查看: 1445|回复: 5
UG热键一览表
发表于 2008-4-13 12:32 | 显示全部楼层 |阅读模式
ug热键一览表; d: g; Q/ F8 D
Application 对应菜单功能4 L% u0 P* y: s- i4 `( X
F1 Help -> Context…) F. _, C( d9 ~! V! u* a
F3 View -> Current Dialog, _! j' f  P6 C2 D
F4 View -> Information7 F: D% P, h8 y8 K. Q* l
F5 View -> Refresh: l5 S& {$ a6 @  h) g* A! V* M; d
Ctrl- A View -> Assembly Navigator
6 b2 r# W& s5 P, l7 @3 OCtrl-Shift- A File -> Save As…
; b$ e6 W' ?! b$ h  FCtrl-Alt- A
* }0 m1 h! S6 R$ S2 j' KCtrl- B Edit -> Blank -> Blank…
6 p& I8 A  f% i( s: p: \7 [Ctrl-Shift- B Edit -> Blank -> Reverse Blank All6 [) K0 O$ S% K2 t* V9 f- F
Ctrl-Alt- B Manufacturing Tools -> Boundary…0 _  A$ y8 @' r7 \# ^4 r( D. i
Ctrl- C Edit -> Copy
/ x) B- R: A3 t4 P1 T+ N2 z5 fCtrl-Shift- C View -> Curature Graphs3 x) D5 F$ Z0 m9 |' q* K
Ctrl-Alt- C Tools -> CLSF…+ K0 Q' N) a8 s% p! Y$ e7 W
Ctrl- D Edit -> Delete…
0 p+ p, w& _$ H7 t/ _+ W9 n& s( j; wCtrl-Shift- D, f/ `# j0 q+ f% b0 G' f7 q
Ctrl-Alt- D, J9 O; L* u! ?( l  |, V
$ c/ F$ E' |4 C2 |) }) r: wCtrl- E Tools -> Expression…' N5 o7 r: ^" r; x
Ctrl-Shift- E( w" Z# `9 Q0 W& m  C- Z. c/ O
Ctrl-Alt- E
( ]3 ^3 ]8 T( _9 R, {Ctrl- F View -> Operation -> Fit
: U7 v0 I# A# M$ G+ Y7 bCtrl-Shift- F Format -> Layout -> Fit All Views" M! q% d6 m9 Z, `( E# K, `7 X, }- C
Ctrl-Alt- F
2 M. E2 M: j8 GCtrl- G File -> Execute UG/Open -> Grip…
- ]9 y7 N  G2 V. g) U8 E' r  tCtrl-Shift- G File -> Execute UG/Open -> Debug Grip…
# A7 O! i& W# Y- t2 H. D% }Ctrl-Alt- G
5 s5 ^% \: E$ S: kCtrl- H
. ?7 W% ?6 b2 M+ p) nCtrl-Shift- H View -> Visualization -> High Quatity Image5 C. L7 I6 ^5 Q0 d
Ctrl-Alt- H$ Q% c4 W! l8 h/ Z  [* Z' K. H- u0 V; o' r
Ctrl- I Information -> Object…
! F5 L3 E  I, n! J4 \* c, BCtrl-Shift- I1 [- n; {; i& y6 p3 `
Ctrl-Alt- I6 H1 }, _1 V( w* Y& V
Ctrl- J Edit -> Object Display…
. A6 J2 }. m2 ]5 JCtrl-Shift- J Preferences -> Object…2 V, \, l( T# O2 D& c
Ctrl-Alt- J: O; u- I2 k3 Y% I. U
Ctrl- K
1 V  n& g; s4 D" K; m6 CCtrl-Shift- K Edit -> Blank -> Unblank Selected…
0 ?  L* X7 P: k1 T/ BCtrl-Alt- K( w4 R/ \: x' z5 A6 `$ _
Ctrl- L Format -> Layer Settings…
