#! NX/KF 6.09 |3 ^8 X3 ~8 q" h! J/ H$ t2 o$ ^
DefClass: aaa (ug_base_part);
8 o% [) m( _# X2 l(number parameter) Beam_Width:5;' k% x+ P# L2 v3 a' q( a
(number parameter) Beam_Height:10;
: d7 p4 X3 w# n& D: f+ U(number parameter) Flange_Thickness:2;, l Z& o& V( ]1 \2 k( M! u! i( }
(number parameter) Web_Thickness:2;9 q6 l% f& _' c; i$ C% f6 `
(number parameter) Beam_Length:9;
; O' i* Z" s3 @7 X7 B* V(Point) Origin: point(0,0,0);/ C9 D, b% a; D. m
(Child) HandleGuide_1: {+ m2 h: Z) T3 n+ c# S- b [
Design; UG_line;
2 P& w3 Z6 i$ B [* ?, J& ^Start_Point; Origin:;
( L* k5 a( K+ C* h; i1 REnd_Point; HandleGuide_1:Start_Point: + Vector(Web_Thickness:,0,0);
% [0 y6 \- y8 X7 t1 G, W};7 U0 [0 R5 \# `& t: M+ _
(Child) HandleGuide_2: {5 R- ]. C* w; b3 N# F
Design; ug_line;
* h! J+ t0 y9 T; ^- d& Z) [& V- zStart_Point; HandleGuide_1:End_Point:;( ^5 Q* Z% ~5 D+ A8 U
End_Point; HandleGuide_1:End_Point: + Vector(0,(Beam_Width: - Flange_Thickness /2,0);
% t$ E0 ^( a6 m7 P$ C};4 i! y/ ?0 W$ N2 o& _1 k8 X9 G
(Child) HandleGuide_3: {3 H& A; v7 u7 x7 E+ [2 y% t m- ~
Design; ug_line;' x2 d$ w$ q& _2 W
Start_Point; HandleGuide_2:End_Point:;4 \+ v4 n& [ `# i6 J
End_Point; HandleGuide_2:End_Point: + Vector(Beam_Length: - 2*Web_Thickness:,0,0 );4 @( ~& t! [. o7 x3 |7 O* w, |, C! n
};+ V, g5 S( k; ?" l0 y9 U
(Child) HandleGuide_4: {
w6 x1 S' |4 Z3 Q9 v5 Z7 sDesign; ug_line;; f; j+ b, D% }7 |3 @, L
Start_Point; HandleGuide_3:End_Point:;% p: o( H2 ^: Y' s. u( |- j
End_Point; HandleGuide_3:End_Point: - Vector(0,(Beam_Width: - Flange_Thickness /2,0);4 {' h0 p8 u& b9 c# J
};0 V! R* \& V* ^
(Child) HandleGuide_5: {
1 Y0 u# a# @' ]* G$ U1 S# S$ _1 ]; e( eDesign; ug_line;
1 D1 ?0 Q; {( p$ B' T XStart_Point; HandleGuide_4:End_Point:;9 Q' Q l7 T( z, e. E& J0 ]' t
End_Point; HandleGuide_4:End_Point: + Vector(Web_Thickness:,0,0);" u/ Y* ~+ [1 |
& O% s) u* K z8 L& N5 A) u* L(Child) HandleGuide_6: {
) ?% O- r; @ f- |" mDesign; ug_line;
) q* f! H. G7 U" J( s0 w& D. DStart_Point; HandleGuide_5:End_Point:;; {( R- d% s+ h, X
End_Point; HandleGuide_5:Start_Point: + Vector(0,Beam_Width:,0);
( f* S% ^. X- S% `; h- H$ X6 E};- X4 K8 [7 t. V' t
(Child) HandleGuide_7: {* Q* J! r' Q% X3 K4 f/ Q/ L
Design; ug_line;
% g. C1 D* x: |, b1 I! n9 aStart_Point; HandleGuide_6:End_Point:;8 K D/ c; _" G5 ^. N' d3 b
End_Point; HandleGuide_6:End_Point: - Vector(Web_Thickness:,0,0);# z3 u6 ~: x4 O# w9 a* H6 t2 s9 E8 I5 D
};6 s5 ^' v3 p5 q) E
(Child) HandleGuide_8: {& Q1 M$ F. b7 o. P* ?7 y W: o; P! P
Design; ug_line;1 O; p+ Z# Q0 D6 ~7 q6 t9 @: X
