S-Z
Sample, 样本3 d, {# d% u3 F$ N4 x( O7 \) p
Sample regression coefficient, 样本回归系数0 o b) @3 {. U- x! O2 J' d
Sample size, 样本量" [- w3 L: Z: u% k# z8 b
Sample standard deviation, 样本标准差( d) ~3 Y+ `3 L$ S, a* ]( z, }
Sampling error, 抽样误差
/ R* V: t6 N c" |0 \" x! O8 xSAS(Statistical analysis system ), SAS统计软件包: @) _( C( \8 R1 t4 ^7 g
Scale, 尺度/量表1 y3 I0 a) k3 o5 Y: V% a
Scatter diagram, 散点图
& u0 f" c) D XSchematic plot, 示意图/简图& Q! j* {' Z: e, N$ ]! \/ l
Score test, 计分检验
, z1 D! p5 ]; d+ S$ e: V% [Screening, 筛检3 i* f0 \; a7 Y2 _+ v( {5 e5 {
SEASON, 季节分析
, m* f9 s: Y! ~$ {0 aSecond derivative, 二阶导数
) _) F. m& C; h7 L" `; bSecond principal component, 第二主成分6 J c6 l9 l- }9 O; z
SEM (Structural equation modeling), 结构化方程模型
% j& w& z! G6 PSemi-logarithmic graph, 半对数图
! R6 K; {/ J0 HSemi-logarithmic paper, 半对数格纸
9 O3 X; \% c* R7 S( ^# |Sensitivity curve, 敏感度曲线7 h( l3 f, u* @. g/ K9 e* d
Sequential analysis, 贯序分析; D4 O! C. [3 w4 i8 j% H
Sequential data set, 顺序数据集
4 c9 \& [- N8 b: ]; zSequential design, 贯序设计/ ?/ f% g' L X: g* M
Sequential method, 贯序法
/ P3 a5 |8 z7 D# Z$ I( v2 V) s0 ESequential test, 贯序检验法6 f2 v& a& x' D& P# h
Serial tests, 系列试验5 j' E4 d9 ^1 x- K
Short-cut method, 简捷法
# R2 |! B0 j' N3 U4 |Sigmoid curve, S形曲线! q5 ?6 _$ f: s8 R3 T
Sign function, 正负号函数' ~- u9 C; J& Y, u. G( N$ f' g& Q0 O
Sign test, 符号检验: W6 _" t4 l6 `% A9 N+ j& d
Signed rank, 符号秩- o' c; M4 Z1 d4 l1 v- X3 l
Significance test, 显著性检验9 n& h- x& ]: P
Significant figure, 有效数字# S: E9 O* L8 b c0 V: } p
Simple cluster sampling, 简单整群抽样
2 y4 D' N" @9 |2 P! j/ X1 B" OSimple correlation, 简单相关5 x/ j, z" @/ T' U+ `4 v
Simple random sampling, 简单随机抽样8 c: V( m! a% h. a4 t2 J
Simple regression, 简单回归
+ ^! p' P6 a% y5 Z7 }- J" qsimple table, 简单表
; L& g' j2 ?! C# [0 BSine estimator, 正弦估计量& R+ H n9 R) @+ h1 W0 i) @
Single-valued estimate, 单值估计+ E4 _* J, c% ~ [
Singular matrix, 奇异矩阵: z- H5 k, q/ e' a/ ?3 h1 ~7 f8 o: F
Skewed distribution, 偏斜分布+ X4 n( E; \9 `- y6 ?5 S0 e7 V( P
Skewness, 偏度
. ?( }; |# t7 f; Q: y9 S# }Slash distribution, 斜线分布3 h, M/ j# k3 b! i9 n
Slope, 斜率& P6 y. w6 l) ]5 d* O" K
Smirnov test, 斯米尔诺夫检验
- {! r4 F2 }; P |5 M! f$ [! cSource of variation, 变异来源
9 I% n- s- Y4 U' b) hSpearman rank correlation, 斯皮尔曼等级相关! d4 F, j* j9 t
Specific factor, 特殊因子5 {: v/ p( u% o; \9 o6 [
Specific factor variance, 特殊因子方差
) h( E+ n5 ?9 K; E# r! ESpectra , 频谱
) G0 d$ f' J. p+ s( { |6 ~) Y/ {Spherical distribution, 球型正态分布
- y& J2 [: C* w: n2 \Spread, 展布
3 i: X3 U: p3 g ?* b4 ^# GSPSS(Statistical package for the social science), SPSS统计软件包
( O @. V( G8 t9 S( B# \; RSpurious correlation, 假性相关5 h' ^9 q: X. T8 r& g. a! H5 U/ `
Square root transformation, 平方根变换8 h. t: Q' b2 C$ u3 s6 Q- s$ u8 X7 J: c
Stabilizing variance, 稳定方差
- H7 L; U% a/ |Standard deviation, 标准差0 q% G# `* s. P( ?* D
Standard error, 标准误1 D! W0 O# K4 k1 H, Q8 D9 d
Standard error of difference, 差别的标准误
* q: U0 L' M, j4 U. B( C) BStandard error of estimate, 标准估计误差$ q, Y: n+ ^% {% W) E
Standard error of rate, 率的标准误8 {3 o' w1 O8 \& {
Standard normal distribution, 标准正态分布
& `" _ I& G- |% }& @Standardization, 标准化) q- s- J; P m R A0 ~; R7 r5 z C
Starting value, 起始值
, ?5 |" `& t" T6 E6 t9 fStatistic, 统计量% N, V. C4 E. j/ w
Statistical control, 统计控制# I8 ]' I: K9 u9 K
Statistical graph, 统计图
, Q; Y- T3 _8 B5 v$ ZStatistical inference, 统计推断
3 s/ e" H2 E* JStatistical table, 统计表- A2 Y, ^: f* b1 X& N" M$ W7 Y
Steepest descent, 最速下降法5 F, a2 }7 | a. B: T# N
Stem and leaf display, 茎叶图7 L, q& t0 F: k9 p$ I* s
Step factor, 步长因子$ @2 A5 }% w/ Y" e9 Z4 ~, p4 t
Stepwise regression, 逐步回归& N. Y! }6 k2 t( G7 _' P
Storage, 存
5 l, B8 m9 \6 t9 y/ uStrata, 层(复数)
) H+ j6 B/ A+ a% F- v: O. yStratified sampling, 分层抽样$ [: u& I: j7 R% G. T- j
Stratified sampling, 分层抽样0 r, W% Y2 `5 v7 Y* J c" F
Strength, 强度
: V9 p/ i6 ?3 X! N9 {( JStringency, 严密性7 `7 M3 \& |' I m% k. g: s
Structural relationship, 结构关系
* B+ N' t( q. K5 RStudentized residual, 学生化残差/t化残差
. \9 G" J: {- p, J- L% BSub-class numbers, 次级组含量2 _* B9 {7 V/ S/ w
Subdividing, 分割
. W1 Z6 g9 C; \ |$ i- R4 xSufficient statistic, 充分统计量/ W: L. r2 |/ m$ I( \
Sum of products, 积和$ j0 `! x. X6 [; a U
Sum of squares, 离差平方和0 C. t* {7 \: j2 R; c
Sum of squares about regression, 回归平方和
, ^2 w8 E; p1 C, QSum of squares between groups, 组间平方和/ I2 _8 T/ a, m0 D0 E3 ~" c
Sum of squares of partial regression, 偏回归平方和
- T. E/ y1 C9 ?6 R1 r! `& ~8 a aSure event, 必然事件, }: n! W% r5 ~+ m) }
Survey, 调查+ z% ]1 v& y# c, x' E- |+ z( H) |7 V
Survival, 生存分析
. }7 j) T( T1 [3 q$ LSurvival rate, 生存率
% u; P, n7 e# r+ n5 h) t$ ~Suspended root gram, 悬吊根图7 i/ f( L+ T7 O8 N E
Symmetry, 对称
( u" I3 L3 w X7 R# V- @Systematic error, 系统误差
: ]$ B5 |3 W8 o i& q( \9 Z4 ?Systematic sampling, 系统抽样* d5 C7 {. x, j* A
Tags, 标签1 X/ |: x- b% T; L
Tail area, 尾部面积
" T: ]1 a4 w$ WTail length, 尾长
" q, \$ {1 Q8 C L" [. YTail weight, 尾重
W# V+ |9 R2 `( a" I; _" ATangent line, 切线
% ]. Q8 k3 I/ ~& v; h( L" xTarget distribution, 目标分布
- L3 w$ I- x# {+ V7 TTaylor series, 泰勒级数
6 j( v7 ~) z9 X3 C& e: `( q8 hTendency of dispersion, 离散趋势& W X3 s3 a& o% o( M/ S5 g
Testing of hypotheses, 假设检验
# @+ o8 ]6 `$ O6 p8 mTheoretical frequency, 理论频数9 _0 {5 y$ Z! d8 \* C4 w; O2 @3 W
Time series, 时间序列
6 F- j3 D/ `& E: `Tolerance interval, 容忍区间
' E1 D* T* f# s& k7 X* KTolerance lower limit, 容忍下限
$ l v. S9 ?$ x5 i& HTolerance upper limit, 容忍上限
7 j' Y K) ~5 l& tTorsion, 扰率
4 j8 s/ l6 s9 ~1 @5 hTotal sum of square, 总平方和
# r1 `5 F7 j6 {* e9 A) JTotal variation, 总变异
( \+ C0 \, q: k2 o4 DTransformation, 转换# P# o' b. @' ^# n
Treatment, 处理
, f! b2 G3 H& t2 w- XTrend, 趋势. c5 W8 J0 d2 n B. x4 L5 h
Trend of percentage, 百分比趋势
y5 Q& T$ r/ [4 ~/ [Trial, 试验
* e- R/ D5 l9 s* {; XTrial and error method, 试错法
% S& j7 I. y- m4 n. WTuning constant, 细调常数
2 P9 ?! K/ q' F: x5 q. d4 t2 nTwo sided test, 双向检验4 f) Q9 q4 o5 h& u; l/ M. \# Q
Two-stage least squares, 二阶最小平方
: w0 f9 R& i. V1 W, xTwo-stage sampling, 二阶段抽样
