查看: 3026|回复: 2
[讨论] NX自带实例File2Points
发表于 2010-11-25 11:50 | 显示全部楼层 |阅读模式
  1. /*=============================================================================4 L( p: }" ?9 W
  2. Copyright (c) 2004 ugS Corp.
    2 G; ^7 Z  ^* C6 k' q3 D1 i/ b3 |% C% F( A
  3. All rights reserved
    4 [- Q0 I! K6 b  J
  4. ===============================================================================
    . s" s- u  p: q7 B8 O- m  N
  5. File2Points.cpp
    7 m0 h7 x& A" L7 Q
  6. 2 {/ \, `/ P( l1 f6 H+ k' j" \
  7. Description: Contains Unigraphics entry points for the application.
    5 F; Y- {' d- A& x, t
  8. / F5 k. D5 h4 i% A8 h! a( H
  9. 9 o2 j/ R1 q" d9 k/ @% \
  10. =============================================================================*/
    - z, g; d: h5 R+ I% k
  11. ; U! z) i* G# d4 c/ Q  S
  12. #ifdef WIN32/ h: w$ p" i* B. M% h/ o& g
  13. #define USE_MFC
    ; C) o* Z* o3 U
  14. #endif
    3 |! g% j  J& V/ R$ w3 S; E' M
  15. $ W( Y0 B; x  L3 G2 a4 U3 y
  16. #ifdef USE_MFC
      y8 c) N" J* b4 I& w
  17. #include <afxdlgs.h>
    # E4 i, J* z+ n1 J' m0 Q
  18. #include <afx.h>
    9 w) A0 |3 Z! F
  19. #endif" \9 o9 h- j  a- W( M
  20. - e3 r; J2 N$ Y% Z# H3 i- L
  21. #include <NXOpen/Session.hxx>$ A3 Y: c7 ~4 C- B9 |
  22. #include <NXOpen/Part.hxx>/ d! ?/ }6 _) X( ~% k
  23. #include <NXOpen/PartCollection.hxx>0 g7 S( [. _4 |* U  Y
  24. #include <NXOpen/Point.hxx>
    ! Y0 n& f1 ~* H8 x; K
  25. #include <NXOpen/PointCollection.hxx>  n; l7 m5 z8 u6 q6 X4 C* j  r( v
  26. * c) D( |* a7 P3 A0 ?
  27. #include <fstream>
    0 A( ]/ }- J. l3 \& F, J
  28. 4 s- Z: P7 ^' N/ y
  29. using namespace NXOpen;
    0 s" z5 i% D5 U, a. n8 S3 }4 s4 |
  30. using namespace std;
    ; L6 ], b3 v3 _# A+ N
  31. 2 O. o. u4 k9 `
  32. /* Include files */4 A! B" C2 y4 N! {) E
  33. #if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
    8 x* }' \( d# H, w
  34. # include <strstream>
    2 v% x  R: i- n6 v/ v
  35. # include <iostream>/ c# n' b" R! H% P4 X& I
  36. using std::ostrstream;
    $ `6 Q0 f* w* v) V
  37. using std::endl; ; j4 |5 B! o$ {& [
  38. using std::ends;% R3 m5 D+ J& D  D
  39. using std::cerr;
    # B, F# Q6 p. S3 i& z& X: h
  40. #else
    ( ^( i- g1 q0 {& D6 v- @; C* m
  41. # include <strstream.h>0 b) K% l7 e0 A, ^, g& e# F
  42. # include <iostream.h>. Z+ r1 I* H; M- Z0 ]2 N9 X7 ?
