本帖最后由 yuan_zm 于 2009-6-15 23:21 编辑 + K! { Y3 i( t4 J
" I, k5 e6 E1 C5 y
BLOCK_TEMPLATE linear_move
- X8 H; q" u# [+ ~! m1 ] {6 m: g3 q3 _7 |0 ~5 Y# ^6 z6 H% I$ l
G_motion[$mom_sys_linear_code]
5 c1 @ J4 c Z- t$ I5 S* z& T* t G_cutcom[$mom_sys_cutcom_code($mom_cutcom_status)]\opt
0 e% n7 x: ^$ f) [ X[$mom_pos(0)]6 {2 D7 T( e( l3 ^9 y9 E2 a
Y[$mom_pos(1)]! S1 p* H \) N3 F& d
Z[$mom_pos(2)]
" A4 n4 U5 T3 i( M& A+ i! }, D F[$feed]
+ G9 ?9 u6 g. G% O: E S[$mom_spindle_speed], y* x8 R; P- p8 L( @( O
D[$mom_cutcom_adjust_register]\opt (这里这样加上30呢??)
/ t; y4 b$ W8 F4 |+ S4 V# o" N: C M_spindle[$mom_sys_spindle_direction_code($mom_spindle_direction)]\opt
3 a8 U: K8 Y1 x2 B }
: ^# P! @" r% S9 A: e BLOCK_TEMPLATE linear_move_turbo
: U9 ~/ x$ }" ` Z: x; d4 @ {' x0 S& i# D* v' V3 [0 H2 w
G_plane[^sys_cutcom_plane_code(CUTCOM_PLANE)]\opt' g% S0 V7 T2 S) q0 e" r) [
G_motion[^sys_linear_code]/ w: g Z3 C; {+ c) v& N! c
G_mode[^sys_output_code(OUTPUT_MODE)]
8 W, A6 {" {6 c# c G_cutcom[^sys_cutcom_code(CUTCOM_STATUS)]\opt2 x1 \; m% v% \: O T
X[^POSX]+ u9 Q0 Y6 w) U, d
Y[^POSY]
) X, }2 Y! ^ g) t; u Z[^POSZ]
5 S2 ^/ k8 D6 f6 \4 C* @9 c2 v F[^FEED]
) W6 s; H9 D6 Y0 i8 v7 `. b S[^SPINDLE_SPEED]8 y* ~6 D# s: u* u
D[^cutcom_adjust_register]\opt - I- m$ R/ f# ?% P. b
M_spindle[^sys_spindle_direction_code(SPINDLE_DIRECTION)]\opt7 R# R9 w# j" K$ x' x/ R* J
M_coolant[^sys_coolant_code(COOLNT_STATUS)]\opt0 n( y! m r& r, K }, R* s2 T
}$ U( ~; ~3 X4 L7 J
(PROGRAM NAME: 000)
8 `; [8 S/ @: a v: n1 IG40 G17 G49 G80 G90 G21; l# Z: R& W* _ b3 W$ @- r
(TIME: Thu Jun 11 13:44:18 2009)
, A6 I' p+ A# Y2 VG28 G91 Z0.0* r" R' \* {3 ]: e" a! `) A7 q
G28Y05 `/ |6 @, }* ^" J2 D
(Tool Name: CED10.0 )0 @ X. l* a5 o1 m% {
(Tool No.:10 Tool Len No.:10 Tool dia No.:10)3 M) c- @) N1 I" c+ e! c
T10 M6
! X& ?2 G& b, h' _7 \& FG0 G90 G54 X50.66 Y.747 S1687 M3
5 n: @, P! X9 W& ]G43 Z20. H10
) t: `1 ?+ p# r% \; C; GM8
' I- |4 ?2 _% y7 ~6 LZ1.) Z1 P6 a' ]: F( ^1 [1 _
G1 Z.5 F1012., [+ l2 N) n; }5 ~: W
Z-.5 F607.
: L# _& X: I' O& o$ ~G41 X50.223 Y.504 D10 (我在ug机床控制里输入的是10,但是我想处理出来的都是在原有的10上加上30,也就是"D40",因为有的机器是A寄存器,只能这样????)7 B& u D. Q5 e; r/ N9 }
G3 X48.892 Y-5.606 I3.147 J-3.885
4 K4 ~& O# P, w7 Y$ N$ L& rG2 X48.998 Y-5.833 I-4.478 J-2.2252 l) Z5 ^# i/ P3 k; K+ L
X49.339 Y-8.7 I-4.583 J-1.999 F675.( w* f4 q8 t7 k5 \) I! X1 ]/ L F
X-50.1 Y0.0 I-49.339 J8.7
- {; y- L" K$ L/ K4 wX-48.835 Y3.324 I5. J0.0 |
