查看: 1758|回复: 3
[疑难] nastran 4.1找不到求解器?
发表于 2010-9-2 10:55 | 显示全部楼层 |阅读模式
Solve Error:5 Y: ~) o7 s( M3 _7 j4 g3 [
nastran solver directory cannot be accessed:c:\program files\nxnastran\4.1\bin\
' F# l  e0 N( w尽管我对ugII_ENV.DAT设置过.不晓得对不对?还是有其他的问题?* ^8 t' K4 M. L+ l  \
) V% @) c" \( ^$ D+ N' I: ^关于UGii_env.dat的设置如下:
7 w. P4 R1 G8 Q! d#  UGII_MSC_NASTRAN must point to the "bin" directory where MSC NASTRAN is installed
$ \- z4 G' `( l. M5 v. X% T! R#  this definition is assigned by the user after installing MSC NASTRAN
  }0 s3 ^; T3 L8 yUGII_MSC_NASTRAN=C:\msc\bin\, Y2 A$ K$ F- t. E& e+ ^
#  UGII_NX_NASTRAN must point to the "bin" directory where NX NASTRAN is installed- o, C- P/ a. R  m# T2 h
#  this definition is assigned by the user after installing NX NASTRAN
+ x8 v) J2 j9 m6 f% qUGII_NX_NASTRAN="C:\Program Files\UGS\NXNastran\4.1\bin\"
9 N3 J/ r* b8 E9 M#  UGII_FEA_FOREGROUND = 1 sets the Nastran job to execute in the foreground
, U  ^/ B4 U4 d! h& V8 I  @& M# UGII_MSC_NASTRAN_VERSION sets the MSC NASTRAN version number of the solver, valid
) }* G& I6 e. w% P4 E# versions are 68 for 68.2, 69, and 70, this environment variable allows the
+ T( F6 U& X& r* r# authorization to work on various versions of MSC Nastran if you are using
/ q: N5 b) J+ }& s0 ?( n" Q( f  _# another version besides 70 you must set this variable to either 68 or 69
. N$ k0 q4 V8 R, D6 k' K# O- Z# j# for the appropriate version./ E2 Z; ]3 p+ k, o5 H$ T, I
UGII_nx_NASTRAN_VERSION=70
: S- c  m7 [7 j. `: `! e. n2 }4 C/ u  R
# UGII_NX_NASTRAN_VERSION sets the NX NASTRAN version number of the solver, valid$ D% ?& e; O' s: U0 e
# versions are 1 and 2, this environment variable allows the
& V+ v3 ^0 R) o$ W# authorization to work on various versions of NX Nastran if you are using' [! h+ R( k& n
# another version besides 1 you must set this variable to its appropriate version.1 D9 s( D1 i7 r
UGII_NX_NASTRAN_VERSION=4.18 C' d9 I3 h# O5 b
#  UGII_ANSYS must point to the directory where the ANSYS executable resides.
% j- }: K6 m+ |$ D3 i# f#  An example for Windows NT Intel is C:\ansys55\bin\IntelNT
& h# g. \" m4 H  z8 n2 \3 ^#  An example for Windows NT Alpha is C:\ansys55\bin\AlphaNT; Y4 s1 A! T; O
UGII_ANSYS=C:\ansys55\bin\Intel5 N8 r+ C( p# P, Z
#  UGII_ANSYS_VERSION sets the ANSYS executable version .3 L* X) q. _8 J; S! g
#  valid executable versions are "5.5" and above.+ e( L& R: l4 z- u. W
UGII_ANSYS_VERSION=5.5
 楼主| 发表于 2010-9-2 10:57 | 显示全部楼层
另外,我也设置了电脑-环境变量:
* N! p5 z& N- \3 uugii_nx_nastran;                  c:\program files\nxnastran\4.1\bin\$ x" t* E* S. i7 Q% U( X
2 C2 _  Q( @2 s* ]6 kugii_nx_nastran_version;   4.1
 楼主| 发表于 2010-9-2 11:00 | 显示全部楼层
在开始--所有程序--NX nastran 4.1下面,有个可执行文件为nastran 32-bit.exe,不晓得我的nastran有没装全?
 楼主| 发表于 2010-9-2 11:01 | 显示全部楼层
我是在高级仿真里做的,点解算就出现此提示...
GMT+8, 2025-9-17 01:36 , Processed in 0.050803 second(s), 25 queries .
