查看: 4846|回复: 3
[原创] 在AutoCAD中将小写字母批量转换为大写字母部分代码
发表于 2008-4-3 22:16 | 显示全部楼层 |阅读模式
开发环境:VC6+ObjectARX2002+AutoCAD2002,VC2005+ObjectARX2007+AutoCAD2007等均可.....(关键是利用选择集的概念构造字符选择集,然后处理....),希望对大家学习ObjectARX有所帮助!代码如下:
3 Q7 R. C( }1 H$ ?: b# p
: x, e9 J+ q' \7 i) E+ G" U
void BLUEARXrp()# z% J' K0 Z3 O) J
; Q: ]1 a+ V# e$ [% E. g  struct resbuf rb_txt ;
# x8 k: ^" B$ b5 S3 E  struct resbuf * rb , * head ;
5 P& y+ ^- r3 k, ]: [  char       filter_need[10] ;" H/ _0 H7 Y. l! b" R' x
  ads_name     Select_Need,ent ;
0 a8 ^/ s  q# H  long       count ;4 y+ L& `% j( F$ H4 s
" Z2 N# P5 V, L9 U
  rb_txt.restype = 0 ;
; N5 \+ K/ n. n0 b, ~  strcpy(filter_need,"TEXT") ;
- {$ Z+ G) Y0 u0 o/ z7 ~  rb_txt.resval.rstring = filter_need ;& }& F/ C) E& o0 s) W9 ~$ E; @
  rb_txt.rbnext = NULL ;1 z+ F: ^0 v; @+ `$ U, l: O
6 D& A+ W5 t" f9 Z' \
  if(ads_ssget("X", NULL, NULL, & rb_txt,Select_Need)!=RTNORM)
1 Z6 t8 n6 J9 v( a+ n, X  b  {
8 r1 k) C) Z; j% o  {- e1 S    acutPrintf("\n系统不能正确创建出图选择集!") ;3 J, H/ X% k; E. h: |4 r4 K
    return ;( Y0 T( ?& B! j3 G6 v5 D/ @' e& c
7 L$ \9 W5 T: j$ _
( z. ]: g8 k/ J" J1 |9 y  ads_sslength(Select_Need,&count) ;4 o3 d, C! n( e4 o( t
6 \) Z7 l2 `4 V$ ?; L0 q/ t
  AcDbObjectId txtID ;  m; r9 y3 Y" L3 ^
  AcDbText *entTxt ;; L; e+ W4 @" r: h8 q
  char tmpStr[255] ;4 s& a+ @& t! }7 [
  long len ;
  x+ S* J# W' P* d8 v
- ]0 U; B0 _9 Y1 ~& t; C5 N7 g; J( R  for(int i=0;i<count;i++)
0 A: S& O+ f% J  {
8 d# G, S$ a/ t9 y  k    ads_ssname(Select_Need,i,ent);9 i0 ~/ V* F# F- j0 j4 {0 F4 d
    acdbGetObjectId(txtID,ent);% m( v; V1 O+ a7 [; X! [8 ~
) x7 v8 d! G$ D
    Acad::ErrorStatus es = acdbOpenObject(entTxt,txtID,AcDb::kForWrite);
4 h2 m3 U0 t2 |- `* S& k+ `! R, ]4 d* ~, |- U1 D# r
    strcpy(tmpStr,entTxt->textString()) ;
0 h, }: p0 G- C, t8 D" ?8 i; a    len = strlen(tmpStr) ;- }4 }( O5 g: H; N+ N8 ?/ R1 W
    for (int j=0;j<len;j++)7 g& U  l; U( Q, j! D" H
  x# E* g) E. s' I" S        if(tmpStr[j]>=97 && tmpStr[j]<=122) tmpStr[j] -= 32 ;
  E- t8 }2 F1 y# L0 \0 q/ \7 m: K    }6 U4 R) J% F: v3 L# H: N
    entTxt->setTextString(_T(tmpStr)) ;% @& L! C  ^! O' R& ?( d
    entTxt->close() ;
8 c' |! [! b) V$ a  }
  S/ k' c, p: }5 x7 o* F3 z0 N}3 K0 M( O$ i, T8 o  ^
 楼主| 发表于 2008-4-3 22:17 | 显示全部楼层
;;;定义命令 TT 用于将图形中所有TEXT内容改为大写
/ S' T  d+ F7 V9 z(defun C:TT (/ SS I ENT STR), O  [. Y4 T4 H2 w
    (if (setq SS (ssget "x" '((0 . "TEXT"))))
2 a3 M1 M# y# y    (progn2 O" [3 B  U4 |3 B; T% {7 D. [8 a
       (princ (strcat "\n找到了 "' o5 C% {  O0 O
               (itoa (sslength SS))4 y7 t: I! X$ w: O' m+ I: j
               " 个对象。"
: O( e  m4 `! S( t           )
9 S9 \  |7 c0 [: F& q6 h/ |       )
' Z0 u3 A( q+ e7 {4 f$ h       (setq I 0)
0 f6 X2 f. v& N! {" T9 c- y6 u; S       (repeat (sslength SS)# l" {3 P; s0 M! p$ ]
        (setq ENT (entget (ssname SS I)); U7 w" e' J9 x% d# ^% D
             STR (strcase (cdr (assoc 1 ENT)))
1 P% y( X# c! T' M- D7 K        )
- p+ @( V  B6 w  X% G        (entmod (subst (cons 1 STR) (assoc 1 ENT) ENT))/ Y  L! N# J: P" U% m  k
        (setq I (1+ I))
8 S4 I2 q' ?; L1 ^' S       )
3 T: U. e" n/ Y    )  b9 G; s: M5 B! F7 ?1 b5 ^
    (princ "\n没有TEXT对象。")0 ^' \0 K6 e' M+ @; R+ i% Q- M6 {% N- n
9 s9 d4 m9 s( a" K6 w    (princ)
! k" N% S4 l- N; z)
发表于 2009-10-22 12:00 | 显示全部楼层
谢谢分亨……
发表于 2013-12-2 10:03 | 显示全部楼层
看了LZ的帖子,我只想说一句很好很强大!
GMT+8, 2025-9-14 12:27 , Processed in 0.052183 second(s), 24 queries .
