我在2.0里面的宏命令,在3.0或更高的版本后没法使用,怎么解决啊?
: F( w) _" [' X9 I- k ^宏命令(举例):
( k6 q) P, Y2 s( EUnigraphics NX 2.0.1.2
) u5 |& j2 h, W5 ^# B. A4 rMacro File: C:\ug_NX2_MACROS\EDIT_OBJECT_PREF\2green.macro+ p m' q% E; G. L' {* n: g& u
Macro Version 7.20
% U# N$ f% ]. ?; c: q+ v) ]Macro List Language and Codeset: english 17
1 D1 ~! g9 b6 I0 pCreated by gabgar on Thu Jan 22 09:25:06 2004
* m: F; `& |1 H) SPart Name Display Style: $FILENAME/ b7 x. z% P4 {5 F% I6 b8 Z
Selection Parameters 1 2 0.216535 13 `( s, V5 v4 h5 Z. g; `+ J4 N
Display Parameters 1.000000 14.852362 10.295276 -1.000000 -0.693174 1.000000 0.693174: M- U, |5 q6 H
*****************( ^4 q& M n( A2 H4 _
RESET; F! M; k- ?7 S% N/ B
MENU, 0, UG_EDIT_OBJECT_DISPLAY UG_GATEWAY_MAIN_MENUBAR !
0 \7 |, U0 q4 `! A' ?1 jDIALOG_BEGIN "Class Selection" 5002, K! n* [; e, t
BEG_ITEM 1 (1 WIDE 5002) = "" ! Name4 `6 Y) S: U9 n( o2 X: L: L
BEG_ITEM 5 (1 BLO 5002) = -1 ! ; V' T9 a8 Q5 ]0 z" u' `
BEG_ITEM 7 (1 CTOL 5002) = 1 ! ! D$ I R& p! \. W/ q. R
BEG_ITEM 10 (1 OPTM 5002) = 3 ! Inside/Crossing
4 F; ]/ C; t/ ?* B0 k BEG_ITEM 12 (1 BLO 5002) = -1 ! : a# N" J m! O+ J+ c
BEG_ITEM 13 (1 BLO 5002) = -1 !
% m4 q7 `$ G4 Z5 m# iFOCUS CHANGE IN 1/ ^1 P' ?" P# t4 D5 ^) z" F2 z. p
MENU, 0, UG_MACRO_USER_ENTRY UG_GATEWAY_MAIN_MENUBAR !
1 ?% w$ U% i8 t" o6 r5 ^# c USER_ENTRY_PROMPT -2 0$ A6 ^% F. E4 o$ f0 P ^" u
USE_ITEM 1 (1 WIDE 5002) = "" ! Name
% U. w. _" \8 K" v6 @ USE_ITEM 5 (1 BLO 5002) = -1 ! - i$ s( I" I1 H2 _) k, {/ S
USE_ITEM 7 (1 CTOL 5002) = 1 ! : c' R1 U) G( ], \' T2 a1 G
USE_ITEM 10 (1 OPTM 5002) = 3 ! Inside/Crossing7 z) o! a- f' R+ m; O1 @2 K( c+ W
USE_ITEM 12 (1 BLO 5002) = -1 ! & t5 f" `6 Q. n b5 E2 B
USE_ITEM 13 (1 BLO 5002) = -1 ! 5 _ x% W) M# @8 Y8 W
USER_ENTRY_BEGIN. C4 W: `+ G* q: G$ ?- {1 r/ ?* W! x
CURSOR_EVENT 1001 3,1,100 ! single_pt, mb1/0+0, U_Sel_sngl (T+:0+0)) U5 H5 A2 @/ z+ ?) N
CPOS -11.9852709086845,-2.11035858648157,8.8324541114055
3 o( D- r x7 o& v* A X! @ OK 0 5002 ! OK Callback; Y" i) U$ `( w; S" P
ASK_ITEM 1 (1 WIDE 5002) = "" ! Name
+ ]2 F% `8 p, R6 i END_ITEM 1 (1 WIDE 5002) = "" ! Name3 G0 m# [% q7 Z; h7 y
END_ITEM 5 (1 BLO 5002) = -1 ! $ c' O& L% c. Z2 D2 q& g
END_ITEM 7 (1 CTOL 5002) = 1 ! " I) \# r+ t( G9 h- Z" _
END_ITEM 10 (1 OPTM 5002) = 3 ! Inside/Crossing
8 \. e% Q8 A. { J( n END_ITEM 12 (1 BLO 5002) = -1 !
