查看: 5973|回复: 27
UG刀具补偿
发表于 2012-12-15 08:14 | 显示全部楼层 |阅读模式
小弟用ug6.0编程的,做大孔和外形时用刀补机床不报警,但是一做小孔就发生补偿干涉,试过好多次都不行。例:6H7的孔用5MM刀来加工。程式如下:%
. F8 U% s6 R( d* iG40 G17 G49 G54 G801 V. c+ K+ n; m' F4 A, m; ~
G91 G28 Z0.0$ G9 ?! f' Y& s4 P& Y# N( j. |
( NAME: Administrator )
# F) \5 C( g. N) N, `& O/ K( PART: E:\UGlx\model5.prt )* r& H. ~' p: X. ^) B$ `# ^
( DATE: Sat Dec 15 08:17:35 2012 )
# \- S8 h% \0 ?% r( D5 ---> D=5.00 R=0.00 )
' y8 _/ w- x* {  U2 {1 [/ LT01 M06
. [; e8 m5 x# r3 Q# }7 NS5000 M03. q2 q4 X6 S/ X% O$ l
G00 G90 X.016 Y.165 M08
9 B# n3 c- W' _3 ZG43 Z10. H017 q9 b1 g. P/ Y, k; Z& H# T
Z0.0
! w% R4 Q/ S: o+ EG01 Z-1. F250.% w7 p5 k' u$ s8 L' l
G41 G17 X-.181 Y.2 D01
, @* u, {+ m9 J7 ]+ m% `X-.279 r5 q3 c9 g/ x
G03 X-.47 Y0.0 I0.0 J-.2
. z/ Z( H+ {: ]- q$ x3 GX0.0 Y-.47 I.47 J0.0: z* j1 i3 O& h! Z% W1 }; E
X.47 Y0.0 I0.0 J.47) f7 m! ^$ {  r8 K1 k6 k  C9 v
X0.0 Y.47 I-.47 J0.0( l! d0 `3 Y; e
X-.47 Y0.0 I0.0 J-.47" H* j4 Q7 d" T- W0 K; Y5 m; C$ Z
X-.228 Y-.411 I.47 J0.04 _9 f. k7 ?4 @/ o
X-.131 Y-.436 I.097 J.175) D& R' h& u# w6 r3 o; ~; U" I' I* w
X.044 Y-.333 I0.0 J.2! F# S4 O3 c' g% C/ J. Y) V3 j
G40! A1 v, a' Q' E0 u4 B
G01 X.109 Y-.144; ^8 m7 r4 v% o+ N
X-.103 Y.165
# e3 O  \6 o8 T) j) QG41 X-.3 Y.2
& T/ A$ K5 U  o7 k! D8 eG03 X-.5 Y0.0 I0.0 J-.2
# e+ P4 b8 M% M7 O( C4 @: _7 lX0.0 Y-.5 I.5 J0.0
3 A) {* h2 z' pX.5 Y0.0 I0.0 J.5. m/ v; M* c& ]9 s1 D
X0.0 Y.5 I-.5 J0.0
3 a  s9 [- }2 Q. v. fX-.5 Y0.0 I0.0 J-.5
4 q9 i: Z- i$ s! K" q+ @8 H: dX-.27 Y-.421 I.5 J0.0
) v0 u6 j8 R- M: d$ TX-.162 Y-.452 I.108 J.169
( F7 Z0 R+ \! \" Y! \X.006 Y-.361 I0.0 J.2) @' D3 q) I  t* B$ a7 R& b2 Z4 E* _
G01 X.07 Y-.261/ y  p4 Z* h, {% W$ T
G408 e& C1 V4 q0 d2 O% t& ?2 G
X.147 Y-.076) p! E1 Y3 V: C0 h/ P
Z0.03 Q2 Z: w! ~1 p' R* L% o
G00 Z10.. G, N2 y' B* X( M2 m: c
M09
1 [. d* Z# T5 Q, _4 e8 u7 _M05
; q2 j/ R, C/ JG91 G28 Z0.0' H1 {, S8 ~# U. N  _
G28 Y0.0
/ M0 z* U  U- GM303 |9 B, V8 }4 r4 L: |
%* M; y! ?. d! |5 ?. T, C
( TOTAL Machine Time: 0.2 MIN ) 11.jpg
点评
肯定可以,在孔中心下刀,采用点+半径形式进退刀,半径足够小,2%刀具直径,角度2度以下  发表于 2012-12-16 08:08
发表于 2012-12-15 15:19 | 显示全部楼层
你有学过数控编程吗,所有的机床在执行刀具半径时,如果移动距离小于刀具半径进会报警过切,6mm的孔用5mm的刀加工你也是高手!
