from_move and MOM_gohome_mov were not being output is fixed.
5 g3 L5 u; M9 \3 N' I2 b
4 ~" E' V9 G* B0 G$ \MP5
* O  ~. s- R) n9 {) |! _. N 2082203& }5 z+ [  L) E. o9 s! o
The problem where blanking a component in the ANT, then unblanking that component in the ANT, then after performing an undo the component was displayed while the ANT showed it was blanked is fixed.$ f4 P% n$ Z- u
8 E: J' i: _' E5 m1 I9 Y
MP5
, G' u/ i9 W+ N  A' C( b( {# W; Y 20846462 S! _4 c* O: U3 i
The problem in Drafting where inter-part References did not update normally and caused an error is fixed.
. z5 ^$ G9 A* I3 j9 { % N, g/ S, U# ~' L' }/ Y2 F/ |8 U
MP5
  m& C1 ~6 ]* @4 @+ \1 Z 2085392
' W' U" o/ _$ G* h* D" [ The problem where using Copy/Paste in the Assembly Navigator caused the components to be placed on invalid layers is fixed.
+ o& k3 H0 V* g4 s. Q% M7 B   c* e' w( {5 E0 w- T
MP5! J+ q! G( p5 w/ m; l$ j  r
2087830
5 s. ^- @5 r1 V8 s8 u0 C/ }6 C The problem where Extrude using the limit option Until Selected was not working correctly is fixed.! Y, d9 |# p, [- a* U& n
See Note 5.3 below.
! L7 P& F$ r0 ~2 a' f7 Y" G % w9 K8 H) Z5 |7 L
MP5
1 W# X$ b# `0 x' P8 e  S 2089732
) m2 c+ |2 K8 Y7 E( A The problem where some part files had empty tool bodies that then disallowed any further modeling commands is fixed.
6 M  l' C7 s. E. [$ K
$ Y9 e& l" I7 b& U$ h; \' w& MMP50 T+ s+ @! S( }" R
2091914
/ ^! P( Z" r8 f' D0 m- y# z1624846) o1 Q# u* |* f/ ^
20922858 v( N7 s& o- [  `. L) _8 ^7 l
The problem in Teamcenter Integration for NX where an assembly structure was not correctly updating in the Product Structure Editor (PSE) when that structure was already opened in the PSE window is fixed.
$ W& t, ]/ U8 B
/ h/ \& j; O; Y1 C  @MP52 |/ S* Z% j+ h3 Q$ b' t- R
5773519. Y& \( T- z- ~8 ^) H- W4 \
58218756 B' p, p* A2 c) g& X
5895083
5 y2 K% J  Z" `5 X The problem where it was difficult to select the datum planes of a Datum CSYS in the context of an assembly is fixed.
- q5 _4 R! J9 l+ U
6 @4 T  M$ C. M4 K' LMP5
6 v% p+ b* M$ F$ x1 l" o 5791576
4 c; @( S: @8 H( j/ K! ]7 t4 G0 q The problem in Assemblies where repositioning a Routing control point caused an error is fixed.
: J( ~% ~. ~( J6 A7 U, W
; e- }9 E+ a/ S$ O, u: tMP5. _% m' a9 m9 g  d
5792083
- l9 z' F4 Q0 A The problem in Routing where the "routing_combined" license feature was not correctly issuing the correct number of licenses is fixed.$ ^" B6 t( q( E, C
& i8 Q5 h5 ]2 ]& `5 M& a
MP5; z) b, b1 S$ ?7 n: e/ i
5805943
& |2 x0 v) _# e: T9 R- W5 H8 @3 a The problem in Routing NX 64-bit where adding stock to a path did not work correctly when the display and work parts were not the same is fixed.- K" E/ I: T7 B% v8 M, w* g
5 F* v2 B( P, E0 W+ _; h
MP5
- s; b; a0 ~( t* L; b3 Z 58088873 n" N/ Z- K9 X4 m/ S* Y
16019198 j. }: ?3 p4 R  _: W
1639301, K( R% m# m0 T
1639981' @( K7 {6 {$ Z+ F" g2 B2 l4 N
2094495
6 l6 \% H) j/ U* ?; g2094658# R1 X5 O. I  K$ j+ |7 m" a
58888229 G1 D1 b6 D/ u0 e5 @
5808887# Y$ W7 k' h/ C
1545311
& {3 C7 S. h! s1630983
% y) g; b9 m+ M* ~) G1559168% B& Z: K; C; R' l$ Y' \9 @
1561364
$ A: d+ `! {9 Z3 O1615786
( |" ]& _/ f9 o: Q- [20772751 n: p. g) H/ \0 m# d4 R+ \2 P
2086526% {( @4 L6 H7 M0 s8 x
20886746 G% x0 c7 j+ x8 K. t  S( K
5718065
* N" {3 D6 N; F& }7 d8 L5824588$ m# G1 {/ H3 b! o, Y, ~+ Y& D
The problem in Teamcenter Integration for NX where Save As did not work correctly is fixed.
; _/ G) Y0 g3 e7 X4 Z+ G7 G 3 g' ^3 o4 ^2 U& a; i7 X" }6 t+ Q) I
MP5# i3 v% e% M. l# U8 \) `
5828360
  W3 v3 d' Q9 H; d The problem where User Defined Features were not being remembered in dialogs after initial use is fixed.) T8 I% Y6 e2 v
$ a: _( \5 E$ t2 N6 P" T: CMP5
, F, U- p* ?( z0 S, x1 K+ m! x9 ? 58312424 l0 H: i8 B  O8 Y: G) ~% i0 Z5 J
The problem in CAM where Visualize did not show an assembly tool in the correct position after the tracking point was changed is fixed./ y2 J- y, n6 h8 y$ }
; i4 X4 Y6 K, j( Z9 H, Q) K# a8 W5 jMP5
% w( H5 A$ w2 o! n 5841021: s. |6 w1 p2 r! g  G
The problem in CAM where the Operation Navigator did not update when the work part was changed in a User Function Program is fixed.+ J; o. R$ U+ M& b: |
* S4 z: o: Y4 X0 B% ?5 h
MP58 D* r0 \" r7 j" j3 {+ {2 W0 W. ~
5848184; a& x6 `+ l$ T: d7 Q1 M3 _7 s( o
1593710
& ^+ Z$ ^3 s- I0 L' T2091570) B% N7 ?" W! e( W* W
20909896 b9 |. `; W, k; j- q; r, s
16140850 R8 u6 J/ t+ y
2082573
* [9 h/ L7 N) M  m4 Y5812561
# |* |' ~' O1 r9 I) Y# y58404888 r# E3 j, C9 D' T9 ~4 I
The problem in Teamcenter Integration for NX where the assembly component quantity was not correct is fixed.
: d( `0 Y6 W# ~" g9 b- pThe problem in Teamcenter Integration for NX where the environment variable UGII_UGMGR_PLIST_SUPPRESS_WARNING=YES was not working is fixed.
9 A( J/ x4 b8 F& Z- P9 r; FThe problem in Teamcenter Integration for NX where there was a "Parts lists will not be synchronized" message occurring unexpectedly is fixed.' n$ {. [: S, a) J
The problem in Teamcenter Integration for NX where after editing the DB_PART_NAME it was no longer possivle to display the latest Attribute is fixed.2 v7 q) K& V+ L7 V
The problem in Teamcenter Integration for NX where components became "reference only" after substitution is fixed.! }* O+ s7 o  J. d0 a
The problem in Teamcenter Integration for NX where the Attribute Object of a drawing was not referred to correctly is fixed.6 s4 X. C: m) G. V, t+ b
+ n2 y* ?3 k! o9 h% u' c) L8 V
MP5. a9 l* V+ o- C+ h) D3 J& a' H. r
58525834 V: o# t) G4 T+ q$ k( a; T1 V
The problem in Teamcenter Integration for NX where extra parts were added to the Parts List and the Product Structure Editor was out of sync is fixed.6 q2 r2 D7 x; f
See Note 5.4 below.4 f0 }* d+ c6 n  D* L) C" P7 L
+ y6 F: j) M  NMP50 o3 T. U8 H6 \7 Z
5853265
5 f& k$ k5 I/ q- n; [ The problem where interpart expressions were not updating correctly is fixed.
' C7 b/ l6 ]* O& `; E 9 V* ]/ h6 V5 e: e5 q2 I. X" W
MP5
& A3 O0 L4 R7 u 5856883
& N6 W  B1 [+ ^# e& P3 f The problem in CAM where the zigzag Cut Direction for Planar Milling operations was re-computed when neither the user-defined cut angle nor the WCS had been modified is fixed.$ p& b- S4 z& I# ^6 r6 M8 B
- f0 \- E- k4 H3 }MP5
$ j6 p( v& h2 ]  t2 A* H8 ]0 k  ? 5866645
' d! ?! S, B! H7 O The problem in Assemblies where there sometimes was an error while updating Drawing Views is fixed.
- g! h* y9 c9 ^$ |9 m , z4 P8 \$ c, C) ~* u' }
MP5# a( I1 a. z& j
58702599 j& V( ?& P. p
58811825 r0 }" Z& A9 V( g
The problem in CAM where some User Defined Events failed to be shown in the tool path listing is fixed.
9 M- [0 ]+ `" O5 ]4 K" Y( Q - O3 l% m6 O4 z9 U
MP5) H1 |: t9 m6 t2 B
5874772
0 X0 ^0 O4 s) i2 X+ P% b5 G# M The problem where there was an error when inputting an existing expression name for a Sketch dimension value is fixed./ k6 x, L  c% q* _. w6 t: [
' B3 x, I  s$ }+ q# N: P
MP58 ~( Y) G4 ~" E! F6 \& _. o: Q; a/ t) I
58752129 Q4 ^  V) |( ]8 S5 z( p; u( a
The problem where there were license errors in the syslog if there was no ufunc_execute license available is fixed.