8 w% h5 |8 m6 C# W# wTwo-tailed test, 双侧检验
! h& M( ^0 ^1 t9 d2 @+ q8 G0 _Two-way analysis of variance, 双因素方差分析
' J/ c! R, h; M* q- ?Two-way table, 双向表* f# a* {2 O: U Z, u% _
Type I error, 一类错误/α错误
: t: J. X* E$ Q6 ~) r5 NType II error, 二类错误/β错误
2 p; A/ I/ r) J6 ~# TUMVU, 方差一致最小无偏估计简称1 D( v" ~3 K+ o
Unbiased estimate, 无偏估计
# g5 o# ~& S0 ?Unconstrained nonlinear regression , 无约束非线性回归
$ Z# z% a8 u3 j: Z7 aUnequal subclass number, 不等次级组含量
7 k+ ^; t+ T! W e5 I6 JUngrouped data, 不分组资料 d, M6 ?- n3 E7 O4 r
Uniform coordinate, 均匀坐标
: Q) g( L, p0 E, R; R' Y& M% V5 @! \Uniform distribution, 均匀分布; Y% Z% p4 _$ ?" Z7 X! ?( j
Uniformly minimum variance unbiased estimate, 方差一致最小无偏估计1 q5 B8 H0 M) T0 l% w
Unit, 单元1 V0 j8 b" k3 T/ |1 s
Unordered categories, 无序分类3 ^" ^: m- K) s* A; G5 m. ]3 A
Upper limit, 上限1 Y4 m: i$ F `- i6 [* W
Upward rank, 升秩. ?4 m1 N/ t7 q' |& z7 V
Vague concept, 模糊概念
/ R9 e! a. I5 v+ U# g* |Validity, 有效性
1 n1 E; n/ r4 x9 x- fVARCOMP (Variance component estimation), 方差元素估计
- f5 w7 @: W8 L/ WVariability, 变异性
8 _ J6 |4 v: `" d' MVariable, 变量! g* r! e" c/ L* q
Variance, 方差
9 ]. r6 u: J9 D3 H, X+ f$ o* RVariation, 变异
! j! g) X; _* Q' z; IVarimax orthogonal rotation, 方差最大正交旋转
+ s- n. F ? K8 fVolume of distribution, 容积
: O- T9 A0 q: UW test, W检验0 F( O# Q( a; p* P3 s
Weibull distribution, 威布尔分布
3 p D$ e" J" j; _Weight, 权数 N$ w8 X: W* C
Weighted Chi-square test, 加权卡方检验/Cochran检验9 w2 }2 r. c) C- o7 Y6 E7 I8 @
Weighted linear regression method, 加权直线回归
$ e0 ~4 B4 q$ r# i& gWeighted mean, 加权平均数
2 L0 D$ v9 o% T' W6 q1 N! A7 a5 jWeighted mean square, 加权平均方差
% K# |, i+ U( }) {+ o8 n& AWeighted sum of square, 加权平方和9 N: a% Y; _' G# |) ]
Weighting coefficient, 权重系数, ~3 v1 Z& h2 F3 [3 L
Weighting method, 加权法 ! S u- @) h9 J3 u6 L3 c+ z2 ^. ^9 i
W-estimation, W估计量
: p9 k9 C. D- L1 H2 aW-estimation of location, 位置W估计量
7 |' z/ Z; T B. A* VWidth, 宽度
0 u1 x& r1 X# N- G- N& lWilcoxon paired test, 威斯康星配对法/配对符号秩和检验( q# k3 |2 ~) d; e! g+ ]% R6 b3 M3 X/ r
Wild point, 野点/狂点0 p8 ?1 h w* O6 G) T$ L
Wild value, 野值/狂值
6 [6 l1 O; N+ r# \2 U- jWinsorized mean, 缩尾均值5 z1 c& h/ V( T7 v1 p& e9 Y% L w
Withdraw, 失访 T: Z m4 u3 P- ]- ` `
Youden's index, 尤登指数
3 d; f2 K L) f5 T. TZ test, Z检验3 }0 |, R- s9 N& M
Zero correlation, 零相关3 \- S. ]9 i0 D) i. b E7 @
Z-transformation, Z变换
M-R
Main effect, 主效应. {4 E1 x- |5 Q: x
Major heading, 主辞标目. H; c. P8 Z4 }+ l5 h, h
Marginal density function, 边缘密度函数
: y& I. M. R9 g* H2 p( \Marginal probability, 边缘概率) G9 [2 O7 Z) I: h
Marginal probability distribution, 边缘概率分布
( c" }# `3 ~$ h) Y* LMatched data, 配对资料
8 l8 j1 A2 R# V5 Y4 C9 zMatched distribution, 匹配过分布5 o" a5 c# @7 J
Matching of distribution, 分布的匹配( W/ S. m) Z) b1 h
Matching of transformation, 变换的匹配4 ~% l$ g" h8 i) U0 [. I4 R& t0 n
Mathematical expectation, 数学期望% d4 J/ Q) u% @8 V
Mathematical model, 数学模型: i8 N; M8 H& u7 t+ R
Maximum L-estimator, 极大极小L 估计量
. h' n/ `7 n6 U; `/ VMaximum likelihood method, 最大似然法
$ h2 A; z9 Z0 K) T; M- W" F6 ?Mean, 均数
/ `5 t9 _7 i2 R3 e9 YMean squares between groups, 组间均方
8 I+ n5 I- I8 B( w' b$ `2 `- ~Mean squares within group, 组内均方
1 l3 m+ t( E0 v! c' K" PMeans (Compare means), 均值-均值比较/ F3 ^# F( ?7 A. |6 n. j* ~
Median, 中位数- ^, I7 K/ o6 A4 j, p$ T
Median effective dose, 半数效量! x! [7 y' X# j
Median lethal dose, 半数致死量
* K; X9 ^% x$ Z h. {, _5 UMedian polish, 中位数平滑
' \6 V6 V5 X I- NMedian test, 中位数检验
, e+ V) v7 _( v' dMinimal sufficient statistic, 最小充分统计量
+ p) |: L0 U# cMinimum distance estimation, 最小距离估计
& [5 a z* p. G2 x: W+ K6 VMinimum effective dose, 最小有效量
- r, ?: L0 {; x$ D6 e. [Minimum lethal dose, 最小致死量4 f$ \7 {, ^4 Z* ~. w, [ j
Minimum variance estimator, 最小方差估计量
. B+ Y+ n8 v% D$ y: vMINITAB, 统计软件包3 e O* j/ a) y) S, T
Minor heading, 宾词标目+ w ~, d' [" u* n6 K7 |* d1 Z4 y
Missing data, 缺失值
* q* |9 C( \! l4 _' }8 W7 d/ HModel specification, 模型的确定, ^3 [9 a3 K5 @
Modeling Statistics , 模型统计4 I; b6 n! m+ r; ]+ h5 J% Z) p) T- {
Models for outliers, 离群值模型
5 {4 d v0 Q- m( a4 U5 s; zModifying the model, 模型的修正# ~* ]5 T9 v: l, J! k
Modulus of continuity, 连续性模# m- z! _* k9 e# W) j
Morbidity, 发病率
0 o' s3 ^. b% H- G& gMost favorable configuration, 最有利构形
3 E, a1 C) Q" VMultidimensional Scaling (ASCAL), 多维尺度/多维标度
& h2 H* S+ n1 Q! e6 I; ]: W! X5 i% oMultinomial Logistic Regression , 多项逻辑斯蒂回归
3 D7 P& {, B6 k- R4 l) \Multiple comparison, 多重比较
9 U7 p: @& ?+ Y3 p- GMultiple correlation , 复相关! `" V/ N+ e/ b8 `1 K# g' A- j
Multiple covariance, 多元协方差" `5 [8 N7 [; y% s3 Q, [' X0 ]# b( d4 `
Multiple linear regression, 多元线性回归+ b3 D+ V% ^, r# G4 N! L" w: t4 a
Multiple response , 多重选项% u$ c0 G* d7 d2 o6 N7 q4 V
Multiple solutions, 多解
' ^# o2 F! @$ _Multiplication theorem, 乘法定理. T) ^! o% m) m9 Y# o' @
Multiresponse, 多元响应
& D6 K- H5 T: ?9 t# ~Multi-stage sampling, 多阶段抽样. S: @5 x9 h( Z7 S( L9 e, W/ i
Multivariate T distribution, 多元T分布- T" G, E+ p& v
Mutual exclusive, 互不相容
0 j+ B) t! |+ H6 |Mutual independence, 互相独立$ B# X: t7 E6 q0 I( `# Y! G3 i; v/ h
Natural boundary, 自然边界
. b2 }8 d6 ~% J) F8 Q9 uNatural dead, 自然死亡
3 ]- H5 }; W8 k" U0 V4 fNatural zero, 自然零3 {: |1 Z( W/ s/ w/ Z; c) _' v2 \
Negative correlation, 负相关1 r% a6 z5 `6 V1 L" k: _: N
Negative linear correlation, 负线性相关
4 r/ ^9 ~' [1 P4 g. C5 _$ F5 v! j NNegatively skewed, 负偏5 }3 e& u1 U5 l: p. l8 ]6 `6 k
Newman-Keuls method, q检验
. i1 o" }1 M" Q9 B3 ^4 UNK method, q检验! r' n2 ?" A) ^" U, d) r
No statistical significance, 无统计意义
3 [4 P* N! o- HNominal variable, 名义变量 p5 Z5 |2 Q" ~! ~
Nonconstancy of variability, 变异的非定常性
5 _! F B! x" C7 ?. g0 q* FNonlinear regression, 非线性相关# G* E) ?" G; l0 ^7 H2 | y
Nonparametric statistics, 非参数统计
# v4 ?6 M' O5 JNonparametric test, 非参数检验
/ g3 R' O9 q6 w2 n* r2 [' p [6 }Nonparametric tests, 非参数检验3 d% Q3 a4 c# i) D1 P2 j% S
Normal deviate, 正态离差
# F% r# w5 u. y3 |Normal distribution, 正态分布
, P& Y; T; G* k% ?Normal equation, 正规方程组
7 f& \4 E# c0 B& E( R) y1 LNormal ranges, 正常范围& e( A0 W4 [2 C2 g+ p1 V! ?
