LOG_FILE =' M$ W& a7 z2 {$ |6 u
MSG_MASK = VOLUMINOUS
! @9 l8 d+ k- z+ @DSP_MASK = VOLUMINOUS' I+ `% Y$ p! P; M- } ?) d+ m' w: O
!dxftoug or dwgtoug keywords
* N: @3 q1 ?( r4 G2 B* iUNITS = English* U( |6 U, h& W' {) a( p
MAX_SPLINE_DEGREE = 3& ^; e& w# a: l7 ?3 E$ x
UGI_DIM_IMPORT_FLAG = ASSORTED_DIMN: M8 ~; d% d) y. Q& T
!ugtodxf or ugtodwg keywords
0 Y6 v& Q! ^- Y( I3 b9 v s9 jUGI_SOLID_EXPORT =
& m* o( m! a0 a& E6 oACAD_VERSION = R2000
4 p6 |: z' y( l+ T4 R5 c4 U+ ~/ B" `$ GUGI_CURVE_MASK = Points,Lines,Arcs,Conics,B-Curves,Silhouette Curves,Solid Edges on Drawings+ u" I: W0 }4 g! y9 {8 R. H
UGI_SURF_MASK =
0 z4 K: e+ P# }. w0 d$ n$ }: ]UGI_ANNOT_MASK = Dimensions,Notes,Labels,ID Symbols,Tolerances,Centerlines,Crosshatching,Draft Aid by Parts,Stand Alone Symbols,Symbol Fonts8 c0 o" V. K5 R6 D2 s; F5 E
UGI_STRUCT_MASK = Groups,Views,Drawings,Components,Reference Sets& H D) [' x' ]
UGI_SOLID_MASK =
7 W- ~4 J8 }& N& m2 LUGI_DRAWING_NAMES =
1 Q- m+ Y: x2 X1 A) vUGI_USER_DEFINED_VIEWS = 4 W% l( M- n0 l! V+ _' }
BCRVD = 2: W7 Q9 a# e( m! R* M; Y
SURFU = 8
0 W; j$ k4 u( y' G/ M4 P. y7 GSURFV = 8
* r" C' }) M ?( ?+ h/ }8 d4 C8 _ oUGI_PROC_ASSEM = Use load_options.def options9 |/ U/ g R7 V" y( |7 U
UGI_COMP_FAIL = Abort if Load Fails
! P8 v: S$ A) h- K# x$ |UGI_LOAD_COMP = Load Components
% }2 U) V) P. s" D1 A$ @2 N# GUGI_LOAD_VER = Load Exact Version3 i7 a0 Y' k$ \# B7 K' L5 z
UGI_COMP_SUB = Do not Allow Substitution/ r) @ B! H" ^4 i1 a$ ^
UGI_LOAD_OPTION = Load From Assem Dir8 \6 B* n& Q# s! M9 y3 \/ t
UGI_SEARCH_DIRS = 6 e8 R8 @/ E0 Z$ M- [) L, @
VIEW_MODERASE_MODE = YES, d: ~' E. v& O7 u: k! m& ]. x2 {
ASSEMBLY_MAP=ON
# y; k9 e( \. I- ^ |