  43. #endif
    # I* Z3 t8 f5 ^/ D7 G$ j$ i9 q
  44. #include <uf.h>7 a; C3 y* r2 H
  45. #include <uf_ui.h>5 P: d- Z5 b+ Y3 o, C0 R) B8 j
  46. #include <uf_exit.h># B) \% t- C, V6 n/ w4 \7 M
  47. #include <uf.h>/ f$ H7 P6 n: ~3 `9 n
  48. #include <uf_exit.h>5 Y$ X& d+ X0 R9 u0 u3 w
  49. #include <uf_ui.h>
    / h& r2 ~" S: R% g- \, J8 \
  50. #if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
    ) m0 e2 K1 \- @6 Y% J: e
  51. # include <strstream>
    4 e! x8 Z- {+ U9 _
  52. # include <iostream>: l" E' R( r% v% I' f" h+ V4 W& ~& j
  53. using std::ostrstream;2 v( {, h) s+ v: _% O7 A! g
  54. using std::endl;
    " N/ q3 [! B. R
  55. using std::ends;9 f$ q8 o9 O# I# s* O5 k
  56. using std::cerr;
    * k" {; W+ \- r3 p7 ^3 B. e# G
  57. #else
    4 I, M" S7 s# T: P; i
  58. # include <strstream.h>& S3 o, K: m( V/ Q
  59. # include <iostream.h>
    % O( ~! D8 ?$ y1 I; |. }
  60. #endif
    * z7 M; i& A) A# \" w+ o3 b% t0 }' r9 T
  61. static void PrintErrorMessage( int errorCode );0 q2 N; E* Q. W/ G2 p1 ~
  62. static void PrintErrorMessage( const char* );
      p3 n9 g6 x6 W8 M/ N3 y
  63. 0 e: o, P8 o9 S; q+ b! ~" r7 \- D: v
  64. static int create_filebox( char* prompt, char* filename )' C; [8 ]4 a! |0 v& A2 |
  65. {! i; K8 X/ y: w, @( P
  66. // We could have used UF_UI_create_filebox on both Windows and Unix.
    + v1 @7 J2 P$ _( H6 N  V
  67. // The ONLY reason that we use MFC instead of UF_UI_create_filebox on Windows
    0 Q* N* S& i, A/ v/ D( _4 [) |, l2 h
  68. // is for the purpose of demonstrating how MFC can be used inside an NX Open application.
    . f2 x: r- z  s3 U8 A3 l
  69. #ifdef USE_MFC# V% G' U* q8 _% a3 D
  70. char Filters[]= "txt files (*.txt)|*.txt|All files (*.*)|*.*||";5 y/ Z) [" W' R" B
  71. / ?5 f! W# R. V4 E. c$ L$ C$ q
  72. // Create an Open dialog; the default file name extension is ".my".3 p2 ~! u& n; V2 w
  73. CFileDialog fileDialog (TRUE, NULL, NULL, OFN_FILEMUSTEXIST | OFN_HIDEREADONLY, Filters);" V5 a4 {% n5 }. x# ~, n* T% |
  74. . B3 B9 _6 V0 n0 \- ]! m0 _
  75. UF_UI_set_prompt( prompt );
    5 i# i* c3 C- m% ^' r* h6 ]4 w
  76. int response = fileDialog.DoModal();
    7 `( ^' J! p1 A" r- R
  77. 4 k  O' c- j- i0 E, ~- V( h1 S
  78. if ( response == IDOK)" h8 ?% y2 Z! @( S7 y
  79. {& W8 l5 s' f; z9 i) O, O2 O
  80. strncpy_s( filename,UF_CFI_MAX_PATH_NAME_SIZE - 1, fileDialog.GetPathName(), UF_CFI_MAX_PATH_NAME_SIZE - 1 );1 ]: [7 q* p7 v9 j
  81. filename[UF_CFI_MAX_PATH_NAME_SIZE-1] = '\0';
    ( |# s  @$ X; {" n5 q- Z3 J
  82. }
    8 p4 ^+ k* j) ~% v
  83. return response == IDOK ? UF_UI_OK : UF_UI_CANCEL;# l, d  y) y9 b* O
  84. #else ) D: \( R: J6 n: @( X8 A
  85. int response;* N$ J6 @; Y  F3 [  {
