楼主 |
发表于 2011-9-14 10:08
显示全部楼层
0 i8 f4 k$ x' _$ u" f* S) `) N| 时间 | 体积 | 压力 | 锁模力 |流动速率 |螺杆位置| 状态 |- i" ^, u# ?5 z& k; T+ X( O
| (s) | (%) | (MPa) | (tonne) |(cm^3/s) | (mm) | |
* h/ v1 X% z& ]- X( H3 B1 s|----------------------------------------------------------------------|1 [- I6 X* }; `8 z- G/ Z
| 0.01 | 1.42 | 18.93 | 0.00 | 21.18 | 14.52 | V |
. [( t3 J# ^' H# g6 {% M| 0.02 | 3.13 | 29.17 | 0.00 | 22.46 | 14.23 | V |
/ V* P: {9 d* X3 l| 0.03 | 5.91 | 38.54 | 0.00 | 29.83 | 13.84 | V |7 ?2 k$ ~- [6 V% e/ K
| 0.05 | 9.55 | 44.51 | 0.00 | 35.26 | 13.44 | V |- r0 c: r: l" C6 |& d
| 0.05 | 12.17 | 48.35 | 0.00 | 43.97 | 13.16 | V |
; Y+ C( h8 [0 F$ S H! l6 E: z/ d| 0.06 | 13.33 | 49.21 | 0.01 | 45.84 | 13.05 | V |
0 V1 ?. {4 B( T! V2 D, x" ^1 {| 0.07 | 19.21 | 51.07 | 0.08 | 48.03 | 12.53 | V |2 m+ R. G+ s& ~ u, m
| 0.09 | 26.30 | 53.34 | 0.23 | 47.80 | 11.85 | V |/ h1 ~2 v" W1 B, |7 G2 E j' e# y
| 0.09 | 28.54 | 55.30 | 0.42 | 45.66 | 11.63 | V |
0 W9 {2 H( n. `| 0.10 | 31.99 | 63.06 | 0.89 | 45.73 | 11.26 | V |
8 q2 {" Y: [1 l2 V9 }. J| 0.11 | 32.63 | 63.53 | 0.89 | 46.64 | 11.20 | V |$ X1 I' E. Q8 b/ [
| 0.12 | 37.32 | 69.25 | 1.01 | 54.31 | 10.76 | V |+ d( Q6 l5 _+ t0 i9 [/ |$ o. X
| 0.13 | 43.38 | 68.87 | 1.05 | 57.18 | 10.25 | V |" T* f7 i4 k: U# _% H
| 0.14 | 49.46 | 67.24 | 1.13 | 56.64 | 9.74 | V |5 p! j: u3 x# q9 Y3 Y- Y! P
| 0.15 | 55.51 | 66.87 | 1.24 | 55.83 | 9.22 | V |
( @# T" I& W/ {| 0.15 | 55.73 | 66.07 | 1.24 | 54.63 | 9.20 | V |' z$ I, d8 p5 [
| 0.16 | 60.73 | 57.27 | 1.15 | 43.34 | 8.82 | V |# d% M! A1 _ h( {& V
| 0.17 | 65.09 | 58.15 | 1.20 | 40.65 | 8.44 | V |/ ~# u5 ^; v6 s
| 0.18 | 69.56 | 60.66 | 1.31 | 40.80 | 8.04 | V |
3 P3 V( [/ K' G! \ H( [| 0.20 | 73.74 | 62.73 | 1.41 | 40.98 | 7.66 | V |; L# u) u: T4 ]9 g
| 0.21 | 77.96 | 64.56 | 1.54 | 41.21 | 7.29 | V |
) ^9 j" ~5 |, T* m$ ]| 0.22 | 82.19 | 66.21 | 1.70 | 41.33 | 6.91 | V |
0 D0 s( E, `0 v" R| 0.23 | 86.75 | 67.56 | 1.85 | 41.52 | 6.51 | V |
) B- F U* Z* U2 F) X" ~| 0.24 | 90.90 | 68.91 | 2.19 | 41.06 | 6.13 | V |! d! \ t- O H( I+ U: c a+ n% `
| 0.25 | 94.91 | 72.52 | 3.02 | 40.13 | 5.74 | V |6 l7 j" ^ Z2 F: N" M
| 0.26 | 98.67 | 77.26 | 4.08 | 39.89 | 5.37 | V |( H* e' `- Y% Q/ W( W
| 0.27 | 99.54 | 81.22 | 6.09 | 36.06 | 5.22 | V/P |# _6 R* j% t6 m% V1 @0 \+ j' j
| 0.27 | 99.92 | 80.99 | 7.62 | 28.02 | | P | l T: O' k/ h1 A
| 0.27 |100.00 | 80.95 | 7.90 | 28.02 | |已充填 |& V' |1 M6 v1 M% p6 r, b5 x
! M4 r$ x: n/ |- H/ o" _|----------------------------------------------------------------------|
|4 o$ m7 l% ?% w2 m" Y x3 u 推荐的螺杆速度曲线(相对):
% e( F v3 L, a, E. S %射出体积 %流动速率
0 m' K8 q8 u; F+ \- t- {, G ---------------------------------5 O% l. o1 `# T
0.0000 10.0000) K% k- s( E4 e) @- Z6 m6 ?0 l
12.0000 10.0000
0 S! N3 c9 x7 D7 f! j1 g 12.0000 10.7254
, I* N$ X% k& Q0 e. H7 s 29.2933 10.7254
- n& T7 [5 c5 t6 H 25.3333 17.2215
1 S; T+ g5 u6 S, z" l3 { 38.6667 43.7028, p7 a' y* s' p& @
38.6667 62.3361
( N" S3 s$ F9 x- k 72.0000 100.0000
0 [* k( ? Q* m: L' \ 100.0000 50.9157
+ m' `" |! h1 t$ ]) ^* p % 充填时熔体前沿完全在型腔中 = 29.2933 %- P* C4 I+ R0 g! W: A
请问假如我要用3段来注塑的话,哪些参数需要给调机师傅???
1 d& R7 k8 q; A# e5 d0 Q; _% h5 z
& U( A( [! S8 R4 p' @
4 i1 F- }9 l) m# }9 ?6 _0 C( p4 p9 Q9 q9 i