0 _- f# ^$ a7 B2 o- ]6 k: a8 f0 |
. D: _  D4 ^6 a, QNote: If there is not a ufunc_execute license available, the Open C API will use a feature license and will not output the "ufunc_execute license not found" message to the syslog.7 ~' x- y. m0 h" D
  N/ }. @) p7 p6 w9 }9 I" kMP5
# I% _2 p& P3 }5 _ 5875914
- K# N. l0 C/ q& M# u7 F2 K0 u4 y The problem in the 2D Exchange Translator where notes were exported in the incorrect position is fixed., H/ |; P+ X$ m
( o/ M; D# ?5 A) w, c- Q# d2 ?MP5
; k. N" u3 w) S- B& x6 K  o 5865027
0 B* b. E' l/ O, k, ]' G The problem where Assemblies with instance overrides failed to open with multiple revisions "on" in managed mode is fixed.- M$ K  _& T8 [* x+ `
. L1 v2 `1 I( g) E) X. a
: j+ V4 I3 Y9 {/ v' J5 R  r- g4 {( Y3 h2 M
- o' z. l: P. M# V$ _/ F
/ O8 {2 @' _, `$ LRelease
2 C! p2 G  w' Y5 T) X, Q/ v PR Number1 D- ~# G7 u# b- p  z
Problem Description
8 h  c& L  L* x + R$ M$ }( f2 k" S  U
MP68 U( @) y  B0 ~( G& h
1554060. O: l" u( T- t2 l
1573135
$ r% b, m3 q) S! m1577977) l4 o4 S& o7 M% B4 c' L: T' I
1583912
2 L- ]( s  J1 P9 S* z: X3 q- c1596624
5 e8 }- f" e0 `( |) Y16058113 `: |: P9 s' p3 w5 \; L
16149150 r- R$ C3 j$ h/ O8 G/ ]
52201186 U8 P" N% ^+ S3 R% ^  x
58867939 v2 f3 r; g8 ^5 J6 \9 n
1555056
( _5 z- Y% |, \1 e/ I( e; _6 n1555086. E$ p& z/ s: ~( b. y$ `
1648313
9 l& Q# @  I* W) w; d1648889
4 Y% p$ d' u* o& P+ b1 E% N/ G The problem where there was an error in 2D exchange due to the presence of a Body Measurement feature is fixed.
! e! i$ X/ e% Y. x* G' q 2 v7 b- B' M$ G; `
MP6* l' r0 X6 L$ p! t. k8 z
1567981
( X3 ?8 B0 x0 z  S; K The problem in CAM where regenerating some Variable Axis Surface Area cutter paths using Scallop Height to control the stepover was slow is improved.! Q7 B% o' d8 L% j
( k. e( m& Q% a5 c9 A) _# M% |MP63 s$ H( x) l$ \+ @1 Z- L7 m5 Z: V. L
1578516
: r, N/ E7 H6 ~3 |1 D8 o, z6 \: N1592524
1 f/ w" k0 Y$ U9 m. d; n5890684
8 q5 L$ z6 ?/ N' Y4 I  d The problem in Sheet Metal where Straight Brake flange created the wrong unit for the angle is fixed., \3 h+ @  j/ W# _1 r$ e8 o' k' A
. M' A- z+ U0 |/ K! j$ o
MP66 N. D& j6 @; E# g* S4 Y- g9 L
15839657 @1 @& h9 M2 C9 Q9 D
1591337
4 }1 j6 S% R3 P: k$ ], E) ~  @ The problem in MoldWizard where the hole report identified all hole diameters to be the same size when the counter bore diameters were the same size is fixed.
; s; c! z" v+ w0 w2 i" s/ TThe problem where the Hole Report did not sequentially list the categories correctly is fixed.
( J  j$ m4 t0 o! H' q 1 u. v5 O- H+ ?7 M' [
MP6
9 \' [: a$ Z1 ]. n* b/ y 1585199) K6 h/ K6 [; a" U, p0 K" y
5833277( c/ s/ N! d6 t, x+ |" ~% X
The problem in Assemblies where performance was impacted during a Save that involved the presence of modified part family members is improved.
$ j) S5 n# y& D% L- ^, \) U % A9 R# w, g* D, H  U& k! Q
MP6
4 y3 }7 j; k6 C3 \/ d8 x 1594083
# f) L* p; N: L! C The problem in Assemblies where the exclude ANT component filter was not correctly restored from the bookmark is fixed.# ~8 h' q6 Q$ K
& u0 F3 n2 T0 x2 s
MP6. c/ w5 C5 i% M; |7 t
1595936
  t& \) ^* u3 q+ P! N/ Z" f/ B5 m2080808, O; Z9 L+ u4 \! O, R. B
1602410
, [6 u, R/ z8 J- D3 y  P. a The problem in CAM where there were several cases of non-existent gouges reported during gouge checking is fixed.
; X( l2 ~/ ^9 k% D' s
* M; o0 M8 q- C6 ]2 uMP6( N' k# b9 @; j) H9 r7 Y
1608188
9 ]2 J. i: o5 M* N6 V5 Y1613325
: [( N4 L" J* A8 w8 O  n1635517
, ~6 n) l& a( _9 u: v5920013) I! r6 d- o& m$ w3 ]- E, O/ |
The problem in Teamcenter Integration for NX where the Revision ID was shown as ??? for part family members is fixed.
  j0 J6 ^4 H( E/ \6 T  }* W1 R " Z2 p* U: q# G" J
MP6
/ A" f6 j5 ^3 h2 N5 R" p- n% l 1610627
# z0 r" \6 M1 p2 v The problem where the NX Window dropdown menu would show the incorrect active part is fixed.6 Y( R* j! h6 A7 a! b* T/ [
: H  `) t1 V, z: w  _4 z
MP6: m  ?% C; @: k
1614718- g: M9 G: p2 _  J% Q
The problem in CAE where the Strength Wizard did not solve on UNIX with UGII_OPTION set to lower is fixed.
7 u" T' K9 z4 f+ a7 c% e+ @ 3 x  }' |2 y) Z. @
MP6
, p8 X# R" @, s 1615424
0 e* U5 r5 T4 ]8 P: l& ] The problem in NX Sheet Metal where the Bead dialog did not display the formula used to calculate the depth when editing the feature parameters is fixed.
" j& X* u, y. h* e
  \5 A" Q5 h- u9 U5 PMP67 X0 v" c0 ]' p& D" Z: F$ X- G
1618013
3 \0 z0 F) t! T# L/ j% p# O The problem where some drawing part files with sub-assemblies that had promoted bodies without parents would not correctly Open is fixed.
7 N& l1 R! C- e0 M8 b! w ; v8 U2 d5 ]: Z0 O4 [# n' o3 `
MP6( H5 D3 F/ h8 \6 f
1618686
5 ^& ^- f- [0 a0 Z; L+ O  The problem in Drafting where there wasn't a NX/Open method to query dimension text is fixed.
9 G; [) E$ D" _& {8 P
" r3 e* c4 O# P+ v8 J5 dMP6! |/ Y+ V+ H, I7 R# n9 }8 v$ y) h
16191658 S# s3 a, s% r- E8 p9 u
The problem in CAM where non-library tools were deleted after changing to Gateway and then back to Manufacturing while working in a Teamcenter environment is fixed.0 L% m3 {( ~: N; S+ N3 a- J% a
# s/ z4 z1 I, V- k
MP6
+ S  _; t8 X" K1 _5 y  N" ? 1619222
. f/ y0 @$ s, T. J3 M The problem in Drafting where there was an error when opening a legacy part file is fixed.5 M, A* T1 ^6 H2 V/ X- _
& j( K9 X0 Y! B8 \. U' [; KMP6
8 r: ?! V' c( a0 y' U 1620524
, M; D' F$ G3 f- ~, x* b1624343  x. N) j- Q' d2 B- f
1630433
/ P3 D( u8 I2 \% A# K' T& I The problem in Assemblies where some component names were too long or contained one or more characters that were not allowed is fixed.
- m) E6 U; u# |
% {3 v/ b5 d7 ?7 |MP6
5 A3 N1 L& X* w; X" p; j4 X 1622657; y' B8 x) R" M+ J0 @$ v
1622659
9 z0 ?7 K2 k3 t" c! ?- L2 F; ~! I9 P The problem in CAM where a Rough Turn operation did not generate the same cutter path on Windows XP32 and Windows XP64 is fixed.
1 Q. ]5 Z! |. R: }5 H 0 K3 {! f8 {1 Q7 \/ p- m
MP6
) p7 z  z5 j) s6 m 1632251
) k, }! E9 ^/ J# A The problem in Routing where UF_ROUTE_is_part_fabrication was returning an incorrect result is fixed.
  j2 b$ z8 u! \: ?3 _6 t4 } ; F- I% Z9 K" G. `5 U) f: H9 e1 w
MP6% b5 ~; h$ D, {4 ~4 i$ ], U+ W
1634754
( d& S+ Q+ J( U& l" K, v8 I0 c1351885
/ {9 _( W" {" T1410457
+ C) J5 J4 G7 O* W2 G1447669
+ q% D3 n4 T! \  R! ~1420273$ L/ b$ U! F9 X
1420293
' u) g4 e; {; y# e) N' g1445161& y1 E7 h* P) a6 V$ V1 j
1494306
$ X# q5 T1 U( R+ @) @15679728 `' q. q9 }+ H, P' k1 z, C- m
1539789$ l( O0 u- @1 N" [  H. v
1541393, o( r. {3 h+ l
1551938
; ?7 f& |1 Z4 W2 \! Q1554453
' K1 I0 g+ d, B1 ]8 V; x4 N2051316( A% g( J  Q, H
2052026% `  R: d+ {9 W- B$ M
51796418 M% t3 B* B9 f
The problem where some legacy symbolic threads were displaced during a feature update is fixed.