Normal value, 正常值
, S* Z/ Z; ^1 H) ]Nuisance parameter, 多余参数/讨厌参数
3 f5 \8 e( x5 ^ n- tNull hypothesis, 无效假设 * h" b2 N; N! k- f- S$ L
Numerical variable, 数值变量
7 c& d' a2 c \4 W5 xObjective function, 目标函数! T ]0 J. `$ r8 [! f2 k
Observation unit, 观察单位2 ~0 ?* l& |! P- o9 ^: y/ n
Observed value, 观察值
+ k+ b4 K6 M8 v$ `3 X7 ]3 P- }. oOne sided test, 单侧检验
* E& {# j' X8 p4 Y) dOne-way analysis of variance, 单因素方差分析
h- I. Y0 p; h: G( N. I& _Oneway ANOVA , 单因素方差分析
: f" }$ I& q$ {: L! YOpen sequential trial, 开放型序贯设计4 ~* P' I8 x8 n
Optrim, 优切尾
) b4 g0 N, u0 a F( N" m; R UOptrim efficiency, 优切尾效率
: |6 u3 o4 e7 ~Order statistics, 顺序统计量! e* P; U! A# c i( A
Ordered categories, 有序分类3 r/ E9 q% e; E6 M1 w
Ordinal logistic regression , 序数逻辑斯蒂回归3 r/ |. ?/ o* P$ d# D
Ordinal variable, 有序变量
4 h' q/ N- @% H" s9 UOrthogonal basis, 正交基
+ r5 L- j2 \+ n N3 f! j) DOrthogonal design, 正交试验设计2 F% M3 v" C5 O) F! B
Orthogonality conditions, 正交条件
6 n& S4 x1 J: i, TORTHOPLAN, 正交设计 ) l5 }- h$ X. C; {+ k0 l. @
Outlier cutoffs, 离群值截断点
9 H. C& X1 L" B7 a6 }8 d6 P0 GOutliers, 极端值7 G2 _" a, R$ {) o8 G
OVERALS , 多组变量的非线性正规相关 ( i/ |5 b& m# `
Overshoot, 迭代过度
3 k3 F+ D, J+ R# BPaired design, 配对设计1 v0 e( s1 l y' n+ V# B0 y
Paired sample, 配对样本
# N, I4 d' F% D; m ~5 TPairwise slopes, 成对斜率7 n8 Z! q6 F; G9 P/ w
Parabola, 抛物线
, }* L( [0 K# M0 \1 f/ X) RParallel tests, 平行试验, E* a3 [7 m, P! ?0 B! z5 t
Parameter, 参数& J: [, Y# i1 k: h
Parametric statistics, 参数统计" r/ ~" I7 t8 T& B D6 y
Parametric test, 参数检验' w; \0 o2 |0 g( W3 D- a* p
Partial correlation, 偏相关
0 N+ c1 W6 m; ^4 U4 MPartial regression, 偏回归
# ~; j6 ?. H3 mPartial sorting, 偏排序
4 C* m% ?7 f% V7 D3 N, \9 @) ?# \Partials residuals, 偏残差4 q7 P% M" z1 E+ [& k2 ~
Pattern, 模式' F5 I W# f) S, j7 L$ _
Pearson curves, 皮尔逊曲线
; A. T+ S/ J% O9 T! aPeeling, 退层6 b* y9 o0 l' Z
Percent bar graph, 百分条形图) s# n, m& }; g- v5 Z
Percentage, 百分比: f5 K* G2 K4 y9 V* _1 K
Percentile, 百分位数
- x0 v2 J! v0 P* @Percentile curves, 百分位曲线8 D- I1 }7 l' r$ v- M7 _. C
Periodicity, 周期性
4 [ v! i1 S* ~+ |! ?Permutation, 排列+ b& v+ c- i% V q' b) z; h, V
P-estimator, P估计量: H. ^8 ^' A" r$ i3 {3 ]6 `
Pie graph, 饼图- n) G8 R3 c4 x) ^7 z2 L
Pitman estimator, 皮特曼估计量4 q3 ^# S8 Q" `; S1 b" }& a4 @$ O
Pivot, 枢轴量
1 r/ w- F9 z4 q W8 W: GPlanar, 平坦& ?( `9 _8 E" O, [6 h) q
Planar assumption, 平面的假设
; D+ m$ B$ C+ B. ^5 P3 SPLANCARDS, 生成试验的计划卡; n, y4 c. y8 ?; N& S# g% f) K( G0 A
Point estimation, 点估计
; ^# h4 Z5 u/ [) b& _Poisson distribution, 泊松分布+ M- F. ^. O% G+ u9 p
Polishing, 平滑
! p2 L4 M/ |/ `# u9 z9 UPolled standard deviation, 合并标准差4 i) ^; M# L! j
Polled variance, 合并方差6 Z6 O# M# Q+ l7 e! A
Polygon, 多边图
7 v# v) [0 ]) g3 q: a5 E) p0 oPolynomial, 多项式
7 r- @4 Z$ p5 O- Z9 `Polynomial curve, 多项式曲线
" q/ {9 s: B: TPopulation, 总体
1 k. S5 L: B% K+ s- ]7 y+ _+ T9 |Population attributable risk, 人群归因危险度3 [: `# W/ E% f( u5 F3 `* Q" A
Positive correlation, 正相关& E' ~/ _8 @3 d
Positively skewed, 正偏
5 ?4 F' F2 g5 |; p6 A- pPosterior distribution, 后验分布
6 I3 z! }5 G- ?' F8 X( N! _Power of a test, 检验效能# H9 K2 R5 I# }) c0 L: `
Precision, 精密度
% D6 E, R, G' \9 ?; IPredicted value, 预测值/ b* D2 k. D* o/ M- j9 z
Preliminary analysis, 预备性分析) d- \! B6 D1 r4 l
Principal component analysis, 主成分分析
; g E! b2 w! D% l6 L. {Prior distribution, 先验分布
0 c. W" }7 M( w f7 {Prior probability, 先验概率# P6 ~8 W0 n5 m# [* G* v9 l1 ]2 j) z' Q
Probabilistic model, 概率模型7 n: q% L. Q) i! U3 Q
probability, 概率
" u7 ~$ O& J/ w2 K1 l4 Y4 DProbability density, 概率密度
- c& V( S- G- l1 c; s; e2 ? OProduct moment, 乘积矩/协方差* @+ ?% F& P! R8 ^) E* A6 J& x
Profile trace, 截面迹图" X [3 b# _# W9 L3 I' a
Proportion, 比/构成比
/ f& ~ D+ k, w5 o" o2 hProportion allocation in stratified random sampling, 按比例分层随机抽样; C& m. Y' M. Z" s! {
Proportionate, 成比例
6 |' U8 N5 P( P! JProportionate sub-class numbers, 成比例次级组含量
$ m) ?$ v- P: ]8 U' N. Z3 vProspective study, 前瞻性调查
" @, L1 H1 o5 C# {" o* _5 c# wProximities, 亲近性 & L3 H O1 d; A( z' ^+ a
Pseudo F test, 近似F检验- k8 |* F: t2 w t& k
Pseudo model, 近似模型
; i" E4 E0 L0 ]( kPseudosigma, 伪标准差' X \6 U7 S, e |: c L: k- Z6 J, p" ^
Purposive sampling, 有目的抽样- E4 f8 \; v, ^6 k: K5 t! M
QR decomposition, QR分解* s5 v/ f' V8 J( k0 {. V
Quadratic approximation, 二次近似- U0 g/ W6 z- c
Qualitative classification, 属性分类
8 P& O; a( U0 ~) v/ N$ L2 v% SQualitative method, 定性方法
$ l' i" z- T& `# Z) pQuantile-quantile plot, 分位数-分位数图/Q-Q图3 g1 ?! P; A& O+ c: o/ I% L) @
Quantitative analysis, 定量分析% L, n. P+ i0 t
Quartile, 四分位数
8 T$ {* f4 k6 o- y$ [3 Y, ^Quick Cluster, 快速聚类0 j J3 M. e/ n7 g- h- Q8 y0 M8 k
Radix sort, 基数排序% E& p- k9 B6 v) a+ x9 ]& l' V9 m
Random allocation, 随机化分组
