查看: 2234|回复: 3
英语谚语佳句推荐(1)
发表于 2007-7-7 21:47 | 显示全部楼层 |阅读模式
A bad beginning makes a bad ending.. r5 Y! Z* R! _* g# t5 u
  不善始者不善终。
( r3 M6 d1 P! d* z8 \) d2 `. b  A bad thing never dies." t: |3 s# E% _/ c6 q6 e
  遗臭万年。 # F! w- w% n2 [  Y
  A bad workman always blames his tools.
+ `. _: q. p" l3 ?2 N  不会撑船怪河弯。 ; Q: [( l- M5 t9 s7 b# H0 [3 Z
  A bird in the hand is worth than two in the bush.
/ `3 B  L7 H3 c  x3 J: x; O  一鸟在手胜过双鸟在林。 " k& v& j/ Y1 F4 U
  A boaster and a liar are cousins-german.
, H& K; X* `; U5 _  v  吹牛与说谎本是同宗。
2 @: I6 \* |) `( @2 P; q  A bully is always a coward.. t% I7 x! t( s/ r" g
  色厉内荏。 3 F/ Z2 L3 v4 M: \8 y: {
  A burden of one‘s choice is not felt./ b2 N8 n$ U# b) ^% ^) x
  爱挑的担子不嫌重。 # U# S0 s6 P1 k. L
  A candle lights others and consumes itself.
8 a8 _2 [- i# F2 M9 w8 D& K  蜡烛照亮别人,却毁灭了自己。
$ `- N' J( j3 w. b; G1 Y  A cat has 9 lives.' T7 c4 o9 G' n. G# H+ [- u: }/ g
  猫有九条命。
0 V' f: K' I! J, c* r  A cat may look at a king.
, r" h7 r% W6 |( o- m# G/ E# O  人人平等。
; A8 d0 p- \' ^! T  A close mouth catches no flies.6 A, f4 h$ ]7 [+ q# F# f
  病从口入。
+ C. H$ q- W' m* Y  A constant guest is never welcome.
' z4 h1 i1 O; T1 Q, J' g$ x  常客令人厌。
4 z$ D; h- u0 H1 a# x  Actions speak louder than words.0 d4 `1 P# G' X+ j
  事实胜于雄辩。 8 e  ~/ a# t8 l3 f9 ?- z0 L. q" G
  Adversity leads to prosperity.4 ^; s# k. ~; P3 j' [# V4 c
  穷则思变。 7 n& x* O. V  f( J. M+ h6 _9 n
  Adversity makes a man wise, not rich.3 R5 R$ A( J! K; ~( f: _
  逆境出人才。
. a1 Q  M# h. C* H$ J5 J  A fair death honors the whole life.
5 ^# f" @; `8 q3 U- c7 v5 h  死得其所,流芳百世。 , X# v  J, K; ~0 m( _: C6 J( y
  A faithful friend is hard to find.5 e  x5 ]5 N" A3 }* q. {1 i" b
  知音难觅。 " n. i+ K3 U5 p  H1 C
  A fall into a pit, a gain in your wit.& v& d4 T; _5 M: ~5 W
  吃一堑,长一智。 ( d/ b; H- K) K0 t
  A fox may grow gray, but never good.) j5 X/ M, }) w8 Q# B' z
  江山易改,本性难移。 : B6 g6 E5 u4 V2 i
  A friend in need is a friend indeed.( F2 X  d! H2 a
  患难见真情。
- i: [2 U  {- t7 |/ i  A friend is easier lost than found.
- x$ v) e9 Q& A7 g  得朋友难,失朋友易。 0 W/ _( n1 @3 A% p7 D2 V4 t
  A friend is never known till a man has need.. C% A, |" J% E" {
  需要之时方知友。 3 J9 \+ C* u& r. f# M! |/ N# ^
  A friend without faults will never be found.1 ?. K" @% w$ c( y
  没有十全十美的朋友。 7 [  K8 q3 J' D7 |' h9 w" t% L
  ‘After you‘ is good manners.
5 K* T; t! U9 j; t7 @  “您先请”是礼貌。 8 I6 k- k# d  C& S
  A good beginning is half done.
. y3 u' ^& @; i2 O/ |8 G  z- Z  良好的开端是成功的一半。 - f3 ^! r5 j3 f: E+ }8 ]1 A
  A good beginning makes a good ending.
( P5 u; X8 T3 Z, x5 @1 d0 ]7 k" y; ]  善始者善终。
" n# z  E* o& U$ `$ v" Q! X  A good book is a good friend.
4 L$ y0 o! [  P9 S# g9 @( p  好书如挚友。
1 A; A; N6 q6 \( g  y( Z  A good book is the best of friends, the same today and forever.7 c+ N& C2 p, ^4 G* g: P
  一本好书,相伴一生。
( V" d! i% F$ V  A good conscience is a soft pillow.: _! u- B' R' Z, d2 K; I+ P" ~
  不做亏心事,不怕鬼叫门。 6 j7 Q: m2 }* \: s6 _
  A good fame is better than a good face.
发表于 2007-7-10 21:58 | 显示全部楼层
怎么那么像当年我们翻译课本上的谚语啊,亲爱的?你该不会真的是从课本上摘录下来的吧?不像你的作风啊,你一向都那么懒,跟我一样……呵呵
发表于 2007-8-31 08:50 | 显示全部楼层
少了最后一句的译文,楼主复制粘贴时看清楚啊。
发表于 2008-7-21 11:34 | 显示全部楼层
最后一句的译文是应怎样的,楼主没有表达出来的呵.
GMT+8, 2025-2-2 06:48 , Processed in 0.304978 second(s), 24 queries .
