查看: 861|回复: 1
[原创] UG倒出2D圆变样条解决方案
发表于 2016-5-12 23:00 | 显示全部楼层 |阅读模式
* D4 c: ]  s0 f9 N( v$ J+ W! y& D- E7 G* P" T; H
ug三维中的圆,在制图投影导出到CAD中总是变成了样条线,每次标直径尺寸都要用三点描圆,很是麻烦,我做了个小程序,分享给大家,可以在CAD中把样条变成圆,比三点描圆快多了,且可以一次多选! 样条成圆.rar (768 Bytes, 下载次数: 6, 售价: 1 G币)
" I! l8 A0 I* _: _9 U
" f2 n1 g* s' ?) r7 E0 I; yAUTO CAD加载解压后的LISP程序,CAD命令行输入:YY启动命令!- _9 Q' ?& L, m- C4 A! K$ C
程序如下:
0 `' L- E* m0 d0 s" ]7 |
0 F+ ~0 c  e  v( i(defun c:yy (/     ss    object oname  fitplt spt1 spt2 spt3* |( x) g0 ~. J7 u+ C! X, i  g0 V
      spen   object2   clo  i dd     linw   lint# J* c) t6 [( P! w0 K; n4 ]
      lay    a    b   fixpoint jj     colo
9 U* g$ u% i4 C7 s     )+ C6 }- E+ s# x) W7 I2 E
  (vl-load-com)
. n5 T; R( F/ I& b  (setq ss (ssget '((0 . "SPLINE"))))
, K8 f; `1 m' S/ d$ a  (repeat (setq i (sslength ss))& s7 I* z" h: V+ ]
    (setq object (vlax-ename->vla-object (ssname ss (setq i (1- i)))))* `- T' E" q0 B& j
    (setq clo (vla-get-closed object))
" c2 V+ }: e1 `    (setq colo (vla-get-color object))
! ?2 R3 N* v# ^) _. }    (setq lay (vla-get-layer object))
9 O$ d& P- {3 s2 Q1 }, G- |3 k    (setq lint (vla-get-linetype object))
6 l( k' n$ g9 f    (setq linw (vla-get-lineweight object)), `! D( S  [. p7 ?
    (if (= (vla-get-splinemethod object) 1)
" R1 J; G; M- H7 X      (vla-put-splinemethod object 0); H8 M. m" J0 r2 X/ e" X7 J
    )/ v) n6 [1 f% ~
    (setq fixpoint (vla-get-numberoffitpoints object))
! w+ q9 g2 Q- d, p# h' [    (setq fitplt (vlax-safearray->list
  H% Z. o3 E) g) n  S     (vlax-variant-value (vla-get-fitpoints object))
/ h2 n) i: S/ k9 {( h5 }" g+ s  `$ Z/ ~   )
) ~' X# \3 h5 [  j# f/ a    )
5 _* a  u6 G3 J& [# B6 e$ _8 _& o    (repeat fixpoint
" F, ?' B, b( n9 s$ s1 _      (setq b nil)! |6 u% h5 i; B+ }, v
      (repeat 3
6 f; G# Z3 ]$ {" L (setq b      (append b (list (car fitplt)))( S2 C, ^( h: J. J( d$ L
       fitplt (cdr fitplt)
" p& P- N, k/ G# d$ p% U! R )' w4 c  f. F: }  j; b
      )" V' }' @) r( ^0 ?2 b5 e
      (setq a (append a (list b)))+ f6 v# n# J2 _) Q6 `2 i+ Y& a( C# f$ R
    )1 f$ \. ~) {1 {' W0 H5 M, Z
    (cond ((= clo :vlax-true)
" E2 g1 N% }* i, P    (progn
' a2 \  x+ t4 D+ u      (setq jj (fix (+ (/ fixpoint 3) 0.5)))  z' x8 z- K6 A. d( H
      (setq spt1 (3dpoint->2dpoint(car a)))& k, I: y$ D% \( o
      (setq spt2 (3dpoint->2dpoint(nth jj a)))
( [/ ?; x0 S1 M$ s3 _( o      (setq spt3 (3dpoint->2dpoint(nth (* jj 2) a)))" C7 f; d+ g) S* {/ F
      (vl-cmdf "circle" "3p" spt1 spt2 spt3)
, x2 }; ^* L/ L; I, Y& b6 `    ): `% }( v. e. W) a2 s7 R) I
0 m( I. b" b) g' l. p4 b1 a   ((= clo :vlax-false)
: B% D, t8 e8 N& R! q    (progn
+ h: x* ]; @' W( ?5 m9 a      (setq dd (fix (+ (/ fixpoint 2) 0.5)))
* g/ F+ ^6 O& E: q7 k7 L      (setq spt1 (3dpoint->2dpoint(car a)))
/ Y/ ?$ q; I% d  A! ^      (setq spt2 (3dpoint->2dpoint(nth dd a)))4 s+ B# `! k+ ^
      (setq spt3 (3dpoint->2dpoint(nth (- fixpoint 1) a)))
% q" |3 H4 V! \  i$ q) {      (vl-cmdf "arc" spt1 spt2 spt3)
" _$ b$ D9 \5 d7 H; }7 [    )
+ D0 N* l, i+ p* F* z   )1 j" o/ O4 X! ^: D
- x- ]! w: G3 |2 X; i$ B    (setq a nil)
$ G5 m. N  @5 u6 z+ D! }5 |3 h    (setq fitplt nil)
! S$ W- R% S9 {    (setq fixpoint nil)2 y1 ]* m/ i) v) c0 E4 z
    (setq b nil)3 c! g! T& E6 a
    (setq spen (entlast))
- z2 f& N; p, _! D% ^# @+ O    (setq object2 (vlax-ename->vla-object spen))
0 G2 d+ h& _+ t" R/ R    (vla-put-layer object2 lay)8 u1 F6 n- i: g) c8 E+ Q
    (vla-put-linetype object2 lint)
8 X0 o: b* e* u( z    (vla-put-lineweight object2 linw)
1 d& A6 f' A' q- p' A* [# U    (vla-put-color object2 colo)
, D6 a! B4 K4 e* ^    (vla-delete object): W1 y7 t1 W' {
7 v2 g, _  d" \) N& m2 e7 w* |)
% a* l3 U+ t) R2 T3 V(defun 3dpoint->2dpoint (3dpt)6 p+ @' t% X. R# E3 W% V0 n
  (if (apply 'and (mapcar 'numberp 3dpt))
9 y5 J4 P( g' v/ z+ l: m- U. K    (mapcar '+ 3dpt '(0.00 0.00))1 I# p- D. Q! T' Q, \
  )5 W7 F3 j# d8 N4 ^
)/ o- P! ]& u- G& X" Z
* E- \! P) Q* {/ j5 X
发表于 2016-5-13 07:56 | 显示全部楼层
yyyyyyyy     ok
GMT+8, 2025-7-29 15:43 , Processed in 0.214863 second(s), 24 queries .