2 }, c6 A6 X1 X* nRandom blocks design, 随机区组设计
/ C: l% k. v9 a! }1 WRandom event, 随机事件6 { X0 M( K( ^- }, W
Randomization, 随机化
! x/ J# D% N& y8 PRange, 极差/全距4 Z, m* v: Q0 _5 @2 M. d
Rank correlation, 等级相关
/ p0 L' M: I M6 r7 n* URank sum test, 秩和检验
+ M) ]) V9 A: J5 }Rank test, 秩检验
' i/ ^4 H/ o5 Z# j+ i/ P% VRanked data, 等级资料
3 ~6 K, z |2 R; kRate, 比率* o9 j- M' T4 R+ I' D4 B
Ratio, 比例
- J1 ]/ s$ o! }8 B- S* ARaw data, 原始资料7 U+ Z+ T( U6 N/ Z7 [
Raw residual, 原始残差
1 b* A9 F5 r9 M3 kRayleigh's test, 雷氏检验
6 v. N+ S$ ]. {2 x9 h! IRayleigh's Z, 雷氏Z值 ! O" r z$ _" X% a( r( [5 i7 W
Reciprocal, 倒数 b# q; e' e4 u/ r% U4 w/ L
Reciprocal transformation, 倒数变换+ s' U1 ~6 j- F: c3 ^0 ?
Recording, 记录
1 t% ? h8 j# }Redescending estimators, 回降估计量
1 R- k8 R+ z) w. f! QReducing dimensions, 降维
$ d/ l' R& ^9 O$ h3 u" C; wRe-expression, 重新表达; e# c$ J1 r! E/ K
Reference set, 标准组
# D# _) |) m2 r1 [1 p7 j: V# VRegion of acceptance, 接受域
% Q1 x% Q, B g9 P$ g! Y/ U& D# ]Regression coefficient, 回归系数9 J$ m+ z. T6 e9 v% Z' q9 L, h
Regression sum of square, 回归平方和 ' C O, K4 T; `/ v- d% c/ ]: u! D
Rejection point, 拒绝点
5 u2 s+ T2 Y4 NRelative dispersion, 相对离散度
S* l! r* `6 v+ ORelative number, 相对数# K$ K8 }4 p' I: P2 r9 q9 ~
Reliability, 可靠性
+ W8 G2 U0 e$ O; Q6 jReparametrization, 重新设置参数
2 V* z- q4 {: gReplication, 重复3 s5 @* V4 U3 {( y! n7 ^/ s# f
Report Summaries, 报告摘要
# d, g8 g" S2 Q' MResidual sum of square, 剩余平方和
- N9 m- J! M5 _6 y) q& Q4 N: uResistance, 耐抗性
6 T6 _. v6 a* K2 @/ zResistant line, 耐抗线
' S" c' Y, x; M% xResistant technique, 耐抗技术
2 f$ ?3 F% f. E. [3 |2 {R-estimator of location, 位置R估计量
( r: r" e/ o9 E1 l! \# g5 ]3 dR-estimator of scale, 尺度R估计量( F1 E. r4 w. Q: y
Retrospective study, 回顾性调查
$ i2 v- z g$ @+ kRidge trace, 岭迹
4 x- C1 ]4 h$ `! jRidit analysis, Ridit分析- U% b3 I* P! W
Rotation, 旋转- F9 v) f& J, Y
Rounding, 舍入5 o* V8 `+ _2 w& e
Row, 行- y" M% \, t3 N3 g
Row effects, 行效应4 Y/ Y2 n! x' b- T0 O) e
Row factor, 行因素( _, @$ w) {& H+ M: w
RXC table, RXC表
E-L
Effect, 实验效应
4 N; A7 t, Z7 vEigenvalue, 特征值
( F* Y' X0 Y9 y0 }6 \3 Y% ]Eigenvector, 特征向量# F# G% E* Q5 l, B) r- k
Ellipse, 椭圆
" C# x1 B* X' i/ |Empirical distribution, 经验分布+ q, ]( g1 Q( o
Empirical probability, 经验概率单位 F, H3 P4 j) j4 X. \
Enumeration data, 计数资料& t, a' r) L/ N/ R+ [& u+ W
Equal sun-class number, 相等次级组含量
: q6 c3 i+ L# rEqually likely, 等可能
) t- | @. p2 e. V* B1 }Equivariance, 同变性
! j- W6 r9 \) j0 c) l9 Y1 l, ZError, 误差/错误/ n$ L( k5 O% R1 X9 _ h6 x" V
Error of estimate, 估计误差% T+ @8 q c' s" k [$ g1 ?
Error type I, 第一类错误
D! p# f: y# t5 S! j5 E' S7 ]Error type II, 第二类错误* d& p: O/ I. `/ S7 N
Estimand, 被估量% U+ i9 U: \* a2 f% p6 P2 W
Estimated error mean squares, 估计误差均方
7 R# N* z( {. G' W1 N9 G( CEstimated error sum of squares, 估计误差平方和
( b% y' m5 Z8 n; m) aEuclidean distance, 欧式距离9 c; j7 {; T' W% h* t" _0 h: ~. S
Event, 事件% Z) q; E9 V* K3 z' [, l
Event, 事件; B$ N: y% o6 ^3 @7 |7 W2 v# s
Exceptional data point, 异常数据点
4 h0 k, x" ^! ]; a" B! mExpectation plane, 期望平面4 T X$ P# q8 E- J5 i7 x1 P
Expectation surface, 期望曲面5 Z+ [7 Y( I3 j- Y
Expected values, 期望值
1 X% [2 k1 X3 L$ _# iExperiment, 实验! T3 \2 T) x# m }. Z
Experimental sampling, 试验抽样" `& g! \1 _: y5 F! j
Experimental unit, 试验单位
9 A# r3 a0 O5 [* N) ]" b8 y# t: MExplanatory variable, 说明变量. p6 _3 r' i/ A- l' a& W7 W ^& s
Exploratory data analysis, 探索性数据分析
8 s( s4 F# ^1 A: i3 C Y( jExplore Summarize, 探索-摘要
: W# y3 J8 e! K3 ^Exponential curve, 指数曲线; w+ F4 V: V B- W
Exponential growth, 指数式增长
3 e/ x) g( Q" Z7 E/ oEXSMOOTH, 指数平滑方法
2 F. v! V3 M* I) ZExtended fit, 扩充拟合0 r/ v/ v' A. h% q! W' e8 B
Extra parameter, 附加参数6 L6 y0 S; J; f( _2 l3 A
Extrapolation, 外推法: e' P- H/ Z# t8 [$ d4 }1 W7 e3 y
Extreme observation, 末端观测值
+ G( `8 m. m& z6 C5 wExtremes, 极端值/极值
, X# @! f8 c6 u% P1 @# x: l2 TF distribution, F分布
. |- [ g8 h! Y8 ?! `0 }4 iF test, F检验
; z9 C' R: B, o+ U" w& m4 _* x2 Q4 ?Factor, 因素/因子
- }+ _: V$ I# G5 ^( w% r' tFactor analysis, 因子分析
4 ]% v" d! [# z" ]. mFactor Analysis, 因子分析
+ \' M3 n x) x5 H# G/ x" VFactor score, 因子得分6 \5 I/ c7 k$ h' Z
Factorial, 阶乘
) q( e/ l( V' b4 a6 pFactorial design, 析因试验设计0 N2 B% a1 k; @- r! I! h( l
False negative, 假阴性. E! b8 w% u) s( m; x+ z
False negative error, 假阴性错误5 M+ T* s! r7 T6 I
Family of distributions, 分布族
' s0 A! T: N4 d: AFamily of estimators, 估计量族( U# D! d% b$ E* ^1 q5 q% M
Fanning, 扇面
+ F n* S0 e" D6 J, oFatality rate, 病死率
5 {* k7 V" L; W9 j1 ?1 D) HField investigation, 现场调查
' M8 g) k5 X, K! v1 FField survey, 现场调查
( G6 Z1 t: f. [; I' m$ EFinite population, 有限总体
7 S& m9 l2 s; l+ E0 cFinite-sample, 有限样本. O" _- w& s, n5 k$ A( c* O1 T# s0 b
First derivative, 一阶导数 C2 p* U8 _/ K, R; ?
