查看: 3704|回复: 11
[疑难] 指教一下,在UG后处理中为什么只在的一段能加G41D2,后面的要处理出来没有D值
发表于 2009-5-14 11:37 | 显示全部楼层 |阅读模式
指教一下,在ug后处理中为什么只在的一段能加G41D2,后面的要处理出来没有D值============================================================
' R; V. P/ D: q$ [. BInformation listing created by :  luozhiwen, R3 P5 K: l. r" o$ D) {
Date                           :  2009-05-14 11:48:54. \7 m% Z' {1 R+ }7 r
Current work part              :  D:\luozhiwen\120171560_SS.046493G.prt' ~; L; d* k/ k, w6 D0 z
Node name                      :  luozhiwe-10fe740 D% w; G8 O5 g/ n
============================================================( v: X+ Y9 L+ Q/ w7 J2 |) U
8 z- v6 z% U5 S  e0 j0 s120171560_SS.046493G
( F- w* C4 \- S. C! n( 120171560_SS.046493G -A-No.30-C1-DT1580-lzw-luo)
  E7 @, _8 E# Z8 S2 H5 N, z(D:\luozhiwen\120171560_SS.046493G.prt)5 j. o1 b0 w1 e( x, b
(#  D16R0L40  #)
3 J/ q3 q; j$ j6 {; F- }, P(Cutter Diameter: D16.00-R0.00 )
0 }% E2 P( _3 rG21
, c! \6 H6 T, A5 fG40 G49 G80 G69- q& F9 F, f" o% `5 L. a" U
G91 G30 Z0 T02
& S1 M& M3 F; |' R" xM6
8 n0 U9 T' E1 L9 X) ?' E4 r4 pS1600 M3& k1 Z' W" n: n
G90 G17 G0 G544 Q, c, B* l3 X, Q" j7 u
X520.521 Y-31.822" `& D! C7 U- q3 J' t3 O6 c
G43 H02 Z100.
! M# H" L- s5 {, O6 kB0.
, K: X3 Z: p- }1 R( P+ CZ49.993
. ~- c$ v1 j! `3 |Z46.993; K8 K& n5 F) {. h7 m% a
G41 G1 Z43.993 F120. D2
5 e* p. ?1 ]! I! j$ e. R) M( j! b; KX522.4 Y-31.138) c7 }1 l2 \4 C2 U
G3 X525.4 Y-25.942 I-3. J5.196 R6.
2 I' u2 n- n% \5 l1 Z" n+ f1 bG1 Y25.942
1 N; k% i3 M% o+ {4 gG3 X522.4 Y31.138 I-6. J0.
; Z# [( }3 [; c& o- u# j: s% wG40 G1 X520.521 Y31.822
6 t- b$ F; y! [8 K. I3 L7 z6 A* WG0 Z46.993
& `+ f2 ~6 i0 fZ100.
5 R8 h! m/ D* O' O; {X495.479
& f" d: k- r8 o1 [6 y; @# l$ NZ49.993
- F9 m% G5 ?1 E) F4 pZ46.993
0 x; X) H9 C4 D4 e2 RG41 G1 Z43.993
4 B4 |7 l' y# P3 lX493.6 Y31.138
9 t# [5 Y* U& }! y: l. K4 f2 |* CG3 X490.6 Y25.942 I3. J-5.196- o" N. ]& ^0 u
G1 Y22.226- M& P% j' X" W9 j
X42.8* f  G6 ~" H% S1 |$ f3 O
Y25.9420 [( h& X$ a; v: X
G3 X39.8 Y31.138 I-6. J0.& i+ ~& C' Q  ?& k, U
G40 G1 X37.921 Y31.822
" @8 r; |/ u1 @$ ~G0 Z46.993
% n4 G- |1 w. s  j3 B( ^Z100.
