查看: 1409|回复: 0
ADAMS快捷键
发表于 2012-8-7 10:50 | 显示全部楼层 |阅读模式
ADAMS快捷键.pdf (133.32 KB, 下载次数: 15)
1 J- i& D; E6 O& ~& ~7 K) p3 u. z3 L
: a; ^1 D& x0 I4 [8 L
( ~5 T* G$ s1 T6 V4 \* E
. T- G/ @, y1 D5 d7 [) m
Overview
This appendix shows the keyboard shortcuts for ADAMS/Car. Keyboard shortcuts are key combinations that access commands quickly. When you enter a keyboard shortcut, the focus must be in the main window except when entering a keyboard shortcut that works in dialog boxes.
The shortcuts are organized into the following operations that you can perform:
              File Operations, 2
              Edit Operations, 2
              Display Operations, 3
              Viewing Operations, 3
File Operations
Table 1. File Operation Shortcuts
To:
Select:
Create a new modeling database
Ctrl + n
Open an existing modeling database
Ctrl + o
Save the current modeling database
Ctrl + s
Print
Ctrl + p
Read command file
F2
Exit
Ctrl + q
Edit Operations
Table 2. Edit Operation Shortcuts
To:
Select:
Undo the last operation
Ctrl + z
Redo the last undone operation
Ctrl- Shift + z
Copy objects
Ctrl + c
Paste text in text boxes in dialog boxes and as comments
Ctrl + v
Cut text from text boxes in dialog boxes
Ctrl + x
Delete selected object
Del
Modify object
Ctrl + e
Escape operation
Esc
Display Operations
Table 3. Display Operation Shortcuts
To display:
Select:
Command window
F3
Coordinate window
F4
Menu Builder
F5
Dialog Box Builder
F6
Working grid
g
Plotting window
F8
Help window
F1
Viewing Operations
Table 4. Viewing Operation Shortcuts
To:
Select:
Rotate view in the XY directions
r
Rotate view in the Z direction
s (lowercase)
Translate view
t
Change perspective depth
d
Dynamically zoom view
z
Use dynamic increment
Shift
Table 4. Viewing Operation Shortcuts (continued)
To:
Select:
Define a zoom area
w
Center view
c
Orient view to object
e
Fit view
f
Orient view to front
F
Orient view to right
R
Orient view to top
T
Orient view to isometric
I
Toggle render mode between wireframe and
S (Uppercase)
shaded
Toggle screen icons on and off
v
Drawing Operations
Table 5. Drawing Operation Shortcuts
To:
Select:
Turn off snapping to geometry
Ctrl
Turn off highlighting of geometry during
Ctrl
selection
GMT+8, 2025-6-18 19:40 , Processed in 0.182804 second(s), 28 queries .