First principal component, 第一主成分
# c w- m; v9 p$ N2 t. P! s3 TFirst quartile, 第一四分位数
3 z5 I4 A& x/ b4 z! BFisher information, 费雪信息量/ m2 x+ O6 z/ ?( c
Fitted value, 拟合值* V$ c, ?' z' z0 r
Fitting a curve, 曲线拟合
6 O5 o( G. R2 T1 i0 ?" HFixed base, 定基
2 P1 l! k# c& l* A, s X5 \9 w/ |Fluctuation, 随机起伏
. ?; P4 H0 l* D/ O3 Q0 w" MForecast, 预测' u J$ c' P) a3 x
Four fold table, 四格表
' H, j5 @" e0 r& x) k$ ^& z# RFourth, 四分点
. L( v0 _! I. q$ h0 NFraction blow, 左侧比率( e/ a3 a. i Q2 H5 u) i3 x
Fractional error, 相对误差
! X5 @! u+ h+ m5 GFrequency, 频率
- Z% r( \. J7 _. w1 L0 R* d: x- F( pFrequency polygon, 频数多边图2 p: L7 Z9 R& D$ W1 O& z5 \' X
Frontier point, 界限点
( j/ N. B% w6 ?7 o3 T) r7 FFunction relationship, 泛函关系! h% ?0 M3 Z3 i8 ^% R
Gamma distribution, 伽玛分布+ ?( J K' ], R/ o5 ^
Gauss increment, 高斯增量
0 G/ O3 u3 `3 W8 zGaussian distribution, 高斯分布/正态分布
0 Y, Y/ ]/ X0 P/ h2 M7 E3 \+ wGauss-Newton increment, 高斯-牛顿增量
; T: ~0 u1 F$ A+ L' W0 V* ?% hGeneral census, 全面普查! V) v( ^8 q# a/ T
GENLOG (Generalized liner models), 广义线性模型 6 ^; q% ?1 D9 a3 {8 `# }
Geometric mean, 几何平均数+ V3 n. X! V+ c
Gini's mean difference, 基尼均差
& \2 ?( R5 \4 }9 S) D, tGLM (General liner models), 通用线性模型 4 K# ~; `: ?! E5 M; t8 ^
Goodness of fit, 拟和优度/配合度( V0 r9 t7 w# y. f# x
Gradient of determinant, 行列式的梯度3 l. J6 {0 j2 h' i4 y
Graeco-Latin square, 希腊拉丁方
( O3 e1 @& R4 E& m( bGrand mean, 总均值
5 [9 S$ `0 p" x1 a5 @( G' u0 `Gross errors, 重大错误
- D6 I9 |: I" ~4 OGross-error sensitivity, 大错敏感度
( ^0 i3 D9 @+ y. d+ u4 Y$ nGroup averages, 分组平均
M' k% k% W( \& x/ [; tGrouped data, 分组资料2 E" R) G" j, C/ A) U1 b1 b% r
Guessed mean, 假定平均数! c9 j; X# W+ B5 k
Half-life, 半衰期9 Z# k3 X* ]" k' k S
Hampel M-estimators, 汉佩尔M估计量
% K$ m2 `6 D4 H1 P$ M& u* v/ oHappenstance, 偶然事件8 P1 F0 V& ?# Y$ v; [
Harmonic mean, 调和均数# N. ?: p M, V
Hazard function, 风险均数& H( w! q+ Z% u7 t6 C
Hazard rate, 风险率
# o+ ` o4 u3 |0 R/ f8 P; p: B) N, t3 pHeading, 标目
4 l' @" ]: N$ y. f# e0 `Heavy-tailed distribution, 重尾分布
1 Y$ F& X/ n: v, v1 q" B/ oHessian array, 海森立体阵$ q% f6 b) ^+ g5 J& e
Heterogeneity, 不同质5 d( I0 A; Z0 g% |5 W
Heterogeneity of variance, 方差不齐
4 {! h7 G) [ n. g& s% Z8 qHierarchical classification, 组内分组
. K% _! A$ w, X {* iHierarchical clustering method, 系统聚类法
! y; K' G' h, `& @; KHigh-leverage point, 高杠杆率点8 D& l0 J S5 }. E% w" q3 N
HILOGLINEAR, 多维列联表的层次对数线性模型
/ S* R, h7 p" b9 p1 ~" b d# THinge, 折叶点9 S. D7 k) Y- Z
Histogram, 直方图6 `; o( c& k3 v3 m) N5 Q y
Historical cohort study, 历史性队列研究
( |; Z) l; [* z9 q2 BHoles, 空洞
9 f" U! y0 S& `' h: i3 F3 DHOMALS, 多重响应分析
, J9 v% Z& i4 a' Y# U( NHomogeneity of variance, 方差齐性
, N: a4 U: w0 xHomogeneity test, 齐性检验! b& V. Q) h: o- ]
Huber M-estimators, 休伯M估计量
8 b- ~0 M& P8 }Hyperbola, 双曲线
$ A: D5 y1 r( e' Y9 MHypothesis testing, 假设检验
0 M; P+ W7 p& n+ ^Hypothetical universe, 假设总体4 m! P# E: Y, T8 r* w
Impossible event, 不可能事件3 V: G1 l& D' b; t' g2 [5 c
Independence, 独立性
0 Z3 ?4 j8 \/ f, C3 xIndependent variable, 自变量
4 h0 r! M, G" C: U9 JIndex, 指标/指数5 c3 |) j( }+ L( ^! ~. ^& n" J
Indirect standardization, 间接标准化法
4 \ Q! U3 |6 h6 n4 SIndividual, 个体
& V+ I F2 |& ^$ J9 u w; PInference band, 推断带& F" b' e# g* E2 N6 [6 \
Infinite population, 无限总体
0 C" X, q- u! k' l* w( Q! y7 PInfinitely great, 无穷大
6 E2 h, d( w2 V( S$ K. UInfinitely small, 无穷小: D! I3 c& Z. F# k' S6 n
Influence curve, 影响曲线' r9 u2 Z1 X3 g
Information capacity, 信息容量6 O0 `# z+ d. A: _) d e N
Initial condition, 初始条件* o! w4 ?0 Q* I# Q! g& [ }; F
Initial estimate, 初始估计值
$ I, B; C/ e# _' OInitial level, 最初水平* J6 U9 U" M# i
Interaction, 交互作用6 H5 J8 m7 ~3 _3 y2 }
Interaction terms, 交互作用项
6 y: y( M# F/ T+ \4 [7 kIntercept, 截距; \# i: ~ T' X( i, U
Interpolation, 内插法
( S$ e9 C% h" o; z0 ^( K+ o1 SInterquartile range, 四分位距
* ^) X( C/ D+ Q) e: X% y' V& cInterval estimation, 区间估计
( L9 _( x+ W# QIntervals of equal probability, 等概率区间
7 x" ?$ S% g0 j! Z) H2 {Intrinsic curvature, 固有曲率8 P; S' O4 P4 ~+ N; G6 u, I$ L" X5 ~' W6 h
Invariance, 不变性* g/ G! W4 Y; s# `4 W$ f+ A5 H7 f! ~
Inverse matrix, 逆矩阵
' Y. x* U! Z PInverse probability, 逆概率
. C( q% j7 [% x/ ]8 lInverse sine transformation, 反正弦变换
' H0 I2 X* _8 U2 q+ d/ c4 ~& OIteration, 迭代 : c Y4 d2 q9 C
Jacobian determinant, 雅可比行列式
" v; c. d7 ?. u# K/ p f. T; z1 H( }Joint distribution function, 分布函数9 I- a: F0 U% U: @) t6 v+ V/ O
Joint probability, 联合概率
6 z) ]/ J: \' p2 fJoint probability distribution, 联合概率分布
% y; r. ]3 _3 k7 A1 [ m2 _& uK means method, 逐步聚类法
- }& Y9 U/ f3 y% m! y& JKaplan-Meier, 评估事件的时间长度 3 Q+ ~0 q! g* p; U2 B
Kaplan-Merier chart, Kaplan-Merier图$ Y: a, j& I0 r, h* @
Kendall's rank correlation, Kendall等级相关! d# A9 A( i; c( M4 P! U* X* M
Kinetic, 动力学
' I' o% G- r; xKolmogorov-Smirnove test, 柯尔莫哥洛夫-斯米尔诺夫检验" a9 _" z3 x" u' m j# Z
Kruskal and Wallis test, Kruskal及Wallis检验/多样本的秩和检验/H检验
- z! r2 p: I6 n# O! \Kurtosis, 峰度$ A, X" {! R' g) o3 F3 Z! ]
Lack of fit, 失拟
( L" X9 U' ^5 O9 ]0 |# t+ ?; BLadder of powers, 幂阶梯1 M2 d9 ~8 R4 A" Y; Y
Lag, 滞后
& m( u% y& z4 j! N7 }Large sample, 大样本
: p5 P$ {0 T [1 |" Z; M2 iLarge sample test, 大样本检验