+ G& I* ?+ b& d" f* WCtrl-Shift- L5 c. m# f- J  o' z2 p
Ctrl-Alt- L
8 n0 q8 j1 {7 d6 b  {& {. x& ECtrl- M Application -> Modeling…1 ?& Q0 v. v  @6 \# q- Y
3 E% \0 a  `4 K; p0 |9 JCtrl-Shift- M View -> Model Navigator& B- v$ `% s2 D* ?1 [% U
Ctrl-Alt- M Application -> Manufactoring…8 J" f, x. i; z4 E" N! i5 L9 v
Ctrl- N File -> New…. S: s; y* E, w. W, O
Ctrl-Shift- N Format -> Layout -> New…
* o; L5 c: R' LCtrl-Alt- N Manufacturing Tools -> Unisim…  M2 [0 q# }6 y( f
Ctrl- O File -> Open…* a( R4 R2 `, |% d' m
Ctrl-Shift- O Format -> Open…
4 @  e8 q* p0 O4 i/ QCtrl-Alt- O
7 k; A+ c0 `  J& t( ?0 f. D0 R0 }Ctrl- P File -> Plot…
4 \" \6 t0 p: |7 ~' |1 S$ R. T1 pCtrl-Shift- P Tools -> Macro -> Playback…+ {4 C6 \  t# A- f! r8 w" I2 L
Ctrl-Alt- P
9 g& A3 V4 A% J: m0 [+ x( ZCtrl- Q
% T, U* X6 F0 d: ICtrl-Shift- Q View -> Visualization -> Create Quick Image; u! k4 R% j1 n5 c* n4 S
Ctrl-Alt- Q4 ~. b2 I6 i# I4 z; D' {* v
Ctrl- R View -> Operation -> Rotate…
0 D% `% D# }* d+ }5 E$ gCtrl-Shift- R Tools -> Macro -> Start Record…! u: X8 u4 @1 s, u4 q+ A
Ctrl-Alt- R
5 y" O3 l9 g) F1 W. DCtrl- S File -> Save
4 [+ O% a8 m1 X( I) oCtrl-Shift- S Tools -> Macro -> Step…
8 O% ~% E6 i8 dCtrl-Alt- S+ h/ Y8 I2 |! O
Ctrl- T Edit -> Transform…
) v1 S) P  u4 v/ UCtrl-Shift- T Preferences -> Selection…, C% [( t& z$ s; O6 f& w
Ctrl-Alt- T
6 [: m+ e  j( T4 R0 x2 r- \' O2 RCtrl- U File -> Execute UG/Open -> User Function…
5 o0 u8 r6 P7 J; t# j" B7 S/ R$ ZCtrl-Shift- U Edit -> Blank -> Unblank All of Part( u1 L5 T2 f% R" R& u
) _/ [% B) v- H. O: LCtrl-Alt- U# C4 C+ y0 @& [' l" U$ m4 k9 u
Ctrl- V Edit -> Paste
' n& V, J* C5 M2 P* x# L  mCtrl-Shift- V Format -> Visible in View…
6 \! I! Y# {! ^/ \Ctrl-Alt- V7 ~1 j9 E9 P; S+ E* {
Ctrl- W Application -> Gateway% n! g# M* o* c( O  n% s3 _7 X
Ctrl-Shift- W
7 U  m  a: P/ e+ d& oCtrl-Alt- W Application -> Assemblies
2 u/ ]' P. n5 O, I9 n5 B, ECtrl- X Edit -> Cut
! a) z. Y8 N$ T4 N& xCtrl-Shift- X
2 c3 w2 s, o* c% `" r3 sCtrl-Alt- X Manufacturing Tools -> Lathe Cross-Section…: d! z7 w  C4 S: ]
Ctrl- Y
6 s2 Y. ?, d9 t. jCtrl-Shift- Y8 [. P$ Q! j$ u* ^3 r6 E
