三菱,台湾新代,螺旋圆弧插补方式1 U1 t l1 e" L
G17平面G02/G03 X_ Y_Z_R_* d! l" l5 ~' u; M+ J3 f
G17平面G02/G03 X_ Y_Z_I_J_
( U0 q5 ^# h6 a4 b3 J用R螺旋圆弧插补方式,大家可能都知道怎样去改,我就不多说了。% c! q, B9 F# m! j' B v
用I,J,K输出圆弧,螺旋圆弧插补不能有K值的。用ug后处理构造器打开后处理文件找到螺旋下刀"proc PB_CMD_init_helix"中找到"rise_radian"改成"none"% N1 ]3 t5 ^6 M9 G
改完保存,螺旋圆弧插补就不会有K值,在三菱,台湾新代都能通过。fanuc我没用过,不知道是否行,(可能fanuc系统版本低不能用)
7 K% o& r5 f9 q& F9 n# ]& i- O以果有说的不对地方,多多包涵,望大家能回帖子。 a/ r. N. ^6 o9 P
, s6 Q7 n2 E' B, x6 ~/ ~: f
#=============================================================3 c% r9 K+ z2 u) R0 U, N1 P
proc PB_CMD_init_helix { } {
7 e7 w+ O; f6 P# F#=============================================================1 W; q& h! Q& {8 z% l
uplevel #0 {
4 G7 ?, r% \8 @#; A& W5 y L5 b3 C5 P7 f. x
# This procedure will be executed automatically at the start of program and
, H# K; c# M2 ^1 Y( R/ c, M6 N- V5 J# anytime it is loaded as a slave post of a linked post., E3 B, |' N& f e' v1 A" w
#4 Q0 `4 I" J. [) |3 r
# This procedure can be used to enable your post to output helix.# Q4 g- l; R. q4 h- P( _
# You can choose from the following options to format the circle ( Z" R3 b g! U" S" l$ M3 \% D
# block template to output the helix parameters.
) w4 V9 L( ~4 q( I#1 h$ c# `# o# W7 b f
set mom_sys_helix_pitch_type "rise_radian" 2 V: _$ N# k" B/ D. c
#$ g$ q1 B( t8 [ m# M3 i$ J+ |
# The default setting for mom_sys_helix_pitch_type is "rise_radian".6 {; c' `7 I6 W0 a) E% M( c" u
# This is the most common. Other choices are:+ }) y, g$ e7 o; m) s' j& D
#- ~8 ?: t" j: ]' I$ m# ?, X+ A2 U
# "rise_radian" Measures the rise over one radian.3 x, W* D1 c- y) \2 G% k
# "rise_revolution" Measures the rise over 360 degrees.$ K( l1 p& a" n4 o9 P: I5 f
# "none" Will suppress the output of pitch.( u2 t0 @4 D! e) ]) B4 w
# "other" Allows you to calculate the pitch; y1 L" U+ s4 k' a/ f/ r; [
# using your own formula.6 [6 {+ F9 m) r- Z3 R, O5 e
评分
查看全部评分