; v% B7 x4 j/ p
! n- L+ d; q5 x! }/ Y: j, TMP6' |, b$ P9 }% V5 V/ D
1636917+ V7 k! ~0 O% k9 L$ x+ x
The problem where there was slow performance while loading parts which had interpart expressions linked to an assembly is partially fixed. In our tests, the loading times of such parts was improved significantly.
2 w9 N8 Z/ X" v! {
& ^. B7 ^) x2 U+ }% G- fMP6
+ \0 u' T+ a+ q 16372008 H7 J1 @" p3 I9 H8 M. j- s- [
The problem in Drafting where some legacy perpendicular dimensions were not being shown with their correct values is fixed.. U6 s7 L6 ~. G) s
3 t9 r( r, V2 s! Z% D
MP6
  ~- t1 Z8 Y: z( g* k+ G" G 1638631; u! o0 P/ Z: z6 o, x3 k# y
5887832# T- {1 [9 a2 K3 j
The problem in Assemblies where Open By Proximity could have errors with out-of-date assemblies is fixed.
! r6 M) l; h' c2 m) V3 a1 ~ 4 {6 W" v( o( n( b; T" ?  e  E
MP6
1 i1 B) j3 ]$ k2 z9 W 16387148 I" K, H( L" F
The problem where some parts with an unattached symbolic thread wouldn't Open is fixed.# P! E* B, i5 V5 E* K" z2 D/ c  P* d
8 n4 p# f% S9 n/ x- A) V
MP6+ l6 p( n- L/ B8 H$ Q3 J
1638974
0 l- E8 W1 {2 m4 A$ p# J9 x4 K, Z: L2090414
3 Y/ f, n! m" e. f  c# w& Q3 S5719006
' u" Q2 B2 s% [3 i: A! J  R The problem in NX/Open where the wrapper AskUdfDefinition failed if the User Defined Feature didn't have expressions is fixed.
* Z% C' y& t/ D7 fThe problem in NX/Open where AskCellPrefs (the wrapper method for UF_TABNOT_ask_cell_prefs) failed is fixed.
- X0 `, p/ _. e7 |The problem in NX/Open where AskDefaultColPrefs returned a Null Reference Exception is fixed.
0 v4 o- s2 f: T 4 U& G9 D$ @9 Q. R; ^  e
MP6
0 X: O3 _' X4 u# `+ e! I 1639555
4 x3 e: ?0 }1 ^. _% ?2 Y9 f: R9 ^ The problem on Linux where creating a ruled surface would cause session termination is fixed.6 V. ]) V9 B( r0 n# p5 G) [! E0 |
8 ~% z* D$ I" h; rMP6
4 U! y1 U$ x* q4 L 16444484 T. w$ a" j# A2 D( W
The problem in Teamcenter Integration for NX on Sun/Solaris where the Update Structure in a heterogeneous 4-tier Teamcenter environment failed is fixed.
7 L/ J% q" ?2 `* x% E3 g- p' b
& B" Z# k  ^- a- V; @* \7 JMP6% _7 |5 F+ w& U1 I
1645545
2 d/ {  t: d) @5 b, y1645531
9 I" u% R% g. a1 x  The problem in CAE where the Analysis Mass Properties would give incorrect values for polygon bodies is fixed.
. `: M' J% z- q" A* s  u! H( C
7 B0 Y3 \/ y; hMP66 q( ~' v5 c9 e/ l
1647101& m7 D) C' S. l* Q" D  \+ @( ?
1650503
; {% v" ?/ a  q% ?# ]5943086
) U: ]6 T2 b; m7 }/ _16487930 S$ z, `" g1 F
The problem in Teamcenter Integration for NX where opening an assembly sometimes caused an error is fixed.
6 V2 M* L: V! m9 O% c# C( ~7 H ( y% O; G: c" \$ w& p
MP60 I+ U: ~; g7 [5 Y
16488261 x1 {6 V7 P6 ^0 ~. ]. P  y, Y  Z# j
1648540# A5 v: h( f: k" S3 u" B1 Y$ w
The problem on Linux where the fillet weld symbol would be incorrectly displayed is fixed. : x) X6 G5 C  z! f
The problem where creating or editing a weld symbol with reference text would cause an error or session termination is fixed.: Z2 e/ G; n% h& i! E
0 b! _( z* h7 w. D/ m# {MP6
9 A& P0 I! a3 u) c7 y 1648984
, ~2 y* l$ q, x0 M7 W/ d8 [: g  u The problem where the geometric expressions in the top assembly sometimes failed to update while playing back the component part is fixed.
' g7 G; m. v7 A% J% z, l, l , Y" `/ g6 Y  y0 y: c
MP6! ^$ y0 H0 C5 Y( W' c
1649051
/ H* F6 P5 u" h) m The problem on Linux where importing a CGM file would fail to import the text is fixed.( w9 z" S- ]! e. `* P) I. w; G
; L4 l0 r# a  _( N& P) d$ c
MP6
; z' ^1 v$ ^3 a) C! \! G1 g, O 16502908 `+ j: l* z5 |' Y6 d4 R8 J
The problem in CAM where some Planar Profile operations would not generate correctly if Output Contact/Tracking Data was used is fixed.
0 n( e/ s) k2 z& y+ F: {
3 u$ B! |0 a1 A7 L+ ~( b0 ^MP67 r' L* h2 [1 X
1651482
* T* A" I' Z# A/ A/ O The problem in CAE where the Function Manager creating a vector force did not allow access to the Derived option is fixed.6 X2 F- x7 _% G  O
* p( m+ x: k7 VMP6
* u3 G! i* x2 P( l 16539469 b- |7 _' D5 S4 _' k
The problem in Drafting where UF_DRF_ask_id_symbol_geometry returned the wrong radian values for ID Symbols that had non-zero lettering angles is fixed.8 }& X, C+ P* L6 a+ E/ L
" U  c, A; ]! `9 `# a
MP65 e8 r, q9 E8 Z) J
1655448
' F0 g! |# E( q- a16531177 I; F. z' D, |( q5 H' ~
The problem in CAM where initial Turning Operations contained in sub-groups of the Program Order View generated the message, "You attempted to move the component too far away from the origin" is fixed. The un-initialized position coordinates are avoided now, and an appropriate warning message is raised in case the system detects that the initial tool position is not defined.) V! {* @0 _9 O) ^' Y$ r
( S0 \+ @7 n8 W
MP69 L0 _; _# R# U( o( v! p0 @
20817165 f1 z; N1 O8 U9 c
2095702
5 {9 G* L" |/ s3 G The problem in CAE where edits to the material properties were not updating correctly in NX Motion is fixed.
3 g9 n) ~/ M0 q; r# q
7 E$ g/ q8 @! M  k6 }2 _MP6: q. O7 ?. N: I" A: U
2083475
1 D+ Q. D7 U! m/ N5 F6 p! d1 u The problem where setting the current feature sometimes caused an error recovery failure is fixed.. o! o3 X8 l! g1 N. V
. ^; \" D% J! u+ B1 M8 X7 @! k' Y
MP6
2 W7 @; D& S3 `6 j" T; u+ L 2084150
( J' n9 T, `5 T7 P5930916! ?1 X% b) o5 X6 v( Q
The problem in Drafting where there sometimes was a load library error when using the Tolerance Feature Editor is fixed.
. q5 g( R2 f. _: `4 }- G4 P/ |4 |
4 v8 j2 n  P  G3 `9 _MP6
3 e* g. ~- X# F  [# b6 G 2094860
) U5 U! }& V' P3 c% ~6 D# l9 p The problem in Drafting where Print or Plot did not fill arrows is fixed." ^9 y0 L) p; f  @
6 W- v* }& j' ~8 }4 G4 \" o
MP6
9 I2 }  ~- N' }3 l5 z$ {+ ^7 { 2097103
0 s7 R% @9 Q# e9 _7 E The problem in Drafting where setting the retained annotation line style via the NX/Open API toolkits sometimes caused an error is fixed.  J6 y5 i. _7 X, F( p8 O0 M
& P+ p, {  ]' I! N2 MMP6
8 l7 {7 H( T% [: f/ B8 [: l7 W 2097220
* z) E: k8 v( m. F; n" t( s& H The problem in Assemblies where there sometimes was an error when an assembly could not load due to mating condition conflicts is fixed.4 P) |+ Q$ D6 U0 j1 ?5 C. G) M0 X
) a8 P+ X0 x. p) r' _0 K% D
MP6
: c; u! T  ]" A, H 5732683
. V! N- z- j4 o4 f9 @& U5734983# Z  S# _* P! u/ ~* i; O& T7 s
The problem in CAM where no drive points could be generated in the Surface Area method is fixed.
" v9 T4 `' B& q4 a& F" x  x 3 e, ~: X3 G7 |8 f0 Z9 h: r" I/ h- X
MP6
: a; E; \6 y6 M' ]% S! C 58560408 A. E- b' f! w% ?, Y3 D
1645866
4 q3 N- s1 g, p2 u1555824
, M5 y) {% U7 h! @+ v& B1628062+ E* A$ o" q+ k7 u+ n1 _- e/ E
5864929/ i6 C  y+ L  J' `# Q' R
1646487" Q1 h: p" v7 A+ {/ a
The problem where drawing dimensions on an assembly cut feature (this also affected deform features and promotion features) became retained when opening the assembly is fixed.0 l* y8 E1 L4 T5 P
2 ^, N5 x$ m- u" ]6 R4 ~- A# L: A4 S
MP6
# q% x! a, f* ?7 i: q7 O8 a! u 5860694
/ V/ S$ b8 H, @4 m3 m/ {) Y The problem where annotations were missing when legacy drawings were opened is fixed. The view independent annotations (previously created during data import) had bad z-coordinates. This fix automatically sets the z-coordinates of such annotations to zero during part loading so that they are not deleted.