Ctrl-Alt- Y# V0 n1 M! L" {" V% P! U
Ctrl- Z Edit -> Undo List
' g4 }( _" F! YCtrl-Shift- Z View -> Operation -> Zoom…
+ {, I+ J* p" h8 `Ctrl-Alt- Z
- r$ e& ^0 C1 @* j/ }2 \$ R, {' G  V$ s; Y& [4 d7 P, M/ L- k
UG热键一览表4 L! P% C/ y; D' |+ L0 ~1 j
Application 对应菜单功能
" `1 t! v1 F  E& t3 D$ N( N! nF1 Help -> Context…
# T. X5 t# N) G( bF3 View -> Current Dialog  Q) k9 K  u- S0 n
! l  _7 ?% a: I3 @" JF5 View -> Refresh/ z+ K! b& R& x( K: _, g* y
/ N2 l, w1 h/ r3 j& zCtrl-Shift- A File -> Save As…
' C' {1 d/ d- v: e: BCtrl-Alt- A
9 i: A) N2 {) T6 L" QCtrl- B Edit -> Blank -> Blank…
/ W' T. {- ^- CCtrl-Shift- B Edit -> Blank -> Reverse Blank All
* C0 r# @& L# [Ctrl-Alt- B Manufacturing Tools -> Boundary…6 I' F( T6 z6 Z1 I, o6 M
Ctrl- C Edit -> Copy- ?5 I/ a- d' z  H$ S
Ctrl-Shift- C View -> Curature Graphs- ~/ u; p8 H" b# E3 b2 G
; e! s; O5 n2 f7 m8 C0 S2 i; OCtrl- D Edit -> Delete…
: ~% t& u4 {: A( p, B4 SCtrl-Shift- D: n$ ~" g* J: [& M' J
Ctrl-Alt- D
. F/ X! n: ]; e1; _* o/ R; Q, c7 c
Ctrl- E Tools -> Expression…' E. a- T0 j8 \0 v4 e. Z3 V" u7 K
Ctrl-Shift- E
3 n" v: e3 b6 D$ |0 g, \Ctrl-Alt- E; d- k5 ~  l9 i" `5 C1 ?
. U* R0 e( P; O* RCtrl-Shift- F Format -> Layout -> Fit All Views7 B" j% S- b; G2 W. \
Ctrl-Alt- F% F1 G: s4 `" p; l: o- l* y
7 N- B# n  o# z/ z: jCtrl-Shift- G File -> Execute UG/Open -> Debug Grip…! H/ H" r$ e, O; S* T4 G5 z9 B) H
Ctrl-Alt- G
2 s' U- m- \, W& k4 _Ctrl- H5 H7 J( Q4 W; o8 m) X% b0 e- _
0 r; ~# }* Z! _, q4 v! E4 cCtrl-Alt- H( o& b: \2 z0 Q% z' q7 E. P
Ctrl- I Information -> Object…+ |1 b  o9 E4 s3 T! K, x/ I7 j' I
Ctrl-Shift- I3 A. C: b* t1 J& L% _& p" J
Ctrl-Alt- I
. s0 D+ o6 O+ e) s; X0 ~6 u* CCtrl- J Edit -> Object Display…
$ ^" N3 T: N7 p" {9 PCtrl-Shift- J Preferences -> Object…! V# v5 H; `4 O; q6 e# k" O
Ctrl-Alt- J
" X* m) G. a1 f) C* @4 U7 \; rCtrl- K0 y8 g1 P8 \6 [
Ctrl-Shift- K Edit -> Blank -> Unblank Selected…4 M$ `  h- o9 ]7 p& C* X
Ctrl-Alt- K4 o6 v' x( T9 {8 |6 j2 A( D% m
" f0 k% C4 f5 qCtrl-Shift- L+ J' I0 T# X5 A
Ctrl-Alt- L
% W' e0 ^9 `( S' j  ^Ctrl- M Application -> Modeling…9 l: F8 W$ E+ k: k
22 D0 E/ _; e9 \7 d! z% J
