$ F. B8 W6 ]7 C: {L=直线;
6 `4 i3 ?5 { X. ]6 nPL=多段线; 8 s3 d1 v/ F( R' J0 w, ?
U回车=Ctrl+z=后退;
/ B' I t- V& M4 [# ED=修改,调整;
" |8 s: @0 [! Q5 d3 ?) Q* nREC=矩形; ( @6 g; O3 s6 d* U
C=圆; & P* X0 s5 Y! T1 i) F3 W6 y7 X% N5 r
TR=修剪;
( ~' X- ^. w* c, fO=偏移; % U" p' @) y& y0 B
XL=放射线;
4 K! ~+ ]' p- C ]8 ZX=分解; # h3 U# D- p3 S. N# M
CO=复制;
5 ]7 y6 h' o' ~, VM=移动; - e) [+ g. Y0 o; l, M
MI=镜像; . M8 O+ G6 l4 R
EL=椭圆;
4 F, R9 z3 w( c8 }* J EBR=打断;
6 V; F3 J' E( a& l6 S }POL=多边形; " d( B5 V2 V( \! p! A: N! u
LEN=拉长; , I& M* l* ^1 [+ ]
S=拉伸; 5 T! \* q0 ~# j- D
ME=等分;
+ l( N i W& N0 Y, \: ZE=删除;
$ |, f: U# }% _( W/ SE回车ALL回车=全部删除;
) D& W" I+ ~0 r6 C Q P# |4 ]AR=阵列;
8 Y4 r) C, V' p% F/ m/ p8 eRO=旋转;
2 U7 O" ?' t) ?: p- `! o; J. FSC=比例缩放;
3 ^; d7 m! m" Z6 b$ C. hEND=端点; , A" J5 O) \7 ~. g/ R/ W
MID=中点; 2 q, ?- j6 q, g5 g$ L
PER=垂足; / Y3 s6 c2 F, {1 k: k/ K7 Y
INT=交足;
6 m" J3 g8 a! @& ] M6 ?CEN=圆心; ! n1 i) Y* y7 {: e3 T( f
QUA=象限点; ( X! [9 K: ], Y/ l( W. G" _
TAN=切点;
* t" o2 v0 M2 J, @" f+ ~SPL=曲线;
' i" {& u3 i- Q) CDIV=块等分; - E6 m' |7 K$ p: Z! P5 y
PE=编辑多边线; + r0 w6 J- W2 o( k
NOD=节点; 5 W9 z( s) `* k6 T
F=圆角; ' T) z( Y/ C' t' I( L. u- s* U
CHA=倒角; 3 i$ ^2 E8 d4 m( P4 B
ST=文字样式; + S W0 n3 b3 W9 d0 v5 a
DT=单行文字; 1 L1 I3 j4 f9 I+ b9 _3 L5 m0 h6 ]
T=多行文字; 1 C( i B' Q& k0 ^7 {' R, n p
ED=编辑文字; , S! L+ L. R) Q7 f1 V: r
A=弧; 3 g( F& W1 h8 c) |% L+ m
H =填充; 3 x+ W3 V; w5 K, N) d1 V
HE=编辑填充; , F R1 {% M1 j) g
B=创建临时图块;
. p4 F6 v* l. H: J7 S9 KW=创建永久图块; 8 q* c' r: N$ g0 u; b6 ~
I=插入图块; $ z) r, z P7 | M
LA=图层;
# B3 T3 Z& _! O; b% tMA=吸管加喷枪;
3 h3 o2 P8 F6 B1 p6 T1 @9 C* X1 Z- r() PAR=平行线;
5 T/ Z2 z( E% Q4 A3 BFRO=正交偏移捕捉;
# I2 q4 W' l( L) J" ePO=创建点; * A% ?- b8 W r2 c T# {$ K
SKETCH=徒手画线;
" u8 `- d V! `( J- ~- e+ F# rDO=圆环;
& L2 }! [& U. M" c1 v5 Z+ x# }RAY=射线; . j" b9 y3 ?9 b9 y+ d& K* [9 V- }# ]
AL=对齐;
7 d4 ]* I5 p- W: V+ _; b0 _& M) zREG=面域; 8 D* W: J' w, R
AA=求面积周长;
$ e& @4 R* b2 u0 A0 B5 i' E. n2 HSU=减集;
5 R) j( l9 F# ~4 ?+ u E5 n3 g+ R) t$ DUNI=加集;
" @8 ^7 b% Z! U5 L( l4 d% L! oIN=交集;
7 V# O. |4 Q0 i% eBO=提取轮廓;
) } P, G2 s! W9 T: R gREV=二维旋转成三维; # V! P" t! S0 _: \* T
EXT=拉伸;
3 F6 m( t3 W( O; G( TUCS=三维坐标;
/ _. G, q% J, X: F. [ROTATE3D=三维旋转;
! w& @/ K( x4 AMIRROR3D=三维镜像;
( z9 o! \. {9 A2 r& P3 F3A=三维阵列; : U8 j3 V( H2 m; J" l$ g
