查看: 4134|回复: 0
震雄注塑成型机参数规格表二
发表于 2009-10-29 21:18 | 显示全部楼层 |阅读模式
震雄注塑机规格表
Chen Hson Injecctor Specifications
说明DESCRIPTIONSUNITJM55MKⅢ-C
  Z6 c+ e8 b" i* N
射胶容量Swept Volumecm3664
螺杆直径Screw Diametermm.60
射胶压力Injection Pressurekgf./cm21478
螺杆行程Screw Strokemm.235
螺杆转速Screw Speed RangeR.P.M10-140
熔胶能力Plasticizing Capacitykg/hr.145
料斗容量Hopper Capacityl.70
射嘴行程Nozzle Travel Strokem.m.330
螺杆长度直径比Screw L/D Ratio 20
锁模部分CLAMPING UNIT
锁模力Clamping ForceMp.218
开模行程Opening Strokemm.405
连接柱内距(水平×垂直)Space Between Tie Bars (H×V)mm.×mm.510×460
容模量(最薄-最厚)Mould Thickness (Min-Max)mm.225-500
模板最大距离Maximum Daylightmm.905
油压顶针推力Hydraulic Ejector ForceMp.5.5
油压顶针行程Hydraulic Ejector Strokemm.100
定位法兰直径Mould Register Hole (H7)mm.120
动力/电热POWER/HEATING
0 V1 e$ a& n1 \/ d& F* J9 r
油泵马力Pump MotorKW.(HP)22.5(30)
电热量Heating CapacityKW.19
系统压力System Pressurekfg./cm2175
温度控制区No. of Temp. Control Zones 3+1
其它OTHERS
循环时间Dry Cycle Timesec.1.8
占地面积Floor Spacem.×m.5.42×1.13
装箱尺寸Shipping Dimensionm.×m.×m.5.4×1.3×1.7
油缸容量Oil Tank Capacityl.450
机重Machine Weight (Dry)ton.5.6
说明DESCRIPTIONSUNITJM268MKⅢ-C
射胶部分INJECTION UNIT
射胶量(硬胶)Shot Weight (PS)oz.28
  gm.795
射胶容量Swept Volumecm3888
螺杆直径Screw Diametermm.67
射胶压力Injection Pressurekgf./cm21550
螺杆行程Screw Strokemm.240
螺杆转速Screw Speed RangeR.P.M0-120
熔胶能力Plasticizing Capacitykg/hr.125
料斗容量Hopper Capacityl.64
射嘴行程Nozzle Travel Strokem.m.410
锁模部分CLAMPING UNIT
锁模力Clamping ForceMp.268
开模行程Opening Strokemm.505
连接柱内距(水平×垂直)Space Between Tie Bars (H×V)mm.×mm.560×560
容模量(最薄-最厚)Mould Thickness (Min-Max)mm.200-640
模板最大距离Maximum Daylightmm.1145
油压顶针推力Hydraulic Ejector ForceMp.7
油压顶针行程Hydraulic Ejector Strokemm.125
动力/电热POWER/HEATING
6 B# l: `. s! G0 x7 T" I. e4 i* ~
油泵马力Pump MotorKW.(HP)30(40)
电热量Heating CapacityKW.18
系统压力System Pressurekfg./cm2145
温度控制区No. of Temp. Control Zones 4+1
其它OTHERS
循环时间Dry Cycle Timesec.2.2
占地面积Floor Spacem.×m.6.4×1.5
装箱尺寸Shipping Dimensionm.×m.×m.6.53×1.7×2.2
油缸容量Oil Tank Capacityl.500
机重Machine Weight (Dry)ton.9.5
说明DESCRIPTIONSUNITJM368MKⅢ-C
射胶部分INJECTION UNIT
射胶量(硬胶)Shot Weight (PS)oz.39
  gm.1108
射胶容量Swept Volumecm31237
螺杆直径Screw Diametermm.75
射胶压力Injection Pressurekgf./cm21583
螺杆行程Screw Strokemm.280
熔胶能力Plasticizing Capacitykg/hr.220
料斗容量Hopper Capacityl.100
射嘴行程Nozzle Travel Strokem.m.460
螺杆长度直径比Screw L/D Ratio 18.5
锁模部分CLAMPING UNIT
锁模力Clamping ForceMp.368
开模行程Opening Strokemm.660
连接柱内距(水平×垂直)Space Between Tie Bars (H×V)mm.×mm.700×700
容模量(最薄-最厚)Mould Thickness (Min-Max)mm.260-700
模板最大距离Maximum Daylightmm.1360
油压顶针推力Hydraulic Ejector ForceMp.7.8
油压顶针行程Hydraulic Ejector Strokemm.150
定位法兰直径Mould Register Hole (H7)mm.150
动力/电热POWER/HEATING: Q2 }  }& j  |
油泵马力Pump MotorKW.(HP)37.5(50)
电热量Heating CapacityKW.20
其它OTHERS
循环时间Dry Cycle Timesec.2.8
占地面积Floor Spacem.×m.7.5×1.7
装箱尺寸Shipping Dimensionm.×m.×m.7.65×1.9×2.3
油缸容量Oil Tank Capacityl.700
机重Machine Weight (Dry)ton.14
说明DESCRIPTIONSUNITJM468MKⅢ-C
射胶部分INJECTION UNIT
射胶量(硬胶)Shot Weight (PS)oz.55
GMT+8, 2025-5-26 13:12 , Processed in 0.139460 second(s), 25 queries .