点评
同意三楼观点  发表于 2013-4-5 12:06
回复 支持 1 反对 0
发表于 2012-12-15 08:35 | 显示全部楼层
机床上的刀补设多大。。。。
; T* @) V: Q( I: l: a1 @" {: g7 W& y; s) N
建立刀补的距离要大于机床上的D* g+ n3 o) ^( M6 N, o
* ]! W/ K. E) J/ S# D$ f3 ]; ]% p. I" K, u( H, U5 z# @. ~) W
6的孔,5的刀加工。。。很容易发送建立刀补错误的。。。. I, L* o# c. x$ U* ]0 N5 p
( U, r* v. p: |3 e% L" M2 G5 c- C
既然是带公差的孔么,小点的钻头下去,拿来镗啊。。。
; V, e2 `+ z. z( a
发表于 2012-12-15 16:27 | 显示全部楼层
也就是传说 发表于 2012-12-15 15:19 ( R5 ^' \5 j- r( U- K9 Y
你有学过数控编程吗,所有的机床在执行刀具半径时,如果移动距离小于刀具半径进会报警过切,6mm的孔用5mm的 ...
2 ]6 ^5 r) R4 y, n: o" R你脑子也太死,编程的时候已经把刀补算进去了的话刀补值是0,之所以0还要刀补用于批量调节尺寸什么的。这样刀补的移动值一般也就0.0几,主要还是他的进刀参数设的不好
发表于 2012-12-15 19:15 | 显示全部楼层
duanzhimeng 发表于 2012-12-15 16:27 # l; V3 S" Y' O4 k5 U+ P
你脑子也太死,编程的时候已经把刀补算进去了的话刀补值是0,之所以0还要刀补用于批量调节尺寸什么的。这 ...
& c4 D" ~2 h# T8 h; P& i. o1 ~1 I
你也是一高手!
发表于 2012-12-15 22:17 | 显示全部楼层
路过。。。。。。。。。。。。。。。。。。。。。。
 楼主| 发表于 2012-12-16 22:20 | 显示全部楼层
2 O; s0 f; B3 ^5 U7 V8 c, f) o- G你有学过数控编程吗,所有的机床在执行刀具半径时,如果移动距离小于刀具半径进会报警过切,6mm的孔用5mm的 ...
$ C5 W" b% M$ m) Y$ ]) N) I
MasterCAM9.1可以这样子用啊,关键是进退刀那里设置搞不好
 楼主| 发表于 2012-12-16 22:22 | 显示全部楼层
* ^: a' h2 ~' t9 n: f你有学过数控编程吗,所有的机床在执行刀具半径时,如果移动距离小于刀具半径进会报警过切,6mm的孔用5mm的 ...
2 b4 J/ y8 x3 ]) z; R$ F- ]3 mMasterCAM9.1可以这样子用啊
 楼主| 发表于 2012-12-16 22:24 | 显示全部楼层
乱来 发表于 2012-12-15 08:35
, d5 b( y2 C8 a% X机床上的刀补设多大。。。。
$ d$ p7 H9 n8 q  ]2 H+ Q; ?+ Y
! x$ R& g( a; n0 h$ f* D1 t5 L建立刀补的距离要大于机床上的D
; N7 f8 f' w( u- T, N, t
做产品的,精密尺寸多,镗孔很慢啊
发表于 2012-12-16 22:45 | 显示全部楼层
liangyongtang 发表于 2012-12-16 22:24
' t' m4 E% ~+ k' x; ]  E做产品的,精密尺寸多,镗孔很慢啊
- X$ j+ {9 R' ^5 `7 }
哥哥。。。精度高的才是镗孔啊。。。
$ A' c8 M5 M: X  N3 n+ K" y( P& s- z7 e) N
铣刀哪有镗刀的精度啦。。。0 _' C' h! O% C
! I  i0 I' E# x  D
: s7 Q! S, a3 O- N/ e& J
而起你那个还是h6的公差。。。。
+ U- k; B! S. e" H5 v' A! r
% P/ v0 J# _  M" x7 H! L当然如果你一定要用铣刀。。。那还是换把小点的刀吧。。。。6的孔5的刀做,而且还要带刀补,真的不合理
GMT+8, 2025-6-7 22:51 , Processed in 0.066722 second(s), 24 queries .