! [6 U# w  s* f7 f % q# G2 O2 V+ n+ _  s
MP6
$ x2 i& p% q: T3 c) j' o1 r3 |. n 5860959
" u* O( {, _0 M! n5900587  h% u! h$ u( @( |/ b
The problem in Electrical Routing where the cable data in a HRN file was not imported properly is fixed.$ ~! ~( \; {. k# d+ j, I
The problem in Electrical Routing where routing from a harness node did not route wires inside twist/shield groups is fixed.- E' ?- ^+ u9 h' u! y
  b% ^$ q# @5 J
MP6
2 Q9 [8 Z3 _1 v( C" a2 b, V! U( X 58707166 p4 b# W  d+ Y, L
1617830
8 h& Y+ j  X4 E: `: v4 H" n. p1376633
# i6 }+ Y- Y* X7 L$ F1 r8 N The problem where some Assembly Load Options were not working correctly is fixed.  S8 m* y: f( R# m1 i
" N$ j+ r- j5 z& i+ @
MP6
% m) d& _' x7 G7 T 58880721 N4 @5 c  B$ r
The problem where the license check for NX/Open author did not work with non-.NET main applications is fixed.: i# T4 k7 V! u8 [4 V
* Y: }& Q7 X2 HMP69 q) n4 |& J( D2 U/ c5 s" E/ }
5889920+ F; b# a6 g' z2 |6 x3 Q( H
The problem where NX/Open batch mode applications were not able to properly initialize User Function User Defined Objects (UDO's) is fixed.# J9 x% N" |# U3 s
. ~0 X6 P' u, O1 Z9 L( c
MP64 c8 N, r3 {0 E8 c
5892007! I& F" @' |' E
5893052
7 z( `6 B4 v3 t8 n. R5893053
/ l7 b) q! K; _. S8 }* w9 ~8 } The problem in JT Translator where some GD&T Datum Targets did not get translated is fixed.- f& v+ p/ \& t2 ~0 c+ T* V
$ R5 {1 o/ ?0 y4 u& W( w% T, y
MP6
4 W* X$ @* x6 x" e0 Y# C 5898348& c8 D$ \  m1 @6 C: F: O* _
1574080( b$ N* |  `- l: r0 M
16084188 g% K* ?' y! T# |1 V
The problem in CAM where Turning Teachmode operations caused an error in the Follow Curve Motion sub-operation when entering the sub-operation's feedrates dialog right after selecting geometry for the first time is fixed.! w3 m0 D/ |" }" j
. S, m) s" C3 C$ I( eMP6
$ w4 l$ y: S3 ]+ y4 D 5914943  E9 b2 r. O  J0 z& G" [4 v
1648879/ j6 S3 y$ K3 ~, L! P7 `
15995490 ~/ K( U9 E& e4 C- B4 b* A8 A% h: _
1599590
4 v5 H0 `8 O7 w$ F% y# O! \2 O. }& F The problem in Teamcenter Integration for NX where load times for large assemblies was slow has been improved.
2 |) a+ e/ l3 Z9 Z+ x$ N
8 e2 O+ M1 Q' o$ C( p) a6 }  S* U' {: K/ Z& e9 u
7 i3 y; t6 T, H  m+ l, S
1 X3 H! \! I( u+ E8 aRelease
$ H: U+ y8 J# [# t  F, F% z PR Number+ [: E1 G; V% I& q6 L5 C
Problem Description; C  a7 K* f3 Y8 k' |  N
0 f( H& C0 u% k* u% NMP7
/ F# d1 ^& m1 c: V 15489806 G! p% U. j3 A' o9 k
The problem in CAM where Wire EDM NoCore cutter paths sometimes resulted in an incorrect Finish Pass is fixed." R' B( ~+ g+ Y( x7 k
% W& Z! c5 ]0 Y# C* kMP7: ?  c! K' Z, q9 N1 S3 d0 r: w
15932297 F; Q' F9 f, H; [% _, R
5885106
3 u- A% |, t) R! @1654661! L1 L' z6 s7 S7 g# _& p
The problem where the Checkmate license was not released after the session was exited is fixed.# E; i% s& n. B
5 `, N8 Q! s, j% {/ [- T9 \% E& v
MP7
: S* i! B; b% L# i9 t 1599944
4 [1 r3 _, u: v3 B2 O' O* z! G3 V The problem in CAM where the Synchronization Manager and the Channel Window were sometimes not correctly matching the same tool path data after Show Machine State and then single stepping forward is fixed.. J# p; o, j# M" D2 q4 L
/ U5 _+ F! f3 iMP7& Y8 u0 R3 t0 I- w1 ]8 U
1600226
, ~9 i! F6 d5 e1614880# h, l( [. _. _
The problem in Teamcenter Integration for NX where the Quantities were not correct in the Product Structure Editor after Save is fixed.
1 U2 o1 ~+ _8 n; t. S  Y& o2 M
See Note 7.1 below.
- }" R* z- ]: t$ ?5 `/ B
3 U0 d. Y  z4 rMP78 m( u9 I8 Q: M' b
1609003" A1 ]" }2 Q/ L4 _  c% b
1613254
( a% }' z( e0 { The problem in CAM where some Cavity Milling tool paths were not correct when UGII_CAM_USE_ANALYTIC_TOOLPATH had been set to 1 is fixed.6 L; \' }8 J) ?
, i$ n- t  p% w/ E& N& V+ YMP7+ b  }( W( K5 R* w: _/ j. M
16091219 o$ p/ |0 M5 f4 m  J: l. b
The problem in Cam Visualize where there sometimes were errors when single stepping backwards through a NC program is fixed.; t( M+ e. [  N2 O- r6 g) u
1 `$ R) I5 R1 ]
MP7; v& D: P$ f+ z9 Y1 ]2 o- f- {- q
1622706
: Y6 H  u+ A' V6 `, C$ c4 D/ I, J The problem in CAM where Custom Face Stock sometimes created incorrect and unconnected tool paths is fixed.: q4 |3 R0 N# b: x
7 R8 @2 C/ P& i! @; l  X) GMP7" R  \' Q; S8 O2 |2 |( T
1624586
2 s5 T  ~( F3 z$ W# I. ?! z4 V The problem in CAM Post Processing where mom_nxt_motion_event and mom_nxt_motion_type were not working correctly is fixed.$ R) S4 G) [2 D/ Y- c* K' A9 k- E
5 @  h* ?$ D1 O/ V+ W
MP7
& E& @6 P5 @# M7 ^9 B 1625909# y* Z2 c9 I( m9 _
1612198
! m8 l1 n' ?- \3 O The problem in Translators where the import of a STEP file failed is fixed.
' ^+ }% p" v( A* c) M: C: r  z5 nThe problem in Translators where annotations by expression were exported incorrectly to IGES is fixed./ u; D& }: G7 h
9 P4 `9 i0 Z4 lMP7
) z) i0 h  _0 C& f* q7 @ 1631301' b8 S9 [/ C/ c/ L" ^1 k* q% _
The problem where NX provided translators using the new NX/Open API would require additional licenses to run is fixed.
) q5 c; D, ]0 F3 S & e1 y' M5 p( |, H9 [
MP7: B+ [% I3 \# n$ @/ S- F' D
1636215
7 q* s% W6 ~9 i  y, b The problem in CAM where the Tool Holder collided with the part in a Cavity Mill operation using Tool Holder Checking and a 3D IPW is fixed.
. F1 r) _: q% @' v4 D! T) L 6 S. M% d: X# \
MP7
) T! K8 ^6 B; A- z 16377591 @. m5 p8 P+ N* k
The problem in PMI where some dimensions did not update properly after changing the Current Feature is fixed.
. h9 z) ^5 _+ ]& S
% T; H  v6 o1 V: U* SMP7; V: _$ {9 e6 w8 Z
1648521
5 v4 ^6 p7 |4 B1 y3 E# q% C6 G1663622
2 Z1 w/ s' l3 ^9 g The problem in Drafting where dragging a Drawing View over existing text sometimes caused an error or session termination is fixed.
# L" f! ]1 @8 J! M% B( P3 x( _8 F
; V/ d4 t0 U, JMP74 m: N* P7 a" H' @: p: G
1650388
6 C1 f. U/ z4 d4 g/ J The problem in CAM where there sometimes was an error when specifying a tool axis for a Gohome Point is fixed.
' ^6 j* b5 Z- n& z% {+ a9 [$ w 5 ]" J% r) i, w  t1 u& V; i
MP7
7 x7 L7 C$ [1 ^ 1651807& |4 V  |& y4 c5 v' I! o; [: U
The problem in CAM where Hole Making was not working correctly is fixed.
7 d1 z5 P. z8 T; `
  V# Z$ ?* u/ ^0 m/ |MP75 Q# z6 r4 r; {% b
1657030
( l/ y/ [- S9 s! s0 l/ L+ ~/ B' K1 _ The problem where editing one of the Associative Line Limit Values sometimes caused the other Limit Value to round off is fixed.
% ]! m. c3 S0 v- [5 a / h$ g/ [0 s0 |; E$ ~
MP7. E# L) \9 G/ d  f
1657098+ |1 B. |9 h, @: I) Y" \) D
The problem in Sheet Metal where creating a SMBEND feature sometimes caused an error is fixed.
. s1 L& |& E. c4 \9 b" I& E
; \4 L# ?; A7 Z) P0 v: vMP7
: K" h8 f6 Y0 b( a1 G1 M/ t5 V 1657904
: P. a6 k) y- \: R, X$ Y% V The problem where independent parts in a session were updated if they contained a User Defined Feature (UDF) with the same name as the UDF that was being instantiated in the current part is fixed.