# W5 w$ t- ^0 W) H7 Y- U* \Latin square, 拉丁方% b4 Y ~/ S- S9 q4 K4 B: }0 ~
Latin square design, 拉丁方设计0 S5 A! t& ~* s7 J% k9 `
Leakage, 泄漏
3 L) |2 z# z& {5 j* A; J0 F/ qLeast favorable configuration, 最不利构形' K8 c# u) E/ @9 U
Least favorable distribution, 最不利分布
3 N, H, z5 z1 k3 z; ?" `/ _& aLeast significant difference, 最小显著差法
$ U' p& [6 u a+ x$ w- tLeast square method, 最小二乘法" {: K1 B2 H' @' X1 U5 P+ a" T
Least-absolute-residuals estimates, 最小绝对残差估计 z, U# H9 j1 m) o
Least-absolute-residuals fit, 最小绝对残差拟合$ H+ H- u m; s1 \
Least-absolute-residuals line, 最小绝对残差线
4 D( O" C* y# U2 P( tLegend, 图例
& G- i1 E$ ~5 N7 J# C+ i9 m) vL-estimator, L估计量
1 z! K( @2 d0 OL-estimator of location, 位置L估计量
7 c, S1 [' M A f6 QL-estimator of scale, 尺度L估计量; g/ u; ]/ h |. H: E+ |8 I8 g8 _
Level, 水平
) ~0 M6 n! Q6 O2 z# hLife expectance, 预期期望寿命
( _6 F3 d# E q0 W2 S! g( yLife table, 寿命表
& ~& e- N- V4 [8 p2 k8 jLife table method, 生命表法+ V: g2 W- b: B2 K3 a
Light-tailed distribution, 轻尾分布
2 p* c- b6 m: I$ g; l6 S6 }Likelihood function, 似然函数6 R% d1 x! B, _
Likelihood ratio, 似然比) n3 i" g4 Z0 W- a/ ^
line graph, 线图
% K! y! C- Z' M+ r tLinear correlation, 直线相关
1 Y1 j- d: h2 e5 F" Q& BLinear equation, 线性方程
3 k- v# {# S: |$ R0 u0 `. zLinear programming, 线性规划
6 D/ `5 ?; M! z3 T( SLinear regression, 直线回归- h- L1 h4 k: l
Linear Regression, 线性回归7 ^, o; e) A' a5 E! m$ n
Linear trend, 线性趋势
8 i( K8 [$ B1 S. @Loading, 载荷 4 p/ u3 W* o) t8 R/ _
Location and scale equivariance, 位置尺度同变性/ F% b' N5 R+ T
Location equivariance, 位置同变性
. M/ t+ Z! q& iLocation invariance, 位置不变性
9 J+ b4 n2 T8 ]! G6 bLocation scale family, 位置尺度族% _( {7 F/ p, X0 W8 i& y A0 J; K
Log rank test, 时序检验 2 y, j& D3 M1 X3 e
Logarithmic curve, 对数曲线( W2 r7 J: d! A, E
Logarithmic normal distribution, 对数正态分布0 _; E& p" F7 Y$ `
Logarithmic scale, 对数尺度
: @0 N- t3 l9 e+ gLogarithmic transformation, 对数变换' G* R* ]- b4 f! u. V3 S1 v5 G: t* n
Logic check, 逻辑检查9 ]9 g: ?. G1 A! B% F" {
Logistic distribution, 逻辑斯特分布, Y* d9 j/ L, R- T! @0 \
Logit transformation, Logit转换
6 E5 y" R2 _- g( c6 @( TLOGLINEAR, 多维列联表通用模型
4 Z. _( n+ G D! c4 Y5 @ A: SLognormal distribution, 对数正态分布 L* e* n. S. P i* D0 m" ^, G, O
Lost function, 损失函数! W$ ]. Y* F5 o+ o
Low correlation, 低度相关
4 H4 m0 F% ~- c' D& OLower limit, 下限
- F; _5 C. j# R$ h# [Lowest-attained variance, 最小可达方差
8 i3 Y: D9 [+ t1 ~) W G8 w% g$ [LSD, 最小显著差法的简称2 Z+ ?& N- i* I& A; i
Lurking variable, 潜在变量
A-D
Absolute deviation, 绝对离差/ H6 ^4 ]1 O# W8 |2 t; ^2 F) j
Absolute number, 绝对数
7 ~; ]# C u( H4 O# kAbsolute residuals, 绝对残差0 x# k* u+ K5 n# J% g
Acceleration array, 加速度立体阵- x/ s; A" H" N } o
Acceleration in an arbitrary direction, 任意方向上的加速度
! p4 a4 y: h8 wAcceleration normal, 法向加速度
. f1 v1 n' h5 G9 jAcceleration space dimension, 加速度空间的维数
! `. Q4 A; i* W4 EAcceleration tangential, 切向加速度 T! \- n1 }4 C$ d
Acceleration vector, 加速度向量
/ L t4 q( Q2 O3 ^7 G8 [& DAcceptable hypothesis, 可接受假设! L6 l) F% L+ `4 C" `4 `; w
Accumulation, 累积
$ M! H$ i/ v6 TAccuracy, 准确度' `! z$ `6 f+ S$ U# n- p
Actual frequency, 实际频数
' j0 B+ V$ O- E! T( N( Z7 qAdaptive estimator, 自适应估计量
: k5 |/ f% g1 F/ p( b0 w0 J" kAddition, 相加
% G4 x( t: g4 O/ u. q! ~8 TAddition theorem, 加法定理
9 q/ f2 s5 ^: Y N/ v3 E* V4 gAdditivity, 可加性' l3 _! { g0 [3 L& j6 i8 c
Adjusted rate, 调整率
9 k4 j& e4 ]* a4 F5 j5 [9 tAdjusted value, 校正值8 [/ |- \6 N+ d4 L; C* |) w* ?! w
Admissible error, 容许误差
, {% H: Y( s XAggregation, 聚集性
+ t! _; l$ i {- ?5 cAlternative hypothesis, 备择假设" }0 q. y/ h4 t& _& _
Among groups, 组间
% p% H" g' E8 u/ fAmounts, 总量
$ ]; ?! E2 d( }2 b( R5 {3 b2 hAnalysis of correlation, 相关分析+ A3 s( B, ^2 l, E# h
Analysis of covariance, 协方差分析
$ g; Q! |/ _2 l# k) u7 MAnalysis of regression, 回归分析- X$ k9 M& ~# n! ], h
Analysis of time series, 时间序列分析
7 U$ ^$ L1 H" {6 C, ?Analysis of variance, 方差分析
' Z5 P& D, s! l/ b5 F1 D: |Angular transformation, 角转换* p+ b7 |# Z4 y, d5 H
ANOVA (analysis of variance), 方差分析
9 p" y% ]9 p2 u# Q- A' CANOVA Models, 方差分析模型
4 e4 ~0 a# W4 k9 ^Arcing, 弧/弧旋 ]1 m+ M4 \) g% \% n
Arcsine transformation, 反正弦变换
5 z) N; k' Y8 k# z4 x9 iArea under the curve, 曲线面积
* o1 [3 b! T# L' lAREG , 评估从一个时间点到下一个时间点回归相关时的误差
& M x& [$ L v* ?9 G7 ]ARIMA, 季节和非季节性单变量模型的极大似然估计
* S( y6 X8 h M! _" o' i& c6 {; K% `Arithmetic grid paper, 算术格纸
5 g1 M6 A8 B: O9 z8 O' m7 tArithmetic mean, 算术平均数" f+ u% J; O- h7 x9 o
Arrhenius relation, 艾恩尼斯关系
/ K7 X k+ B% l! D- w( mAssessing fit, 拟合的评估
0 F' w' B) ]. O0 o8 B4 cAssociative laws, 结合律
) B4 B9 f& v @: BAsymmetric distribution, 非对称分布
4 D/ a6 z: h- yAsymptotic bias, 渐近偏倚. h4 N/ b1 Q/ L2 M& [
Asymptotic efficiency, 渐近效率1 Y: a) P! z% J: }& b5 [
Asymptotic variance, 渐近方差
( Q- ]$ h% U6 `# l7 g* iAttributable risk, 归因危险度# V! h0 ^( f: l9 I$ _
Attribute data, 属性资料
3 p1 H$ j8 w2 g U' }1 U& ]Attribution, 属性, E4 P4 B! P% F
Autocorrelation, 自相关
, n( m5 g& A! W( aAutocorrelation of residuals, 残差的自相关
2 g9 L; L4 a4 @Average, 平均数* a% o5 Z0 n$ s
Average confidence interval length, 平均置信区间长度/ z4 Y- I6 z4 A' I1 U4 u
Average growth rate, 平均增长率5 d$ p" T- a, R( e: \* g
Bar chart, 条形图8 z# S1 q- j" o! X. @1 b! V