Start_Point; HandleGuide_7:End_Point:;: h* {% r8 ~3 P% @1 u) }( q
End_Point; HandleGuide_7:End_Point: - Vector(0,(Beam_Width: - Flange_Thickness /2,0);
# X6 C# z0 T9 L$ a/ N5 A9 N$ i. \' q};
" d% k+ _ J# [3 J) w/ b6 [9 w(Child) HandleGuide_9: {
' q- Z) U$ E: S' @+ KDesign; ug_line;
; S! _* H( M. d3 A6 |8 v# {5 W. j2 nStart_Point; HandleGuide_8:End_Point:;
1 N3 P$ T( Z: t1 k( uEnd_Point; HandleGuide_8:End_Point: - Vector(Beam_Length: - 2*Web_Thickness:,0,0);' ?( m% }3 j# f, T" `: L
};4 s7 Q8 _; \' n- f* @9 ?1 P* L
(Child) HandleGuide_10: {
7 f# J4 R, C9 k" bDesign; ug_line;
0 U) w/ P. z! b5 QStart_Point; HandleGuide_9:End_Point:;, [3 S0 D1 p3 d8 G# ~+ m
End_Point; HandleGuide_9:End_Point: + Vector(0,(Beam_Width: - Flange_Thickness /2,0);% A/ X( \0 P# h3 [5 |
};' J% F: `0 g! f" J# j/ g
(Child) HandleGuide_11: {
8 a* g7 J+ E* \! z) Y- DDesign; ug_line;
' F1 W( H1 B4 b7 P, R4 L. ?Start_Point; HandleGuide_10:End_Point:;
- @% U8 T/ d/ tEnd_Point; HandleGuide_10:End_Point: - Vector(Web_Thickness:,0,0);
4 }1 K' h+ L c' v) m};) M% f9 [# B: u: `, @
(Child) HandleGuide_12: {( c6 I! g& ~7 T* |" }. i# O5 N
Design; ug_line;0 D' H0 ^ g+ Y! x( l
Start_Point; HandleGuide_11:End_Point:;
' [: ?- x: o8 L { L8 S9 L0 X* KEnd_Point; Origin:;" R# P1 e% V$ ]% i, a
};) `5 W/ Q5 W; K3 g9 O
. ^, J6 e5 @% }. r$ _7 V3 v& ](Child) Direction: {% S/ G5 v: e5 t9 T
Class, nx_direction;
& x& \& a3 }5 n9 Y& N' h6 C) cVector, Vector(0,0,1);8 r: q/ |/ K( s' m5 ]1 X
origin, Point(0,0,0);
; V; l E( _7 }$ P) J$ y) o x, n9 vupdate, within_modeling;& R; [$ A- M* q2 u
Visibility, invisible;
9 [* p, f) r$ HColor, 0;
0 s8 T% A3 _; T/ T$ s8 W/ a* iLayer, 0;
8 R! B3 y( b e# Z% a4 a6 X# gLine_Font, solid;* ~0 g H1 z6 I8 R
Line_Width, normal;) ?5 v1 u( \: i/ l1 @; m1 m) a
Name_Location, Point(0,0,0);$ w. T) T9 e. y h/ v: V
Name, "";
, t3 B Q1 X# ~- ?! vlockObject?, TRUE;
, h0 p3 g/ a) v: H! ^. m. y; Q# t};
, L/ V8 k! K' u( F) O* U(List) HandleSectionList: {forward, HandleGuide_1:, HandleGuide_2:, HandleGuide_3:, HandleGuide_4:, HandleGuide_5:, HandleGuide_6:, HandleGuide_7:, HandleGuide_8:,HandleGuide_9:, HandleGuide_10:,HandleGuide_11:, HandleGuide_12:};" C' }* o" c2 B4 d- W- R5 d
(Child) EXTRUDE: {
; a s+ q- M& [, ^) T" WClass, nx_extrude;
1 K2 _+ A9 `& ~8 j& J& J& usection, {HandleSectionList:};
) `$ [5 J% _, a- g" h0 vDirection, Direction:;# |& S: ?$ H' L' \- h! ~
Height,Beam_Height:;* d# ~0 `2 W6 t8 v( T/ H
}* }8 x$ s# d9 x, {5 |8 A# P3 p
4 s% y- G3 j- H
拉伸这个类总是出错,改了不是语法问题就是别的错误,请大侠帮忙改正,谢谢!# G/ X6 W7 x: X6 @7 s
小弟是初学者,还请大侠指点,谢谢! |
