'Auto2004 使用C:\新旧图层名对照设定文件.INI 文件中设定的对应关系对当前图形文件图层更名
7 d- y8 C+ e. r0 y'可对含有中文的DWG档图层名修改以便ug读入9 R4 g2 G- N& x' s* i$ n! x
'INI文件中 [NEW_NAME]项目下为需修改的新图层名; [OLD_NAME]项目下为需修改的旧图层名
N6 l O' G% G$ @ D'Change_row_count = 9 代表需修改的新旧图层行数& E) b& l) G5 W' }/ d
'使用的宏文件源代码如下: 作者 逍昇wensanren. {6 j$ j; f" i/ J# s6 X0 `
Option Explicit
$ @, T/ m% w9 t$ U5 x2 {Private Declare Function GetPrivateProfileString Lib "kernel32" _
" F' h8 W3 [& z- g+ W' q; U4 {1 W( J
Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As String, _& }! `/ w) Y2 v f7 L$ Z
y* e# c8 `0 p7 G2 G1 f% i2 y4 D
ByVal lpKeyName As Any, ByVal lpDefault As String, _ Z1 r" S& o n6 Y( q
& ]9 B( z' }9 M: O y# ?
ByVal lpReturnedString As String, ByVal nSize As Long, _
8 A, X9 g7 ?# I2 N: A& Z) }3 q. f9 ~, H: _& |+ w s
ByVal lpFileName As String) As Long
: z6 t) H+ d2 R+ J! ]/ Q: EPrivate Declare Function GetVolumeInformation Lib "kernel32.dll" Alias _
m$ c" h9 ]" m6 e- X" Z- M$ r- b) k$ q( l" l# w- ?
"GetVolumeInformationA" (ByVal lpRootPathName As String, _: c+ V2 q4 \/ ]4 @- ^
( ^6 \" n! u% \4 k# Z4 j/ R
ByVal lpVolumeNameBuffer As String, ByVal nVolumeNameSize As Integer, _
/ o1 m! K5 K D& {3 y9 u( I5 s7 f
( ?/ U5 x2 Y) ?) E: p) ClpVolumeSerialNumber As Long, lpMaximumComponentLength As Long, _
0 y) ]1 ^% K1 G( H, M& c% c/ s2 @+ s0 `; U7 r& e0 _- L
lpFileSystemFlags As Long, ByVal lpFileSystemNameBuffer As String, _- P; h) }2 u2 A6 V
! E0 k* v! m0 ~$ U: E
ByVal nFileSystemNameSize As Long) As Long+ {' s% l9 T9 ], j8 F/ T
Sub replayer()
% U( Z0 q, [1 |# i P l: a% B8 gOn Error Resume Next
" ]+ g# K1 z( T. Q# g) g( N2 U0 XConst IniFile_Path = "C:\新旧图层名对照设定文件.INI"1 s, Q' c8 i" t! l9 `" K: H5 }" i; K
Const ForReading = 1, ForWriting = 2, ForAppending = 3, TristateFalse = 0
' B* j" ]/ a$ l' ^' T/ T# `7 U'TristateFalse
. x7 ]- A5 X9 k" {) ?& \0 以 ASCII 格式打开文件
- t$ o& B' u: q& s/ B$ kDim fs, f As Object! s7 W9 @8 d1 O8 b' }2 v
Dim i, u, j, RowCount As Integer# r7 W8 h0 {' Z" h9 u* R! c2 V
Dim ent As AcadEntity; ?6 p0 W, X/ L7 v
Dim Layerobj As AcadLayer5 U8 {& H7 Y& e2 h
Dim oldname, newname, OLDNAMEFLAG, NEWNAMEFLAG, OldStr, NewStr, TMPSTR As String
, X. W _3 ]& u) {# U. g2 [* M9 ], k, L* t3 ?, Y
Dim Msg, Style, Title, Response, MyString! q. a9 ]+ z$ ~& {% u
Msg = "[新图层名] 替代 [旧图层名] ?"
8 |1 v0 B" t0 l% ~' _, P/ A' 定义信息。9 s0 j$ C! j; W
'Msg = "汉字 -> 字母(ASCII) ?"9 L& t! H8 I6 y; X: }
Style = vbYesNo + vbCritical + vbDefaultButton2
+ [# y* {1 G# m/ I5 Y* O' 定义按钮。8 t+ Y& n' p5 x- g9 M1 g3 i) X+ \
Title = "MsgBox Demonstration"" t5 {9 e$ @0 C* p$ U/ k
' 定义标题。
7 p; Q% R2 G5 [$ m# m' {0 n6 e( A* U! _/ P7 E7 M
Response = MsgBox(Msg, Style, Title): q- e) n. B3 B. E; ?