! ?- F/ w' G+ V0 c# u ! [. T  V) l0 z0 E3 U2 x  p
MP7
2 a: c) L2 o. B4 P 16597764 `6 K# J2 d; u" C, p' H
The problem in Sheet Metal where Flat Pattern sometimes did not work correctly when using custom standards is fixed.
/ V8 Q) V8 q4 z% v & a8 ]$ W6 r+ W: a* d2 f2 c. ^
MP7
3 B1 M# S, m0 T, e3 Z- \# f 16624739 M# w. J2 E& W% j" V
1663333+ S2 R9 ?2 ~! G
16634019 L. `3 D/ I2 j8 Q
1664243
8 K; Z. D3 i1 z, X- R8 o1664677
; @! w4 q4 M$ ~59616875 Z# S; R3 W, K( M# U) a
5965503& X' u+ Q' [/ T+ }: a
16664120 v8 y+ m9 T5 k( H3 s% v* i; K
1665554$ j- W- A8 L- i. ^1 f* r
16699101 L9 j# L, N( h* q
The problem where there were errors saving some assemblies is fixed." Z9 }! P+ Y/ e$ a
/ b, r5 O) w; e* j8 ^* F
MP7* }- C- v4 R9 C: S( U9 J
1665578
5 T% E0 H$ h9 n% U  o$ l$ O The problem where excessive time and memory were being used when opening the Part Navigator containing User Defined Features is improved.
" I( b5 E: z& X& H0 x: r8 [7 F) M 1 z- S5 i9 }6 y$ T1 J% X8 t
MP76 l( @2 D5 z6 Q, I$ ]+ w
5870215& t; j0 H* H! F; u) p
The problem in Routing where selecting Routing Control Points for Place Part sometimes caused an error is fixed.
8 V  f: \1 J8 t6 X
! T) ?5 n3 `# k/ u0 Z2 uMP7, s2 t+ w. I9 [
5910859
2 s% L* Y6 y# v  s! y The problem in CAM where the Planar Milling Slowdown option was not working correctly is fixed.
, X, H5 {! g) R' Q) t
# m* V6 f+ Z) @, kMP7
# B8 M# ]3 ?$ _+ [' ?+ s$ a: E 59176438 [5 p' F. R+ S
The problem where it was not possible to call a Dynamically Linked Library (DLL) from the common application programming interface (API) Java toolkit is fixed.6 N4 l8 o# G- M0 U
% z. ~. Y, ?, o1 ?
MP7( n% x4 E" I; D8 g; M/ P
5934833
7 E9 d6 {# O3 I8 g' N The problem where there sometimes was an error using Quick Pick while in a Single Select dialog launched from an Open C executable is fixed.
! t; p1 K1 L* m  @* j 9 `) u3 F  L) z6 G/ N  B2 q
MP74 k) ]  X; @" B- Q" V% v  h
5944229
4 @4 J: `- Y1 z8 X. j, Y6 v The problem in Teamcenter Integration for NX where an incorrect quantity was reported when a component had a Unit of Measure is fixed.$ }6 ], x8 v6 z  d
  X! d) c2 H% m' aMP7
% A' `& K* q* m$ {3 ] 5962885
0 f/ @4 p" e1 N The problem in Teamcenter Integration for NX where there sometimes was an error when using a component group to Open/Close a component is fixed.
0 R/ U! q1 b2 q  r# |2 ^7 r 3 ]6 ]# ?! a6 W0 k! A0 }4 A
MP7! c( q8 m9 Q* z1 \# a
5963583
. c* q0 S! z2 Y2 Z) `8 K& B2 `55980876 S' g* ^  N& h
The problem where there was an error opening some assemblies that referenced legacy surfaces in a component is fixed.
0 ~1 X7 T8 [- e: s
9 n4 u  i: O4 l" NMP7
+ \. G+ G/ F6 L; K 5964528
4 Y; n$ t' P. q The problem in Routing where Transform Path did not work correctly if the path had a corner is fixed.
1 f* [" R( I) Y+ t2 [& S2 J 4 V* z/ h7 f5 a4 q  A, u- V
MP7
9 X: G( B$ z3 x5 |: g& l 5978927
" r1 b( f& W8 s2 a& ^ The problem where there was a copy feature error when instantiating a User Defined Feature is fixed.* V4 v: `1 [/ P
9 p& p, z- a+ v$ G" SMP7
2 F+ O( C& ?$ h2 ^5 k; J$ h 57268098 V, n4 A3 l% {) R
5675558! e/ P; L" Y+ y% e3 h# L) ?( Z# y
The problem in CAM where the Radius value in the TURRET statement was not being output properly when multiple operations were listed is fixed.
; c! y. I  g6 Z: b
9 o0 U4 [2 N2 Z! M7 J3 s1 `5 f# Q) x( \9 n4 n* J8 f- D, r
8 @3 F) H" A, _! a. j4 v+ v0 ?2 i. E8 [# i. [+ x
Release! q' x$ _1 \0 Y: T2 R
PR Number3 S# D) |1 B' h, f) V3 \
Problem Description/ Z2 L# M( _0 E+ L$ Q! h  `8 T! W
: {; ?& F& O* v. |( z
MP8
' j8 U7 S, R  K& W0 y: ~3 D- q 1571812: w! f' z4 g( I/ H2 ^, ?) B2 O' }# t) ?
1592620
4 x+ B5 A" z" m# t/ s3 q: r2086986
% [) g. N; O; H, G0 c, ?9 A$ X' y The problem in Teamcenter Integration for NX where Save As caused a "Part number is longer than 32 characters" warning is fixed.
2 N, s9 Y* k4 z; f% ~: A , a: a( h7 ]5 }- P; O, x
MP8
# T7 j6 r( N( V4 M- r 15957994 o6 \( z3 ?) W+ m! o
The problem in Drafting where re-opening some parts caused the part to be marked as modified is fixed.& c9 S9 B2 [& m" s
) \2 x# M# O( v- i* ^; iMP8
/ _0 k) v* R/ m: S, A) h# D; ` 1612404
' }7 d/ J. @. p9 {. j4 A4 f9 D The problem in Drafting where text in tables sometimes had altered font and wrap/no wrap display when re-opened is fixed.& I# x. G  i$ C5 \' N
: Y/ E/ o; H2 y  E
MP8/ P5 o  D4 }0 V8 }8 C
16235754 @0 w* r4 s- g: l1 ^5 g
The problem in CAM where some Flowcut tool paths gouged the part is fixed.
7 b" j+ b% M3 K
: u; Q& z  N( r, i) YMP8, p5 o+ }/ ?, u' W9 z, ?
1636038# G* B+ C& p; t' R- m6 p
16617076 V( _5 D4 \7 `
1663586
" `7 v0 k7 \+ m. n( {1666918% @6 X$ V) `2 i- y/ g5 u% [8 T$ k
1669315
" X" N1 D7 Z3 y* s; P The problem in Teamcenter Integration for NX where the load performance of some parts was slow is improved.. T2 X& T' ^* n
3 y& e7 i! R9 Q# W
MP8% H- v1 ]# w0 g# f% _) ]  G
16525472 S/ v) f1 J. n0 C8 I. |/ `1 Y1 S8 z" D
1663047
3 `2 }$ ?9 s: H$ J5 K5901675
# J$ l  T: R) |0 n/ z4 r The problem in Translators where some Drafting details were missing or incorrectly positioned after importing the DXF file is fixed.! R1 F5 W- L0 K- c7 o1 b
/ R2 k) @# }! ZMP8
1 W7 c0 N# o8 Y# x0 ?/ i 1653781
4 R+ O, ]  j$ t. E5 |2 P. ` The problem where synchronizing the Routing Bill of Material and the Drafting Parts List in Teamcenter Integration for NX caused errors is fixed.
( k  N. K( i& \# z. v! e5 h
- `% q% K% C) {& b: uMP8
6 x( E( z# A, v 1667825
/ Y( S; I( n8 K7 a% N- K5 ~* a The problem in Assemblies where there was an error when changing the Reference Set from Model to Entire Part is fixed.  L" h+ [2 u4 r% z1 @2 [
: w0 ]* n5 J* ]- U) q* e' ?; tMP8
1 S8 \, F4 y# ?" V/ h4 k( K 1670906; G4 ~6 A" v( e; ~; m
5973653
1 f- A- S! n; P. G. z- f The problem in Translators where some STEP files failed to import is fixed.
8 t7 u% X: d& x* t3 D, V 5 U, Z# ]: S. v7 X
MP8
6 Z4 r" c6 y; N( _  J. D 16725209 l; a8 C) r# F. w+ |+ m3 C
The problem in CAM where Thread Turning did not generate the correct tool path after flipping the tool around the A-axis is fixed.
( s' p1 r9 {) S2 {
# v/ x% n4 g6 n/ YMP85 M9 K7 f! t3 x3 @- G' P, p. f
1674031) E( ]) [% j& l! P& \- r5 r0 ]* v
The problem where the NX Open .NET toolkit was missing the wrapper for the NX Open C API function UF_UGMGR_ask_export_directory is fixed.) P* {  v  Y  x, D. L
3 N4 H$ v( q5 s8 |8 I- ]MP8
6 h" Z- B9 B; R% \3 Y; D 16749161 D* w0 T- N2 _
The problem in CAM where there was an error after generating a legacy Teachmode operation is fixed.
3 P' {+ r% z. \0 \3 T, h. U , ]4 R3 J( H* S3 T+ P) l
MP8% N* j' G; g' {9 n4 i5 _
2102848
% C; _) f0 t7 J2 a3 B# b6 I The problem where there sometimes was an error when saving parts after reordering features is fixed.