SURFTAB=曲面网格;
" q' ^- W" [& VTXTEXP=分解文字; 8 k) [8 P: C4 L* [! N
CTRL+P=打印;
7 m3 ?, r- G3 B, x8 q. D; d8 ^5 U. v(一)字母类 1、对象特性 ADC, *ADCENTER(设计中心“Ctrl+2”) % Z' C% N* S$ n' _
CH, MO *PROPERTIES(修改特性“Ctrl+1”)
; j, [$ l' X/ I" @! `MA, *MATCHPROP(属性匹配)
: _. O( {9 a9 `8 n- k( L; CST, *STYLE(文字样式) 8 M; U, I7 G: n
COL, *COLOR(设置颜色)
0 I. ^' \" H' `$ J- XLA, *LAYER(图层操作) 2 @( W8 w) ?- `- R3 L( F" |
LT, *LINETYPE(线形)
- N+ r' ~ X, ^ k' {* V) S3 zLTS, *LTSCALE(线形比例)
: i5 P u+ r& e: U* u8 _0 RLW, *LWEIGHT (线宽) $ M) r% A2 }: ^* D, e
UN, *UNITS(图形单位) % l9 U! a* U; C# t+ d. o6 S' N$ o1 u6 [& u
ATT, *ATTDEF(属性定义) ! |" ?* x9 x9 w
ATE, *ATTEDIT(编辑属性) % n8 k" ^' M; {+ n* `* u4 I
BO, *BOUNDARY(边界创建,包括创建闭合多段线和面域) , L& O" w# h! x; G- J+ d3 @9 ]
AL, *ALIGN(对齐)
# `$ p4 y2 v% t3 \5 u, eEXIT, *QUIT(退出)
& k& r# [3 }9 p/ s& XEXP, *EXPORT(输出其它格式文件)
' j! f2 d7 D9 _# QIMP, *IMPORT(输入文件) 5 f; r. m3 u) |8 e$ d
OP,PR *OPTIONS(自定义CAD设置) / J+ d3 M& B" B, j q. p
PRINT, *PLOT(打印)
2 J1 H* C3 f' ZPU, *PURGE(清除垃圾) ' i( s! p) n+ i3 P
R, *REDRAW(重新生成)
* c ]! G3 i& Y1 V' v- lREN, *RENAME(重命名) + L8 a6 i( O0 P5 q8 S2 c
SN, *SNAP(捕捉栅格) 7 s' P, d' f9 |& n1 `5 N/ j, n; z
DS, *DSETTINGS(设置极轴追踪) 7 E/ U6 Z5 u6 a- ~" C) f
OS, *OSNAP(设置捕捉模式) $ q) ~. C+ ^$ D2 z9 e/ y
PRE, *PREVIEW(打印预览) ; @! q4 u/ j2 S: B
TO, *TOOLBAR(工具栏) R* m% q; ?3 o6 h, f; z
V, *VIEW(命名视图)
l" m* T1 S/ l! J- pAA, *AREA(面积)
; z5 O' h: |. C% W. ]DI, *DIST(距离) ' e, X1 h% O* m8 @9 x
LI, *LIST(显示图形数据信息)
4 l7 H6 Z `1 @0 u2、绘图命令: PO, *POINT(点) {4 Z$ g7 o. m% Z. L' B( j6 b
L, *LINE(直线)
) ^- F! E6 Z9 S( x7 Y( J0 zXL, *XLINE(射线) l! N7 `7 G) b7 a& V
PL, *PLINE(多段线) 0 _! p' ^8 r- }0 p: I, N! H/ x
ML, *MLINE(多线)
$ b% M% M. N, v1 i. [" ^6 tSPL, *SPLINE(样条曲线) 1 G" e8 a2 _2 y
POL, *POLYGON(正多边形) 0 [+ _$ Z: e: I7 }/ u3 D, p' c
REC, *RECTANGLE(矩形)
1 K$ P, F; k- PC, *CIRCLE(圆)
; |- q( S! T4 O9 UA, *ARC(圆弧) ) b" X4 s* p9 r' u& I3 w
DO, *DONUT(圆环) . l6 x$ }! L! d5 Q N
EL, *ELLIPSE(椭圆)
1 J# r6 {- v V+ tREG, *REGION(面域) R) C: O# k$ x( P0 Y, H, \. E
MT, *MTEXT(多行文本) 6 _3 x( t3 ?. I! {( S
T, *MTEXT(多行文本)
0 U3 x, n, v7 Y1 z5 zB, *BLOCK(块定义)
# A2 V% C9 A3 j1 t& eI, *INSERT(插入块)
# W8 Z6 D, b% [W, *WBLOCK(定义块文件)
( E) w- c9 C* Z0 x9 Q1 R* m- TDIV, *DIVIDE(等分) # d' ]5 F1 i/ c2 ^5 F
H, *BHATCH(填充)
