查看: 3508|回复: 13
求助特殊后处理
发表于 2007-11-2 14:55 | 显示全部楼层 |阅读模式
小弟加工的零件是由12段圆弧与12段曲线共同组成的封闭轮廓(2维),为内孔,加工时(三轴)刀具顺时针运动,要求作出的程序: 12个G2,之间为数不清的G1,请各位高手指点如何修改后处理!在这里多谢了 ~~
0 F- `3 S5 ]( w' e9 q
$ T3 K5 u4 k  Q; U图纸拿不出的@!请谅解!
 楼主| 发表于 2007-11-2 14:58 | 显示全部楼层
自己先顶一下,一般的后处理作出的既有G2,还有 G3(当然也有G1),这个是不可以的!在这里向高手学习了!
发表于 2007-11-3 08:15 | 显示全部楼层
贴出你的程式各式看看
 楼主| 发表于 2007-11-3 13:29 | 显示全部楼层
%$ V# F, \3 C0 u6 R  q( n
O0100
8 D) W. g) @% T* A. H8 A# p( f( F T36
* |) {9 v& N* B% g G90 G80 G00 G17 G40 M23% w( h9 G" B! j$ f$ X. q
G43 H36 Z150. S1000 M03
" R' E( \+ U+ `$ E G00 X131.1 Y18. Z150. M093 g- z: [/ O$ t# \9 H' ?/ i2 Y/ D
G01 Z59. F150
) y# J6 \3 L: t0 P( B! A: v# M G42 D36 X132. F500
& _8 j/ a& J9 @1 O" a G02 X150. Y0.0 J-18., l$ Q9 C0 b, v! w3 D/ n. `
X148.352 Y-22.171 I-150.
1 b; z0 z% ^* o. | G01 X147.906 Y-27.473
5 I! d2 h" t! \* R9 l2 {* @ X148.153 Y-33.288
& a, W0 I  }, R" ` X148.59 Y-36.65
, X7 j2 T/ N4 V- V4 C/ B0 @ X149.236 Y-39.988
6 ^. D& X- {% ]; \! g6 O. W3 N/ V7 j X149.786 Y-43.235
  U7 X( ~9 C1 U# w" V  A  h X150.009 Y-46.496
7 S: N# q1 `3 s# x4 t. R( g" h X149.922 Y-49.559: _4 O7 a1 F  L' I" Q/ |
X149.539 Y-52.5973 _! D% @4 y. _& i2 Y: P. ?0 C  ^
X148.88 Y-55.463
/ ~( ?& i1 a+ [' V$ a* M X147.936 Y-58.274
9 ?) W; M* ~6 { G02 X124.435 Y-98.98 I-147.936 J58.274# S, y; I0 e; j7 i1 L! m. F: u/ H
G01 X122.473 Y-101.202
3 a+ a; A2 y, O9 y X120.32 Y-103.2064 x5 Y3 M$ V: \  Z  D
X117.881 Y-105.057* P7 M3 Z3 Q. |4 U) z( m) t. Q
X115.271 Y-106.664
$ H6 R$ l) C! |) y, R* ~3 d& D X112.336 Y-108.101
9 u0 e" b# ~1 E: N- Y X109.248 Y-109.248; h' G9 B( }' Z; J. }
X106.035 Y-110.357
+ }7 _& p- Q( q1 V. t6 h5 Q X102.905 Y-111.66+ Z! `  v. f1 |1 s7 v% L
X97.745 Y-114.354+ ^( B+ L) ?; L0 Q% L
X93.377 Y-117.391
$ U% v& w& h) r4 W G02 X54.975 Y-139.563 I-93.377 J117.391
* m% {8 O& c8 C& D' |* @1 o  B  E G01 X50.161 Y-141.827
/ J0 a: x& Q  V4 B7 [2 A1 g X45.248 Y-144.9494 N. x% |. Q/ k- L2 M
X42.555 Y-147.007) b' c# {$ R6 o! U, [
X39.988 Y-149.236
8 r, o* Q# E3 z5 R' K' Y1 ?( D" j2 T X37.451 Y-151.3366 w; }3 w8 s9 ^- W1 m; x5 Q
X34.738 Y-153.16( K; V" M: v  Q& F, p' f* k6 e
X32.042 Y-154.616
: a$ b/ ?5 l; [( B2 r$ ~ X29.219 Y-155.804$ ]6 P1 U7 A: @5 u( J
X26.407 Y-156.665
5 O/ }$ L7 l( A. q) W1 r# B X23.502 Y-157.254
  W! T+ d5 n. n+ j G02 X-23.502 I-23.502 J157.254
+ t: ?* ?3 `$ A! O8 K, _ G01 X-26.407 Y-156.665
0 c7 f! \+ V* w) O% z X-29.219 Y-155.804
$ Z" y8 L; Y& P/ G( e X-32.042 Y-154.616! r$ [, u, W  I" @
X-34.738 Y-153.16
4 d6 r+ z" [0 n4 }, z X-37.451 Y-151.336
