各位大家好:
3 F9 `0 }% m0 ]4 x; W2 s" F下列问题与大家探讨,希望大家给我意见,谢谢!
" b0 Q+ m8 l& r- x0 w' q+ m( i, S' w7 c% \# u- q
1.描述:两个U型槽,一个开口大,一个开口小,正好对着焊接,有两对相接的触面,在接触外进行焊接,中间形成中空形状。我用一维单元进行边到面的连接,出现如下情况,计算不了。请教各位了。(我按照SugGESTION去修改,却找不到要修改的地方)
4 T, c2 q/ O. f) D2 o具体在附件图中.
/ F4 H7 y( y2 ?5 S7 VWARNING
7 G! ?0 s5 g5 z8 P/ CPotential problems with the rigid links may exist in the model:" A5 k5 x% M8 _ ?8 h3 Z& C: j$ w; k3 t
- Rigid Links are connected to elements which do not have rotational degrees of
' Z$ Z. }4 d7 e" ^, L: o freedom (DOF). This may result in solver errors.
/ A4 ^* x) [; S! }+ f+ j - Rigid Links connected to other rigid links. (Watch for rigid loops.)0 F2 m1 D2 K2 H6 q, n0 C: u) X
- Rigid Links not connected to other elements.
5 X( a: f8 a8 U% Y3 g+ qIf solver fails, check for inconsistent degrees of freedom.
' w5 G+ F" n! c+ n! nERROR
. e, ?- }. c0 z3 q$ {7 A" N! XDOF 1 of node 4262 is set as dependent by mesh "connection_recipe_1_spider" and mesh
* a) B( S1 f, i; b( r* ^, A) _"connection_recipe_1_mesh".
" w) { M8 H. G9 i( h" j) oSUGGESTION: Set parameter "AUTOMPC" to "YES" in the "Solution Attributes..." dialog.
' j9 s O6 N8 R) ?% _; c7 vTotal: 1 error and 1 warning9 S% U! M1 @$ [* `
2.我的目的是想用上述模型进行焊接模拟,两对接触面用“Surface-to-Surface Guling”和两对接触面用“Mesh Mating Condition”进行建模。仿真结果相差很小。请问用这种方法模拟焊接,对吗?有没有其它方法模拟两块板料的焊接问题?(肯定有,请大家赐教赐教?)* ]9 U% A" I; j/ i
3.我在模型上施加力,在线上施加力和在面上施加力,结果还是有一些差别的,请教是否两种方法都可以用?(在线上施加力和在面上施加力,其力的大小是一样的,在面上其实等于施加了压强) |