  86. char filter[UF_CFI_MAX_PATH_NAME_SIZE] = "*.txt";& P- p1 ?. e$ K' e# ^  C
  87. UF_UI_create_filebox( prompt,
    5 M1 l2 [8 P' h# z, T
  88. "Select point data file",* j- K# s  `" b2 n' v5 M
  89. filter, NULL,
    * L- R: R. P/ \0 n8 R" f' m
  90. filename, &response );: M8 x  D% E- T- X, p) ^4 H3 w
  91. return response;
    0 G. A: r$ t  ^7 S
  92. #endif, d7 o# l% r- `4 s: d  V4 p1 ~- A+ _
  93. }( M0 \& j9 U9 @: p
  94. * {, z7 k, v" y2 k' l
  95. /*****************************************************************************; x0 w& r: y3 {0 R
  96. ** Activation Methods
    ' V" x+ v" ]$ L3 d
  97. *****************************************************************************/, w3 r3 B. M3 d. u
  98. /* Explicit Activation( k7 g0 n: z: R, j
  99. ** This entry point is used to activate the application explicitly, as in
    ) ~2 c. K' r* T; e1 P  @
  100. ** "File->Execute UG/Open->User Function..." */$ q. j# f  N$ u+ _; H# i5 C8 o
  101. extern DllExport void ufusr( char *parm, int *returnCode, int rlen )
    ; U# e; e- J2 l8 J2 j9 \" \
  102. {* }5 l0 i$ o" v. k- `0 U
  103. /* Initialize the API environment */5 o. B' p3 v! S' ~9 ^; A  M
  104. int errorCode = UF_initialize();6 Y$ o- }5 |) |8 X" A
  105. " M7 H  h. b4 s4 D" [/ x- s/ R8 s
  106. Session *theSession = Session::GetSession();
    3 B" p0 n$ C2 k! O
  107. 3 ?! R. H6 S# B" C4 c8 ?3 b; `- t
  108. Part *workPart = theSession->Parts()->Work();- g* y: v$ S7 _- J% x$ Y
  109. if ( workPart == NULL )
    ( |# Y7 n9 _- u) \, x1 ^5 M3 e: x8 H
  110. workPart = theSession->Parts()->NewDisplay("File2Points", Part::UnitsMillimeters);1 ]- W; _4 t8 \7 D, S: o) y
  111.   _. [- Q3 u, s& O2 I4 k
  112. char fileName[UF_CFI_MAX_PATH_NAME_SIZE];
    . N1 [4 h( j: G3 I2 c7 {4 W- D$ Z
  113. if ( create_filebox( "Select file that contains the point coordinate data", fileName ) == UF_UI_OK )
    ' N! X% a& _: e
  114. { : F  e2 B5 I' ^$ w) X. L
  115. ifstream file1;: V' C9 w9 }  y7 {( |" K/ I9 I
  116. / Z, G* }0 C# a) S
  117. file1.open(fileName);
    9 J* U0 o# s8 |: Q+ i" u  _
  118. % h7 z; N$ M3 a! i* Q$ O" B
  119. if ( !file1.is_open() )
    8 n9 V, U( [) s& p* O+ R
  120. PrintErrorMessage( "Could not open file\n" );( n" d7 D% t) B8 b8 R2 y
  121. else" u. @; w3 C+ B' `0 {- t
  122. {* [/ G6 I) c- a* R
  123. double x,y,z;! p! c# H- u( j  Q3 @7 t' n& r
  124. char c;
    6 c- I) F4 F9 @
  125. while(!file1.eof())
    2 V% R4 ^: y4 n& f# h
  126. {1 ]) e  X% j" z6 r3 Y$ V) Y1 M
  127. file1 >> x >> c >> y >> c >> z;8 O! j- m7 ?, X* t2 C
  128. if(!file1)5 ?  d- {4 s( n, _
  129. {. y( d  }; D, S2 A+ m
  130. PrintErrorMessage("File format error:\n The input file does not have the expected format\n");
    5 l. N4 q  K8 x* a+ z
  131. break;+ [1 A0 N" O- g, C  ?