0 l1 v+ A. Q2 N% }& I; i, D X-39.988 Y-149.236% {: H/ H/ x6 g9 z8 O5 V
X-42.555 Y-147.0073 z2 q7 D) |& n9 \% ?/ S$ l+ D# d! }
X-45.248 Y-144.949$ J& g5 ^! R' T+ A- K) Q3 x
X-50.161 Y-141.8276 d) S; A+ b! B: a2 x' _
X-54.975 Y-139.563, p9 M7 X- N2 W3 }  q" f
G02 X-93.377 Y-117.391 I54.975 J139.5638 U: {& w" ?/ w* h- D% m
G01 X-97.745 Y-114.3547 l7 [; j( y0 }9 W3 O( t: s' i
X-102.905 Y-111.66$ R& D7 l  I, E" b* X
X-106.035 Y-110.357# [' |# q; F* `4 W+ P4 A. C. g
X-109.248 Y-109.248
& d4 Z0 m0 N  l9 C X-112.336 Y-108.101
6 \, R+ U% r1 B" ? X-115.271 Y-106.664
+ H# m& g# V* z X-117.881 Y-105.057
& }! B! j: G" p; t3 d3 B X-120.32 Y-103.206# h' s$ n5 J+ Y( P5 O
X-122.473 Y-101.202) R) K9 V$ I! A2 s# X8 R0 B5 I
X-124.435 Y-98.987 u- ^7 c# t) l
G02 X-147.936 Y-58.274 I124.435 J98.98
; k. e& |7 Q" d* s' Y9 V G01 X-148.88 Y-55.463! S1 s2 f2 {3 r0 s0 C& P. p4 X
X-149.539 Y-52.597
& F+ q+ X( o. \7 T% H X-149.922 Y-49.559
3 u' E1 A5 E& [2 G* t' ] X-150.009 Y-46.496
; i! n+ r2 l  w1 l X-149.786 Y-43.235
2 A# `) _' h3 J* Z: w  ?# D X-149.236 Y-39.988
3 K) H% V8 i! K3 Y" s: n X-148.59 Y-36.651 q- b5 d/ }" U4 \1 v& V9 I
X-148.153 Y-33.288
- x) z, c( Y2 }1 {, L X-147.906 Y-27.473
; ~' z$ ?( {0 G7 l: x! Y X-148.352 Y-22.171: ~: ~. h% U9 D/ G+ A
G02 Y22.171 I148.352 J22.171
2 f% h8 h2 r  u9 U1 f! N7 C G01 X-147.906 Y27.473% E9 k8 Q# p: M
X-148.153 Y33.288- l, l- F. z; q, y9 T5 z3 `) e
X-148.59 Y36.655 D; I+ Z9 g1 n" l- y
X-149.236 Y39.988
. `! h  a8 ^: o! m6 H X-149.786 Y43.235/ Q2 s9 l# o4 i8 p
X-150.009 Y46.496, O6 l+ Y0 |4 T- r) q0 u
X-149.922 Y49.559, C( G7 _& [* y* Z, Y( g' k& p
X-149.539 Y52.597
  D8 t) S# `0 G6 U X-148.88 Y55.463
: Y% }9 I8 M8 G0 W/ Q& m4 E X-147.936 Y58.274
- O9 g+ j( U# x; P) e G02 X-124.435 Y98.98 I147.936 J-58.274* o1 {: p0 e% t: \: l: E$ t
G01 X-122.473 Y101.2026 C1 y* P9 r( ~3 X( o1 Q. R: H
X-120.32 Y103.206
8 I/ A& v, j$ }9 G! Y X-117.881 Y105.057
" {* p0 c- T% k& t" n X-115.271 Y106.664
+ H% G" S7 @3 q0 Y X-112.336 Y108.101
3 P' P/ v% _  R9 L5 {% y X-109.248 Y109.248- |# E" u+ f! J: I' l- U, j# j
X-106.035 Y110.357
$ R* H3 W- g" m# y X-102.905 Y111.662 S0 D/ U$ _  R. @) P
X-97.745 Y114.354" a- _" [0 A  b/ z: G$ N2 W: N5 \$ W
X-93.377 Y117.391
+ X) V) C; V, O7 v" _% A8 W G02 X-54.975 Y139.563 I93.377 J-117.391" T) I, r4 d  B
G01 X-50.161 Y141.827
3 a6 i0 G  a( Y. _' }0 Y+ c" N X-45.248 Y144.949
5 ]" M- J0 w2 b5 ?. ~, h. _2 E$ ? X-42.555 Y147.007
) Q# I1 `8 T6 ]) [* @  b; Q. _ X-39.988 Y149.236  g( R- v5 a% U1 x- X' o
X-37.451 Y151.336
! b; f6 U1 s8 |. t! P7 A6 b X-34.738 Y153.16
