楼主: cycloneeric
[疑难] 约束手动耦合后报错,解算时停止,求高人解答
发表于 2015-6-2 17:12 | 显示全部楼层
qiufang840706 发表于 2011-12-23 08:411 t" [3 t1 c0 m$ g6 q$ v9 _
在参数列表中有一项“AUTOMPC”,其右选择框中是“NO”设置为“YES”。
/ P, [! d. l$ o% K
一直改   改完还变回去啊  1 [3 V$ ]) H' D$ P  {
! r  o' E% m! V) F4 M2 H9 R
8 e) K1 t4 ^# b& E) ^6 D USER FATAL MESSAGE 2050 (AUTOMPC)
9 @0 V1 R3 D# w7 a% V2 K     AUTOMPC PROCESSING ABORTED DUE TO FAILURE TO EXTEND MEMORY SUFFICENTLY% t& O+ y, D1 t( D; E
     TO KEEP THE EXPANDING CONSTRAINT MATRIX IN MEMORY. THIS IS A VERY
  V5 ?- i5 @$ q! C% ?     UNUSUAL OCCURENCE BUT CAN RESULT FROM A LARGE NUMBER OF DOFS BEING
' ]& D4 G( G1 B2 Z* [+ [% y- i# Z     DEFINED IN THE U5 SET. INCREASING THE MEMORY ALLOCATION WILL RESULT IN
5 Z4 Y) M- Z9 h1 F9 W$ o     SUCCESS BUT THE AMOUNT NEEDED MAY BE MORE THAN IS FEASIBLE., m! {! E' _' F6 r: \  u4 Q
*** USER INFORMATION MESSAGE 4110 (OUTPX2)
6 F; d/ j0 U+ a$ L! G4 z; e! W/ a0 n2 P; j
4 @5 y1 S; m1 l# n; i- E! N* S$ s+ g$ N( {  S5 ?
高级仿真中AUTOPMC  还有BAILOUT改-1也不好用啊   改不过来啊    跪求指点啊6 k1 Y! [, d9 l0 b9 S
GMT+8, 2025-10-11 15:52 , Processed in 0.045838 second(s), 19 queries .
