板金属回弹仿真与模面补偿方法
 楼主| 发表于 2013-1-12 10:08 | 显示全部楼层
高强钢板沿与轧制方向上成90度方向下料时,冲头圆心与板材
) U) x+ W% }! p- q5 _6 I3 B两最远临界接触点的夹角大小比拟
 楼主| 发表于 2013-1-12 10:09 | 显示全部楼层
本帖最后由 青华模具培训 于 2013-1-12 10:10 编辑 4 Z8 t# P& y% O: F2 g# P# p# o) Q
0 d- U6 w1 H& A  ?5 u
结果与讨论9 A5 ?3 K* K: e* E2 ~
1.  一汽集团大卡车纵梁
 楼主| 发表于 2013-1-12 10:11 | 显示全部楼层
2.  卫星天线模具外表回弹补偿
" w- a! @* r; F# y结果与讨论
 楼主| 发表于 2013-1-12 10:12 | 显示全部楼层
Results and discussions (continued)
6 E- h  h* M% E) u; O: X9 _" \; ?6 l7 o& c6 `5 C. l( L
工具补偿算法得到的回弹后的⊿z 坐标 (最大误差1.13mm)
 楼主| 发表于 2013-1-12 10:13 | 显示全部楼层
Results and discussions (continued)9 H, T# v7 i' {- X5 ?/ `
+ Z1 f+ j: {6 u4 C5 CComparison Between Designed and Compensated Tool Surface, which ! N3 x# ~0 |8 c! ~
means z-coordinate difference between the two surface shapes on the section A-B
( `5 {- P1 K2 Qbefore and after compensated
结论
* n. J+ T) m% E( n( v2 V; T9 @! d„ A combination scheme of the Dynamic Explicit Spring-
# O# O5 z) e6 m. h& J! ?3 ~back Algorithm (DESA) and the Tool Surface
8 K5 N  y/ C0 cCompensation Method (TSCM) are proposed. The
7 o" G7 e; |( I$ s% X/ Xformula of the critical  damping coefficient for  DESA is
- ]8 B5 x* H; B' }. yprovided. The springback results of the  truck  carling
# ?9 n% p% p+ m( v$ y4 J; @0 Bshows that the present method is valid, the effect of the 8 Y5 f4 T& s, z1 D2 a
springback compensation is verified by the tool surface
, F! s+ J  T" d7 z) r. Fcompensation scheme.
GMT+8, 2025-10-11 17:45 , Processed in 0.052811 second(s), 19 queries .