3 V' H1 i, ^, K, R# X2 j   t: g- _' t0 q: Q% S" c6 V
MP85 ]* ?. q. }! \0 t9 q5 K
21038865 B: o2 `( U0 t/ u# t; _% H
The problem where there was an error when instantiating a child rule of the Knowledge Fusion class nx_curve_length is fixed.
3 t& F/ f% t9 |
$ E9 b6 Q. }4 H( c1 `MP8
+ o* R' z4 p! E/ I* x3 V* N 2103893% ^* j4 U3 K, a, p5 N4 q
The problem in Teamcenter Integration for NX where the Product Structure Editor was out-of-sync with NX and showed an empty Bill of Materials View Revision (BVR) when using Mold Wizard is fixed.
$ w) ~9 n' j9 j 2 g; h% S5 ^: P; M
MP8
. ~* l8 B0 u7 t- j 5765693
* p% \) F+ L, M. S( V- u1641065
! Q, A$ P' d6 A' k0 |5882690+ c! ?( D3 `3 M3 [* q% n/ Y, p
The problem on Linux where some keypad numbers did not work correctly in some applications is fixed.
* Y2 V1 n9 e: @2 z! a* [
1 L+ `  X/ S  J7 M4 `( NMP8
9 a9 b& F: I3 \5 u( _( ? 5825668
1 o9 U7 @) g2 u- p0 m) x  m/ {: k5993121
+ e" W1 y& \+ @. A) C4 P; o The problem where Check-Mate's Spell Check with "Ignore Words with Numbers" was still reporting words with numbers is fixed.8 C, U+ G8 @& }% q8 n" b7 H- F
/ ]& _, M. U9 d& W* Z, G8 LMP8- X& \( h% |6 r4 F( f+ X
59669387 ]8 z3 T/ ~1 }& p, a
The problem in Routing where the Piping Component File did not work correctly is fixed.
5 `* q& ]# D& g3 A+ \5 f$ z
" B' N# i4 l1 S& O2 oMP8
: ^& u+ C4 ?; {. M 5972945
/ A1 j5 i6 m3 B6 V) D  J3 l6006348
3 Z2 W  K' Y+ A$ l+ U The problem where Java remoting was not working correctly is fixed.% U7 ]; x. i( v' U
3 d% Y. N  @' a" s9 S( p* k" [MP86 o- v; I* z$ R/ h- G  X  B) U2 U  e
6006894) G: V' H/ [; I: a0 m
The problem in CAM where the maximum RPM control was not working correctly in Turning is fixed.
7 @2 a0 f" b- e1 t! p4 ~
+ g- s. K" k7 Q* n* c0 {: G+ }1 H8 H& q! o+ g) W
- f- v( q# i) [
9 A: b- O% h9 h
Release2 M& F+ C3 G# A% i
PR Number1 R) R( Z: R) x% p+ ^; v
Problem Description  R9 o, f- i) m8 W
+ B" Y. n/ i" A7 N1 {
MP9
6 ~  e# ^; |' b' T2 {3 ^8 f 1560498
( C  H5 w% U6 C* z8 g) s5571720
( ~9 M8 N7 D& A, X# |9 _/ O/ s5986167% H$ K% _% d5 a' i( u% [/ B' r
1560498
2 V9 _6 R$ j6 @  z* |0 L1554952+ O' M3 u5 U# G* s  @
1572092
3 y4 m* e8 x/ Y20747968 d* i' @" w* B/ f
5681444
9 z' K2 L8 e0 `5684214
  E/ {" ^) X/ j- l5693855
: W% @# G: Q) h7 E$ y9 P5918711
, h; V9 q) ]& W+ M! y The problem in the STEP translator where exporting assemblies would sometimes result in duplicate copies of the components is fixed.
+ _- S/ e& q4 A1 @% S
; Q* n8 j4 C: @MP9
/ V" @; ~) F* Q9 Q 1662755
2 F3 T& {. s8 a2 {7 Y The problem in Teamcenter Integration for NX where the load time for large assemblies seemed excessive after modifying one component's sequence number is improved.
8 g1 l5 U4 u% ?" ~' L! X 0 I/ B4 l+ q: _" x
MP91 i# z: y, K' f( d# I5 ?
1668913
& U" r' F6 H2 \ The problem where annotations of an assembly whose components had been revised went retained in managed mode when multiple revisions was enabled is fixed.
5 }/ c- G; C1 T9 t ! }5 V3 w5 B! H" P  r5 [
MP9
. Z- i  H8 ^* ?* d9 l. V 1669385
5 u/ q1 \9 s* G" R7 S The problem where some assemblies failed to close is fixed.
0 r! I/ t- ^. d5 L2 O ) q; u6 F$ S) d5 P
MP9( T0 S0 F0 R* m! ^4 A  k& z4 V
1671212/ i* M2 D: _' |) \0 M0 t% [; Y
The problem in Teamcenter Integration for NX where the parts list quantity was incorrect when using a suffix is fixed., n2 R- E) ^" k
! g2 @" e* d0 W% F( ]' [9 e! \MP9
/ G, S" h& e, ^3 e9 ]% Q8 R( Y5 B) q 16731478 L: S: g  ], O. S
The problem in Teamcenter Integration for NX where there was an error after fabrication in Routing Mechanical is fixed.
7 T4 F$ O/ v3 v6 ]
! |- s* f7 F& k  m' UMP9/ H" Y1 T) X: g4 W3 D( E
16733017 \) H9 {5 h; K2 t0 \4 g# c( k
1674379
9 M. _: S  k4 H0 I# G0 ]3 h/ w1686072' D' m2 B$ e, C# v5 l4 A+ C
5818954* M, w  X( z: z6 h0 t# d: Q1 k
59841303 t$ O1 J8 o7 W" Y: C
The problem in the 2D Exchange Translator where merged tabular notes were exported to 2D Exchange as unmerged is fixed.
! G! b$ e) t) H- g, c# u: ZThe problem in the 2D Exchange Translator where tabular notes were not exporting correctly is fixed.+ z+ m; i7 a' u3 g  s
The problem in the DXF-DWG translator where line weights were not exporting correctly is fixed.# h# b: r, U6 s2 e% ?
The problem in the DXF-DWG translator where some custom symbols did not get exported correctly is fixed.# J# D3 I# O- ~; d, i% R5 L# K1 P
The problem in the DXF-DWG translator where some dimensions were not correct after being exported is fixed.$ E8 ]5 p6 R3 Z3 Z+ Y
" G, a1 G/ Y, z3 [2 B* [MP9
! I+ p& Z, M* v0 x. j+ H6 j  ? 1678387# [6 R3 V0 ?4 o7 ]
6003115$ W$ ?  a6 x# _+ \
The problem in NX/Open where the method ufs.curve().editSplineThruPts caused an error is fixed.
6 U- ^# |$ ~1 d( {. OThe problem in NX/Open where the method AskDrawingRefPt wrapper for UF_DRAW_ask_drawing_ref_pt incorrectly output a single double rather than a double array containing the X & Y coordinates of the drawing reference point is fixed.
: Q3 \" d" Y- \) J* |
* X3 s7 N, X9 T. C2 {8 G$ e) R8 K. }MP92 t3 [0 V4 [; P% o
1678691; w) a* ?$ |" B9 f
1603109. G- _+ M) v  `4 q' a/ W
16866550 v7 b% z. k2 e& G; l
6026572- d$ `: N3 }3 F% H
The problem where incorrect circular NC outputs were produced during post-processing is fixed.
4 t) C3 t8 b+ p* G
5 ~- S2 J) z! c% L3 bMP9
+ e% a/ z% U5 a. C: [- Z6 N, E 1683464& F7 g  `8 n" a% |
The problem in Teamcenter Integration for NX where Edit Levels did not remove components from the Parts List that had user-defined Quantities is fixed.* P3 v4 U8 j% v; ]
" Q3 \/ @8 p( F% k7 U, |5 JMP9+ Y% f( s3 m; A3 ~' `. v* w# M
1685470- Z/ E+ H& f* E/ w% c
The problem in Routing where all of the connection data was not available in the Connection List Stock Report is fixed.
- Z9 C0 P; h7 s' q$ z. B( G
  j* V) w- w9 b7 M: S/ [( g' {& `MP92 S' R. O1 D* E* O2 Y6 q, w
1686205
! f& v: ^) }/ B The problem in Teamcenter Integration for NX where Save As caused "Part number is longer than 32 characters" is fixed.
, n' s" m% x, G$ a" a4 }! w, o
! @2 _/ F0 D" [1 O/ NMP9
4 _3 g% K& x7 c" `! e& a! M 1686426. ~% p; s' M/ M6 k; k* j
The problem where Mirror Feature created an additional basic curve based on the internal extrude sketch is fixed.& F7 }, B4 |5 L& k
6 x" Q4 g3 ]* w6 J9 ~  n5 n4 TMP9, B# M4 C# Z$ r7 e' r& m+ c
1686936
% c4 ^+ T+ m, u' \, r: N The problem in Drafting where a particular dimension changed when the drawing was updated with Open C is fixed.
" d' L; t' _9 l4 U' T/ t % b/ x6 q6 E! a1 M5 }( w8 u
MP9$ n8 E8 z0 k" v0 ?+ a2 T
16895505 x+ {8 `/ ]) a9 k7 d" k3 s
The problem where it was possible to overwrite a newer version of a component with an older version is fixed.
; G" b- z4 d" x1 g8 t/ E9 P7 x7 ^
' }6 u8 \, t- eMP9# f, R: S  @7 u& J' n5 W% w. m3 h
21070810 ?9 b, a2 {7 ?: S" ~3 U
2107122
/ O1 n. |0 u( f21074170 d; {0 k' }( r* y
The problem in Drafting where some ordinate dimension values changed is fixed.
" r9 c# G- q3 I% K5 \The problem in Drafting where some ordinate dimension values were not persistent after Part Cleanup is fixed.
