4 Z N, l# T& z* d% z4 |
b) C( Y/ r, h1 f1.With the FEM displayed, choose Tools→Materials→Manage Materials (Create).! t: s$ q7 P: w: Y
5 v, v1 c! G! K! e0 k9 ] T2.In the Material List group, select Local Materials.
; e7 s7 o( ^4 P# U* d) i. y* b* H9 L& I- k' w
3.In the New Material group, select the material type from the Type list.
4 I) w! [6 d1 c/ ~2 X* s' P! b
- G- ^6 t( V% u' b4.Click Create Material .
' k& j O+ } J
% ^' A. m2 B3 G0 {- V( r" ^- ]5.In the materials dialog box, enter a Name for the material.
3 J3 B: u7 r8 Y+ d! E/ P8 c
6 b$ G( j9 H3 o# o8 @2 S3 I4 C* xNote; t3 v3 \% _# g2 m9 Z9 n
Do not use a name that is the same as a library material. With assemblies, it is possible for two material records to use the same name if one is a library material and the other is a local material, or the two records are of different categories or material types. This situation can cause problems and should be avoided by using unique record names.
5 @2 d. F' S! N7 L9 F
) y; h6 G9 R) s4 ?& b$ M& O
9 t- c; ^4 ^( e" P) L6.Enter values for material properties. # S, H0 t0 \& X7 N3 y/ k8 Y
& _( F. s! D: x( n0 d2 a
Select one of the following:
! G9 f) C: y( k, \8 p4 {) `8 }/ v& `( K4 P7 g C3 @5 N
◦Expression to use a constant value or NX expression to define the property values.
. k6 u6 I+ G h9 E. [$ U
$ O$ F% z% R! s1 @0 R$ g7 PFor more information, see Expressions overview.
$ ^, w$ e2 K+ D7 f& g
- r& q6 W+ o/ Y◦Field to define varying values for material properties.
5 J+ f5 m9 H: N3 m. y9 ^& q4 b, I* \ R% N# @
For an example of how to do this, see Define a material with stress/strain data. 3 v: A- I* g! w8 b$ G
, r) ^, |+ v! y0 E; r, s; vFor information about properties for specific material types, see the list of links in the Material dialog box topic.
6 _- C6 B4 t# a1 e$ h8 b; ]' t6 |9 \$ o0 N" g7 }" e1 \
7.Click OK.
. i; P7 C, S0 F' l7 J9 w/ P0 _% |6 j+ L
The new material appears in the Materials list.) R& n1 W' }% f1 I4 M- s
# @( e8 K; R. S8.Click Cancel to close the dialog box.! [3 N* _/ x* R0 _+ A* F4 C, T
" S& }2 {; l& f
Note
2 p) L+ ^7 M1 R; ^The new material is saved directly in the current FEM. To add this material to a custom material library, see Add a new material definition to a custom library.1 y$ e% A) \6 ^: D* w p4 Q
5 i+ R! G. u& u2 \2 P( a% A |
评分
查看全部评分