' ^7 C! L' @/ z+ [$ [ END_ITEM 13 (1 BLO 5002) = -1 !
+ |! R5 O9 u" d/ L; a, h* E" UDIALOG_END -2, 0 ! Class Selection: OK$ \7 o4 k) J6 o5 G" y( v
USER_ENTRY_END
7 i1 p& Y7 D# a! z% }DIALOG_BEGIN "Edit Object Display" 0
+ V" P- d" m1 }2 l! _8 A BEG_ITEM 0 (1 INTE 0) = 2 ! Layer
' n9 X' i+ B: u$ D- k# T BEG_ITEM 2 (1 CTOL 0) = 2 ! 3 d/ `: f, a n5 h" S+ ~
BEG_ITEM 3 (1 OPTM 0) = 1 ! Solid
& |- E6 y( w7 y) Q+ G2 e9 R+ A BEG_ITEM 4 (1 OPTM 0) = 2 ! Normal Width% H1 i$ l' h1 {5 g9 _( h( s
BEG_ITEM 6 (1 BOOL 0) = 1 ! Apply to all faces
, i+ A% q* b. \4 o BEG_ITEM 7 (1 INTE 0) = 0 ! Grid Count - U
% x7 F0 a1 j' N0 T1 u; T7 `& e BEG_ITEM 8 (1 INTE 0) = 0 ! Grid Count - V
. a. o! }+ W2 j9 v$ t3 z3 \% i BEG_ITEM 10 (1 SCAL 0) = 0.0000000000000000 ! 3 s* b: m! J i- l" `8 A" V' H
BEG_ITEM 11 (1 OPTM 0) = 2 ! No
- k! c1 t: E& ] BEG_ITEM 12 (1 OPTM 0) = 2 ! No
7 q4 T' A6 o5 D9 E- FFOCUS CHANGE IN 1; U D/ ^$ Z; z$ F( f' a
END_ITEM 0 (1 INTE 0) = 35 ! Layer
$ K0 A. z+ V& S1 s( U, Y END_ITEM 2 (1 CTOL 0) = 11 ! ) Y7 z* i! `& j) g
END_ITEM 3 (1 OPTM 0) = 1 ! Solid" L9 \. b# I2 l- x; X# `9 O9 q
END_ITEM 4 (1 OPTM 0) = 2 ! Normal Width
$ ?. Y- ~4 c- v; F, M END_ITEM 6 (1 BOOL 0) = 1 ! Apply to all faces# k/ \. [2 C1 K4 o9 V- y
END_ITEM 7 (1 INTE 0) = 0 ! Grid Count - U( k2 ~5 a- k+ v7 D- o" o
END_ITEM 8 (1 INTE 0) = 0 ! Grid Count - V
( d: j& z) G3 ~1 w9 @8 c END_ITEM 10 (1 SCAL 0) = 0.0000000000000000 !
6 m) i! R3 G) z6 \+ F END_ITEM 11 (1 OPTM 0) = 2 ! No6 h* R k* c% |8 e7 v
END_ITEM 12 (1 OPTM 0) = 2 ! No; I& S" M. g; n. m1 }
DIALOG_END -2, 0 ! Edit Object Display: OK2 j0 l) v8 {/ Z* O
FOCUS CHANGE IN 1 |