Bar graph, 条形图
5 Z/ l# |$ v) ^" C# ]3 f+ r" U0 S' wBase period, 基期; a3 x: f! T( S$ p( l
Bayes' theorem , Bayes定理1 J5 N: p! D( I+ V4 \/ ^- X. B
Bell-shaped curve, 钟形曲线
g# d1 F; r; zBernoulli distribution, 伯努力分布
% e, ~2 l( H* r C" c# WBest-trim estimator, 最好切尾估计量
# t, K" Q* r6 @ a6 fBias, 偏性
! h# x3 @4 @+ U( ?$ P# I) C mBinary logistic regression, 二元逻辑斯蒂回归( Q" \" s1 q/ |- a
Binomial distribution, 二项分布) I1 r4 `- A1 X
Bisquare, 双平方
, L4 h4 r; p% ]4 z2 mBivariate Correlate, 二变量相关; O# o3 k7 h/ A
Bivariate normal distribution, 双变量正态分布% N. c- w; }# \8 o. m
Bivariate normal population, 双变量正态总体( H; |" d( n+ v" G6 i
Biweight interval, 双权区间
; R& _' G( J( w3 _; o6 u7 M4 dBiweight M-estimator, 双权M估计量# z+ P' k& @. F
Block, 区组/配伍组+ B6 S0 b* ~" `
BMDP(Biomedical computer programs), BMDP统计软件包' }, I1 }4 t* V+ {
Boxplots, 箱线图/箱尾图
. c% f! I X9 D; @1 U( b( {Breakdown bound, 崩溃界/崩溃点
) S$ X2 h" n6 }7 j( \Canonical correlation, 典型相关
/ o4 H3 \4 c% @) h! c' F5 kCaption, 纵标目
+ V4 x) \4 n5 _9 O6 b* ]( hCase-control study, 病例对照研究
. |) b8 N r: N4 L& _Categorical variable, 分类变量
4 y: B7 M& `/ W5 q: `Catenary, 悬链线: z. ~6 \9 E2 x0 }; b7 r; T
Cauchy distribution, 柯西分布9 b0 l' O- l; h* J0 @
Cause-and-effect relationship, 因果关系
: l# g; ], F7 F; _+ T' b0 S/ fCell, 单元
( i! @! Q/ ~( ]6 W: cCensoring, 终检8 G4 \: ^# D. \2 u& N3 D
Center of symmetry, 对称中心
% {" U% x# H6 J) w( q$ n- \' cCentering and scaling, 中心化和定标4 H8 m8 I% |+ L$ ^
Central tendency, 集中趋势+ @8 c1 M9 P: a- ^
Central value, 中心值
$ g/ q7 d/ o$ {. a1 \+ d3 i. QCHAID -χ2 Automatic Interaction Detector, 卡方自动交互检测
D S2 J9 y* F& vChance, 机遇
( B" W# b3 |3 vChance error, 随机误差
9 A3 F/ Q' W6 t5 N0 h' S) [+ bChance variable, 随机变量7 n j$ |3 \6 _8 p% z
Characteristic equation, 特征方程
! ?2 w5 o; X8 D7 q8 j" }Characteristic root, 特征根
7 c' l$ Z! P( G3 H2 C7 ~Characteristic vector, 特征向量# X: F6 ?) N5 U/ w
Chebshev criterion of fit, 拟合的切比雪夫准则
9 T' Z5 K1 g! a6 ~, ~Chernoff faces, 切尔诺夫脸谱图( `2 Q6 f& I# u8 a* w/ d$ P
Chi-square test, 卡方检验/χ2检验% C4 |1 e. M7 h8 Z* V( W9 i) v* i
Choleskey decomposition, 乔洛斯基分解
4 `6 o) v4 y% iCircle chart, 圆图
# r# W4 K# y! o: f# N/ _Class interval, 组距0 l0 \% R- y7 o( u1 W- A
Class mid-value, 组中值
9 f" n+ A( P( K7 A5 r9 q& I1 ^Class upper limit, 组上限1 I6 s3 ~7 |0 R2 t
Classified variable, 分类变量6 P7 A3 R/ c, o, |1 ], q2 |; E1 N
Cluster analysis, 聚类分析
. t1 d" d: `/ A# ~& U! }* B# \* wCluster sampling, 整群抽样) S( w6 z$ k y3 t$ g& I' P
Code, 代码1 h2 t5 [) ?: F% f$ Y- V( _
Coded data, 编码数据
" b6 o( t1 U6 ]/ M. VCoding, 编码7 ^3 ?3 i1 c) F8 p r8 p. L$ D @
Coefficient of contingency, 列联系数
" ?$ ?/ F; [5 ^- n& Y( g0 X5 XCoefficient of determination, 决定系数* R4 K/ d7 Y& L% v @
Coefficient of multiple correlation, 多重相关系数. A2 d4 {, e b8 F
Coefficient of partial correlation, 偏相关系数7 T6 f) w' a. _4 L: S
Coefficient of production-moment correlation, 积差相关系数
3 T ^9 n' Z3 W2 L1 m0 jCoefficient of rank correlation, 等级相关系数 Z# P. [: J1 n; h
Coefficient of regression, 回归系数
* c& b9 ]. Y0 [! BCoefficient of skewness, 偏度系数
1 n8 H. v8 \1 m; R" b4 t8 ~4 k4 d6 KCoefficient of variation, 变异系数
- P4 d4 r$ S0 J" V, TCohort study, 队列研究
' A" D. Z$ |- T8 T4 \Column, 列
6 e) O9 ~: a! p3 o% g" I' M" S# \Column effect, 列效应" ^" }0 l( {! w$ u
Column factor, 列因素
- p- f1 V) i" I. D TCombination pool, 合并( U4 l6 ^- |6 R/ L0 s
Combinative table, 组合表
6 h, ^. l) s! D K+ c( `Common factor, 共性因子" q" t& \ n; U" H) H" D
Common regression coefficient, 公共回归系数# l- A, {. a: q( m8 Y0 d- x; p
Common value, 共同值
6 ]% A0 ~1 f9 J" OCommon variance, 公共方差
7 \6 H0 K7 t8 ICommon variation, 公共变异: H3 j. Y" n( v' S# n/ {: Y+ A
Communality variance, 共性方差3 a1 I) H7 T4 | a% G; p
Comparability, 可比性3 d: D; O& f' l. I/ s' F" A, o
Comparison of bathes, 批比较
+ v: `0 A: ~$ {Comparison value, 比较值
8 H- I' f2 B) N3 FCompartment model, 分部模型
# k, C. v* U: Y N `8 `% MCompassion, 伸缩9 C9 C. j8 W( z4 A( H
Complement of an event, 补事件
) S/ p$ G8 O6 MComplete association, 完全正相关; r2 ]; Z) j( B) _- } J4 Y/ [
Complete dissociation, 完全不相关/ @/ I' M4 G/ B
Complete statistics, 完备统计量
- t" |8 s, h' O4 e- ECompletely randomized design, 完全随机化设计4 u0 ?5 L+ o/ X, n8 t
Composite event, 联合事件
8 t) |0 P, Q% e6 mComposite events, 复合事件7 G: U' b( G9 P) |* j# ]
Concavity, 凹性) G' q4 c' ^- F, g
Conditional expectation, 条件期望
/ r' T1 p4 e; c: V' k9 `Conditional likelihood, 条件似然* C6 U" @6 ]+ U7 W
Conditional probability, 条件概率( F& |# Q% o( E) k
Conditionally linear, 依条件线性7 E2 `" I, g6 Z
Confidence interval, 置信区间
9 r' O4 q! o @2 F) oConfidence limit, 置信限" h+ I7 G$ ?0 [( {
Confidence lower limit, 置信下限
( ?( x3 B! _3 W5 B/ H* gConfidence upper limit, 置信上限0 A" E2 u6 ? Q. W/ O
Confirmatory Factor Analysis , 验证性因子分析
8 g+ a. @0 y6 X T2 BConfirmatory research, 证实性实验研究; |0 p% M* I* T y
Confounding factor, 混杂因素
9 S$ _/ Y2 Q7 D% K7 jConjoint, 联合分析
" z7 |9 U" [0 B( Z5 cConsistency, 相合性
, \2 M) N1 \: T3 w0 B' }, r6 z, |Consistency check, 一致性检验$ s7 e, m7 h. O7 b6 W
Consistent asymptotically normal estimate, 相合渐近正态估计# @6 Y- {$ X; i d/ ?6 K& i
Consistent estimate, 相合估计, E, _+ W# Y% u: j! s' S
