1.ug中的CAM操作:
{- q5 K! Z0 r5 ]$ C% O6 o0 a; ? 如图,创建一个变轴铣,
! s! ^2 l2 z% p7 d. P: |
/ ^6 D1 T: [% b: [+ r
通过UG中的程序仿真没有问题,通过List显示刀轨文件
' ~8 G# S- p, j* x7 ?8 }..........
% k% d0 l! W- O# a$ ]: kRAPID
/ b( t, F# A b$ Z4 }+ k- y& {( lGOTO/66.1651,16.2659,-12.4019,0.5870421,0.1443180,0.7965889# p& K$ R- B9 ?) U0 l
PAINT/COLOR,42$ p& z z+ u+ U% l. c
FEDRAT/MMPM,250.00007 ^) R' h; D& z6 K; Y. L
GOTO/48.5538,11.9364,-36.2996
+ A* _$ L7 N" H: e0 T$ z/ K2 BPAINT/COLOR,31# }( [5 C% R. D: {
GOTO/49.7832,13.6573,-37.4851,0.5858862,0.1057162,0.8034684, z3 b* O7 j6 R* p6 y
GOTO/50.9344,15.4890,-38.5718,0.5837673,0.0660045,0.8092337
9 H% S& J# ^+ K6 S......
" z% d$ P6 E! b2.通过UG/POST创建后处理文件
0 m2 T* Z* j5 e! w; A/ l 机床为AC轴摇篮式双转台机床,带RTCP功能。) M& s! R7 R% @
创建如下后处理,其他默认。- ?6 D7 J! v% [2 ?; O, N$ u6 e
0 B# |1 n9 ]" B( [
对应生成下面的部分G代码. X- g0 H O, o7 E" o8 T
2 ]. b5 w$ R6 X m! Q* z0 HG00 G90 X0.0 Y49.411 Z27.15 A-37.194 C283.812 S0 M03( U2 Y7 O$ {& W' e
G01 Z37.15 F250. M081 n+ F9 P$ q' b8 D* Q' {7 ?- y
G00 A37.194 C103.812
/ \- y' A3 \, `, }+ u6 ]8 d% N' FG01 Y-49.411 Z27.35( x* n3 ^6 ~. R. X9 Q+ [
Z27.15- I7 p8 d% [9 w. Q! N3 t& ]
Z-2.85
5 y& s5 Z! h9 B& l3 Z. `X4.6 Y-51.454 Z-3.526 A36.537 C100.228
; y X" h& f( J' l0 oX9.668 Y-53.011 Z-4.358 A35.979 C96.451
& w5 M* h9 R' R' d........
* w" p# c' S t2 ]但是通过VERICUT仿真此后处理生成的NC程序仿真轨迹明显不对。4 y# o. u% S, e
4 I- V" G9 j& Z! x& H% `: e/ V 如果将机床设置为AC轴双摆头形式,生成正确的NC代码,vericut仿真得到理想结果
% t ?. S' s1 p$ U
- Z& j# c2 O! Q& o.......* _, g& t; g: q2 a. ?% D
G00 G90 X66.165 Y16.266 Z-12.402 C283.812 A-37.194 S0 H00 M03
* T6 q7 d( @% F# l8 sG01 X72.035 Y17.709 Z-4.436 F10000. M08
8 G7 f1 j" r. x6 z q6 iG00 C103.812 A37.194
6 W- ?' o1 u: j0 o x$ O( _G01 X66.282 Y16.295 Z-12.243
4 L) J6 {8 z L' t* r( ^8 ^1 qX66.165 Y16.266 Z-12.402 F250.
3 i3 Z# v7 r' k: h9 \1 S8 v% [$ a# [X48.554 Y11.936 Z-36.3* R, O0 K+ {9 N6 q8 q8 `
X49.783 Y13.657 Z-37.485 C100.228 A36.537; P( }" \( n5 u( I3 U
X50.934 Y15.489 Z-38.572 C96.451 A35.9794 x; l2 M( F, N2 I
.......5 X0 s6 a- X' V- J+ ]9 D4 O* X8 }! d# l
+ d1 l& V2 r9 J2 z: O
3.疑问:) `1 |% K+ G2 [' j" e4 s# K6 a2 l$ T
1)机床实际为双转台的,为什么双转台出的后处理有错,却双摆头出的后处理正确?
8 h e: H: S. |) i. n比较两段程序,可以发现,只要刀轨中的X Y Z坐标直接翻译过来就正确了,双摆头的正是如此,而双转台却改变了X Y Z坐标。3 J8 e# l0 i' O! @; X4 c! x
在Program中G01代码X坐标的表达式都是$mom_pos(0)。为什么XYZ坐标变化了?怎样改正5 x0 F7 e/ F: A3 y1 g0 B+ P
2)机床零点到第4轴偏置、第5轴到第4轴偏置,在双转台的后处理中我设置了,在双摆头的后处理中没有设置。
/ o3 j/ W5 E( ^3 a8 i我机床的A轴旋转中心-工作台平面为20.45mm,工作台上圆柱形的工件毛坯高度为72.3mm,加工坐标系设在工件上圆柱面圆心。
. u# I/ u6 }1 d# h) D; W我这个怎么怎样处理? |
