查看: 1106|回复: 0
MakerBot Plastruder MK5系统
发表于 2013-12-2 11:22 | 显示全部楼层 |阅读模式
2.jpg 6 ]8 g) N( r4 z9 M: u: c4 X1 l
MakerBot,他们提供了新的PLAstruder MK5。挤出机是专为可靠性,低维护性和易用性。
它具有所有不锈钢,精密机加工紧紧地拧在一起,以防止任何泄漏的热端。它的镍铬合金丝加热器和摆脱其替换为两个功率电阻器。的电阻吸引了大量的电能,必须使用中继板。
进纸器使用MK5驱动齿轮已经使用了一段时间,摆脱惰轮。相反,它使用翼形螺钉可调的聚甲醛柱塞。他进纸器使用相同的直流电动机作为MK4,但有一个NEMA 17计划升级到一个步进模式。
设计是课程Thingiverse。这是销售和库存在商库为189美元。
) W" Y4 c9 s6 }
Yesterday,
Maker Bot announced
they are offering the new Plastruder MK5.   The extruder is designed for reliability, low maintenance and ease of use.
8 z# [* k' ~" O
It features and all stainless steel hot end that is precision machined to tightly screw together to prevent any leaks.  It gets rid of the Nichrome wire heater and replaces it with two power resistors.  The resistors draw a lot of power an must be used with a relay board.
The feeder uses the MK5 drive gear that has been available for while and gets rid of the idler wheel.  Instead, it uses a thumbscrew adjustable Delrin plunger.   he feeder uses the same DC motor as the MK4, but there is a NEMA 17 pattern for the planned upgrade to a stepper.
The design is of course on Thingiverse.  It is for sale and in stock at the store for $189.
3.jpg - B' @" ~0 }/ t
; m7 Y, Z" H+ @7 I- v3 [* \) Q
: X) M# k( o& ^1 G0 n: w3 u
* N% q( _8 g+ o+ P: c& P  D. x
5.jpg - M/ u0 ]4 q' f# A; C- u
0 ?# n1 J6 E0 O- G
, ^& n' T1 k/ B. i4 P9 J
GMT+8, 2025-8-12 03:17 , Processed in 0.055842 second(s), 28 queries .