8 x' c2 o; O! CX12.879
, x9 b2 d4 s! s# A* H6 iZ49.9934 I+ |' b* T' O" Z
Z46.993
$ h) A# x% M+ k, B) Q2 ~+ q1 Z! Q' aG41 G1 Z43.993! J9 Q& H% i4 y- ^! p, j
X11. Y31.138
: V( i7 u9 ?5 v: [G3 X8. Y25.942 I3. J-5.1960 Z2 z8 b  s# L/ Q8 O4 ]1 w
G1 Y-25.942" F; _! Y/ X2 R9 F# E
G3 X11. Y-31.138 I6. J0.& |3 t, a( E" f5 l0 Q
G40 G1 X12.879 Y-31.822
. w# U* i; E9 n! R) _. o9 T. vG0 Z46.993
% \$ x, p+ c- M6 I) K3 xZ100.
- S3 H/ w9 _3 s0 p5 f7 n! x$ {X37.9216 }4 S( u  F) O2 C" A: l
Z49.993
: o# w: S) f* ~7 CZ46.993: H' ]) i9 K9 Q' b
G41 G1 Z43.993" A4 W( u# k) ^$ p
X39.8 Y-31.138
# @, }7 X" h! FG3 X42.8 Y-25.942 I-3. J5.196
7 Y8 k0 |% b( ]* ~% q* L; m" vG1 Y-22.226
5 H1 K. T# V% @) ]8 R2 e1 fX490.6# }* u! r- a5 ]3 F
Y-25.9422 M* [2 w2 g8 i2 }0 g( g- V
G3 X493.6 Y-31.138 I6. J0.
' F4 \' d- G6 {: c& G9 v* C# g" R( YG40 G1 X495.479 Y-31.822
1 i9 c2 K5 E0 P, u& Y4 iG0 Z100.
% ^  z% y9 ?# h4 [0 D+ FM5+ z* b) ^2 v+ N. w, j9 U
M0
1 d  V8 H$ W1 @* mM3
# V" r, l, {9 U' i4 G% TB180.
1 ~! O7 H0 ?0 f4 X  u( O, {# NG0 X520.521 Y-31.822 Z100.0 h* L4 k, O( u3 |
Z49.993, O5 C, x% q& T1 @+ d! ]5 B: L
Z46.993* A3 T* m; B& g
G41 G1 Z43.993 F120.' @, l9 @& Z4 [+ A
X522.4 Y-31.138
; ~! ~5 k* v9 y  X; i+ L- {+ wG3 X525.4 Y-25.942 I-3. J5.196 R6.
$ S% m: m) a+ i2 s; E' S2 IG1 Y25.942, S' Z$ C) a+ ?9 a' o
# n+ t' u6 L, ^8 E* |G40 G1 X520.521 Y31.822- f  n' ?) C( t- G6 l
G0 Z46.9930 n' C8 o- L- |+ Z7 \
Z100.; `! e! B1 r3 j$ B- |: @
X495.479! T  w# q" w, ]" N$ ]1 H
Z49.993
8 E9 g8 r) T# N  U; wZ46.993
( c/ G3 H; O" p% Z; aG41 G1 Z43.993, V% U8 Y: W0 f! z
X493.6 Y31.138: a$ g+ b# O# e) M9 y
G3 X490.6 Y25.942 I3. J-5.196; M+ z* Z5 R, y0 ^0 h% l3 p
G1 Y22.226
# O% t' O7 X0 y5 NX42.80 ]  O6 @8 o% }: u/ y0 L
Y25.942! w- @, l7 T7 y2 Y0 D8 p
1 j5 E3 |7 G, V. A& dG40 G1 X37.921 Y31.822
" I; y5 w1 ]8 BG0 Z46.993
. K# i7 _2 U+ y  T3 vZ100./ X7 `; [5 q% i4 z1 d) z& K5 m& o
X12.879
4 y; a4 |3 S* Y2 H4 _: j" s/ z* EZ49.993
, M7 r8 v6 x* s, o; aZ46.993) {; s/ L" S, g6 W
G41 G1 Z43.993
0 W0 b; h# @$ n4 V3 _2 VX11. Y31.138
6 i: U% W0 K, R" `8 DG3 X8. Y25.942 I3. J-5.196
6 S. |5 n  D+ U: GG1 Y-25.942
- Z+ Q  M: k# _: YG3 X11. Y-31.138 I6. J0.