9 |+ P1 g  g1 X+ a/ c' k. J# F/ CCtrl-Alt- M Application -> Manufactoring…0 G/ C# Q+ V6 u/ `
Ctrl- N File -> New…$ N  @  a( v! a
Ctrl-Shift- N Format -> Layout -> New…6 ^8 w. r8 O: \4 I# k2 g/ G+ y! g
+ o: L3 e; G. T! c" ?# V2 rCtrl- O File -> Open…
: B' q8 d3 W( e- Z# ~Ctrl-Shift- O Format -> Open…
+ [6 w  U  |+ |' D6 w7 o/ g7 D' H. ?Ctrl-Alt- O4 V0 g9 c! M& {* v4 H8 K6 }) y
Ctrl- P File -> Plot…3 ^( @4 _7 X  C$ D/ n
Ctrl-Shift- P Tools -> Macro -> Playback…$ y8 R7 R7 E' u; e1 A/ G
Ctrl-Alt- P
, P0 \# ], L, y* s% G- ^# HCtrl- Q- G/ R' g& M! P$ l7 |  D% c! l
' S1 N% [8 \" s" O) TCtrl-Alt- Q
, o- O. F4 o6 S7 b1 r5 }Ctrl- R View -> Operation -> Rotate…
6 ~  V# X- }# u; v& r. y% B# ^% rCtrl-Shift- R Tools -> Macro -> Start Record…
; \" q6 ]) P& n8 r! HCtrl-Alt- R9 U" h* @% V* V
5 X+ W) j" }0 x2 A. f* i  SCtrl-Shift- S Tools -> Macro -> Step…! f8 A4 z2 o1 G
Ctrl-Alt- S
4 b$ F% y/ n: D/ |2 w1 z) a1 y& i* UCtrl- T Edit -> Transform…& _7 @4 `5 C. T2 v: C( c8 C
Ctrl-Shift- T Preferences -> Selection…! j: f7 r8 q7 x9 m7 k- o! d
Ctrl-Alt- T( L! M: a* x% `; C* {6 a
Ctrl- U File -> Execute UG/Open -> User Function…2 k; i" M: D' F6 |
( {5 T( d2 x6 p( M% L. J38 e- X6 B! A# X' \; ^
Ctrl-Alt- U
9 C  ~' N- [6 W: q- Z' C# ]0 t* Q; HCtrl- V Edit -> Paste
3 o8 D+ }# h' \% T3 C  K& ACtrl-Shift- V Format -> Visible in View…8 x, H0 H- Y/ O. Q2 d0 A0 \! c
Ctrl-Alt- V
! i2 m3 x: p: G: X6 E9 HCtrl- W Application -> Gateway: r! ]8 r2 Z/ q; M
Ctrl-Shift- W* ?( _" C6 j0 }# t  j' T  F6 R3 P
Ctrl-Alt- W Application -> Assemblies! y& V$ H5 a) O1 y
Ctrl- X Edit -> Cut
! W: R  C& E+ l$ F' `. fCtrl-Shift- X0 D! }3 ?- w3 `) ?' b
Ctrl-Alt- X Manufacturing Tools -> Lathe Cross-Section…; L8 I) s/ {* g. l
Ctrl- Y
6 @, E( w0 D# b0 U' B3 a$ |6 `Ctrl-Shift- Y
  a( r" u! `! K5 QCtrl-Alt- Y
) V9 ~# X( L' U& NCtrl- Z Edit -> Undo List9 c% E4 [6 K4 c( h
6 Y/ u$ X  I  aCtrl-Alt- Z
: g( q( R7 c5 F3 w( `7 I; c5 {2 F2 y' \9 I) N0 x) b- g. b* ]! ?
UG热键一览表
% }6 ?+ U# L+ F5 xApplication 对应菜单功能0 f' }7 V% F$ N0 Q$ Z: @
F1 Help -> Context…0 r& N% V; g4 ^/ ~. \8 t
F3 View -> Current Dialog# V) I% V8 H5 ~, ?