Constrained nonlinear regression, 受约束非线性回归. H1 Y. |1 e, x/ v8 l0 w% E8 `
Constraint, 约束! |8 B6 ^9 d% r) p
Contaminated distribution, 污染分布! I$ Y' c/ C, Q( g/ H% O" x1 H
Contaminated Gausssian, 污染高斯分布
/ S. @7 U# _5 ?9 l9 jContaminated normal distribution, 污染正态分布
' @3 Z# J" e L) P. e) qContamination, 污染# Y* ^$ Z& y4 L" {0 s
Contamination model, 污染模型
" k& h' y% z6 V. B4 a4 aContingency table, 列联表
, p* U* D9 q$ W OContour, 边界线3 A( D1 R9 e3 o
Contribution rate, 贡献率
& \! ^2 U9 o N8 [/ E* L9 OControl, 对照& a, G$ i* b1 k, ` l+ X
Controlled experiments, 对照实验
* n. X/ w% q6 L6 ~6 Z. S0 g3 H/ s bConventional depth, 常规深度' G, U& y4 H Q, ~. ]
Convolution, 卷积
2 H, G+ j2 G: J$ `# ^8 H8 QCorrected factor, 校正因子
8 @; F4 u4 q) n# I4 p$ m6 tCorrected mean, 校正均值
9 Q1 i! [' A4 I& K& y! n: gCorrection coefficient, 校正系数 h7 v0 J0 V& o" \! K" J
Correctness, 正确性
5 m i. }! p0 i7 W9 c! N( b/ yCorrelation coefficient, 相关系数
+ r9 t8 h0 _. K! b" `5 r3 zCorrelation index, 相关指数
2 P6 l4 @ P% M5 L+ JCorrespondence, 对应
$ i* H5 D1 j+ ^, k T7 ~Counting, 计数
9 A# `/ ]6 a/ D3 R- M; LCounts, 计数/频数
# C& h) u: x8 R& C3 b9 MCovariance, 协方差7 [/ t! E4 | @: o: ~" U
Covariant, 共变 - K P6 Y$ c+ u, K9 r0 U. }. L; p
Cox Regression, Cox回归; R4 b0 p6 k) R3 u8 I
Criteria for fitting, 拟合准则$ a& y }7 E$ h2 \
Criteria of least squares, 最小二乘准则
& y8 @, l, _* {2 u% f) J7 h2 t M/ UCritical ratio, 临界比. I% a; Q- I3 R* R+ R! S
Critical region, 拒绝域
6 q0 b( O. h [0 E0 |Critical value, 临界值: L: ~7 r$ |7 G, U& P" W" E$ v p
Cross-over design, 交叉设计# a3 V4 l. r- [+ U5 b; ?5 T4 M
Cross-section analysis, 横断面分析
5 D' r3 m E+ LCross-section survey, 横断面调查/ O, a" H R9 C8 F! l
Crosstabs , 交叉表
4 T! u9 a, `& _0 [6 I, C/ Q) yCross-tabulation table, 复合表
2 C% o. ]) V- P7 W" \Cube root, 立方根
# k) d$ S7 J5 P7 k3 q2 M6 MCumulative distribution function, 分布函数+ A# z) P0 H' [
Cumulative probability, 累计概率8 P5 J4 N; T# b: j/ z
Curvature, 曲率/弯曲
B, \; {" ~" t% ~' j, h; g3 ZCurvature, 曲率4 l# i( r- S- x$ i2 t7 @0 w7 M
Curve fit , 曲线拟和
2 D$ E# {- N7 [7 pCurve fitting, 曲线拟合
( ~; y9 B: T: l: V8 r$ a: x D3 VCurvilinear regression, 曲线回归
9 L: s: g' r4 K) F' s2 \$ OCurvilinear relation, 曲线关系
' m9 R: K* r0 g, f9 h2 s5 O: lCut-and-try method, 尝试法
$ G5 F+ H% P" g; h2 m2 d" ?Cycle, 周期1 [7 T, ?+ n- N* M
Cyclist, 周期性
& U- a' d# a. Q$ t$ \9 i0 CD test, D检验
8 y1 o9 r. Y) f" V& dData acquisition, 资料收集
' R; g" E M5 }9 L7 J' a8 xData bank, 数据库
, t/ l5 G$ G$ j1 ?3 A: ]1 tData capacity, 数据容量/ y2 D; l% T8 Z9 a6 E& t" d( o: @
Data deficiencies, 数据缺乏
s5 z7 d& G$ g3 V+ hData handling, 数据处理
% D7 r5 G+ J" U" J9 @Data manipulation, 数据处理( }% k8 x7 G7 J6 B4 Q; i l- o
Data processing, 数据处理
/ x& ]0 a4 R9 N0 p5 `Data reduction, 数据缩减( }+ h) ~& K. O# b% e P4 U* p
Data set, 数据集8 y8 t5 E7 S# ~! J+ [
Data sources, 数据来源+ ?# L) x! @- g# o
Data transformation, 数据变换, q! b- L3 A, N+ _8 m- J- ?% f$ c
Data validity, 数据有效性
# t) N! Z9 e0 Z+ kData-in, 数据输入' H4 A1 N! T# w4 e$ o" b6 J0 ^
Data-out, 数据输出( P# f" c0 s: w" G
Dead time, 停滞期
$ g7 _6 Y5 V; B( pDegree of freedom, 自由度
3 T9 ?0 _- q- _% A/ A2 x( i" CDegree of precision, 精密度
' a4 C$ }0 A9 b0 ]1 qDegree of reliability, 可靠性程度7 `* O# i/ z6 Y& y' n, R7 a
Degression, 递减
+ L4 _+ o1 `' t! v& {4 {( gDensity function, 密度函数
& e6 o0 E; a: FDensity of data points, 数据点的密度
* [! P$ I* @' R1 A+ L4 ~8 SDependent variable, 应变量/依变量/因变量
1 }: D7 M' F+ n: j. L% d5 yDependent variable, 因变量2 e5 Z% f+ U8 l" c* B3 H8 L2 u
Depth, 深度; P6 m; I1 q! S3 o8 x
Derivative matrix, 导数矩阵4 i! i) s5 i: y, E: t7 E/ B
Derivative-free methods, 无导数方法
/ P$ Q6 n: P/ ~/ z% k, Q- IDesign, 设计 h* Y" X5 P7 S3 m2 m0 a r
Determinacy, 确定性6 w& M$ c/ C3 G8 ^; D
Determinant, 行列式
" ?! j6 B* B5 g9 }Determinant, 决定因素
, T5 f. @1 O/ e! L- k$ JDeviation, 离差- | C8 r" W' S b
Deviation from average, 离均差8 }; U9 @4 J B' m% e
Diagnostic plot, 诊断图
, z7 `6 Y1 v2 nDichotomous variable, 二分变量
& U' T' }' ? `Differential equation, 微分方程2 U4 G b0 R( d2 E4 W
Direct standardization, 直接标准化法
8 F6 J% V K6 `7 P4 i( J3 @Discrete variable, 离散型变量4 R' A( G& w3 K- {
DISCRIMINANT, 判断
1 T l( N! w' DDiscriminant analysis, 判别分析9 K: |, v- O: Q) l# U6 q4 a
Discriminant coefficient, 判别系数
, s9 R, `! p3 G3 wDiscriminant function, 判别值: J- u0 Q2 d6 ^/ Y- W1 y
Dispersion, 散布/分散度. D4 S* n8 v9 ^( ]' D! Z
Disproportional, 不成比例的
( x) o3 c- @( x C8 m$ eDisproportionate sub-class numbers, 不成比例次级组含量
7 U- V6 L8 P9 d" D. M! L* TDistribution free, 分布无关性/免分布
5 ~! m) v* F- c6 ?' R; FDistribution shape, 分布形状
* o/ A2 E( @/ W! z8 C5 z8 V, xDistribution-free method, 任意分布法
8 N2 ?. M& X% C0 L" R7 ODistributive laws, 分配律% X( J9 K% Y+ u* D, _( V
Disturbance, 随机扰动项. R. ]/ v# V* m2 p( G8 o S
Dose response curve, 剂量反应曲线 4 H* J' U9 h [, H. n! A( f2 s
Double blind method, 双盲法/ a4 B$ W) }) f/ h
Double blind trial, 双盲试验
3 p+ @6 P% e$ q0 RDouble exponential distribution, 双指数分布
5 p8 x. _4 x# P9 q- M2 `Double logarithmic, 双对数+ m+ G" g- U S; s/ [0 b$ n
Downward rank, 降秩
3 \1 F$ l% O2 {Dual-space plot, 对偶空间图
9 o" ?4 F1 J* u) QDUD, 无导数方法+ Q& R2 c' r; e
Duncan's new multiple range method, 新复极差法/Duncan新法