! [; L, @, |" F* R: s" k/ j' O2 zG40 G1 X12.879 Y-31.822
" Z8 ]! K- e1 ]/ R) r& I% }/ DG0 Z46.993% }7 B( Z8 P3 E" |( N
Z100.0 ?  y+ z3 w9 W, `2 R, h4 k
X37.921& n9 w& _5 n! {% w5 B+ k3 U0 k" s
Z49.9938 x) K8 U% m7 D6 h
Z46.9933 \) r0 B- i5 T, c
G41 G1 Z43.993
; L: x; S% o: S! ^, @# uX39.8 Y-31.138: M3 W8 p6 d. P2 z2 o0 V
9 {+ E1 K1 c2 I. H! u" mG1 Y-22.226
7 m. y8 M. D8 d5 KX490.69 h) |! w5 g$ y) G3 _8 g& X
Y-25.942. n' O* D, ]3 L) l$ w
. @" ^, n* b( PG40 G1 X495.479 Y-31.822
" }0 N0 S; t9 z: |8 N- ?9 R  ~( wG0 Z100.
! @# M& I+ I) l9 V, p& ]M52 J. ]2 m: d: w
M0
0 L2 K# c: A# @) mS1600 M3
5 m! _! I7 {+ @# M1 @6 lB270., |, K) Z# K+ ~$ `+ v
1 B, j+ }3 q8 GZ49.993* v4 V8 n: s0 ]: u3 g' O- d7 e
Z46.993
% n; b# s0 R( R, bG41 G1 Z43.993 F120.
: |5 V' J; g) G: a9 v* `# [X522.4 Y-31.1385 ?4 ]2 {+ a  j, O: m% x
* r; b1 S* i' S# S  P. Q* K' M" C3 ]G1 Y25.942- ^0 D. c; w; S6 t8 N( I6 U
, u6 {2 R" _' w7 y1 B3 aG40 G1 X520.521 Y31.822
( o; `$ N: ^, g3 oG0 Z46.993
+ ^" a/ ?$ l6 |. M, U8 b. }, GZ100./ X6 q+ ?3 \$ j6 W$ D
X495.479
. d( p) n& m- P& E& ^: g: \Z49.9938 |; M/ p. O, f" Y4 y) R6 c  h
Z46.9936 f1 F, W- ^: W9 T
G41 G1 Z43.993: j1 F. o+ f* {4 j: O: Z
X493.6 Y31.138
  c) `( E- ?% w2 u! I9 i! gG3 X490.6 Y25.942 I3. J-5.196. g6 v' W  H( r& z
G1 Y22.226
  d* T$ N2 q8 [2 W9 bX42.85 b* s1 B4 R$ ]6 [* q
Y25.942$ h  m0 N8 i8 [! Y/ y4 B  l+ z
G3 X39.8 Y31.138 I-6. J0.9 @4 H+ M9 w4 y- y: t6 J0 ]
G40 G1 X37.921 Y31.822; o$ K' J  C( }" H
G0 Z46.993
% v2 Q! Q6 [2 Q! x( sZ100./ y& S8 }" o! |: C0 V( |& m- z  o8 o# Q
X12.879
2 ?$ O/ i5 F& }' iZ49.9937 _" ^- {6 G/ q8 [9 ?1 k
Z46.993
- ?" ?5 u" s* U* S1 W- eG41 G1 Z43.993
) _- R7 }6 l, e/ G, @3 SX11. Y31.138: p% n$ r/ S7 p7 j
$ Y7 M6 R/ B, }8 k( y% o+ V( BG1 Y-25.942
2 l3 i$ O. c9 w( EG3 X11. Y-31.138 I6. J0.
" x2 H  ^8 C% ]( F$ P3 V: ^G40 G1 X12.879 Y-31.8223 V. N9 v* b& y; L0 w8 L: D
G0 Z46.9931 Q% V$ _" Q+ `0 d  U1 k3 x
Z100.! o; M3 @" J& B, S! L& B" u
X37.921
. L+ I5 k: q/ x4 m' l/ G* @* zZ49.993# I5 E- o! Y2 o! x
Z46.993+ F" X! \# f. U7 w& G" o  d! D$ h
G41 G1 Z43.993+ j; _' V$ [$ K+ p/ g; A
X39.8 Y-31.138
; V7 s; N/ k2 e8 p# k' `' `, LG3 X42.8 Y-25.942 I-3. J5.196
4 T+ i* O& m  a: c# H: ]G1 Y-22.226, ]2 z; i, J# ]8 \% c
X490.6
, @* `8 X# ]5 Q& Y" fY-25.942
9 S, q, |, i! w: y4 GG3 X493.6 Y-31.138 I6. J0.
# R9 Z1 P3 Q* B, F/ x, H9 ]* VG40 G1 X495.479 Y-31.822
) ?5 L' O, t* fG0 Z100.