1 f6 Y. l% I/ J, i- {/ J' w" p& }F5 View -> Refresh
$ r- H3 ^" H, }9 qCtrl- A View -> Assembly Navigator1 _7 ?- `; s$ U1 N& }- Y6 x3 }1 A1 D" z
" L  @% C. ]3 X1 S5 RCtrl-Alt- A
0 O9 o( o6 x7 j% Z+ c1 XCtrl- B Edit -> Blank -> Blank…7 k( m: O3 r1 ^9 r  ~
Ctrl-Shift- B Edit -> Blank -> Reverse Blank All1 q; Y# x9 Z7 x, k/ k6 z" l% R+ Y; u
Ctrl-Alt- B Manufacturing Tools -> Boundary…9 y( C/ R) f! ]. U8 H
) l* M0 ~% R$ g, X* J( SCtrl-Shift- C View -> Curature Graphs
, c9 T' y$ m0 S* g4 NCtrl-Alt- C Tools -> CLSF…8 j  W8 `% ?' e
3 D. B; t2 k8 E$ ?Ctrl-Shift- D
9 ?3 [2 T9 Q* x0 ^' ZCtrl-Alt- D
5 ^' d! g9 D% Y1 I* [1
" _6 u0 ?- Y& f$ h$ r( t. p8 d' m3 lCtrl- E Tools -> Expression…/ i" o* u! y; H$ E
Ctrl-Shift- E' U7 n1 A+ v  l
Ctrl-Alt- E# r9 w) Q2 Z) i& H3 t0 Y
Ctrl- F View -> Operation -> Fit: z3 Q* L% [0 |: ]7 X
Ctrl-Shift- F Format -> Layout -> Fit All Views6 e' y) [8 l' n4 h* h
Ctrl-Alt- F
( b$ ^& Y% z2 j2 a+ B& \5 @Ctrl- G File -> Execute UG/Open -> Grip…
( C: N$ \0 v1 O' M$ C, kCtrl-Shift- G File -> Execute UG/Open -> Debug Grip…
' }1 T" P/ n7 B3 XCtrl-Alt- G; V$ q0 Q! Q7 r) j3 ?) s
Ctrl- H
' z7 \: J8 e' SCtrl-Shift- H View -> Visualization -> High Quatity Image
. K/ g( J7 S, v6 z* f- tCtrl-Alt- H
- N4 [9 S% R+ S& j0 xCtrl- I Information -> Object…1 g' c- ?. {7 d) ?! |' L
Ctrl-Shift- I& L/ r6 g6 L: V) A6 |9 E
Ctrl-Alt- I' _8 o$ H4 V* I& X! _
Ctrl- J Edit -> Object Display…/ I4 T: ]  Y6 t' q; {
Ctrl-Shift- J Preferences -> Object…& x$ K5 V( T( A3 E' y: H* E+ w
Ctrl-Alt- J
+ A9 ^$ }! C( r2 k6 l: b. S4 \Ctrl- K- g: X; q9 L" h" G/ D8 u4 E
Ctrl-Shift- K Edit -> Blank -> Unblank Selected…2 `3 ]/ Z3 l/ w' v: s9 G8 m6 Z) o
Ctrl-Alt- K
4 p* c5 i3 t" |6 vCtrl- L Format -> Layer Settings…
/ |5 I+ z+ p9 MCtrl-Shift- L+ ?6 T/ z4 q' g7 H3 w
Ctrl-Alt- L8 u4 w3 p5 V. }; H$ Z- \1 @5 h
" \6 Z+ _+ G2 e  n2" E$ w: d' @2 ]) D# K! [( V; |
) x% C. j5 [6 ^5 oCtrl-Alt- M Application -> Manufactoring…- W0 E# y! D4 @/ ]
3 v: o, p) X; m" ?Ctrl-Shift- N Format -> Layout -> New…
