楼主,我的UG6.0在win7上面安装时检测也是看到如图4的提示:! R+ b5 B, o s: U
lmgrd is not running: Cannot connect to license server system.
! G9 U$ m" P% d7 C* A9 h2 Ilicense server manager (lmgrd) has not been started yet,
' W' u, p/ P1 z3 m1 H( I0 E1 Owrong port@host or license file is being used, or the9 P, `* B, H% ?, @1 Y
port or hostname in the license file has been changed.
6 X, c( x/ }. c/ }3 h后来点击start server,下面的提示框也显示为server start successful,但仍然打不开NX软件,2 {2 o7 z) K- [) c
0 K( t9 x" i6 R0 m, i9 p5 A
5 R( P7 [ _/ @7 _% L2 p再次检测,出现的是如下提示:+ Z# g4 n3 f) [7 H9 S- r
lmgrd is not running: License server machine is down or not responding.
; L3 S, Z, A, B0 p8 t& v% V See the system adminstrator about starting the license server system, or
' o' z u. S. k- h2 w1 O. m( ~ make sure you're referring to the right host (see LM_LICENSE_FILE).% o/ w4 j4 \: Y7 o
Hostname: 192.168.1.102
2 n6 ^& x+ Y: l' E1 y3 Y+ [License path: 28000@acer-PC;7 v- U2 M: k- l$ a! `
FLEXnet Licensing error:-96,491* K( Y' y, R/ N* E8 e
; S8 O' ]1 v/ ^# U o' [; g5 x9 w
这又要怎解决呢?8 l, N4 I j& z
有个问题就是我在start/stop/reread中使用reread license file始终提示都是5 W2 {* d' [/ R U9 J" J
Reread Server Failed。
9 T" M& ?; H" H8 B8 ~( t怎么办呢? |