& f! T6 x9 y6 j) D: hM5
- k9 m! K6 C: X1 e7 hM0
% g! O) }5 ?- YS1600 M3
& S# |; T# U: h- L: Y% yB90.
+ F8 F4 u7 I% `+ V( ^! C  ~G0 X520.521 Y-31.822 Z100.
( n" o4 J1 d! Z( g; M# f6 |- U! _Z49.993% M2 Q: b, ^3 F1 H; K/ H% D) I
Z46.993
) E+ i% }. S' M2 F) }. ]8 C7 fG41 G1 Z43.993 F120.2 w7 z" y; ~- l/ m$ W
X522.4 Y-31.138
, q4 ~6 v3 b& e: C6 WG3 X525.4 Y-25.942 I-3. J5.196 R6.( E$ t6 i% D; w) }6 r
G1 Y25.942+ [5 g* v# N/ d, f' G& ~
G3 X522.4 Y31.138 I-6. J0.9 t6 r; p$ t/ V$ I5 C5 L
% z) Y5 k6 B6 Q. m; h3 P6 aG0 Z46.993
- s3 U: l. n0 c" G1 i' kZ100.5 @* u  G: ^$ l+ F( f
X495.479
9 v  q) s$ |/ a- Z1 TZ49.993
4 X: r2 e2 N7 u' [% T% JZ46.993
5 d" c* M& Z, Y) E9 }! c( j* |$ CG41 G1 Z43.993+ W7 r$ l- a6 ~# Q+ B: {; j# J
X493.6 Y31.138- l- d0 q' c' O/ W2 Z+ l& f. z
% @/ f5 f0 t- s# P9 c/ DG1 Y22.226
* {" O* Y/ r8 HX42.8
" b* y" r4 p) d2 ~) u& t8 eY25.942
% h& f& r! h& X' N% hG3 X39.8 Y31.138 I-6. J0.
! E# x5 X8 c$ n0 W/ _G40 G1 X37.921 Y31.822+ W& m+ O) V  g+ C
G0 Z46.993
6 d7 h( c- J" CZ100.
) \9 n* H6 v; R$ @8 yX12.879
; J1 l, r# L  E& a/ I' X+ HZ49.993
3 y! z% G6 v9 v& bZ46.993& i! a3 z9 k% F& n0 ~4 _( ?% O
G41 G1 Z43.993
  a/ U  y! u2 G9 A* r. gX11. Y31.1384 m: N, {0 e9 p' b8 D6 M3 `
& V* v8 j0 ^7 c# l+ ZG1 Y-25.942: [4 x9 @/ A) n( o6 D
  r# {, {8 R% p! {( f/ |6 P2 {G40 G1 X12.879 Y-31.822
; e) V' \' g' i/ J/ j+ P  u/ _G0 Z46.993
$ X8 h7 }/ _1 M( l8 b7 M1 _Z100.4 [9 M( o$ F( L0 M8 U8 c+ |
X37.921+ J1 M: |0 W  t/ U
Z49.9931 a4 z! s9 a& V7 _
Z46.993
0 p0 w& N6 O" u, c" @7 w. IG41 G1 Z43.993
: P$ _& W9 M' K3 |" @X39.8 Y-31.138. b1 y% T! C1 [5 }3 i
G3 X42.8 Y-25.942 I-3. J5.196; A9 Z9 \% @$ l8 m0 }
G1 Y-22.226. R( T/ _/ T: s( V
X490.6' Y5 t9 @. Y8 j4 Z
Y-25.942
/ H: n  z7 n/ M: U- IG3 X493.6 Y-31.138 I6. J0.1 E& q0 @! A1 }8 d8 i
G40 G1 X495.479 Y-31.822" b. q: a8 z( K  [2 E: _
G0 Z100.