4 r/ ^4 W7 U4 b* y5 q" X X-32.042 Y154.6164 p' \' F( T* |6 v
X-29.219 Y155.804( ^0 |, e, J- w# d
X-26.407 Y156.665
- ~1 i! R) A2 p2 k2 `7 i X-23.502 Y157.254
+ |, [8 E% r  z& u. K- i' l G02 X23.502 I23.502 J-157.2546 X) S( q, z5 I* O
G01 X26.407 Y156.665
9 A1 t* c+ L, Y3 f) T! a* G- m X29.219 Y155.8048 Z' b. q3 Y$ q4 e" }4 Z. {* n
X32.042 Y154.616
0 g1 B0 U6 D5 T. D' G: l& s, ] X34.738 Y153.166 z2 M4 ?5 f$ T2 h
X37.451 Y151.336
; d& W$ j0 i3 |/ G: |: K, e X39.988 Y149.236+ L- o  Q! }0 g% X+ d7 Z
X42.555 Y147.0074 d4 ]# k: ]7 ?/ H  d( Q
X45.248 Y144.9498 q. l: `) g6 i4 b" }+ }* m! w
X50.161 Y141.827
9 u/ M; ]$ d  B: G7 Q2 @ X54.975 Y139.5636 F0 @2 |$ U* C( O& Q( ?3 L
G02 X93.377 Y117.391 I-54.975 J-139.563$ t! g, z' U; [1 [& [3 P$ }' b
G01 X97.745 Y114.3541 x& \$ `8 y- w% k" ?  d# i
X102.905 Y111.66
2 d* E" x: a* ]3 |0 P X106.035 Y110.357
& A+ K5 M3 a! c( @9 w3 l2 ~ X109.248 Y109.248
4 ~! f3 l& a% S# G1 h. b# j X112.336 Y108.101( Y" P4 C8 o$ I4 S
X115.271 Y106.664
, Q0 I9 c* d- I. x9 H8 p6 l# G X117.881 Y105.057
9 [" ~% V8 X2 t5 N7 o* j6 H- w; B6 A X120.32 Y103.206
7 x: k/ \$ x" u- ?! m X122.473 Y101.2026 G# X( R8 d* h* n, ^  D
X124.435 Y98.98
( p! g5 B: l; f, C9 C/ m# K/ C G02 X147.936 Y58.274 I-124.435 J-98.98
# U1 o, e3 n% x( t4 n: y: w G01 X148.88 Y55.463. B* K% V# m8 g3 q. F
X149.539 Y52.597
1 a+ b$ U- p( J9 W0 S X149.922 Y49.559
0 V6 u2 L' _7 r+ @+ M" n X150.009 Y46.4968 @1 T# f. B* f) T
X149.786 Y43.2352 S! e8 [5 ~& L7 E7 P; P: y
X149.236 Y39.988
  d* w% b, \7 E: a2 h+ g1 v X148.59 Y36.65, ^9 V; q3 n& B6 ?
X148.153 Y33.288) I9 O  `* [) A- Y, M& L
X147.906 Y27.473( r! y1 u% X0 i) ^: H2 V6 C
X148.352 Y22.171
# B3 r. u( J, q0 z G02 X150. Y0.0 I-148.352 J-22.171
5 Q; v& N; }) m) f, j8 u X132. Y-18. I-18.
0 I# g/ e8 F. { G01 G40 X131.1
* I' U2 p* F$ l9 K8 D" v( @2 m& | G00 Z150.; ]) J1 ~$ _1 C. P7 |
M30
# q, q% i# r& ?4 R3 p$ R %
 楼主| 发表于 2007-11-3 13:30 | 显示全部楼层
李版主.你看看了,就是这个样子程序,如何在UG5.0的后处理中才可做到 !!!
 楼主| 发表于 2007-11-3 13:38 | 显示全部楼层
程序的开头和结尾无所谓 ,我需要的是中间部分@上面的程序是用CIMATRON7.1做的~
发表于 2007-11-3 16:17 | 显示全部楼层
你什么系统啊.到本版的置顶帖里面下载后处理看看.
 楼主| 发表于 2007-11-3 16:24 | 显示全部楼层
机床是SIEMENS 84OD 的 /% u1 L. P9 Y  F# ^: y/ ^8 M8 N
不过和系统没有什么关系!
 楼主| 发表于 2007-11-3 16:27 | 显示全部楼层
想请教李版主:知道具体修改后处理的哪些参数吗 ??/ g- ^% z) |; a+ r
我这个程序和加工中心的不一样的 @
 楼主| 发表于 2007-11-3 16:50 | 显示全部楼层
哪位后处理的高手可以告知小弟要做出以上的程序具体要修改.TCL文件中的哪些参数,非常感谢,在这里向大家学习了@@
4 c* p& s& j4 X我选择的加工方法是PLANE PROFILE ,有更好的加工方式也青告知,在这里多谢了~~
GMT+8, 2025-6-19 07:33 , Processed in 0.486660 second(s), 24 queries .