! d3 p# m4 ^* m) Y0 @" h" O+ e - @3 O0 i' ~4 h3 D" x: G# H5 B
MP9/ N0 |6 [( Y8 P+ ?1 z
6006994
# p- A% Z; i: r1 Y The problem in Routing where opening the Connection Navigator caused an error is fixed.+ s8 Q2 h5 x% v
$ V% f. S: E) F% lMP9  _4 f* V# u  T$ m6 D; S5 [
6020860
+ Y" |0 }) i/ c: x! y6 @; i The problem in Routing where after Manually Assigning the Component ID the Component attribute was not updated with the UNIQUE_ID attribute is fixed.
" ?$ p# N0 f2 i  Z4 F* t3 T  y" L
$ \. O% v3 w2 x6 F5 ~MP9
3 S7 s. y. y4 e) x 6023046& B# [  [" r6 {+ p/ c1 P8 q
The problem in Routing where plugins were missing for PLM XML import and PLM XML export is fixed.
4 ?& e4 C/ M, t3 t
9 L( b9 T6 |* e% o/ I5 n# AMP9
0 Q2 s5 m' f# a3 X1 ] 60265140 v2 N! d( V) A$ E  o
The problem in Routing where cable outside diameters were not being imported from a PLM XML file is fixed.3 I8 d9 B4 f9 T+ B; Q* M+ K
3 n/ p% j* i1 W  Q
* u+ w7 B4 C) j" Y1 Y  Q. ~
- Z8 f$ {8 E+ f+ e( z
9 n; I5 e! d% v
  B% `" s! u8 r9 V: ?1 v( r
& w( @0 w' J5 o, Y" c . U$ }+ U5 d( X% [, M
: e( w% O/ h  r& p9 W6 C3 |
Release
+ M( Q( s! v3 P) _* D$ V PR Number; ^( j$ i4 Z: S2 d5 g
Problem Description
7 B' c2 p$ s1 ]6 }3 b* J9 Z
* p/ S# z7 Z! m4 C+ D  g* AMP10
2 a7 R4 s6 R% Y) v' d& w% Z7 M! | 16560519 g! {5 r9 G1 F' n& Q
The problem where there sometimes was an error when Saving a part after deleting some features is fixed.5 ?2 F0 L1 d  d3 C# F
3 `) P) P; ?" k* d# v% jMP10
' q/ D3 b4 z/ o" _( J" F 1677648
) S4 _" `$ k( A+ a) I The problem in Teamcenter Integration for NX where the Teamcenter connection was lost after an unspecified amount of time is fixed.
5 [3 Q9 x1 t" Z$ m% |4 o) G: j4 ` . j, W" o* u+ E  y: w6 I: A% c9 M9 w
MP10" p9 P! \' U# k* `' q/ G3 L8 D
1682769
  a, y7 \: m' X1688514* G& ^2 l  l- ~2 Z
The problem in CAM's Integrated Simulation & Verification (IS&V) where SIM_unmount_kim_comp did not work correctly is fixed./ X5 H% V: f( a% E9 e
0 c, B7 e" y3 S/ C0 o2 m. m* h' JMP10
' N; f# P2 }/ K8 u+ j 1689370* t. |& F& I& s9 a* m9 H
The problem in the Define Deformable Part wizard where all of the available expressions were not being presented is fixed.1 X7 g2 R$ @0 R/ O  S1 G8 A
( q+ Y# W! _7 |- P% XMP103 @2 b. |, f- s0 ]3 d
1696372
5 ~2 P$ e# n6 P9 G* x2 i The problem in Assemblies where loading a bookmark sometimes unblanked assembly level geometry is fixed.
: @5 A! v+ {& S5 M ( Y" C) i5 N/ c& j
MP10' _/ ^' F& ?8 X0 d9 P
1696866( R/ a8 D; e" [
1696951( J9 E1 y- O( D$ k! `
60130724 D) e5 i+ g# N( {5 O
The problem where the Java wrappers for UF_MODL_create_ruled and UF_MODL_create_ruled1 were incorrect is fixed.( f/ v- `  q, ]: S' ]: R# j6 V
The problem where the Java method modlGeneral().initStringList caused an error is fixed.
1 ~8 e1 w2 @& S( O, C6 ]The problem where the Java method NXOpen.UF.UFDraw.AskViewLabelParms() did not work when the input label tag was set to NULL is fixed.
8 M4 |1 T; W$ j! R5 {0 S
4 a. \% q; t/ X5 ^1 U- c8 _MP10" m" a9 d/ ?) o& Z6 d& M7 S4 Q
1698932/ c6 C' E5 r: T# j
The problem where the parameters for some legacy User Defined Features could not be edited is fixed.
9 I/ P& G+ I$ g5 W
1 V& }5 w9 }9 |: SMP10
3 D7 o6 }* K. O. ^  U4 M7 l' |9 @ 1700358
( T! `/ e, Y- f) F! I& x: L0 S The problem where using Cached Facets caused some components to display incorrectly is fixed.2 R$ F3 G8 e  H6 H3 v: r
' B- L8 ?: G7 Q$ s: rMP10
/ z' A8 y4 Y' u% n; y8 K$ Z+ I) I 1701945
) G* @( @2 t+ { The problem in Assemblies where it was not possible to create a Product Outline if a Product Outline already existed in a subassembly is fixed.) p, P4 F/ v# L  z6 h  o% c( t
4 B4 i0 k5 D# }
MP10
1 T% e# ^- \5 f 1704103
1 F9 V6 k. ~  d, I( m' s. F. W The problem in Teamcenter where CAM .ptp files with different names could not be imported with File Management System "ON" is fixed.
2 n* C* ^) A" w. A# g* {0 SWith FMS running, and as long as the Teamcenter is setup to recognize that file extension as a valid dataset type, the G-code file will be imported into Teamcenter with the proper reference set. ' r- k, Y# K1 N( C+ E$ i
8 ~5 G% M/ u7 @/ H/ q
MP10
% d/ N! L! }% A' R( [9 X! c- x2 v6 M 6025550
6 U$ w0 R4 H$ F  { The problem in Electrical Routing where the route Connection Wizard reported the incorrect size is fixed.
1 L& J% K/ T+ ]- B, H : R8 A. e1 ~" l( Z! _7 [; e, S
+ C. V+ r$ w, x7 D; @
( Z, ]- S/ Z+ a* [. V# l1 q& Y
5 Y5 [4 M1 `+ v7 T( B3 Z) ~
0 m* c' d. w3 Q+ ^& ]+ a0 U! a
2 O; H2 S% T! r+ Y1 d! _/ }
/ [- w. R6 |, j% c6 vNotes:( M2 Q; K! `+ j  E- `9 r
1 G& C# ?( V3 N+ ]& H* V 7 N& w1 ^" v  _- f. P
' S% T8 W8 k, `8 o$ O1.1       PR 5756225, IR 5759724 ― To enable this fix the environment variable UGII_CAM_OUTPUT_2ND_MOTION_OF_2_TO_START_AFTER_TOOL_CHANGE should be set. (e.g., UGII_CAM_OUTPUT_2ND_MOTION_OF_2_TO_START_AFTER_TOOL_CHANGE = TRUE).
; u) g% w. N3 F" c' h' A) \* _* t
2.1       PR 5716014 ― To use the customized version of the library_dialogs.prt, the environment variables UGII_CAM_METRIC_LIBRARY_DIALOGS_PART and UGII_CAM_INCH_LIBRARY_DIALOGS_PART should be set to the full pathname of a part file to be used for this dialog customization. (e.g., UGII_CAM_INCH_LIBRARY_DIALOGS_PART=z:\my_file\my_custom_part.prt).$ E9 g& T( h2 R) D% L# a2 M
, I( B* a+ R7 H7 a2 R2.2       PR 5763610 ― For manually changed quantity values in Parts List to update correctly, the environment variable UGII_UGMGR_ALLOW_MANUAL_EDIT_QTY_VALUE needs to be set. (e.g., UGII_UGMGR_ALLOW_MANUAL_EDIT_QTY_VALUE = yes).
% R' {6 u7 Y6 A# Q: z% f+ u
& H: V6 r- P9 L8 ~& h' w5.1       PR 1620399 ― To enable this fix the environment variable UGII_UGMGR_USE_DB_QUANTITY should be set. (e.g., UGII_UGMGR_USE_DB_QUANTITY = TRUE).& H& \/ j# S, ^9 O5 v& W5 A1 B
' |, c5 n( n5 d% Y! v
5.2       PR 1624982 ― To enable this fix the environment variable UGII_UDF_HIDE_MAPPING_DIALOG should be set. (e.g., UGII_UDF_HIDE_MAPPING_DIALOG = 1).
# B3 n5 {) x; W' q+ f6 j' u
& t+ @$ C" g2 v# q' M% \5.3       PR 2087830 ― To enable this fix the environment variable UGII_EXTRUDE_UNTIL_SELECTED_WARNING should be set. (e.g., UGII_EXTRUDE_UNTIL_SELECTED_WARNING = 1), otherwise there will be no warning message." v8 p, {' J4 `$ d/ r; Y0 @
$ K2 x* |. {, f5 M: u
5.4       PR 5852583 ― To enable this fix the environment variable UGII_UGMGR_CLEAN_INTERNAL_PLIST should be set. (e.g., UGII_UGMGR_CLEAN_INTERNAL_PLIST = 1).