$ H9 {1 i* D3 o- f3、修改命令: CO, *COPY(复制)
; x* _* B; ?2 |8 w1 y" O3 AMI, *MIRROR(镜像) 8 R% ?/ w3 [/ k5 i. |: ]
AR, *ARRAY(阵列)
6 I% a F4 [2 ~' BO, *OFFSET(偏移) 5 J, D5 k0 a2 Q- x' B$ M1 _/ l
RO, *ROTATE(旋转)
) y3 A: m% v2 w3 |0 WM, *MOVE(移动) * ?+ ~* N; ?) ~0 Y
E, DEL键 *ERASE(删除)
* p7 Q% w6 D p: [/ O* B: @. lX, *EXPLODE(分解) 4 U' n4 \* g9 P, y
TR, *TRIM(修剪) $ f* c( M; Q! N+ }2 [+ Q2 C7 b' ~6 ~
EX, *EXTEND(延伸)
! m# a4 s" H9 J; n) RS, *STRETCH(拉伸) # ~3 ?; }3 w% s& X2 N8 W
LEN, *LENGTHEN(直线拉长) " ~& I! |% U- k @. t& _& Z
SC, *SCALE(比例缩放)
$ D: T& n/ p: dBR, *BREAK(打断)
) v: Y/ v. ^" ]CHA, *CHAMFER(倒角) 8 n/ V% L* u# z7 {) K* P
F, *FILLET(倒圆角)
0 q5 B9 \! ?2 O& r2 k" \5 J% rPE, *PEDIT(多段线编辑)
; W; y- S! u( D6 d$ X4 jED, *DDEDIT(修改文本)
% A. n# ~7 m; S4、视窗缩放: P, *PAN(平移)
6 v6 {: i0 s6 b0 T h5、尺寸标注: DLI, *DIMLINEAR(直线标注) 9 }* S! p+ q* s1 }+ A ^4 y4 u6 g8 l
DAL, *DIMALIGNED(对齐标注) $ K$ n9 c7 e7 v* a6 d- r
DRA, *DIMRADIUS(半径标注) t" T7 R! Q+ E& ^9 F
DDI, *DIMDIAMETER(直径标注) # [3 O+ Q8 q0 X* e0 E) I
DAN, *DIMANGULAR(角度标注)
# g- v% m: o5 y+ |* p8 ]6 e8 Q5 RDCE, *DIMCENTER(中心标注)
& V% F0 l: E. H2 b" ZDOR, *DIMORDINATE(点标注)
, v! i3 t5 \" p) S& S5 n1 l; KTOL, *TOLERANCE(标注形位公差)
2 F4 ^3 j1 s8 G+ D8 s; V! L3 `LE, *QLEADER(快速引出标注) 7 W# t4 m6 j# P, k, D* Q% b
DBA, *DIMBASELINE(基线标注)
5 ?4 v# b% [) P# ^9 C' bDCO, *DIMCONTINUE(连续标注) 6 j, E- s& T# `- I. {
D, *DIMSTYLE(标注样式)
8 X) Q8 g! D0 L1 {" q* rDED, *DIMEDIT(编辑标注) 3 I5 h- S4 l+ U: r4 M" h4 o" \, D
DOV, *DIMOVERRIDE(替换标注系统变量) 5 i8 t3 T1 Z) n& z& K0 }- P& b
二)常用CTRL快捷键 【CTRL】+1 *PROPERTIES(修改特性) ( z: Q* y# I& }: ]" Q' _! u# _
【CTRL】+2 *ADCENTER(设计中心) ) d0 u1 D( J" A+ s( Z
【CTRL】+O *OPEN(打开文件)
! k; }0 B4 p: V【CTRL】+N、M *NEW(新建文件)
8 H1 _7 f+ ~& J' T9 |7 d【CTRL】+P *PRINT(打印文件)
# v/ E/ {7 ^% [2 |( Z/ K5 U( d, ?【CTRL】+S *SAVE(保存文件) . m4 \4 K0 m3 D [5 u. n# C1 S6 Z( d* T1 F
【CTRL】+Z *UNDO(放弃)
; _% w0 Z2 Z9 }" V( B【CTRL】+X *CUTCLIP(剪切) ) v( s) J0 p# E
【CTRL】+C *COPYCLIP(复制)
8 {9 U8 G* j9 x- D6 J【CTRL】+V *PASTECLIP(粘贴) 4 `+ u, z) @* H2 e) V
【CTRL】+B *SNAP(栅格捕捉) $ Q1 n n, ?5 f, l6 U
【CTRL】+F *OSNAP(对象捕捉) , ^1 ?# E1 @2 p7 G) f
【CTRL】+G *GRID(栅格)
! L) x0 i4 a6 `+ H2 C7 T# {4 b; P【CTRL】+L *ORTHO(正交) 1 Z- x* Q" Y2 a9 L; Y* l" [
【CTRL】+W *(对象追踪) , j! @; x7 p5 |* T2 U' B& k- J+ X2 s
【CTRL】+U *(极轴) |