  132. } 5 X2 g" I9 F* C  D8 C1 `9 r
  133. NXOpen::Point3d point3d11(x,y,z);
    $ ?' i" b1 B  y% |" z$ r
  134. Point *point1;3 f: p* n5 s# G5 l4 u  y; G. C' l
  135. point1 = workPart->Points()->CreatePoint(point3d11);8 s; X7 L2 B& G5 `( E
  136. // The point is invisible when initially created
    0 h! P0 J7 V' Z; q. [+ e" h
  137. point1->SetVisibility(NXOpen::SmartObject::VisibilityOptionVisible);
    ( a5 I" X& }! c# r, _* o: Z
  138. + w2 D0 G& I, ^
  139. // Check for end of file5 _+ M' D# [* S5 H: u+ H
  140. file1 >> c;
    7 C# p& {& I4 Q
  141. if ( !file1.eof() )' \% u0 n, V& p2 }5 {! h
  142. file1.unget();
    - ]. V; v  p' L8 P2 g
  143. }5 f8 s3 E5 M+ }( g
  144. file1.close();: i9 {& w% a# t6 Y/ o. Z5 Y
  145. file1.clear();" X- ~0 _% W1 H# x
  146. }
    , u* U: W1 s2 l' e& `6 q- j, r# e: z
  147. % H, Q6 P+ e( N; c8 M+ A& k
  148. /* To save work part using NXOpen automation APIs */
    - N* d4 d3 ~- R+ R( N! ?+ j
  149. /*NXOpen::PartSaveStatus *partSaveStatus;% M0 U" ~' C$ G7 O
  150. part1->Save(NXOpen::Part::SaveComponentsTrue, NXOpen::Part::CloseAfterSaveTrue, &partSaveStatus);*/7 [( B6 `; i% O, `, G3 k3 ?! `0 \
  151. 5 u' f- H7 i2 k
  152. /* Terminate the API environment */% h5 W6 e* W& C
  153. errorCode = UF_terminate();
    % x4 H) I6 b4 ?; J7 E5 r/ W
  154. }
    # k) d, L1 u" z& D. Y
  155. 1 P7 B4 |  z, g& A
  156. /* Print out any error messages */$ F. g' Y4 d: E6 }
  157. PrintErrorMessage( errorCode );
    ! N+ C' v2 J) q6 H3 d  W
  158. }
    $ p/ C7 b5 F4 j3 r
  159. ( W! n# G( f3 V6 ?6 P* l4 Q* N2 z
  160. /*****************************************************************************
    : @/ n( w) y' v+ ^0 ~
  161. ** Utilities+ J3 ?6 O5 T, h) F
  162. *****************************************************************************/6 p" S) y) w: N' Q. i2 F& X+ P9 E+ b
  163. + y- V# o" e1 l- z
  164. /* Unload Handler
    $ s7 Y) }+ @. v1 z$ F: C
  165. ** This function specifies when to unload your application from Unigraphics.3 R# j5 d3 P# W9 @* \
  166. ** If your application registers a callback (from a MenuScript item or a
    & m  x4 r1 @; a9 [8 q. z
  167. ** User Defined Object for example), this function MUST return
    , ^3 w2 w7 D; d# W0 `
  168. ** "UF_UNLOAD_UG_TERMINATE". */
    $ c5 j) c1 l: E: i1 P4 m* F
  169. extern int ufusr_ask_unload( void )
    2 \6 m% D1 a5 v' t( c( |
  170. {$ x4 [/ N/ g( v" h: B5 i. r
  171. return(UF_UNLOAD_IMMEDIATELY);' n# b, [1 r$ f
  172. }4 B+ t5 `. ?- \( u# \" {( E. k8 P! I
  173. /* PrintErrorMessage