+ @9 I6 Y& N, N! {. S, z* F  P+ t) g' P7 v8 }9 P
7.1       PR 1600226 ― To enable this fix the following environment variables UGII_UGMGR_UPDATE_QTY_FROM_PLIST and UGII_UGMGR_USE_DB_QUANTITY should be set. (e.g., UGII_UGMGR_UPDATE_QTY_FROM_PLIST = NO
& x2 g6 E4 w" R* rUGII_UGMGR_USE_DB_QUANTITY = TRUE).- n+ b7 y- a( s$ P! J1 h# N
! v! [5 F$ V% g
9 @: R% j$ b3 @5 y/ j1 P' Z* w+ C; ]/ H' l. \- V% R; l, M3 C
) R4 J6 i. i" g. Y+ P3 m& d3 _$ X- d2 M' [, i/ I
Windows update instructions7 X- B1 Z# S* V/ P# `5 O% D8 p
$ j/ [3 v* x" A$ h
& d; I8 q: s+ x; U/ {0 N% U8 x" k2 [/ K6 O4 E# T
The files contained in nx-4.0.4.2.mp10.zip are provided as replacements for previously installed NX 4 products.
. P: p; c( L* J/ p* m. J7 C( c7 E0 S2 H
. `: R! q  Z/ h* Z
( h. g/ P  w( Z7 l  ?/ v% T1 X7 x; RFor the Windows XP32 platform, you should have at least 620 MB of free space to unzip this file. ' j& |. A, Z0 s0 {/ ?
* S$ F$ p3 O  C9 g- }) k8 ~: [; k* hFor the Windows XP64 platform, you should have at least 850 MB of free space to unzip this file.
+ C% r  |- L9 E) k( S6 p/ H/ X2 ^) ~
Version NX 4.0.4.2 must be installed before updating to version NX 4.0.4.2.mp10. Please be aware that these updated MP files will be superseded by the next maintenance release or maintenance pack installed on your machines.
; m1 t6 S0 U# u/ L7 U
/ G0 u9 ~- z- u6 k6 x. q5 B. e& dTo use this update, change to the directory where you unzipped the nx-4.0.4.2.mp10.zip file, make sure the entire set of new patch files have execute access, then execute the “ugs_update.bat” script.
' V" U* J/ E/ J& q: o+ ^6 G: o/ k" W' \' G3 B  y
: @# d1 B/ K0 @
& ^: ~9 G' U( e; Y0 Icd NX404_mp10
  o6 ~( \( H3 @8 t$ q5 R: a0 p  ?0 I( V% W# |
ugs_update.bat /v/ S4 u" `5 G* O% C
3 ^' b' [1 w& x8 C/ n2 U : {; w) m2 n; Z/ [2 a! `; M& d$ L2 C
: U: r" n& n9 d4 _The normal operation of the script is non-verbose; stop to confirm default answers.3 P. P& c/ o/ D; o$ g
: `+ h6 m/ e6 |
The update script supports 2 switches:
$ k3 f/ T0 K  H9 V4 t, `% b0 F
' P! @1 w4 [7 U8 N6 K* w5 B5 q" ~/v = Display verbose messages. , z; g. ]8 ~/ y
% K0 U  ^8 j0 k# {+ ^; p1 H' }
/d = Take all default answers (i.e.: script will not stop to ask questions).
9 q4 ~9 V) b$ [4 I# d# U
9 Q% Y; o5 C* D! v
1 m& i, A" \: G' l* x7 f, [5 N, L7 f2 R
Note: Before running the ugs_update.bat script, please make sure the environment variable %UGII_BASE_DIR% is set to the base directory of the NX 4 release. For example:
% z) u5 Z# e, w4 r$ H# o
8 k( r3 z; Y  T  f' ~: G5 }set UGII_BASE_DIR=C:\Program Files\UGS\NX 4# ~; @7 `* |" U% G" G
+ g  |+ R; d2 B' q* k* u ' f8 d. @/ q+ d. N, g
! W% }% Q3 ^% ^
Or set to the appropriate installed directory on your system.% E' y' k7 f% F7 Q. a- n
9 m" }1 n6 N0 ?# D
, G" e" X+ L) q/ w, H
( U: @4 Q, A! J+ K! ]6 k
0 i. w6 F* R# _0 b
. t( c; D: b: RUNIX update instructions % F' N- A7 q( ?: B2 p7 e# T
# C' I: Q6 H/ x* @
3 Q; Y# d' K* ^9 I% W  S
2 t; Q3 s9 z2 z% t9 JThe files contained in nx-4.0.4.2.mp10.tar.Z are provided as replacements for previously installed NX 4 products. 3 T3 K/ q8 |+ M4 g: m7 F; B$ e2 \
1 q% r+ [# r9 L* s$ E
, }% ~0 G: ]1 ?" z' }8 u2 n
7 o8 B  C5 a% m; P" aFor the SUN/Solaris platform, you should have at least 1.38 GB of free space.0 S6 ]: j* ]/ Q5 p& _  y
2 s* T: h9 `( o. z) G" B7 |; g " c* c: M) v5 O9 f# Z$ f1 ~2 J
/ C# r5 K+ d6 O: C% N9 eFor the HP-UX platform, you should have at least 1.75 GB of free space.2 e/ y+ i7 R, ^: [
% d: ~$ q) M1 J5 \$ I' W, P
4 I2 G! t% s, [) Q2 W* R' C( ~
; g+ u4 c" I) F, w" a4 c
+ @1 K: w- f% |1 H. n
6 s3 y, R$ y; R  A# x5 p" {- ]; R; q) p8 A$ i; N
To use this update, change to the directory where you extracted the nx-4.0.4.2.mp10.tar.Z distribution file, make sure the entire set of new patch files have execute access, then execute the “ugs_update” script.
" D0 q4 |9 W7 v5 i/ h- o& ]  b2 a2 F: S- C% S- }
2 i7 z  s6 I9 S, M3 _' d6 g- k
. V8 u0 T$ J; Jcd NX404_mp10, ^1 S- }( z6 z
& m6 F* `: b: n5 @3 y, F
chmod 555 *
4 k6 r! t6 p! p/ `( I. c4 s
$ P: G; ?0 n# B7 ~- _./ugs_update -v
/ c: h3 b: t$ r- ?4 O5 n% ~: s) o  S1 |+ E0 I0 |
9 Q# \- s1 Q& k9 }
5 V. Y, u; }3 A3 SThe script will interrogate your installed NX directory, and update the installed files.  The normal operation of the script is non-verbose; stop to confirm default answers.
& a( J& K8 h2 d& l6 D1 R
- P) l; w/ D! J! X2 l# g4 L 2 w! o" x$ i0 n, B* c0 v
4 t0 m; @- ?3 p' m: h7 a$ H) a2 qThe update script supports 2 switches:) u5 g+ X% u" w
# m; S  Y* ]" c. r; k: Z2 k( f! W0 q-v = Display verbose messages.
; p' m0 g. q1 A! J& T- n) r
# P- G- i7 h4 D; d-d = Take all default answers (i.e.: script will not stop to ask questions).0 M# H/ ^) ]* \! O2 m
, E! X+ G" ~+ r
0 `6 Y: r& p( L+ N' c3 Y4 D% R9 w  ?8 y
After the MP update has run successfully, the following identifying text will be written into the system log of every NX session:9 C  ]9 K. P% D; l
* r9 F$ t! ]5 C0 U& [3 z 7 Z+ Q/ ~3 F& T+ n2 y; y! y& P
) j/ k* k, j/ K# I5 N6 @3 M- B- g1 K
"NX 4.0.4.2 MP10, 04Feb09. See Maintenance Pack letter for detailed list of fixes."; R! v( c0 _% R& D, f0 I$ j6 Q
: D7 |2 x4 K! k" J! h
2 z- w# D+ f% A% R) f* j- B1 Q, y; r6 A: F3 l$ F
If you have any issues with the installation or support of these fixes, please contact your local GTAC support group.$ k5 q, _- h+ K, `6 V# t
, W/ v( \7 u" z. u$ C3 c
+ H' O' P& {! P; t* W+ g3 @# j
Sincerely,
! ?* h, E0 v  F' i, h0 i) `- [9 O* N: d4 K
0 M$ c$ z& r" ]7 y, q1 Q7 V) z3 s% M% R3 ?1 U; K. g0 N
The Siemens NX Team
发表于 2009-9-30 11:45 | 显示全部楼层
楼主能否发个下载MP10的网址上来/ Q5 F: ^- ?% e& K) I( H
谢谢
发表于 2009-11-24 15:27 | 显示全部楼层
关于UG 4.0补丁
发表于 2009-11-29 12:17 | 显示全部楼层
MP10,的补丁是怎样装的?
$ g$ W7 C2 v2 P3 C6 Z; Z: h' l0 a有没有人说一声,我是新人。
发表于 2011-1-18 17:37 | 显示全部楼层
搞不懂。。。。。。
点评
雷神2 http://www.6699.tv/dz/59727/ 警察故事2013 http://www.6699.tv/dz/67348/  发表于 2013-3-4 18:30
发表于 2011-1-21 14:32 | 显示全部楼层
回复 4# 醒目仔 $ U7 H/ O" u$ r! y
" o( m) `* A5 ], b; W / g1 L& R7 f5 v8 k6 x. g
! @5 U( |! t, M5 W; @2 @0 L/ W3 i
谁能说一声NX4的补丁包怎么安装,放到哪个位置?下载包里又没有说明.....
/ }+ I" Q6 [$ \' S1 T5 A 各个升级包是针对那方面升级的?有没有LIST说明?
+ Q) z# u( C/ N' ~# b! z! o, `
% r) P: G( t* @2 I2 ?TKS!
发表于 2011-1-26 00:53 | 显示全部楼层
补丁怎么装不上啊 UG装好了的
发表于 2011-1-31 17:25 | 显示全部楼层
有没有下载地址?
发表于 2011-6-5 15:47 | 显示全部楼层
搞不懂。。。。。。
5 y$ _9 F/ F2 U+ k, C有没有下载地址?
GMT+8, 2025-7-21 10:22 , Processed in 0.184636 second(s), 27 queries .