8 p) ~' M/ C. d: K1 ]7 H! I3 \. nCtrl-Alt- N Manufacturing Tools -> Unisim…( i0 v' B3 ]8 U* w( T* n
, p1 B, ?* W$ f: t' |5 ^. OCtrl-Shift- O Format -> Open…
6 p9 x( q$ k5 B& P  T! ~* `7 |- p0 I, ~Ctrl-Alt- O
( C1 f% J& Q. H  ^# O1 {Ctrl- P File -> Plot…
. d' P- ]; F8 p. K+ WCtrl-Shift- P Tools -> Macro -> Playback…+ ^, k" t# n+ I6 \9 t9 V
Ctrl-Alt- P9 z' ]/ ~5 b4 c
Ctrl- Q
% O; y1 a# D( k% hCtrl-Shift- Q View -> Visualization -> Create Quick Image
: c  C6 D0 W) A6 |0 WCtrl-Alt- Q
9 V  k/ C6 f3 A) jCtrl- R View -> Operation -> Rotate…
6 R1 {( W/ B* Z/ b! u3 L- BCtrl-Shift- R Tools -> Macro -> Start Record…, d+ P9 |8 M% b4 m/ I& r( f! t) w# W8 B
Ctrl-Alt- R
+ I  X& Z- R$ ~$ ^" T2 U6 h# }Ctrl- S File -> Save1 _% K' V0 F7 S4 b4 d
5 z* c" v; X( V5 y0 HCtrl-Alt- S
0 ~6 U& B: D3 `# @5 h* UCtrl- T Edit -> Transform…
4 u8 v  l( A" b  k) ?Ctrl-Shift- T Preferences -> Selection…; M: Q  Y0 y( b6 q9 }- M
Ctrl-Alt- T# M/ x1 e6 Q8 o) d6 O! Q. M
( [4 w4 A+ _# kCtrl-Shift- U Edit -> Blank -> Unblank All of Part
1 A8 L6 R( x( l. |/ m/ |) F( S0 _3
# ~8 c( Z/ G7 {" xCtrl-Alt- U
  b4 g# L  R" h4 d4 YCtrl- V Edit -> Paste4 C7 ?6 G  t+ p* B- H$ b6 S
' ]) k" ?" }) o; n: y7 Y  rCtrl-Alt- V6 k- [! J) [; `2 C# {
Ctrl- W Application -> Gateway( e$ m4 X; h! C3 D! i
Ctrl-Shift- W
( s6 Y1 E% j2 ]$ t  X" X& KCtrl-Alt- W Application -> Assemblies
" Y& X2 k, f: K0 I3 @. I2 ~1 PCtrl- X Edit -> Cut( {8 ^! G" e' l: n6 ]
Ctrl-Shift- X0 ^2 _1 L/ }  G7 w- V- w
- i! Z) Y2 {) {2 P9 uCtrl- Y
5 _" \3 {: l. c( f' g+ n4 d- H3 aCtrl-Shift- Y$ q$ D- A3 i4 k4 Y
Ctrl-Alt- Y( K4 d6 ~- B' g, W: W
2 l6 k. w2 z6 C  |. `Ctrl-Shift- Z View -> Operation -> Zoom…
9 N- {0 j) E% `6 w4 W' a( dCtrl-Alt- Z
评分
参与人数 1G币 +3 收起 理由
东莞孙师师 + 3 上传资料
查看全部评分
发表于 2009-3-13 14:23 | 显示全部楼层
谢谢楼主的分享
发表于 2009-3-13 14:24 | 显示全部楼层
太厉害拉 这么多啊
发表于 2009-3-26 09:18 | 显示全部楼层
都代表什么意思啊  要是中文的就好了
发表于 2009-3-29 21:07 | 显示全部楼层
有什么用?有几个人看的懂那英文?看得懂那些英文的也不会来学这个了。
发表于 2009-3-29 21:57 | 显示全部楼层
没中文的啊?
GMT+8, 2025-6-29 01:28 , Processed in 0.337842 second(s), 30 queries .