If Response = vbYes Then+ k1 Z- O" S0 j& A5 ]# s
' 用户按下“是”。[新图层名]替代[旧图层名]4 U- G0 ]' }3 w1 b" u
5 K' Q) z8 H+ c! x9 o: w* |
OLDNAMEFLAG = "OLD_NAME"' m0 H7 |+ j* `8 M( L
5 u$ B- g4 m# j
NEWNAMEFLAG = "NEW_NAME"
. b4 L; X) P4 T1 |
; @. Z9 Y3 X/ p. q8 _5 H, yElse
! I; a$ R' R( N% V5 ^3 E7 l' 用户按下“否”。[旧图层名]替代[新图层名]
% o4 @) p6 K4 c4 ]. g
, |1 I, d4 k4 R- A3 oOLDNAMEFLAG = "NEW_NAME"
& S: I7 z9 x' x- H" |8 k9 W, `# U" J) N- d
NEWNAMEFLAG = "OLD_NAME"
+ u8 A" I) I# u" p1 d; SEnd If A' F& X7 n( x! V- Z
RowCount = CLng(ReadIniFile(IniFile_Path, "Change_row_count", "Change_row_count", "9"))
: f1 q" `' e0 `+ J2 b# N4 m2 O9 m3 Z'Change_row_count
# b% b7 P& }4 G/ M' F' `( D' aFor u = 1 To RowCount8 c! C9 T+ R; N
OldStr = "Lay" + Trim(Str(u))' q. e( K! T+ G, ` e
NewStr = "Lay" + Trim(Str(u))
, c0 r0 P V- B2 E: f0 doldname = ReadIniFile(IniFile_Path, OLDNAMEFLAG, OldStr, "")+ X% |3 u o, t4 | Y
newname = ReadIniFile(IniFile_Path, NEWNAMEFLAG, NewStr, "XXX")1 P8 p: U* |9 @' K1 q2 o8 ?6 E1 e
MyString = ""
. @$ e) W8 }2 I1 n8 h1 d' A' P+ jFor i = 0 To ThisDrawing.Application.Documents.Count - 1/ U4 l7 L/ z4 k) R
ThisDrawing.Application.Documents.Item(i).Activate
# X7 f9 c3 ]3 Q! C2 p1 H; DFor j = 0 To ThisDrawing.Layers.Count - 17 j* q( a- J8 k% A! b, u! u# c
Set Layerobj = ThisDrawing.Layers.Item(oldname)
6 b; F- z2 p, ?# o5 oLayerobj.Name = newname
# m5 A+ `: q4 v6 N$ UNext4 L5 D* B! u2 O j
MyString = MyString & Chr(13) & newname & " <- " & oldname & " " ' 最后一个被替代的
8 |% ?8 m' y5 I+ K2 g* rNext
! T: N( K" y4 E) y. Z( f$ U8 G8 s9 j% Y- _7 I2 L
Next
) r! _0 |3 ~! ?. }1 l. B/ rMsgBox ("替代完毕:" + Chr(13) + "最后一个为 " + MyString)
- S( i1 p+ ?5 B: P) t! |. U& x/ g% j' n: l8 {
End Sub+ r; r! q; Q( W# }" A P: Q! Z
, O7 z. \2 d' r f" a/ q. G
Public Function ReadIniFile(ByVal strIniFile As String, _# W7 @' e$ b- y; w
! z) a) i( ?/ SByVal strSECTION As String, ByVal strKey As String, gstrNull As String) As String0 Q- ]; m1 W8 x8 @. i1 Y
Dim strBuffer As String
% o; x4 m1 R' H. q7 @4 lDim intPos As Integer
% f+ g% U5 ]1 A2 a# J& DConst gintMAX_SIZE = 256) ? s1 u4 m2 }- a
strBuffer = Space$(gintMAX_SIZE)
7 C% B' j& \: ?+ I7 nIf GetPrivateProfileString(strSECTION, strKey, gstrNull, strBuffer, gintMAX_SIZE, strIniFile) > 0 Then
2 L2 h. L. V) h3 t) dReadIniFile = strBuffer
- ]4 ]. @( M. D$ N. d" Q, RElse
4 x8 I: M% k, B& v' {8 Y$ P/ a3 H$ M8 p
ReadIniFile = gstrNull! _/ U( l. E- F& ~4 Q* v
End If
2 |/ K8 E5 _! E( \2 Y: K8 @End Function
9 D3 x. _2 o6 r4 I3 S( z3 E* D8 p8 F, s* @
新旧图层名对照设定文件.INI (内容如下)( B$ [, p y/ r* }
[OLD_NAME] 旧图层名
u6 _0 Q. v' c% b ^4 FLay1 =定义点: Z, k0 @) D8 C0 g8 m% @/ k
Lay2 =中心线
+ P0 N( f# Q: v" u# S7 ], rLay3 =注释( U* K2 ~2 h/ x2 z
3 u6 D: D0 y I! X! q$ l
[NEW_NAME] 新图层名
! T; ~ \& ]1 L! f. |Lay1 =DefinPoint
: V# D( }, I' K) ?( V+ s) lLay2 =CenterLine/ }' ?9 |* f& ]4 I. U) ~
Lay3 = Note6 Z7 O! b" q0 z: x" p& s
9 y1 t# `9 r% U5 o/ s1 ] i[Change_row_count]# T s) b/ ]+ e0 [" r& L
Change_row_count = 3 |