    ! O1 w9 T$ P2 f& T
  174. **/ p3 q7 m( I$ b
  175. ** Prints error messages to standard error and the Unigraphics status
    ; j( P% h# g' v6 {5 s: l9 Y
  176. ** line. */3 a; |' [5 W6 |: y$ ]% t+ d
  177. static void PrintErrorMessage( int errorCode )! a: W+ \. T1 H# m
  178. {
    0 m. i3 f2 r( r
  179. if ( 0 != errorCode )
    * a5 S7 J3 _2 ^  ?2 o8 k; `7 n
  180. {
    8 T6 C. g* ]/ Y4 N) _
  181. /* Retrieve the associated error message */
      c( H9 |/ ?3 X. N* ]7 M( v3 e
  182. char message[133];
    8 R) A( y! V% V' K. L
  183. UF_get_fail_message( errorCode, message );6 m- M  g9 A7 D5 q2 }* h! {! T/ [
  184. ( S" h2 D6 q- Q# W* C2 u! W
  185. /* Print out the message */0 _# K1 [* R- n
  186. UF_UI_set_status( message );
      F# s  d: @" E5 B4 k
  187. /* Construct a buffer to hold the text. */6 B9 E( U8 v9 m, j* H5 ?) T! t8 f" y
  188. ostrstream error_message;8 C. }$ K' x9 J, j+ I
  189.   C. g8 i, E6 m: z* W* c+ w
  190. /* Initialize the buffer with the required text. */
    0 K7 x, J) d0 w# ~9 S& g" H
  191. error_message << endl
    6 D1 c* Z  s) X; G/ v! V) e
  192. << "Error:" << endl
    3 `  }9 F8 y4 k% R
  193. << message
    ' k) u6 E/ y+ N2 z
  194. << endl << endl << ends;
    8 F: l, F4 C* x. F
  195. $ w  o* C+ f0 p4 l  s
  196. /* Write the message to standard error */
    ; s2 m6 a& F6 i/ M7 }- ^
  197. PrintErrorMessage(error_message.str());
    7 W  C+ o9 }9 [1 T% W; H1 p
  198. }
    7 @  T4 \, u4 W- u' ?" t
  199. }
    . _: k% B" C8 p) b1 J( s
  200. 4 [3 q6 J/ a& b/ y, p; @; ~; m
  201. static void PrintErrorMessage( const char* msg )
    0 X: ]  R2 ~! l+ J* c2 O
  202. {$ F0 ?( a! o$ F7 k& ]
  203. #ifdef WIN32
    9 f3 }" z5 }) s; O# l
  204. static bool consoleInitialized = false;! y3 }& J2 W0 X' }2 S- P( L
  205. if ( !consoleInitialized )2 M6 _: E+ C, E( ~1 f
  206. {
    3 P, n3 O3 n% i" I: o
  207. AllocConsole();" f8 e# S( B, o) H7 Q! R# Y
  208. FILE *stream;
    8 U- V; u6 f* a3 \7 \
  209. freopen_s(&stream,"conout$", "w", stdout);
    . b. Q0 c( Y) O* t
  210. freopen_s(&stream,"conout$", "w", stderr);- |8 l3 H, }8 m
  211. consoleInitialized = true;
    - z. ?5 Y1 A  U7 R' @6 y
  212. }
    + B( `+ y# E# _0 |9 s. d: x: ~1 I+ X! W% v( ^
  213. #endif
    ( Q% Z6 S, V/ u6 y
  214. cerr << msg;
    & n3 |5 M. X/ p; x6 E- N
  215. }. B) Q$ {' }3 {
复制代码
 楼主| 发表于 2010-11-25 11:50 | 显示全部楼层
代码都不变色
头像被屏蔽
发表于 2010-12-17 05:55 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-7-4 01:46 , Processed in 0.167165 second(s), 25 queries .