" O8 d* d, \" J- y$ ?6 e- WM5
6 s' Q8 q0 v/ }3 J) lM09 t$ }, m3 f: @0 ~9 p
S1600 M3* V* m5 [7 z! K1 @# E
M5
; J4 e$ E$ ?0 e/ A$ F$ oM9
$ s6 q# ~' q; w4 d. S+ r5 ], YG91 G30 Z0, i2 f9 p$ q0 L/ C' c6 m6 j
(Machine Time:36.8 Min)
2 l7 e5 h# C5 N7 t  b6 @, c, I, hM30' T! k- v! j0 W: R' @/ z# O
! R; Z  a: R; O- b% W我有点问题请教,怎样在UG中加刀补G41,G42
7 c* }0 E# G, [- w* w9 ~* R7 ~我的QQ925391856.
发表于 2009-5-15 21:08 | 显示全部楼层
同一把刀只要有一个D值就可以了。如果换了刀就会有新的D值出现。这个不用管它。G41打开是在机床那一栏里打开的。默认是不激活的,你把它改为进刀退刀就可以了
发表于 2009-10-23 20:33 | 显示全部楼层
D  是模态指令了啊
发表于 2009-11-6 18:19 | 显示全部楼层
就是嘛 d是模态指令
发表于 2011-8-10 22:22 | 显示全部楼层
求各位大侠指点,小弟想好久都不知道怎么回事
发表于 2011-8-10 22:20 | 显示全部楼层
设置为进刀,可后处理出来时G43 Z10. H00
0 Y! j* {  D4 s4 s' ?; ?N0060 Z2.8
* A4 P2 X; {; c+ zN0070 Z-.2
- C8 {- V0 O$ P/ B' YN0080 X300.7723 Y254.94% M# P4 [; r4 X3 e0 `  ]4 ^: T
N0090 X300. Y250.% C: S: O6 D( O' g7 X$ e7 B/ J- C" V
N0100 G41 G3 X284. Y234. I0.0 J-16. F600.7 e- V& J" n7 A1 \8 Y0 p
N0110 G0 Y66." g) r# v; r8 a/ A. h
N0120 G3 X300. Y50. I16. J0.0
, c! N, d3 U- _. U; i; M* A/ E5 BN0130 G409 `4 x2 J6 N! W! V0 q3 G# y6 u
N0140 G0 X300.7723 Y45.06
7 J) k' j5 I  U$ JN0150 X310. Y45.8323
# P5 v1 {8 `6 e" g7 [4 UN0160 Z2.8% \9 B5 b+ S9 f4 I. N- S
N0170 Z10.
" p; g( ?& m. [' _4 [& J5 @N0180 X-10.
; L( _5 d1 j" }7 EN0190 Z2.8: C' _" g5 h% B, H
N0200 Z-.2
1 o  v) p# ]4 l' FN0210 X-.7723 Y45.06
' g5 f' [; j0 v, v/ z$ Z7 aN0220 X0.0 Y50./ t6 I& b0 v$ j0 j" j$ h: _
N0230 G41 G3 X16. Y66. I0.0 J16.
. o# ?# m+ o2 F- J) ]N0240 G0 Y234.( C; W! a7 A% }
N0250 G3 X0.0 Y250. I-16. J0.0* H/ V( F3 v& N$ h' e, b
N0260 G0 X-.7723 Y254.948 J! |  z' d* t% l& z, ]; Y
N0270 G40
7 a8 q6 i3 J& ?' IN0280 X-10. Y254.167( v3 }5 O- i! z" s3 H8 s. a+ D
走圆弧,而且没有D,是不是软件问题
发表于 2011-9-2 20:42 | 显示全部楼层
软件没问提,用的有问提,多摸摸找到在哪就好le
发表于 2011-9-17 12:54 | 显示全部楼层
在UG里,刀具页面里有刀补值
发表于 2011-9-19 10:45 | 显示全部楼层
设定为非模态不就OK了,在D代码设定里Model后面的NO打√就行了,
发表于 2012-7-14 22:30 | 显示全部楼层
请我LZ这个问题解决了没有?我也很期待 这个问题的答案,能不能告诉我啊?QQ355555631
GMT+8, 2025-4-30 13:48 , Processed in 0.288828 second(s), 27 queries .
